Layerscape LS1012A
Layerscape LS1012A
1,315 次查看
saleshin
I'm working with development board FRWY-LS1012A with board getting started guide.
I've prepared boot SD card and development board have been started with it.
Ethernet ports doesn't works, but it works only in u-boot mode.  What should i do with it.
Bootlog and u-boot logs are in attachment.
1 回复
1,292 次查看
Bio_TICFSL
For the
FRWY-LS1012A development board, the most common reason Ethernet works in U-Boot but not in Linux is a failure to load the Packet Forwarding Engine (PFE) firmware or a conflict with the PFE state between the bootloader and the kernel.
Immediate Solutions to Try
  • Stop PFE in U-Boot: Before booting Linux, you must ensure the PFE is stopped in the bootloader so the Linux driver can take control cleanly.
    • In the U-Boot prompt, run: => pfe stop
    • Then proceed with your boot command (e.g., run bootcmd).
  • Verify PFE Firmware Files: The Linux driver requires specific firmware files in your root filesystem to initialize the Ethernet ports.
    • Ensure the following file exists: /lib/firmware/ppfe_class_ls1012a.elf.
    • If missing, you may need to copy them from your SDK or download the NXP PFE firmware package.
  • Check Device Tree (FDT): Ensure your boot sequence is loading the correct Device Tree Blob (DTB) for the FRWY board specifically, as using a generic LS1012A-RDB or FRDM tree can cause interface mismatches.
    • Confirm your U-Boot fdt_addr points to fsl-ls1012a-frwy.dtb (or similar) during the booti or bootm command.
%3CLINGO-SUB%20id%3D%22lingo-sub-2340437%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%B1%82%E6%99%AF%20LS1012A%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2340437%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8%E5%B8%A6%E6%9C%89%E5%BC%80%E5%8F%91%E6%9D%BF%E5%85%A5%E9%97%A8%E6%8C%87%E5%8D%97%E7%9A%84%20FRWY-LS1012A%20%E5%BC%80%E5%8F%91%E6%9D%BF%E3%80%82%3CBR%20%2F%3E%E6%88%91%E5%B7%B2%E7%BB%8F%E5%87%86%E5%A4%87%E5%A5%BD%E4%BA%86%E5%90%AF%E5%8A%A8%20SD%20%E5%8D%A1%EF%BC%8C%E5%BC%80%E5%8F%91%E6%9D%BF%E5%B7%B2%E7%BB%8F%E5%BC%80%E5%A7%8B%E4%BD%BF%E7%94%A8%E5%AE%83%E4%BA%86%E3%80%82%3CBR%20%2F%3E%E4%BB%A5%E5%A4%AA%E7%BD%91%E7%AB%AF%E5%8F%A3%E4%B8%8D%E8%B5%B7%E4%BD%9C%E7%94%A8%EF%BC%8C%E4%BD%86%E5%8F%AA%E8%83%BD%E5%9C%A8%20u-%E5%90%AF%E5%8A%A8%20%E6%A8%A1%E5%BC%8F%E4%B8%8B%E5%B7%A5%E4%BD%9C%E3%80%82%E6%88%91%E8%AF%A5%E6%80%8E%E4%B9%88%E5%A4%84%E7%90%86%E5%AE%83%EF%BC%9F%3CBR%20%2F%3E%E5%90%AF%E5%8A%A8%E6%97%A5%E5%BF%97%E5%92%8C%20u-boot%20%E6%97%A5%E5%BF%97%E4%BD%8D%E4%BA%8E%E9%99%84%E4%BB%B6%E4%B8%AD%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2340639%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Layerscape%20LS1012A%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2340639%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3C%2FP%3E%0A%3CDIV%20class%3D%22Y3BBE%22%20data-processed%3D%22true%22%20data-complete%3D%22true%22%20data-hveid%3D%22CAEIAhAA%22%20data-sfc-cb%3D%22%22%20data-sfc-root%3D%22c%22%20data-sfc-cp%3D%22%22%3E%0A%3CDIV%20style%3D%22display%3A%20contents%3B%22%20data-processed%3D%22true%22%20data-complete%3D%22true%22%20data-sfc-cb%3D%22%22%20data-sfc-root%3D%22c%22%20data-subtree%3D%22aimfl%22%3E%E5%AF%B9%E4%BA%8E%20%3C%2FDIV%3E%0AFRWY-LS1012A%20%E5%BC%80%E5%8F%91%E6%9D%BF%EF%BC%8C%E4%BB%A5%E5%A4%AA%E7%BD%91%E5%9C%A8%20U-Boot%20%E4%B8%AD%E8%BF%90%E8%A1%8C%E4%BD%86%E5%9C%A8%20Linux%20%E4%B8%AD%E6%97%A0%E6%B3%95%E8%BF%90%E8%A1%8C%E7%9A%84%E6%9C%80%E5%B8%B8%E8%A7%81%E5%8E%9F%E5%9B%A0%E6%98%AF%E6%97%A0%E6%B3%95%E5%8A%A0%E8%BD%BD%E6%95%B0%E6%8D%AE%E5%8C%85%E8%BD%AC%E5%8F%91%E5%BC%95%E6%93%8E%20(PFE)%20%E5%9B%BA%E4%BB%B6%E6%88%96%E8%80%85%E4%B8%8E%E5%BC%95%E5%AF%BC%E5%8A%A0%E8%BD%BD%E7%A8%8B%E5%BA%8F%E5%92%8C%E5%86%85%E6%A0%B8%E4%B9%8B%E9%97%B4%E7%9A%84%20PFE%20%E7%8A%B6%E6%80%81%E5%8F%91%E7%94%9F%E5%86%B2%E7%AA%81%E3%80%82%3CSPAN%20class%3D%22uJ19be%20notranslate%22%20data-processed%3D%22true%22%20data-complete%3D%22true%22%20data-sfc-cb%3D%22%22%20data-wiz-uids%3D%22RzyiAf_k%2CRzyiAf_l%22%20data-sfc-root%3D%22c%22%3E%3CSPAN%20class%3D%22vKEkVd%22%20data-sae%3D%22%22%20data-wiz-attrbind%3D%22class%3DRzyiAf_j%2FTKHnVd%22%20data-animation-atomic%3D%22%22%3E%3CSPAN%20aria-hidden%3D%22true%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%20class%3D%22Fsg96%22%20data-processed%3D%22true%22%20data-complete%3D%22true%22%20data-sfc-cb%3D%22%22%20data-sfc-root%3D%22c%22%20data-sfc-cp%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CDIV%20class%3D%22otQkpb%22%20role%3D%22heading%22%20data-sae%3D%22%22%20data-processed%3D%22true%22%20data-complete%3D%22true%22%20data-sfc-cb%3D%22%22%20data-sfc-root%3D%22c%22%20data-sfc-cp%3D%22%22%20data-animation-nesting%3D%22%22%20aria-level%3D%223%22%3E%E5%8F%AF%E7%AB%8B%E5%8D%B3%E5%B0%9D%E8%AF%95%E7%9A%84%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%3C%2FDIV%3E%0A%3CUL%20class%3D%22KsbFXc%20U6u95%22%20data-processed%3D%22true%22%20data-complete%3D%22true%22%20data-sfc-cb%3D%22%22%20data-sfc-root%3D%22c%22%3E%0A%3CLI%20class%3D%22dF3vjf%22%20data-sae%3D%22%22%20data-complete%3D%22true%22%20data-hveid%3D%22CAEIBBAA%22%20data-sfc-cb%3D%22%22%20data-sfc-root%3D%22c%22%3E%3CSPAN%20class%3D%22T286Pc%22%20data-complete%3D%22true%22%20data-sfc-cb%3D%22%22%20data-sfc-root%3D%22c%22%20data-sfc-cp%3D%22%22%3E%E5%9C%A8%20U-Boot%20%E4%B8%AD%E5%81%9C%E6%AD%A2%20PFE%EF%BC%9A%E5%9C%A8%E5%90%AF%E5%8A%A8%20Linux%20%E4%B9%8B%E5%89%8D%EF%BC%8C%E5%BF%85%E9%A1%BB%E7%A1%AE%E4%BF%9D%E5%9C%A8%E5%BC%95%E5%AF%BC%E5%8A%A0%E8%BD%BD%E7%A8%8B%E5%BA%8F%E4%B8%AD%E5%81%9C%E6%AD%A2%20PFE%EF%BC%8C%E8%BF%99%E6%A0%B7%20Linux%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E6%89%8D%E8%83%BD%E5%AE%8C%E5%85%A8%E6%8E%A7%E5%88%B6%E5%B1%80%E9%9D%A2%E3%80%82%3C%2FSPAN%3E%0A%3CUL%20class%3D%22KsbFXc%20U6u95%22%20data-complete%3D%22true%22%20data-sfc-cb%3D%22%22%20data-sfc-root%3D%22c%22%3E%0A%3CLI%20class%3D%22dF3vjf%22%20data-sae%3D%22%22%20data-complete%3D%22true%22%20data-hveid%3D%22CAEIBBAB%22%20data-sfc-cb%3D%22%22%20data-sfc-root%3D%22c%22%3E%3CSPAN%20class%3D%22T286Pc%22%20data-complete%3D%22true%22%20data-sfc-cb%3D%22%22%20data-sfc-root%3D%22c%22%20data-sfc-cp%3D%22%22%3E%E5%9C%A8%20U-Boot%20%E6%8F%90%E7%A4%BA%E7%AC%A6%E4%B8%8B%EF%BC%8C%E8%BF%90%E8%A1%8C%EF%BC%9A%3CCODE%20class%3D%22o8j0Mc%22%20dir%3D%22ltr%22%20data-sae%3D%22%22%20data-complete%3D%22true%22%20data-sfc-cb%3D%22%22%20data-sfc-root%3D%22c%22%3E%3D%20%26gt%3B%20p%3C%2FCODE%3E%20fe%20stop%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%20class%3D%22dF3vjf%22%20data-sae%3D%22%22%20data-complete%3D%22true%22%20data-hveid%3D%22CAEIBBAC%22%20data-sfc-cb%3D%22%22%20data-sfc-root%3D%22c%22%3E%3CSPAN%20class%3D%22T286Pc%22%20data-complete%3D%22true%22%20data-sfc-cb%3D%22%22%20data-sfc-root%3D%22c%22%20data-sfc-cp%3D%22%22%3E%E7%84%B6%E5%90%8E%E7%BB%A7%E7%BB%AD%E6%89%A7%E8%A1%8C%E5%90%AF%E5%8A%A8%E5%91%BD%E4%BB%A4%EF%BC%88%E4%BE%8B%E5%A6%82%EF%BC%8C%3CCODE%20class%3D%22o8j0Mc%22%20dir%3D%22ltr%22%20data-sae%3D%22%22%20data-complete%3D%22true%22%20data-sfc-cb%3D%22%22%20data-sfc-root%3D%22c%22%3E%E8%BF%90%E8%A1%8C%20bootcmd%3C%2FCODE%3E%EF%BC%89%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3C%2FLI%3E%0A%3CLI%20class%3D%22dF3vjf%22%20data-sae%3D%22%22%20data-complete%3D%22true%22%20data-hveid%3D%22CAEIBBAD%22%20data-sfc-cb%3D%22%22%20data-sfc-root%3D%22c%22%3E%3CSPAN%20class%3D%22T286Pc%22%20data-complete%3D%22true%22%20data-sfc-cb%3D%22%22%20data-sfc-root%3D%22c%22%20data-sfc-cp%3D%22%22%3E%E9%AA%8C%E8%AF%81%20PFE%20%E5%9B%BA%E4%BB%B6%E6%96%87%E4%BB%B6%EF%BC%9ALinux%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E9%9C%80%E8%A6%81%E6%A0%B9%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%E4%B8%AD%E7%9A%84%E7%89%B9%E5%AE%9A%E5%9B%BA%E4%BB%B6%E6%96%87%E4%BB%B6%E6%9D%A5%E5%88%9D%E5%A7%8B%E5%8C%96%E4%BB%A5%E5%A4%AA%E7%BD%91%E7%AB%AF%E5%8F%A3%E3%80%82%3C%2FSPAN%3E%0A%3CUL%20class%3D%22KsbFXc%20U6u95%22%20data-complete%3D%22true%22%20data-sfc-cb%3D%22%22%20data-sfc-root%3D%22c%22%3E%0A%3CLI%20class%3D%22dF3vjf%22%20data-sae%3D%22%22%20data-complete%3D%22true%22%20data-hveid%3D%22CAEIBBAE%22%20data-sfc-cb%3D%22%22%20data-sfc-root%3D%22c%22%3E%3CSPAN%20class%3D%22T286Pc%22%20data-complete%3D%22true%22%20data-sfc-cb%3D%22%22%20data-sfc-root%3D%22c%22%20data-sfc-cp%3D%22%22%3E%E7%A1%AE%E4%BF%9D%E5%AD%98%E5%9C%A8%E4%BB%A5%E4%B8%8B%E6%96%87%E4%BB%B6%EF%BC%9A%3CCODE%20class%3D%22o8j0Mc%22%20dir%3D%22ltr%22%20data-sae%3D%22%22%20data-complete%3D%22true%22%20data-sfc-cb%3D%22%22%20data-sfc-root%3D%22c%22%3E%2Flib%2Ffirmware%2Fppfe_class_ls1012a.elf%3C%2FCODE%3E%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%20class%3D%22dF3vjf%22%20data-sae%3D%22%22%20data-complete%3D%22true%22%20data-hveid%3D%22CAEIBBAF%22%20data-sfc-cb%3D%22%22%20data-sfc-root%3D%22c%22%3E%3CSPAN%20class%3D%22T286Pc%22%20data-complete%3D%22true%22%20data-sfc-cb%3D%22%22%20data-sfc-root%3D%22c%22%20data-sfc-cp%3D%22%22%3E%E5%A6%82%E6%9E%9C%E7%BC%BA%E5%A4%B1%EF%BC%8C%E6%82%A8%E5%8F%AF%E8%83%BD%E9%9C%80%E8%A6%81%E4%BB%8ESDK%E4%B8%AD%E5%A4%8D%E5%88%B6%E5%AE%83%E4%BB%AC%E6%88%96%E4%B8%8B%E8%BD%BD%E6%81%A9%E6%99%BA%E6%B5%A6PFE%E5%9B%BA%E4%BB%B6%E5%8C%85%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3C%2FLI%3E%0A%3CLI%20class%3D%22dF3vjf%22%20data-sae%3D%22%22%20data-complete%3D%22true%22%20data-hveid%3D%22CAEIBBAG%22%20data-sfc-cb%3D%22%22%20data-sfc-root%3D%22c%22%3E%3CSPAN%20class%3D%22T286Pc%22%20data-complete%3D%22true%22%20data-sfc-cb%3D%22%22%20data-sfc-root%3D%22c%22%20data-sfc-cp%3D%22%22%3E%E6%A3%80%E6%9F%A5%E8%AE%BE%E5%A4%87%E6%A0%91%20(FDT)%EF%BC%9A%E7%A1%AE%E4%BF%9D%E6%82%A8%E7%9A%84%E5%90%AF%E5%8A%A8%E9%A1%BA%E5%BA%8F%E5%8A%A0%E8%BD%BD%E7%9A%84%E6%98%AF%E9%92%88%E5%AF%B9%20FRWY%20%E4%B8%BB%E6%9D%BF%E7%9A%84%E6%AD%A3%E7%A1%AE%E8%AE%BE%E5%A4%87%E6%A0%91%20Blob%20(DTB)%EF%BC%8C%E5%9B%A0%E4%B8%BA%E4%BD%BF%E7%94%A8%E9%80%9A%E7%94%A8%20LS1012A-RDB%20%E6%88%96%20FRDM%20%E6%A0%91%E5%8F%AF%E8%83%BD%E4%BC%9A%E5%AF%BC%E8%87%B4%E6%8E%A5%E5%8F%A3%E4%B8%8D%E5%8C%B9%E9%85%8D%E3%80%82%3C%2FSPAN%3E%0A%3CUL%20class%3D%22KsbFXc%20U6u95%22%20data-complete%3D%22true%22%20data-sfc-cb%3D%22%22%20data-sfc-root%3D%22c%22%3E%0A%3CLI%20class%3D%22dF3vjf%22%20data-sae%3D%22%22%20data-complete%3D%22true%22%20data-hveid%3D%22CAEIBBAH%22%20data-sfc-cb%3D%22%22%20data-sfc-root%3D%22c%22%3E%3CSPAN%20class%3D%22T286Pc%22%20data-complete%3D%22true%22%20data-sfc-cb%3D%22%22%20data-sfc-root%3D%22c%22%20data-sfc-cp%3D%22%22%3E%3CCODE%20class%3D%22o8j0Mc%22%20dir%3D%22ltr%22%20data-sae%3D%22%22%20data-complete%3D%22true%22%20data-sfc-cb%3D%22%22%20data-sfc-root%3D%22c%22%3E%E5%9C%A8%E6%89%A7%E8%A1%8C%20booti%3C%2FCODE%3E%20%E6%88%96%3CCODE%20class%3D%22o8j0Mc%22%20dir%3D%22ltr%22%20data-sae%3D%22%22%20data-complete%3D%22true%22%20data-sfc-cb%3D%22%22%20data-sfc-root%3D%22c%22%3E%20bootm%3C%2FCODE%3E%20%E5%91%BD%E4%BB%A4%E6%9C%9F%E9%97%B4%EF%BC%8C%E7%A1%AE%E8%AE%A4%E4%BD%A0%E7%9A%84%20U-Boot%3CCODE%20class%3D%22o8j0Mc%22%20dir%3D%22ltr%22%20data-sae%3D%22%22%20data-complete%3D%22true%22%20data-sfc-cb%3D%22%22%20data-sfc-root%3D%22c%22%3E%20fdt_addr%3C%2FCODE%3E%20%E6%8C%87%E5%90%91%3CCODE%20class%3D%22o8j0Mc%22%20dir%3D%22ltr%22%20data-sae%3D%22%22%20data-complete%3D%22true%22%20data-sfc-cb%3D%22%22%20data-sfc-root%3D%22c%22%3E%20fsl-ls1012a-fr%20wy.dtb%EF%BC%88%E6%88%96%E7%B1%BB%E4%BC%BC%E7%89%88%E6%9C%AC%EF%BC%89%E3%80%82%3C%2FCODE%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22uJ19be%20notranslate%22%20data-complete%3D%22true%22%20data-sfc-cb%3D%22%22%20data-wiz-uids%3D%22RzyiAf_1q%2CRzyiAf_1r%22%20data-sfc-root%3D%22c%22%3E%3CSPAN%20class%3D%22vKEkVd%22%20data-sae%3D%22%22%20data-wiz-attrbind%3D%22class%3DRzyiAf_1p%2FTKHnVd%22%20data-animation-atomic%3D%22%22%3E%3CSPAN%20aria-hidden%3D%22true%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CDIV%20class%3D%22Fsg96%22%20data-processed%3D%22true%22%20data-complete%3D%22true%22%20data-sfc-cb%3D%22%22%20data-sfc-root%3D%22c%22%20data-sfc-cp%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CDIV%20class%3D%22Y3BBE%22%20data-processed%3D%22true%22%20data-complete%3D%22true%22%20data-hveid%3D%22CAEICBAA%22%20data-sfc-cb%3D%22%22%20data-sfc-root%3D%22c%22%20data-sfc-cp%3D%22%22%3E%E6%AD%A4%E8%87%B4%3C%2FDIV%3E%3C%2FLINGO-BODY%3E
