PREEMPT_RT on Linux QoriQ
267件の閲覧回数
pb3
we are currently using the NXP QorIQ Linux kernel from the linux-6.12-rt branch, but we would like to move to a newer kernel version, possibly Linux 6.18.
I have a few questions regarding the RT kernel support and branch strategy:
  • What exactly is the difference between linux-6.12-rt and lf-6.12.y?
  • Is a separate linux-6.18-rt branch planned, similarly to linux-6.12-rt?
  • If not, is lf-6.18.y intended to be used directly with CONFIG_PREEMPT_RT=y?
My understanding is that linux-6.12-rt contains additional PREEMPT_RT-related changes compared to lf-6.12.y. However, starting with Linux 6.12, the core PREEMPT_RT support has been merged into the upstream kernel:
https://kernel-internals.org/locking/preempt-rt/
At the same time, I can see that RT-specific development and stable RT patch releases still continue separately upstream.
Given this, I would like to understand how this is handled in the newer NXP QorIQ releases.
For Linux 6.18, should we simply use the lf-6.18.y branch with CONFIG_PREEMPT_RT=y, with all NXP-specific changes required for PREEMPT_RT already included there?
Or is a separate QorIQ RT branch/release still planned, containing additional RT patches on top of lf-6.18.y?
If no separate RT branch is planned, are there any additional RT patches that NXP recommends applying on top of lf-6.18.y?
3 返答(返信)
200件の閲覧回数
Bio_TICFSL
For QorIQ/Layerscape, do not assume that lf-6.18.y plus CONFIG_PREEMPT_RT=y is equivalent to NXP’s supported RT release. NXP’s current Real-Time Edge material shows Linux PREEMPT_RT 6.18 releases based on LF 6.18, while internal development tracks a separate downstream RT patch stack.
Use the matching NXP 6.18 RT release, preferably the latest one available for your QorIQ platform. Compare your current linux-6.12-rt tree against the corresponding LF 6.18 base, but do not assume that enabling CONFIG_PREEMPT_RT=y alone includes all NXP-specific RT changes.
Also validate:
  • architecture support for ARCH_SUPPORTS_RT;
  • NXP networking, DPAA/DPAA2, ENETC, DSA, TSN, PTP, and interrupt behavior;
  • latency under representative load;
  • any driver-specific RT patches in the NXP downstream stack.
The upstream article’s main qualification is also relevant: PREEMPT_RT became mainline-selectable in 6.12, but support is architecture-dependent and does not imply that every vendor driver has been validated for deterministic behavior
197件の閲覧回数
pb3
Thanks for clarification. Do you know when, more or less can we expect the NXP Linux 6.18 RT support release?
196件の閲覧回数
Bio_TICFSL
So, if you mean the next 6.18-based RT update, the current roadmap points to Real-Time Edge 3.6 in December 2026.
Note that the standard i.MX Linux BSP—not RT—already has newer 6.18 releases, including 6.18.37 on September 24, 2026.
%3CLINGO-SUB%20id%3D%22lingo-sub-2417891%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ELinux%E3%81%AEQoriQ%E3%81%A7PREEMPT_RT%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2417891%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E7%8F%BE%E5%9C%A8%E3%81%AF%3CSPAN%3Elinux-6.12-rt%3C%2FSPAN%3E%E3%83%96%E3%83%A9%E3%83%B3%E3%83%81%3CSPAN%3E%E3%81%AENXP%20QorIQ%E3%81%AELinux%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%20%3C%2FSPAN%3E%3CSPAN%3E%20%E3%81%8C%E3%80%81%E3%81%8A%E3%81%9D%E3%82%89%E3%81%8FLinux%206.18%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E6%96%B0%E3%81%97%E3%81%84%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AB%E7%A7%BB%E8%A1%8C%E3%81%97%E3%81%9F%E3%81%84%E3%81%A8%E8%80%83%E3%81%88%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3ERT%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AE%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%A8%E3%83%96%E3%83%A9%E3%83%B3%E3%83%81%E6%88%A6%E7%95%A5%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E8%B3%AA%E5%95%8F%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%3CP%3E%3CSPAN%3Elinux-6.12-rt%3C%2FSPAN%3E%3CSPAN%3E%E3%81%A8%3C%2FSPAN%3E%3CSPAN%3Elf-6.12.y%3C%2FSPAN%3E%3CSPAN%3E%E3%81%AE%E9%81%95%E3%81%84%E3%81%AF%E6%AD%A3%E7%A2%BA%E3%81%AB%E3%81%AF%E4%BD%95%E3%81%A7%E3%81%99%E3%81%8B%3C%2FSPAN%3E%3CSPAN%3E%3F%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%3CSPAN%3Elinux-6.12-rt%3C%2FSPAN%3E%E3%81%A8%E5%90%8C%E6%A7%98%E3%81%AB%3CSPAN%3E%E3%80%81%E5%88%A5%E3%81%AE%3C%2FSPAN%3E%3CSPAN%3ELinux-6.18-rt%3C%2FSPAN%3E%E3%83%96%3CSPAN%3E%E3%83%A9%E3%83%B3%E3%83%81%E3%81%8C%E8%A8%88%E7%94%BB%3C%2FSPAN%3E%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%3CSPAN%3E%E3%81%AE%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%3F%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%3CSPAN%3E%E3%81%9D%E3%81%86%E3%81%A7%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3Elf-6.18.y%3C%2FSPAN%3E%E3%81%AF%3CSPAN%3ECONFIG_PREEMPT_RT%3Dy%3C%2FSPAN%3E%3CSPAN%3E%E3%81%A8%E7%9B%B4%E6%8E%A5%E4%BD%B5%E7%94%A8%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E6%83%B3%E5%AE%9A%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FSPAN%3E%E3%81%8B%3CSPAN%3E%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3CSPAN%3E%E7%A7%81%E3%81%AE%E7%90%86%E8%A7%A3%E3%81%A7%E3%81%AF%3C%2FSPAN%3E%3CSPAN%3E%E3%80%81linux-6.12-rt%3C%2FSPAN%3E%E3%81%AF%3CSPAN%3Elf-6.12.y%3C%2FSPAN%3E%3CSPAN%3E%E3%81%A8%E6%AF%94%E3%81%B9%E3%81%A6%E8%BF%BD%E5%8A%A0%E3%81%AE%20PREEMPT_RT%20%E9%96%A2%E9%80%A3%E3%81%AE%E5%A4%89%E6%9B%B4%E3%81%8C%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3CSPAN%3E%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81Linux%206.12%20%E4%BB%A5%E9%99%8D%E3%80%81%E3%82%B3%E3%82%A2%20PREEMPT_RT%20%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%AF%E4%B8%8A%E6%B5%81%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AB%E7%B5%B1%E5%90%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3CBR%20%2F%3E%3CA%20href%3D%22https%3A%2F%2Fkernel-internals.org%2Flocking%2Fpreempt-rt%2F%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3E%3CSPAN%3Ehttps%3A%2F%2Fkernel-internals.org%2Flocking%2Fpreempt-rt%2F%3C%2FSPAN%3E%3C%2FA%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E5%90%8C%E6%99%82%E3%81%AB%E3%80%81RT%E5%B0%82%E7%94%A8%E3%81%AE%E9%96%8B%E7%99%BA%E3%81%A8%E5%AE%89%E5%AE%9A%E3%81%97%E3%81%9FRT%E3%83%91%E3%83%83%E3%83%81%E3%81%AE%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%81%AF%E3%80%81%E4%B8%8A%E6%B5%81%E3%81%A7%E5%88%A5%E3%80%85%E3%81%AB%E7%B6%9A%E3%81%84%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%82%82%E8%A6%8B%E3%81%A6%E5%8F%96%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E4%BB%A5%E4%B8%8A%E3%81%AE%E3%81%93%E3%81%A8%E3%81%8B%E3%82%89%E3%80%81NXP%E3%81%AE%E6%9C%80%E6%96%B0%E7%89%88QorIQ%E3%81%A7%E3%81%AF%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%8C%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E5%87%A6%E7%90%86%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%8B%E3%82%92%E7%9F%A5%E3%82%8A%E3%81%9F%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3ELinux%206.18%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81%3C%2FSPAN%3E%3CSPAN%3Elf-6.18.y%3C%2FSPAN%3E%E3%81%AE%E3%83%96%3CSPAN%3E%E3%83%A9%E3%83%B3%E3%83%81%3C%2FSPAN%3E%E3%82%92%3CSPAN%3ECONFIG_PREEMPT_RT%3Dy%3C%2FSPAN%3E%E3%81%A7%E4%BD%BF%E3%81%84%3CSPAN%3E%E3%80%81NXP%E5%9B%BA%E6%9C%89%E3%81%AE%E5%A4%89%E6%9B%B4%E3%82%92%E3%81%99%E3%81%B9%E3%81%A6%E5%90%AB%E3%82%81%E3%81%A6%E3%80%81%E3%81%99%E3%81%A7%E3%81%ABNXP%E5%9B%BA%E6%9C%89%E3%81%AE%E5%A4%89%E6%9B%B4%E3%82%92PREEMPT_RT%3C%2FSPAN%3E%E3%81%AB%E5%85%A5%E3%82%8C%E3%82%8B%E3%81%B9%E3%81%8D%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%3F%3C%2FP%3E%3CP%3E%E3%81%9D%E3%82%8C%E3%81%A8%E3%82%82%E3%80%81%20%3CSPAN%3Elf-6.18.y%3C%2FSPAN%3E%3CSPAN%3E%E3%81%AE%E4%B8%8A%E3%81%AB%E3%81%95%E3%82%89%E3%81%AB%20RT%20%E3%83%91%E3%83%83%E3%83%81%E3%82%92%E5%8A%A0%E3%81%88%E3%81%9F%E3%80%81QorIQ%20RT%20%E5%B0%82%E7%94%A8%E3%81%AE%E3%83%96%E3%83%A9%E3%83%B3%E3%83%81%2F%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%81%8C%E3%81%BE%E3%81%A0%E8%A8%88%E7%94%BB%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%3C%2FSPAN%3E%3CSPAN%3E%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3ERT%E3%83%96%E3%83%A9%E3%83%B3%E3%83%81%E3%82%92%E5%88%A5%E9%80%94%E8%A8%88%E7%94%BB%E3%81%97%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%80%81NXP%E3%81%8C%3CSPAN%3Elf-6.18.y%3C%2FSPAN%3E%3CSPAN%3E%E3%81%AE%E4%B8%8A%E3%81%AB%E9%81%A9%E7%94%A8%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E6%8E%A8%E5%A5%A8%E3%81%99%E3%82%8B%E8%BF%BD%E5%8A%A0%E3%81%AERT%E3%83%91%E3%83%83%E3%83%81%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3C%2FSPAN%3E%3CSPAN%3E%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2418165%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20PREEMPT_RT%20on%20Linux%20QoriQ%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2418165%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3EQorIQ%2FLayerscape%3C%2FSTRONG%3E%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81%20%3CCODE%20class%3D%22p8i6j0h%22%3Elf-6.18.y%3C%2FCODE%3E%E3%81%A8%3CCODE%20class%3D%22p8i6j0h%22%3ECONFIG_PREEMPT_RT%3Dy%3C%2FCODE%3E%E7%B5%84%E3%81%BF%E5%90%88%E3%82%8F%E3%81%9B%E3%81%8CNXP%E3%81%8C%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8BRT%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%81%A8%E5%90%8C%E7%AD%89%E3%81%A7%E3%81%82%E3%82%8B%E3%81%A8%E6%83%B3%E5%AE%9A%E3%81%97%E3%81%AA%E3%81%84%E3%81%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82NXP%E3%81%AE%E7%8F%BE%E5%9C%A8%E3%81%AEReal%20Time%20Edge%E8%B3%87%E6%96%99%E3%81%A7%E3%81%AF%E3%80%81LF%206.18%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%8FLinux%20PREEMPT_RT%206.18%E3%81%AE%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%81%8C%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81%E5%86%85%E9%83%A8%E9%96%8B%E7%99%BA%E3%81%A7%E3%81%AF%E5%88%A5%E3%81%AE%E4%B8%8B%E6%B5%81RT%E3%83%91%E3%83%83%E3%83%81%E3%82%B9%E3%82%BF%E3%83%83%E3%82%AF%E3%81%8C%E8%BF%BD%E8%B7%A1%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%20%3CA%20id%3D%22base-ui-%3Arp2%3A%22%20class%3D%22wdbi343%20wdbi341%20_1ibi0s3ei%20_1ibi0s38m%22%20tabindex%3D%220%22%20role%3D%22button%22%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Frelease-note%2FRN00161.pdf%22%20rel%3D%22noreferrer%20nofollow%20noopener%22%20aria-expanded%3D%22false%22%20aria-haspopup%3D%22dialog%22%20data-base-ui-click-trigger%3D%22%22%20data-label%3D%221%22%20aria-label%3D%22Citation%201%22%20target%3D%22_blank%22%3E%3C%2FA%3E%3C%2FP%3E%0A%3CP%20class%3D%22p8i6j03%20paragraph%22%3E%E5%AF%BE%E5%BF%9C%E3%81%99%E3%82%8BNXP%206.18%20RT%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%80%81%E3%81%A7%E3%81%8D%E3%82%8C%E3%81%B0QorIQ%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E5%90%91%E3%81%91%E3%81%AE%E6%9C%80%E6%96%B0%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%82%92%E4%BD%BF%E3%81%84%E3%81%BE%E3%81%97%E3%82%87%E3%81%86%E3%80%82%E7%8F%BE%E5%9C%A8%E3%81%AE%E7%8A%B6%E6%B3%81%E3%82%92%E6%AF%94%E8%BC%83%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%20%3CCODE%20class%3D%22p8i6j0h%22%3Elinux-6.12-rt%3C%2FCODE%3E%E5%AF%BE%E5%BF%9C%E3%81%99%E3%82%8BLF%206.18%E3%83%99%E3%83%BC%E3%82%B9%E3%81%AB%E5%AF%BE%E3%81%97%E3%81%A6%E3%83%84%E3%83%AA%E3%83%BC%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%20%3CCODE%20class%3D%22p8i6j0h%22%3ECONFIG_PREEMPT_RT%3Dy%3C%2FCODE%3E%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E3%81%A0%E3%81%91%E3%81%A7NXP%E5%9B%BA%E6%9C%89%E3%81%AERT%E5%A4%89%E6%9B%B4%E3%81%8C%E3%81%99%E3%81%B9%E3%81%A6%E5%90%AB%E3%81%BE%E3%82%8C%E3%82%8B%E3%81%A8%E3%81%AF%E8%80%83%E3%81%88%E3%81%AA%E3%81%84%E3%81%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CP%20class%3D%22p8i6j03%20paragraph%22%3E%E3%81%BE%E3%81%9F%E3%80%81%E4%BB%A5%E4%B8%8B%E3%82%82%E6%A4%9C%E8%A8%BC%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CUL%20class%3D%22p8i6j09%20p8i6j04%22%3E%0A%3CLI%20class%3D%22p8i6j0c%22%3E%3CCODE%20class%3D%22p8i6j0h%22%3EARCH_SUPPORTS_RT%3C%2FCODE%3E%E3%81%AE%E3%82%A2%E3%83%BC%E3%82%AD%E3%83%86%E3%82%AF%E3%83%81%E3%83%A3%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%80%81%3C%2FLI%3E%0A%3CLI%20class%3D%22p8i6j0c%22%3ENXP%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%E3%80%81DPAA%2FDPAA2%E3%80%81ENETC%E3%80%81DSA%E3%80%81TSN%E3%80%81PTP%E3%80%81%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E5%8B%95%E4%BD%9C%3B%3C%2FLI%3E%0A%3CLI%20class%3D%22p8i6j0c%22%3E%E4%BB%A3%E8%A1%A8%E8%B2%A0%E8%8D%B7%E4%B8%8B%E3%81%A7%E3%81%AE%E3%83%AC%E3%82%A4%E3%83%86%E3%83%B3%E3%82%B7%3B%3C%2FLI%3E%0A%3CLI%20class%3D%22p8i6j0c%22%3ENXP%E3%81%AE%E4%B8%8B%E6%B5%81%E3%82%B9%E3%82%BF%E3%83%83%E3%82%AF%E3%81%AB%E3%81%82%E3%82%8B%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E5%9B%BA%E6%9C%89%E3%81%AERT%E3%83%91%E3%83%83%E3%83%81%E3%80%82%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%20class%3D%22p8i6j03%20paragraph%22%3E%E4%B8%8A%E6%B5%81%E3%81%AE%E8%A8%98%E4%BA%8B%E3%81%AE%E4%B8%BB%E3%81%AA%E6%9D%A1%E4%BB%B6%E3%82%82%E9%87%8D%E8%A6%81%E3%81%A7%E3%81%99%E3%80%82PREEMPT_RT%206.12%E3%81%A7%E3%83%A1%E3%82%A4%E3%83%B3%E3%83%A9%E3%82%A4%E3%83%B3%E9%81%B8%E6%8A%9E%E5%8F%AF%E8%83%BD%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%AF%E3%82%A2%E3%83%BC%E3%82%AD%E3%83%86%E3%82%AF%E3%83%81%E3%83%A3%E3%81%AB%E4%BE%9D%E5%AD%98%E3%81%97%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%83%99%E3%83%B3%E3%83%80%E3%83%BC%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%8C%E3%83%87%E3%82%BF%E3%83%BC%E3%83%9F%E3%83%8B%E3%82%B9%E3%83%86%E3%82%A3%E3%83%83%E3%82%AF%E3%81%AA%E6%8C%99%E5%8B%95%E3%82%92%E6%A4%9C%E8%A8%BC%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%A8%E3%81%AF%E9%99%90%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3C%2FP%3E%0A%3CP%20class%3D%22p8i6j03%20paragraph%22%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2418178%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20PREEMPT_RT%20on%20Linux%20QoriQ%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2418178%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E3%81%94%E8%AA%AC%E6%98%8E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82NXP%20Linux%206.18%20RT%E3%81%AE%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%81%AF%E3%81%84%E3%81%A4%E9%A0%83%E6%9C%9F%E5%BE%85%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%8B%E3%81%94%E5%AD%98%E7%9F%A5%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2418187%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20PREEMPT_RT%20on%20Linux%20QoriQ%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2418187%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%20class%3D%22p8i6j03%20paragraph%22%3ESO%E3%80%81%E6%AC%A1%E3%81%AE6.18%E3%83%99%E3%83%BC%E3%82%B9%E3%81%AE%E3%81%93%E3%81%A8%E3%82%92%E6%8C%87%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AA%E3%82%89RT%E3%82%A2%E3%83%83%E3%83%97%E3%83%87%E3%83%BC%E3%83%88%E3%80%81%E7%8F%BE%E5%9C%A8%E3%81%AE%E3%83%AD%E3%83%BC%E3%83%89%E3%83%9E%E3%83%83%E3%83%97%E3%81%A7%E3%81%AF%3CSTRONG%3E%E3%80%81Real-Time%20Edge%203.6%E3%81%8C2026%E5%B9%B412%E6%9C%88%E3%81%AB%3C%2FSTRONG%3E%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%81%95%E3%82%8C%E3%82%8B%E4%BA%88%E5%AE%9A%E3%81%A7%E3%81%99%E3%80%82%20%3CA%20id%3D%22base-ui-%3Ar5j3%3A%22%20class%3D%22wdbi343%20wdbi341%20_1ibi0s3ei%20_1ibi0s38m%22%20tabindex%3D%220%22%20role%3D%22button%22%20href%3D%22https%3A%2F%2Fnxp1.sharepoint.com%2Fteams%2F210_48%2FShared%2520Documents%2FPartners%2FPartner%2520Calls%2F2026%2FQ2%25202026%2520Partner%2520Update%2520Call%2FQ2%25202026%2520Partner%2520Update%2520for%2520MCU%2520%2526%2520MPU%2520(slides).pdf%3Fweb%3D1%22%20rel%3D%22noreferrer%20nofollow%20noopener%22%20aria-expanded%3D%22false%22%20aria-haspopup%3D%22dialog%22%20data-base-ui-click-trigger%3D%22%22%20data-label%3D%223%22%20aria-label%3D%22Citation%203%22%20target%3D%22_blank%22%3E%3C%2FA%3E%3C%2FP%3E%0A%3CP%20class%3D%22p8i6j03%20paragraph%22%3E%E3%81%AA%E3%81%8A%E3%80%81Linux%20BSP%20i.MX%20%E6%A8%99%E6%BA%96(RT%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%8F)%E3%81%AF%E3%81%99%E3%81%A7%E3%81%AB%E6%96%B0%E3%81%97%E3%81%846.18%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%81%8C%E3%81%82%E3%82%8A%E3%80%81%20%3CSTRONG%3E2026%E5%B9%B49%E6%9C%8824%E6%97%A5%E3%81%AE6.18.37%3C%2FSTRONG%3E%E3%82%82%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%20%3CA%20id%3D%22base-ui-%3Ar5j6%3A%22%20class%3D%22wdbi343%20wdbi341%20_1ibi0s3ei%20_1ibi0s38m%22%20tabindex%3D%220%22%20role%3D%22button%22%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Frelease-note%2FRN00210.pdf%22%20rel%3D%22noreferrer%20nofollow%20noopener%22%20aria-expanded%3D%22false%22%20aria-haspopup%3D%22dialog%22%20data-base-ui-click-trigger%3D%22%22%20data-label%3D%224%22%20aria-label%3D%22Citation%204%22%20target%3D%22_blank%22%3E%3C%2FA%3E%3C%2FP%3E%0A%3CP%20class%3D%22p8i6j03%20paragraph%22%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
