Restoring LS1021A-IOT
1,331件の閲覧回数
renaud
I have a LS1021A-IOT. it is failing to boot:
U-Boot SPL 2021.04+fsl+gae6f725a51 (Dec 08 2021 - 03:51:46 +0000)
Trying to boot from MMC1
No max bus width provided. Assume 8-bit supported.
I would like to restore it either booting from SD card or QSPI?
Where can I find the binaries and how to program them?
2 返答(返信)
1,303件の閲覧回数
SebastianG
HI @renaud,
You can find the Binary for SD Card for the LS1021A-IoT in the following link:
https://www.nxp.com/design/designs/ls1021a-iot-gateway-reference-design:LS1021A-IoT
In the highlighted area of the following image you can find where you can download the BSP for LS1021A-IoT.
due to NXP didn't  develop the software for your Board, please contact with WindRiver or TechNexion in order to get the binaries or BSP for the LS1021a-IoT.
Sebastian
1,311件の閲覧回数
SebastianG
Hi @renaud,
I hope this post fins you well,
Just to let you know that I'm still working on your questions, I will let you know as soon as I have any update.
Thank you for your patience
Sebastian
