MSI interrupt for LS1046A
1,558 次查看
deepanrajanbara
Hi ,
 We are using LS1046A  and we wanted to use the MSI interrupt to apply other driver(qcom mhi),How do I configure the dtsi file i.e the msi-map and msi-map-mask parameters. Where do i need to check to get the values of the RID base and msi base. Please help asap.
Thank you,
Deepanraj.A
1,550 次查看
ufedor
All required MSI definitions are already present in the "fsl-ls1046a.dtsi":
https://source.codeaurora.org/external/qoriq/qoriq-components/linux/tree/arch/arm64/boot/dts/freesca...
