Ls1046a 1000Base-KX/10gBase-KR Linux support
ソリューションへジャンプ
7,359件の閲覧回数
renaud
We have a board using with two 10G (1000Base-KR) and one 1000Base-KX connection on Serdes 1. Protocol is 1133
We are using Linux 6.4 and soon 6.11.x
My understanding is that the 1000Base-KX support is not found in the kernel.org as per comment in fman_memac.:
/* TODO: The following interface modes are supported by (some) hardware
* but not by this driver:
* - 1000BASE-KX
but can be found in nxp qoirq Linux support:  https://github.com/nxp-qoriq/linux.git
in branch lf-6.6.y.
Also i found: https://community.nxp.com/t5/QorIQ/Eval-Board-for-1000Base-KX-LS1046A/m-p/1178936 which shows what needs to be initialized by the boot loader and Linux.
So could you confirm the following:
1. The upstream Linux support cannot be used to support 1000Base-KX and/or 1000Base-KR on the LS1046A.
2. In the link above, there is mention to configure SGMII_IF_MODE. Which part of Linux does that?
3. Can you show me what the node should look like for the 10Gbase-kr and 1000Base-KX.
4. What is the latest U-boot/Linux to support the LS1046a and specially is there code in U-boot to do the initialization of 1000Base-kr and  1000Base-kx. I guess the link above is the init sequence.
Otherwise, If I am wrong about not being able to use upstream kernel (kernel.org), I would appreciate a summary of what I have to do.
Cheers,
Renaud
6,991件の閲覧回数
renaud
Eventually found the error on the 1000base-KX. There a few more bits to set along with clearing the AMP_RED field
7 返答(返信)
6,992件の閲覧回数
renaud
7,322件の閲覧回数
LFGP
this is an example how to look like a node for the 1000Base-KX
enet4: ethernet@4 {
compatible = "fsl,fman-memac";
reg = <0x4000 0x1000>;
phy-mode = "1000base-kx";
fixed-link = <4 1 1000 0 0>; // fixed link to 1 Gbps
status = "okay";
additionally, you have to follow the steps described in the subject "31.8.1.3 1000Base-KX" in the LS1046ARM.
The LLDP 6.1.55 uses the U-boot release 2023.04
Nothing to config at U-boot
7,209件の閲覧回数
renaud
A bit confusing when you nothing to config at U-boot. Where do you do the config from 31.8.1.3. I supposed it is split between U-boot and Linux
7,229件の閲覧回数
renaud
Let's turn to the 10gbase-kr. I saw that there is LANnTECR0  to set up.
I see two DTS include files:
arch/arm64/boot/dts/freescale/fsl-ls1046a-sd1-1133-lane-c-backplane-phylib.dtsi
arch/arm64/boot/dts/freescale/fsl-ls1046a-sd1-1133-lane-c-backplane.dtsi
Should I include any of them? or keep it simpler.
For some reason I have included the latter and there are some probing errors.
7,242件の閲覧回数
renaud
What about the pcsphy4? Any modification needed to the part of the device tree?
The 1000Base-KX go through the backplane then a media converter (to 1000baseT). The MDIO bus is not connected trough the backplane.
7,311件の閲覧回数
renaud
This is what I have:
ethernet@e8000 {
status = "okay";
fixed-link {
speed = <1000>;
full-duplex;
ethernet eth1: Link is Up - 1Gbps/Full - flow control off
"fsl_dpaa_mac 1ae8000.ethernet eth1: major config 1000base-kx"
What seems to be missing is the last three steps of 31.8.1.3. in Linux. I am using the NXP qoirq Liunx branch lf-6.6.y
Trying to add them in drivers/net/pcs/pcs-lynx.c. Though, I never see pcs_config being called.  Debugging I see in drivers/net/phy/phylink.c:
phylink_pcs_config pcs = 0000000000000000.
Would that not mean I cannot access the MDIO KX and MDIO KX AN?
7,337件の閲覧回数
renaud
I think I got the answer for 1 and 2 but cannot get either 1000Kx or 10base-KR to work
%3CLINGO-SUB%20id%3D%22lingo-sub-2035088%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ELs1046a%201000Base-KX%2F10gBase-KR%20Linux%20%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2035088%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3ESerdes%201%E3%81%AB10G(1000Base-KR)%E3%82%922%E3%81%A4%E3%80%811000Base-KX%E6%8E%A5%E7%B6%9A%E3%82%921%E3%81%A4%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%83%9C%E3%83%BC%E3%83%89%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%81%AF1133%E3%81%A7%E3%81%99%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%9F%E3%81%A1%E3%81%AFLinux%206.4%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81%E3%81%BE%E3%82%82%E3%81%AA%E3%81%8F6.11.x%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AE%E7%90%86%E8%A7%A3%E3%81%A7%E3%81%AF%E3%80%811000Base-KX%E3%81%AE%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%AF%E3%80%81fman_memac%E3%81%AE%E3%82%B3%E3%83%A1%E3%83%B3%E3%83%88%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%20kernel.org%20%E3%81%AB%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%2F*%20TODO%3A%20%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AF%20(%E4%B8%80%E9%83%A8%E3%81%AE)%20%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%A7%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3E*%E3%81%9F%E3%81%A0%E3%81%97%E3%80%81%E3%81%93%E3%81%AE%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%A7%E3%81%AF%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%AA%E3%81%84%E3%81%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3CBR%20%2F%3E*%20-%201000BASE-KX%E3%81%AE%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%20nxp%20qoirq%20Linux%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%A7%E8%A6%8B%E3%81%A4%E3%81%91%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%3A%20%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fnxp-qoriq%2Flinux.git%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fnxp-qoriq%2Flinux.git%3C%2FA%3E%3C%2FP%3E%3CP%3E%E6%94%AF%E5%BA%97LF-6.6.Y%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%BE%E3%81%9F%E3%80%81%E7%A7%81%E3%81%AF%E8%A6%8B%E3%81%A4%E3%81%91%E3%81%BE%E3%81%97%E3%81%9F%3A%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%83%BC%E3%83%80%E3%83%BC%E3%81%A8Linux%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%E3%82%82%E3%81%AE%E3%82%92%E7%A4%BA%E3%81%99%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FQorIQ%2FEval-Board-for-1000Base-KX-LS1046A%2Fm-p%2F1178936%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2FQorIQ%2FEval-Board-for-1000Base-KX-LS1046A%2Fm-p%2F1178936%3C%2FA%3E%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%97%E3%81%9F%E3%81%8C%E3%81%A3%E3%81%A6%E3%80%81%E6%AC%A1%E3%81%AE%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E1.%E3%82%A2%E3%83%83%E3%83%97%E3%82%B9%E3%83%88%E3%83%AA%E3%83%BC%E3%83%A0%E3%81%AE%20Linux%20%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%AF%E3%80%81LS1046A%20%E3%81%A7%201000Base-KX%20%E3%82%84%201000Base-KR%20%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%81%AF%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E2.%E4%B8%8A%E8%A8%98%E3%81%AE%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%AB%E3%81%AF%E3%80%81SGMII_IF_MODE%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E8%A8%98%E8%BC%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82Linux%E3%81%AE%E3%81%A9%E3%81%AE%E9%83%A8%E5%88%86%E3%81%8C%E3%81%9D%E3%82%8C%E3%82%92%E8%A1%8C%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E3.%2010Gbase-kr%20%E3%81%A8%201000Base-KX%20%E3%81%AE%E3%83%8E%E3%83%BC%E3%83%89%E3%81%8C%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E8%A6%8B%E3%81%88%E3%82%8B%E3%81%8B%E6%95%99%E3%81%88%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E4.%20LS1046a%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E6%9C%80%E6%96%B0%E3%81%AEU-boot%20%2F%20Linux%E3%81%AF%E4%BD%95%E3%81%A7%E3%81%99%E3%81%8B%E3%80%81%E7%89%B9%E3%81%ABU-boot%E3%81%AB%E3%81%AF1000Base-kr%E3%81%8A%E3%82%88%E3%81%B31000Base-kx%E3%81%AE%E5%88%9D%E6%9C%9F%E5%8C%96%E3%82%92%E8%A1%8C%E3%81%86%E3%82%B3%E3%83%BC%E3%83%89%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E4%B8%8A%E8%A8%98%E3%81%AE%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%AFinit%E3%82%B7%E3%83%BC%E3%82%B1%E3%83%B3%E3%82%B9%E3%81%A0%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%81%9D%E3%81%86%E3%81%97%E3%81%AA%E3%81%84%E3%81%A8%E3%80%81%E3%82%A2%E3%83%83%E3%83%97%E3%82%B9%E3%83%88%E3%83%AA%E3%83%BC%E3%83%A0%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB(kernel.org)%E3%81%8C%E4%BD%BF%E3%81%88%E3%81%AA%E3%81%84%E3%81%A8%E3%81%84%E3%81%86%E3%81%AE%E3%81%8C%E9%96%93%E9%81%95%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%81%A8%E3%80%81%E7%A7%81%E3%81%8C%E3%81%97%E3%81%AA%E3%81%91%E3%82%8C%E3%81%B0%E3%81%AA%E3%82%89%E3%81%AA%E3%81%84%E3%81%93%E3%81%A8%E3%81%AE%E8%A6%81%E7%B4%84%E3%82%92%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%82%8C%E3%81%B0%E5%B9%B8%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%81%9D%E3%82%8C%E3%81%A7%E3%81%AF%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%AB%E3%83%8E%E3%83%BC%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2053239%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3ALs1046a%201000Base-KX%20%2F%2010gBase-KR%20Linux%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2053239%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%9C%80%E7%B5%82%E7%9A%84%E3%81%AB1000base-KX%E3%81%A7%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82AMP_RED%E3%83%95%E3%82%A3%E3%83%BC%E3%83%AB%E3%83%89%E3%82%92%E3%82%AF%E3%83%AA%E3%82%A2%E3%81%99%E3%82%8B%E3%81%A8%E3%81%A8%E3%82%82%E3%81%AB%E3%80%81%E3%81%95%E3%82%89%E3%81%AB%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%AE%E3%83%93%E3%83%83%E3%83%88%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2038445%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3ALs1046a%201000Base-KX%20%2F%2010gBase-KR%20Linux%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2038445%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EU-boot%E3%81%A7%E4%BD%95%E3%82%82%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%AA%E3%81%84%E3%81%A8%E5%B0%91%E3%81%97%E6%B7%B7%E4%B9%B1%E3%81%97%E3%81%BE%E3%81%99%E3%80%8231.8.1.3%E3%81%8B%E3%82%89%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%81%AF%E3%81%A9%E3%81%93%E3%81%A7%E8%A1%8C%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82U-boot%E3%81%A8Linux%E3%81%AB%E5%88%86%E3%81%8B%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%A8%E6%80%9D%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2038075%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3ALs1046a%201000Base-KX%20%2F%2010gBase-KR%20Linux%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2038075%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E10gbase-kr%20%E3%81%AB%E7%9B%AE%E3%82%92%E5%90%91%E3%81%91%E3%81%BE%E3%81%97%E3%82%87%E3%81%86%E3%80%82LANnTECR0%E3%82%92%E3%82%BB%E3%83%83%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E2%E3%81%A4%E3%81%AEDTS%E3%82%A4%E3%83%B3%E3%82%AF%E3%83%AB%E3%83%BC%E3%83%89%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3Earch%2Farm64%2Fboot%2Fdts%2Ffreescale%2Ffsl-ls1046a-sd1-1133-lane-c-backplane-phylib.dtsi%3CBR%20%2F%3Earch%2Farm64%2Fboot%2Fdts%2Ffreescale%2Ffsl-ls1046a-sd1-1133-lane-c-backplane.dtsi%3C%2FP%3E%3CP%3E%E3%81%9D%E3%82%8C%E3%82%89%E3%81%AE%E3%81%84%E3%81%9A%E3%82%8C%E3%81%8B%E3%82%92%E5%90%AB%E3%82%81%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%E3%81%BE%E3%81%9F%E3%81%AF%E3%80%81%E3%82%88%E3%82%8A%E3%82%B7%E3%83%B3%E3%83%97%E3%83%AB%E3%81%AB%E4%BF%9D%E3%81%A1%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E4%BD%95%E3%82%89%E3%81%8B%E3%81%AE%E7%90%86%E7%94%B1%E3%81%A7%E5%BE%8C%E8%80%85%E3%82%92%E5%90%AB%E3%82%81%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%AE%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2037664%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3ALs1046a%201000Base-KX%20%2F%2010gBase-KR%20Linux%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2037664%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Epcsphy4%E3%81%AF%E3%81%A9%E3%81%86%E3%81%A7%E3%81%99%E3%81%8B%3F%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%84%E3%83%AA%E3%83%BC%E3%81%AE%E4%B8%80%E9%83%A8%E3%81%AB%E4%BF%AE%E6%AD%A3%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%E3%81%8B%3F%3CBR%20%2F%3E1000Base-KX%E3%81%AF%E3%83%90%E3%83%83%E3%82%AF%E3%83%97%E3%83%AC%E3%83%BC%E3%83%B3%E3%82%92%E7%B5%8C%E7%94%B1%E3%81%97%E3%80%81%E6%AC%A1%E3%81%AB%E3%83%A1%E3%83%87%E3%82%A3%E3%82%A2%E3%82%B3%E3%83%B3%E3%83%90%E3%83%BC%E3%82%BF%E3%83%BC(1000baseT%E3%81%B8)%E3%82%92%E9%80%9A%E9%81%8E%E3%81%97%E3%81%BE%E3%81%99%E3%80%82MDIO%E3%83%90%E3%82%B9%E3%81%AF%E3%83%90%E3%83%83%E3%82%AF%E3%83%97%E3%83%AC%E3%83%BC%E3%83%B3%E7%B5%8C%E7%94%B1%E3%81%A7%E6%8E%A5%E7%B6%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2036389%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3ALs1046a%201000Base-KX%20%2F%2010gBase-KR%20Linux%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2036389%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E3%81%93%E3%82%8C%E3%81%AF%E3%80%811000Base-KX%E3%81%AE%E3%83%8E%E3%83%BC%E3%83%89%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E8%A6%8B%E3%81%9B%E3%82%8B%E6%96%B9%E6%B3%95%E3%81%AE%E4%BE%8B%E3%81%A7%E3%81%99%3CBR%20%2F%3EENET4%3A%20ethernet%404%20%7B%3CBR%20%2F%3E%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20compatible%20%3D%20%22fsl%2Cfman-memac%22%3B%3CBR%20%2F%3E%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20reg%20%3D%20%26lt%3B0x4000%200x1000%26gt%3B%3B%3CBR%20%2F%3E%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20phy-mode%20%3D%20%221000base-kx%22%3B%20%3CBR%20%2F%3E%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%E5%9B%BA%E5%AE%9A%E3%83%AA%E3%83%B3%E3%82%AF%20%3D%20%26lt%3B4%201%201000%200%200%26gt%3B%3B1%20Gbps%E3%81%B8%E3%81%AE%E5%9B%BA%E5%AE%9A%E3%83%AA%E3%83%B3%E3%82%AF%3CBR%20%2F%3E%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20status%20%3D%20%22%E5%A4%A7%E4%B8%88%E5%A4%AB%22%3B%3CBR%20%2F%3E%20%20%20%20%20%20%20%20%20%20%20%20%7D%3B%3CBR%20%2F%3E%E3%81%95%E3%82%89%E3%81%AB%E3%80%81%E3%80%8C31.8.1.31000Base-KX%E3%80%8D%E3%82%92LS1046ARM%E3%81%AB%E3%80%82%3CBR%20%2F%3ELLDP%206.1.55U-boot%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B92023.04%E3%82%92%E4%BD%BF%E7%94%A8%3CBR%20%2F%3EU-boot%E3%81%A7%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E3%82%82%E3%81%AE%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2036266%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3ALs1046a%201000Base-KX%20%2F%2010gBase-KR%20Linux%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2036266%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E1%E3%81%A82%E3%81%AE%E7%AD%94%E3%81%88%E3%81%8C%E5%87%BA%E3%81%9F%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%811000Kx%E3%81%BE%E3%81%9F%E3%81%AF10base-KR%E3%82%92%E6%A9%9F%E8%83%BD%E3%81%95%E3%81%9B%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%3C%2FP%3E%3C%2FLINGO-BODY%3E
