Secondary failed allocate mbuff from DPDK Pool
Chidananda22
hi All,
Using : LX2160  LSDK 2108 main
MC firmware version: 10.32.0
DPDK Version : dpdk_19_11_tags_LSDK20.04-isc-09
Primary ( DPDK ) Process : Create a mbuff Pool using [ rte_pktmbuf_pool_create("dlmempool", ]
Secondary ( DPDK ) Process : fails to allocate mbuff using API [ rte_pktmbuf_alloc(mempool) ]
In Secondary i can see mempool is correct. I can see mbuff available is full. The failure happens for 1st mbuff allocation using  rte_pktmbuf_alloc.
Any solution for this. Thanks.
Chidananda22
thanks i will try these options and update you by tomorrow
Chidananda22
thanks @Bio_TICFSL for the quick solution
Bio_TICFSL
The secondary process must map hugepages at the same virtual address as the primary. If ASLR is active, the secondary will resolve the mempool pointer to a different virtual address, causing the first allocation to fail.
echo 0 > /proc/sys/kernel/randomize_va_space
Run this before launching either the primary or secondary process.
2. Provision Sufficient DPMCP Objects
Create as many DPMCP objects as the total number of processes (primary + secondary). For 1 primary + 1 secondary, you need at least 2 DMPCPs:
export DPMCP_COUNT=3   # for 1 Primary + 2 Secondary (always provision +1 as buffer)
./dynamic_dpl.sh dpmac.X
3. Provision Sufficient DPIO Objects
Each process needs its own DPIO portals. The formula is:
(Total Processes) × (cores per process + 1 extra per process)
For example, 1 primary (2 cores) + 1 secondary (2 cores) = at minimum 9 DPIOs.
export DPIO_COUNT=20   # set generously
4. Correctly Blacklist/Whitelist Devices in the Secondary
The secondary process must NOT re-initialize I/O devices (dpni, dpbp, dpcon, dpseci). Only dpio and dpmcp should be initialized by the secondary. Pass the correct blacklist flags:
# Secondary process example — blacklist all dpni/dpbp/dpcon, allow only dpio + dpmcp
./your_secondary_app --proc-type=secondary \
  -b fslmc:dpni.X \
  -b fslmc:dpbp.X \
  -b fslmc:dpcon.X \
  -- [app args]
Or alternatively, explicitly whitelist only the dpio and dpmcp objects assigned to the secondary:
  -w fslmc:dpio.Y \
  -w fslmc:dpmcp.Z \
  -- [app args]
5. Use --proc-type=secondary EAL Argument
Ensure the secondary is launched with the correct EAL flag:
./your_secondary_app -c <coremask> -n 1 --proc-type=secondary ...
Or use --proc-type=auto to let DPDK auto-detect.
6. Verify the Mempool Lookup in Secondary
In the secondary, do not call rte_pktmbuf_pool_create again. Instead, look up the existing pool created by the primary:
// In secondary process:
struct rte_mempool *mempool = rte_mempool_lookup("dlmempool");
if (mempool == NULL) {
    // Error: pool not found — ASLR or hugepage mapping issue
struct rte_mbuf *m = rte_pktmbuf_alloc(mempool);
If rte_mempool_lookup returns a valid non-NULL pointer but rte_pktmbuf_alloc still returns NULL, the issue is almost certainly the DPIO portal not being initialized for the secondary's thread/core.
Chidananda22
%3CLINGO-SUB%20id%3D%22lingo-sub-2408883%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ESecondary%20failed%20allocate%20mbuff%20from%20DPDK%20Pool%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2408883%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Ehi%20All%2C%3C%2FP%3E%3CP%3EUsing%20%3A%20LX2160%26nbsp%3B%20LSDK%202108%20main%26nbsp%3B%3CBR%20%2F%3EMC%20firmware%20version%3A%2010.32.0%3C%2FP%3E%3CP%3EDPDK%20Version%20%3A%26nbsp%3Bdpdk_19_11_tags_LSDK20.04-isc-09%3C%2FP%3E%3CP%3EPrimary%20(%20DPDK%20)%20Process%20%3A%20Create%20a%20mbuff%20Pool%20using%20%5B%26nbsp%3Brte_pktmbuf_pool_create(%22dlmempool%22%2C%20%5D%3C%2FP%3E%3CP%3ESecondary%20(%20DPDK%20)%20Process%20%3A%20fails%20to%20allocate%20mbuff%20using%20API%20%5B%26nbsp%3Brte_pktmbuf_alloc(mempool)%20%5D%3C%2FP%3E%3CP%3EIn%20Secondary%20i%20can%20see%20mempool%20is%20correct.%20I%20can%20see%20mbuff%20available%20is%20full.%20The%20failure%20happens%20for%201st%20mbuff%20allocation%20using%26nbsp%3B%26nbsp%3Brte_pktmbuf_alloc.%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EAny%20solution%20for%20this.%20Thanks.%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2408976%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Secondary%20failed%20allocate%20mbuff%20from%20DPDK%20Pool%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2408976%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Ethanks%20i%20will%20try%20these%20options%20and%20update%20you%20by%20tomorrow%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2408967%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Secondary%20failed%20allocate%20mbuff%20from%20DPDK%20Pool%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2408967%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%3C%2FP%3E%0A%3CP%20class%3D%22p8i6j01%20paragraph%22%3EThe%20secondary%20process%20must%20map%20hugepages%20at%20the%20same%20virtual%20address%20as%20the%20primary.%20If%20ASLR%20is%20active%2C%20the%20secondary%20will%20resolve%20the%20mempool%20pointer%20to%20a%20different%20virtual%20address%2C%20causing%20the%20first%20allocation%20to%20fail.%3C%2FP%3E%0A%3CDIV%20class%3D%22l8rrz21%20_1ibi0s3en%22%20data-ui-element%3D%22code-block-container%22%3E%0A%3CPRE%3E%3CCODE%20class%3D%22markdown-code-bash%20p8i6j0e%20hljs%20language-bash%20_12n1b832%22%3E%3CSPAN%20class%3D%22hljs-built_in%22%3Eecho%3C%2FSPAN%3E%200%20%26gt%3B%20%2Fproc%2Fsys%2Fkernel%2Frandomize_va_space%0A%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CDIV%20class%3D%22l8rrz23%20_1ibi0s3dp%20_1ibi0s332%20_1ibi0s3eo%20_1ibi0s3bm%20_1ibi0s3ce%22%3E%0A%3CDIV%20class%3D%22lqznwq0%22%20style%3D%22mask-image%3A%20url('%2Fimages%2Fcopy.svg')%3B%20vertical-align%3A%20text-bottom%3B%20height%3A%2014px%3B%20min-width%3A%2014px%3B%20width%3A%2014px%3B%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3CP%20class%3D%22p8i6j01%20paragraph%22%3ERun%20this%20before%20launching%20either%20the%20primary%20or%20secondary%20process.%3C%2FP%3E%0A%3CP%20class%3D%22p8i6j01%20paragraph%22%3E2.%20Provision%20Sufficient%20DPMCP%20Objects%3C%2FP%3E%0A%3CP%20class%3D%22p8i6j01%20paragraph%22%3ECreate%20as%20many%20DPMCP%20objects%20as%20the%20total%20number%20of%20processes%20(primary%20%2B%20secondary).%20For%201%20primary%20%2B%201%20secondary%2C%20you%20need%20at%20least%202%20DMPCPs%3A%20%3CA%20id%3D%22base-ui-%3Ar2uj%3A%22%20class%3D%22wdbi343%20wdbi341%20_1ibi0s3ec%20_1ibi0s376%22%20tabindex%3D%220%22%20role%3D%22button%22%20href%3D%22https%3A%2F%2Fwww.nxp.com.cn%2Fdocs%2Fen%2Fuser-guide%2FLSDKYOCTOUG.pdf%22%20rel%3D%22noreferrer%20nofollow%20noopener%22%20aria-expanded%3D%22false%22%20aria-haspopup%3D%22dialog%22%20data-base-ui-click-trigger%3D%22%22%20data-label%3D%221%22%20aria-label%3D%22Citation%201%22%20target%3D%22_blank%22%3E%3C%2FA%3E%3C%2FP%3E%0A%3CDIV%20class%3D%22l8rrz21%20_1ibi0s3en%22%20data-ui-element%3D%22code-block-container%22%3E%0A%3CPRE%3E%3CCODE%20class%3D%22markdown-code-bash%20p8i6j0e%20hljs%20language-bash%20_12n1b832%22%3E%3CSPAN%20class%3D%22hljs-built_in%22%3Eexport%3C%2FSPAN%3E%20DPMCP_COUNT%3D3%20%20%20%3CSPAN%20class%3D%22hljs-comment%22%3E%23%20for%201%20Primary%20%2B%202%20Secondary%20(always%20provision%20%2B1%20as%20buffer)%3C%2FSPAN%3E%0A.%2Fdynamic_dpl.sh%20dpmac.X%0A%3C%2FCODE%3E%3C%2FPRE%3E%0A%3C%2FDIV%3E%0A%3CHR%20%2F%3E%0A%3CH4%20class%3D%22_9k2iva0%20p8i6j0c%20_1ibi0s314%20heading4%20_9k2iva1%22%20id%3D%22toc-hId-258236498%22%20id%3D%22toc-hId-258258633%22%20id%3D%22toc-hId-258258633%22%3E3.%20Provision%20Sufficient%20DPIO%20Objects%3C%2FH4%3E%0A%3CP%20class%3D%22p8i6j01%20paragraph%22%3EEach%20process%20needs%20its%20own%20DPIO%20portals.%20The%20formula%20is%3A%20%3CA%20id%3D%22base-ui-%3Ar2up%3A%22%20class%3D%22wdbi343%20wdbi341%20_1ibi0s3ec%20_1ibi0s376%22%20tabindex%3D%220%22%20role%3D%22button%22%20href%3D%22https%3A%2F%2Fwww.nxp.com.cn%2Fdocs%2Fen%2Fuser-guide%2FLSDKYOCTOUG.pdf%22%20rel%3D%22noreferrer%20nofollow%20noopener%22%20aria-expanded%3D%22false%22%20aria-haspopup%3D%22dialog%22%20data-base-ui-click-trigger%3D%22%22%20data-label%3D%221%22%20aria-label%3D%22Citation%201%22%20target%3D%22_blank%22%3E%3C%2FA%3E%3C%2FP%3E%0A%3CBLOCKQUOTE%20class%3D%22p8i6j03%22%3E%0A%3CP%20class%3D%22p8i6j01%20paragraph%22%3E%3CSTRONG%3E(Total%20Processes)%20%C3%97%20(cores%20per%20process%20%2B%201%20extra%20per%20process)%3C%2FSTRONG%3E%3C%2FP%3E%0A%3C%2FBLOCKQUOTE%3E%0A%3CP%20class%3D%22p8i6j01%20paragraph%22%3EFor%20example%2C%201%20primary%20(2%20cores)%20%2B%201%20secondary%20(2%20cores)%20%3D%20at%20minimum%209%20DPIOs.%3C%2FP%3E%0A%3CDIV%20class%3D%22l8rrz21%20_1ibi0s3en%22%20data-ui-element%3D%22code-block-container%22%3E%0A%3CPRE%3E%3CCODE%20class%3D%22markdown-code-bash%20p8i6j0e%20hljs%20language-bash%20_12n1b832%22%3E%3CSPAN%20class%3D%22hljs-built_in%22%3Eexport%3C%2FSPAN%3E%20DPIO_COUNT%3D20%20%20%20%3CSPAN%20class%3D%22hljs-comment%22%3E%23%20set%20generously%3C%2FSPAN%3E%0A%3C%2FCODE%3E%3C%2FPRE%3E%0A%3C%2FDIV%3E%0A%3CHR%20%2F%3E%0A%3CH4%20class%3D%22_9k2iva0%20p8i6j0c%20_1ibi0s314%20heading4%20_9k2iva1%22%20id%3D%22toc-hId--1549217965%22%20id%3D%22toc-hId--1549195830%22%20id%3D%22toc-hId--1549195830%22%3E4.%20Correctly%20Blacklist%2FWhitelist%20Devices%20in%20the%20Secondary%3C%2FH4%3E%0A%3CP%20class%3D%22p8i6j01%20paragraph%22%3EThe%20secondary%20process%20must%20NOT%20re-initialize%20I%2FO%20devices%20(dpni%2C%20dpbp%2C%20dpcon%2C%20dpseci).%20Only%20%3CCODE%20class%3D%22p8i6j0f%22%3Edpio%3C%2FCODE%3E%20and%20%3CCODE%20class%3D%22p8i6j0f%22%3Edpmcp%3C%2FCODE%3E%20should%20be%20initialized%20by%20the%20secondary.%20Pass%20the%20correct%20blacklist%20flags%3A%20%3CA%20id%3D%22base-ui-%3Ar2uv%3A%22%20class%3D%22wdbi343%20wdbi341%20_1ibi0s3ec%20_1ibi0s376%22%20tabindex%3D%220%22%20role%3D%22button%22%20href%3D%22https%3A%2F%2Fwww.nxp.com.cn%2Fdocs%2Fen%2Fuser-guide%2FLSDKYOCTOUG.pdf%22%20rel%3D%22noreferrer%20nofollow%20noopener%22%20aria-expanded%3D%22false%22%20aria-haspopup%3D%22dialog%22%20data-base-ui-click-trigger%3D%22%22%20data-label%3D%221%22%20aria-label%3D%22Citation%201%22%20target%3D%22_blank%22%3E%3C%2FA%3E%3C%2FP%3E%0A%3CDIV%20class%3D%22l8rrz21%20_1ibi0s3en%22%20data-ui-element%3D%22code-block-container%22%3E%0A%3CPRE%3E%3CCODE%20class%3D%22markdown-code-bash%20p8i6j0e%20hljs%20language-bash%20_12n1b832%22%3E%3CSPAN%20class%3D%22hljs-comment%22%3E%23%20Secondary%20process%20example%20%E2%80%94%20blacklist%20all%20dpni%2Fdpbp%2Fdpcon%2C%20allow%20only%20dpio%20%2B%20dpmcp%3C%2FSPAN%3E%0A.%2Fyour_secondary_app%20--proc-type%3Dsecondary%20%5C%0A%20%20-b%20fslmc%3Adpni.X%20%5C%0A%20%20-b%20fslmc%3Adpbp.X%20%5C%0A%20%20-b%20fslmc%3Adpcon.X%20%5C%0A%20%20--%20%5Bapp%20args%5D%0A%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CDIV%20class%3D%22l8rrz23%20_1ibi0s3dp%20_1ibi0s332%20_1ibi0s3eo%20_1ibi0s3bm%20_1ibi0s3ce%22%3E%0A%3CDIV%20class%3D%22lqznwq0%22%20style%3D%22mask-image%3A%20url('%2Fimages%2Fcopy.svg')%3B%20vertical-align%3A%20text-bottom%3B%20height%3A%2014px%3B%20min-width%3A%2014px%3B%20width%3A%2014px%3B%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3CP%20class%3D%22p8i6j01%20paragraph%22%3EOr%20alternatively%2C%20explicitly%20whitelist%20only%20the%20dpio%20and%20dpmcp%20objects%20assigned%20to%20the%20secondary%3A%3C%2FP%3E%0A%3CDIV%20class%3D%22l8rrz21%20_1ibi0s3en%22%20data-ui-element%3D%22code-block-container%22%3E%0A%3CPRE%3E%3CCODE%20class%3D%22markdown-code-bash%20p8i6j0e%20hljs%20language-bash%20_12n1b832%22%3E.%2Fyour_secondary_app%20--proc-type%3Dsecondary%20%5C%0A%20%20-w%20fslmc%3Adpio.Y%20%5C%0A%20%20-w%20fslmc%3Adpmcp.Z%20%5C%0A%20%20--%20%5Bapp%20args%5D%0A%3C%2FCODE%3E%3C%2FPRE%3E%0A%3C%2FDIV%3E%0A%3CHR%20%2F%3E%0A%3CH4%20class%3D%22_9k2iva0%20p8i6j0c%20_1ibi0s314%20heading4%20_9k2iva1%22%20id%3D%22toc-hId-938294868%22%20id%3D%22toc-hId-938317003%22%20id%3D%22toc-hId-938317003%22%3E5.%20Use%20%3CCODE%20class%3D%22p8i6j0f%22%3E--proc-type%3Dsecondary%3C%2FCODE%3E%20EAL%20Argument%3C%2FH4%3E%0A%3CP%20class%3D%22p8i6j01%20paragraph%22%3EEnsure%20the%20secondary%20is%20launched%20with%20the%20correct%20EAL%20flag%3A%20%3CA%20id%3D%22base-ui-%3Ar2v8%3A%22%20class%3D%22wdbi343%20wdbi341%20_1ibi0s3ec%20_1ibi0s376%22%20tabindex%3D%220%22%20role%3D%22button%22%20href%3D%22https%3A%2F%2Fwww.nxp.com.cn%2Fdocs%2Fen%2Fuser-guide%2FLSDKYOCTOUG.pdf%22%20rel%3D%22noreferrer%20nofollow%20noopener%22%20aria-expanded%3D%22false%22%20aria-haspopup%3D%22dialog%22%20data-base-ui-click-trigger%3D%22%22%20data-label%3D%221%22%20aria-label%3D%22Citation%201%22%20target%3D%22_blank%22%3E%3C%2FA%3E%3C%2FP%3E%0A%3CDIV%20class%3D%22l8rrz21%20_1ibi0s3en%22%20data-ui-element%3D%22code-block-container%22%3E%0A%3CPRE%3E%3CCODE%20class%3D%22markdown-code-bash%20p8i6j0e%20hljs%20language-bash%20_12n1b832%22%3E.%2Fyour_secondary_app%20-c%20%3CCOREMASK%3E%20-n%201%20--proc-type%3Dsecondary%20...%0A%3C%2FCOREMASK%3E%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CDIV%20class%3D%22l8rrz23%20_1ibi0s3dp%20_1ibi0s332%20_1ibi0s3eo%20_1ibi0s3bm%20_1ibi0s3ce%22%3E%0A%3CDIV%20class%3D%22lqznwq0%22%20style%3D%22mask-image%3A%20url('%2Fimages%2Fcopy.svg')%3B%20vertical-align%3A%20text-bottom%3B%20height%3A%2014px%3B%20min-width%3A%2014px%3B%20width%3A%2014px%3B%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3CP%20class%3D%22p8i6j01%20paragraph%22%3EOr%20use%20%3CCODE%20class%3D%22p8i6j0f%22%3E--proc-type%3Dauto%3C%2FCODE%3E%20to%20let%20DPDK%20auto-detect.%3C%2FP%3E%0A%3CHR%20%2F%3E%0A%3CH4%20class%3D%22_9k2iva0%20p8i6j0c%20_1ibi0s314%20heading4%20_9k2iva1%22%20id%3D%22toc-hId--869159595%22%20id%3D%22toc-hId--869137460%22%20id%3D%22toc-hId--869137460%22%3E6.%20Verify%20the%20Mempool%20Lookup%20in%20Secondary%3C%2FH4%3E%0A%3CP%20class%3D%22p8i6j01%20paragraph%22%3EIn%20the%20secondary%2C%20do%20not%20call%20%3CCODE%20class%3D%22p8i6j0f%22%3Erte_pktmbuf_pool_create%3C%2FCODE%3E%20again.%20Instead%2C%20look%20up%20the%20existing%20pool%20created%20by%20the%20primary%3A%3C%2FP%3E%0A%3CDIV%20class%3D%22l8rrz21%20_1ibi0s3en%22%20data-ui-element%3D%22code-block-container%22%3E%0A%3CPRE%3E%3CCODE%20class%3D%22markdown-code-c%20p8i6j0e%20hljs%20language-c%20_12n1b832%22%3E%3CSPAN%20class%3D%22hljs-comment%22%3E%2F%2F%20In%20secondary%20process%3A%3C%2FSPAN%3E%0A%3CSPAN%20class%3D%22hljs-class%22%3E%3CSPAN%20class%3D%22hljs-keyword%22%3Estruct%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22hljs-title%22%3Erte_mempool%3C%2FSPAN%3E%20*%3CSPAN%20class%3D%22hljs-title%22%3Emempool%3C%2FSPAN%3E%20%3D%3C%2FSPAN%3E%20rte_mempool_lookup(%3CSPAN%20class%3D%22hljs-string%22%3E%22dlmempool%22%3C%2FSPAN%3E)%3B%0A%3CSPAN%20class%3D%22hljs-keyword%22%3Eif%3C%2FSPAN%3E%20(mempool%20%3D%3D%20%3CSPAN%20class%3D%22hljs-literal%22%3ENULL%3C%2FSPAN%3E)%20%7B%0A%20%20%20%20%3CSPAN%20class%3D%22hljs-comment%22%3E%2F%2F%20Error%3A%20pool%20not%20found%20%E2%80%94%20ASLR%20or%20hugepage%20mapping%20issue%3C%2FSPAN%3E%0A%7D%0A%3CSPAN%20class%3D%22hljs-class%22%3E%3CSPAN%20class%3D%22hljs-keyword%22%3Estruct%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22hljs-title%22%3Erte_mbuf%3C%2FSPAN%3E%20*%3CSPAN%20class%3D%22hljs-title%22%3Em%3C%2FSPAN%3E%20%3D%3C%2FSPAN%3E%20rte_pktmbuf_alloc(mempool)%3B%0A%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CDIV%20class%3D%22l8rrz23%20_1ibi0s3dp%20_1ibi0s332%20_1ibi0s3eo%20_1ibi0s3bm%20_1ibi0s3ce%22%3E%0A%3CDIV%20class%3D%22l8rrz25%20_1ibi0s3eb%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CDIV%20class%3D%22lqznwq0%22%20style%3D%22mask-image%3A%20url('%2Fimages%2Fcopy.svg')%3B%20vertical-align%3A%20text-bottom%3B%20height%3A%2014px%3B%20min-width%3A%2014px%3B%20width%3A%2014px%3B%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3CP%20class%3D%22p8i6j01%20paragraph%22%3EIf%20%3CCODE%20class%3D%22p8i6j0f%22%3Erte_mempool_lookup%3C%2FCODE%3E%20returns%20a%20valid%20non-NULL%20pointer%20but%20%3CCODE%20class%3D%22p8i6j0f%22%3Erte_pktmbuf_alloc%3C%2FCODE%3E%20still%20returns%20NULL%2C%20the%20issue%20is%20almost%20certainly%20the%20DPIO%20portal%20not%20being%20initialized%20for%20the%20secondary's%20thread%2Fcore.%3C%2FP%3E%0A%3CP%20class%3D%22p8i6j01%20paragraph%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%20class%3D%22p8i6j01%20paragraph%22%3ERegards%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2414346%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Secondary%20failed%20allocate%20mbuff%20from%20DPDK%20Pool%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2414346%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Ethanks%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F34846%22%20target%3D%22_blank%22%3E%40Bio_TICFSL%3C%2FA%3E%26nbsp%3Bfor%20the%20quick%20solution%3C%2FP%3E%3C%2FLINGO-BODY%3E
