TZC400 on LS1046A
TZC400 on LS1046A
2,942件の閲覧回数
Faizanbaig
I would like to seek some clarification regarding the process of enabling TZC400 on LS1046ARDB. Specifically, I want to know if the file "TZC400.c" found in the "drivers/arm/tzc/tzc400.c" directory of the Arm Trusted Firmware repository is adequate for configuring TZC400 on LS1046A or there are any other code files that require attention for this configuration.
For reference I have attached TZC400.C file please do check.
Awaiting response.
Faizan
タグ(3)
2 返答(返信)
2,934件の閲覧回数
yipingwang
You also need drivers/nxp/tzc/plat_tzc400.c, please refer to drivers/nxp/tzc/tzc.mk and drivers/nxp/drivers.mk, TZASC_NEEDED has already been enabled on LS1046A processors.
2,885件の閲覧回数
Faizanbaig
