LX2160A Power Integrity (PI) analysis
981件の閲覧回数
kurokawa
Dear Experts
We are currently proceeding with a PCB design using the LX2160A and are planning to perform Power Integrity (PI) analysis.
Could you kindly provide guidance on the following items for setting up appropriate analysis conditions?
1. Recommended target impedance for each power rail
2. Assumed maximum transient current (di/dt) conditions for analysis
Additionally, if there are any recommended PI analysis tools or methodologies, we would appreciate your advice.
Thank you for your support, and we look forward to your response.
819件の閲覧回数
yipingwang
1. Power Rails Overview (LX2160A)
The LX2160A uses multiple independent rails for core logic, SRAM/PLL, SerDes, DDR, and I/O. The exact rail list and nominal voltages are defined in the LX2160A datasheet and reference design and should be treated as authoritative.
Typical key rails (names vary by schematics):
Rail Function Typical Nominal Voltage Notes
Core (VDD) ~0.75–0.85 V Highest di/dt, most critical for PI
Platform / Cache (VDD_PLAT) ~0.9 V Large on-die SRAM, sensitive to droop
SerDes Analog ~1.0 V Noise-sensitive, lower di/dt
SerDes Digital ~0.9 V Moderate switching activity
DDR VDD 1.2 V JEDEC-driven, external memory dominates
DDR VPP 2.5 V Low-current
I/O (VDD_IO) 1.8 V / 3.3 V Lowest PI criticality
2. Recommended Target Impedance (Z_TARGET)
Since LX2160A does not publish explicit Z targets, the standard voltage ripple-based method is used:
Ztarget=ΔVallowableΔImaxZ_{target} = \frac{\Delta V_{allowable}}{\Delta I_{max}}
NXP generally recommends ≤ 3–5% ripple on core-type rails for Layerscape devices (derived from design checklists and reference boards). [static.chipdip.ru], [community.nxp.com]
Practical Target Impedance Values
Rail Allowable Ripple Estimated ΔI Recommended Z_TARGET
Core (VDD) ±3% (≈25 mV) 8–12 A 2–3 mΩ
Platform / SRAM ±3% (≈30 mV) 4–6 A 5–8 mΩ
SerDes Digital ±5% 1–2 A 25–40 mΩ
SerDes Analog ±5% <1 A >50 mΩ
DDR VDD JEDEC 3–5 A 20–30 mΩ
I/O Rails ±5–10% <2 A >50 mΩ
Key point:
Only the core and SRAM rails require very aggressive PDN design down into the low milliohm range.
3. Transient Current / di/dt Assumptions
Core Rail (Critical)
For PI simulation, worst-case transient assumptions are typically:
  • ΔI step: 5–8 A
  • Edge rate: 1–5 ns
  • di/dt: 1–5 A/ns
These represent:
  • Simultaneous switching of multiple Cortex-A72 cores
  • Cache + datapath accelerator activity (DPAA2, DCE, SEC)
This aligns with how NXP reference boards and design checklists size bulk + high-frequency decoupling. [static.chipdip.ru], [community.nxp.com]
Other Rails
Rail ΔI Assumption di/dt
Platform / SRAM 2–4 A 0.5–1 A/ns
SerDes Digital 0.5–1 A 0.1–0.3 A/ns
DDR VDD Governed by JEDEC burst Slower, regulator-dominated
I/O <0.5 A Very low
4. Frequency Range to Analyze
For LX2160A, PI analysis should cover:
  • DC → 100 MHz (minimum)
  • Up to 300–500 MHz recommended for core rails due to on-die L/C effects
Below ~1 MHz:
Dominated by VRM and bulk capacitors
1–100 MHz:
Board-level MLCCs + planes
100 MHz:
On-package + on-die capacitance (model using package S-parameters if available)
5. Decoupling Strategy (Reference-Based)
NXP reference designs show a three-tier approach:
  1. Bulk
    • 47–330 µF polymer or tantalum per core rail
  2. Mid-frequency MLCCs
    • 1–10 µF, X7R, distributed across package perimeter
  3. High-frequency MLCCs
    • 0.01–0.1 µF directly under BGA
This approach is consistent with Layerscape RDB layouts. [static.chipdip.ru]
6. Recommended PI Tools
Widely used tools that work well for LX2160A-class SoCs:
Simulation
  • Cadence Sigrity PowerSI
  • Ansys SIwave
  • Keysight PIPro
  • Altium PDN Analyzer (early-stage checks)
Measurement (Post-silicon)
  • VNA-based PDN impedance measurement (2-port shunt-through)
  • High-bandwidth probing at BGA breakout test points
7. Methodology Summary (Best Practice)
  1. Start with Z_TARGET-based PDN design
  2. Build sweep impedance plot (log-log)
  3. Eliminate anti-resonance peaks below Z_TARGET
  4. Validate with:
    • Worst-case current step
    • Load-transient simulation
  5. Correlate against RDB behavior where possible
8. NXP-Specific Recommendation
NXP explicitly recommends reviewing AN5407 – LX2160A/LX2162A Design Checklist, which includes power use cases and rail current guidance used internally for PDN sizing. [community.nxp.com]
If you have access to NXP Premium Support, you can also request:
  • Rail-by-rail worst-case current tables
  • Package PDN models (where available)
%3CLINGO-SUB%20id%3D%22lingo-sub-2349052%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ELX2160A%20%E9%9B%BB%E6%BA%90%E3%82%A4%E3%83%B3%E3%83%86%E3%82%B0%E3%83%AA%E3%83%86%E3%82%A3%20(PI)%20%E8%A7%A3%E6%9E%90%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2349052%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%B0%82%E9%96%80%E5%AE%B6%E3%81%AE%E7%9A%86%E6%A7%98%E3%81%B8%3C%2FP%3E%3CP%3E%E7%8F%BE%E5%9C%A8%E3%80%81LX2160A%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9FPCB%E8%A8%AD%E8%A8%88%E3%82%92%E9%80%B2%E3%82%81%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81%E9%9B%BB%E6%BA%90%E3%82%A4%E3%83%B3%E3%83%86%E3%82%B0%E3%83%AA%E3%83%86%E3%82%A3%EF%BC%88PI%EF%BC%89%E8%A7%A3%E6%9E%90%E3%82%92%E5%AE%9F%E6%96%BD%E3%81%99%E3%82%8B%E4%BA%88%E5%AE%9A%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E9%81%A9%E5%88%87%E3%81%AA%E5%88%86%E6%9E%90%E6%9D%A1%E4%BB%B6%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%80%81%E4%BB%A5%E4%B8%8B%E3%81%AE%E9%A0%85%E7%9B%AE%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%94%E6%8C%87%E5%B0%8E%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%EF%BC%9F%3C%2FP%3E%3CP%3E1.%20%E5%90%84%E9%9B%BB%E6%BA%90%E3%83%AC%E3%83%BC%E3%83%AB%E3%81%AB%E3%81%8A%E3%81%91%E3%82%8B%E6%8E%A8%E5%A5%A8%E7%9B%AE%E6%A8%99%E3%82%A4%E3%83%B3%E3%83%94%E3%83%BC%E3%83%80%E3%83%B3%E3%82%B9%3CBR%20%2F%3E2.%20%E8%A7%A3%E6%9E%90%E3%81%AB%E3%81%8A%E3%81%91%E3%82%8B%E6%83%B3%E5%AE%9A%E6%9C%80%E5%A4%A7%E9%81%8E%E6%B8%A1%E9%9B%BB%E6%B5%81%EF%BC%88di%2Fdt%EF%BC%89%E6%9D%A1%E4%BB%B6%3C%2FP%3E%3CP%3E%E3%81%BE%E3%81%9F%E3%80%81%E6%8E%A8%E5%A5%A8%E3%81%95%E3%82%8C%E3%82%8BPI%E5%88%86%E6%9E%90%E3%83%84%E3%83%BC%E3%83%AB%E3%82%84%E6%89%8B%E6%B3%95%E3%81%8C%E3%81%82%E3%82%8C%E3%81%B0%E3%80%81%E3%81%9C%E3%81%B2%E3%81%94%E6%95%99%E7%A4%BA%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%82%8C%E3%81%B0%E5%B9%B8%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%94%E8%BF%94%E4%BF%A1%E3%82%92%E3%81%8A%E5%BE%85%E3%81%A1%E3%81%97%E3%81%A6%E3%81%8A%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2355601%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LX2160A%20Power%20Integrity%20(PI)%20analysis%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2355601%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CDIV%3E%0A%3CH2%20id%3D%22toc-hId--466932074%22%20id%3D%22toc-hId--467735435%22%3E1.%20%E9%9B%BB%E6%BA%90%E3%83%AC%E3%83%BC%E3%83%AB%E6%A6%82%E8%A6%81%EF%BC%88LX2160A%EF%BC%89%3C%2FH2%3E%0A%3CP%3ELX2160A%E3%81%AF%E3%80%81%E3%82%B3%E3%82%A2%E3%83%AD%E3%82%B8%E3%83%83%E3%82%AF%E3%80%81SRAM%2FPLL%E3%80%81SerDes%E3%80%81DDR%E3%80%81%E3%81%8A%E3%82%88%E3%81%B3I%2FO%E7%94%A8%E3%81%AB%3CSTRONG%3E%E8%A4%87%E6%95%B0%E3%81%AE%E7%8B%AC%E7%AB%8B%E3%81%97%E3%81%9F%E9%9B%BB%E6%BA%90%E3%83%AC%E3%83%BC%E3%83%AB%3C%2FSTRONG%3E%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E6%AD%A3%E7%A2%BA%E3%81%AA%E3%83%AC%E3%83%BC%E3%83%AB%E3%83%AA%E3%82%B9%E3%83%88%E3%81%A8%E5%85%AC%E7%A7%B0%E9%9B%BB%E5%9C%A7%E3%81%AF%E3%80%81%20%3CSTRONG%3ELX2160A%E3%81%AE%E3%83%87%E3%83%BC%E3%82%BF%E3%82%B7%E3%83%BC%E3%83%88%E3%81%8A%E3%82%88%E3%81%B3%E3%83%AA%E3%83%95%E3%82%A1%E3%83%AC%E3%83%B3%E3%82%B9%E3%83%87%E3%82%B6%E3%82%A4%E3%83%B3%3C%2FSTRONG%3E%E3%81%AB%E5%AE%9A%E7%BE%A9%E3%81%95%E3%82%8C%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81%E3%81%9D%E3%82%8C%E3%82%89%E3%81%8C%E6%AD%A3%E5%BC%8F%E3%81%AA%E6%83%85%E5%A0%B1%E3%81%A8%E3%81%97%E3%81%A6%E6%89%B1%E3%82%8F%E3%82%8C%E3%82%8B%E3%81%B9%E3%81%8D%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%85%B8%E5%9E%8B%E7%9A%84%E3%81%AA%E3%82%AD%E3%83%BC%E3%83%AC%E3%83%BC%E3%83%AB%EF%BC%88%E5%90%8D%E7%A7%B0%E3%81%AF%E5%9B%9E%E8%B7%AF%E5%9B%B3%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E7%95%B0%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%EF%BC%89%EF%BC%9A%3C%2FP%3E%0A%3CDIV%20class%3D%22___i31lg00%20f10pi13n%20f14t3ns0%20f1nbblvp%20fat0sn4%20f1ov4xf1%20fekwl8i%20f1lmfglv%20f1oz7aqm%20f1abmfm4%20f1w619qj%20f16h0jq8%22%3E%0A%3CTABLE%20class%3D%22___1hm93bs%20f1ddd56o%20f16vktn6%20f1enuhaj%20fdclmfp%20f1ev3kgc%20ftgm304%20f1uinfot%20fibjyge%20fvueend%20f9yszdx%20f1fu4s3n%20f3l3pb3%20f1s2k7dp%20f8fmt76%20fjvbh62%20fysh76l%20fic4ptz%20f1yenhzu%20f1yn6nvh%20f14tj6oe%20f1jq587y%20f1el8yx3%20f1pymoxg%20f1ofu761%20fe6itr%20f7coize%20f1794535%20f70r78m%20f4zgifc%20fk1v6el%20f16pyhcb%20fo436u6%20fzy4j18%20fc43013%20f1hmrcvb%20fc4t9fq%20fgp09rh%20fjnyn6r%22%3E%0A%3CTBODY%3E%0A%3CTR%3E%0A%3CTH%3E%E3%83%AC%E3%83%BC%E3%83%AB%E6%A9%9F%E8%83%BD%3C%2FTH%3E%0A%3CTH%3E%E6%A8%99%E6%BA%96%E5%AE%9A%E6%A0%BC%E9%9B%BB%E5%9C%A7%3C%2FTH%3E%0A%3CTH%3E%E5%82%99%E8%80%83%3C%2FTH%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%3E%E3%82%B3%E3%82%A2%EF%BC%88VDD%EF%BC%89%3C%2FTD%3E%0A%3CTD%3E%E7%B4%840.75%EF%BD%9E0.85V%3C%2FTD%3E%0A%3CTD%3Edi%2Fdt%E3%81%8C%E6%9C%80%E3%82%82%E9%AB%98%E3%81%8F%E3%80%81PI%E3%81%AB%E3%81%A8%E3%81%A3%E3%81%A6%E6%9C%80%E3%82%82%E9%87%8D%E8%A6%81%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%EF%BC%8F%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%EF%BC%88VDD_PLAT%EF%BC%89%3C%2FTD%3E%0A%3CTD%3E%E7%B4%840.9V%3C%2FTD%3E%0A%3CTD%3E%E5%A4%A7%E5%AE%B9%E9%87%8F%E3%82%AA%E3%83%B3%E3%83%80%E3%82%A4SRAM%E3%80%81%E5%9E%82%E4%B8%8B%E7%8F%BE%E8%B1%A1%E3%81%AB%E6%95%8F%E6%84%9F%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%3ESerDes%E3%82%A2%E3%83%8A%E3%83%AD%E3%82%B0%3C%2FTD%3E%0A%3CTD%3E%E7%B4%841.0V%3C%2FTD%3E%0A%3CTD%3E%E3%83%8E%E3%82%A4%E3%82%BA%E3%81%AB%E6%95%8F%E6%84%9F%E3%81%A7%E3%80%81di%2Fdt%E3%81%8C%E4%BD%8E%E3%81%84%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%3ESerDes%20Digital%3C%2FTD%3E%0A%3CTD%3E%E7%B4%840.9V%3C%2FTD%3E%0A%3CTD%3E%E9%81%A9%E5%BA%A6%E3%81%AA%E5%88%87%E3%82%8A%E6%9B%BF%E3%81%88%E6%B4%BB%E5%8B%95%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%3EDDR%20VDD%3C%2FTD%3E%0A%3CTD%3E1.2%20V%3C%2FTD%3E%0A%3CTD%3EJEDEC%E4%B8%BB%E5%B0%8E%E3%81%AE%E5%A4%96%E9%83%A8%E3%83%A1%E3%83%A2%E3%83%AA%E3%81%8C%E4%B8%BB%E6%B5%81%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%3EDDR%20VPP%3C%2FTD%3E%0A%3CTD%3E2.5V%3C%2FTD%3E%0A%3CTD%3E%E4%BD%8E%E9%9B%BB%E6%B5%81%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%3E%E5%85%A5%E5%87%BA%E5%8A%9B%EF%BC%88VDD_IO%EF%BC%89%3C%2FTD%3E%0A%3CTD%3E1.8V%20%2F%203.3V%3C%2FTD%3E%0A%3CTD%3EPI%E3%81%AE%E8%87%A8%E7%95%8C%E5%80%A4%E3%81%8C%E6%9C%80%E3%82%82%E4%BD%8E%E3%81%84%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3C%2FTBODY%3E%0A%3C%2FTABLE%3E%0A%3C%2FDIV%3E%0A%3CHR%20%2F%3E%0A%3CH2%20id%3D%22toc-hId-2020580759%22%20id%3D%22toc-hId-2019777398%22%3E2.%20%E6%8E%A8%E5%A5%A8%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E3%82%A4%E3%83%B3%E3%83%94%E3%83%BC%E3%83%80%E3%83%B3%E3%82%B9%EF%BC%88Z_TARGET%EF%BC%89%3C%2FH2%3E%0A%3CP%3ELX2160A%E3%81%AF%3CSTRONG%3E%E6%98%8E%E7%A4%BA%E7%9A%84%E3%81%AAZ%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E5%80%A4%E3%82%92%E5%85%AC%E8%A1%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%3C%2FSTRONG%3E%E3%81%9F%E3%82%81%E3%80%81%E6%A8%99%E6%BA%96%E7%9A%84%E3%81%AA%3CSTRONG%3E%E9%9B%BB%E5%9C%A7%E3%83%AA%E3%83%83%E3%83%97%E3%83%AB%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%8F%E6%96%B9%E6%B3%95%3C%2FSTRONG%3E%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%80%82%3C%2FP%3E%0A%3CDIV%20class%3D%22math%20math-display%22%3E%3CSPAN%20class%3D%22katex-display%22%3E%3CSPAN%20class%3D%22katex%22%3E%3CSPAN%20class%3D%22katex-mathml%22%3EZtarget%3D%CE%94Vallowable%CE%94ImaxZ_%7Btarget%7D%20%3D%20%5Cfrac%7B%5CDelta%20V_%7Ballowable%7D%7D%7B%5CDelta%20I_%7Bmax%7D%7D%3C%2FSPAN%3E%3CSPAN%20class%3D%22katex-html%22%20aria-hidden%3D%22true%22%3E%3CSPAN%20class%3D%22base%22%3E%3CSPAN%20class%3D%22mord%22%3E%3CSPAN%20class%3D%22mord%20mathnormal%22%3E%20Z%3C%2FSPAN%3E%3CSPAN%20class%3D%22msupsub%22%3E%3CSPAN%20class%3D%22vlist-t%20vlist-t2%22%3E%3CSPAN%20class%3D%22vlist-r%22%3E%3CSPAN%20class%3D%22vlist%22%3E%3CSPAN%3E%3CSPAN%20class%3D%22sizing%20reset-size6%20size3%20mtight%22%3E%3CSPAN%20class%3D%22mord%20mtight%22%3E%3CSPAN%20class%3D%22mord%20mathnormal%20mtight%22%3E%20t%3C%2FSPAN%3E%3CSPAN%20class%3D%22mord%20mathnormal%20mtight%22%3E%20a%3C%2FSPAN%3E%3CSPAN%20class%3D%22mord%20mathnormal%20mtight%22%3E%20r%3C%2FSPAN%3E%3CSPAN%20class%3D%22mord%20mathnormal%20mtight%22%3E%20g%3C%2FSPAN%3E%3CSPAN%20class%3D%22mord%20mathnormal%20mtight%22%3E%20e%3C%2FSPAN%3E%3CSPAN%20class%3D%22mord%20mathnormal%20mtight%22%3E%20t%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22vlist-s%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22mrel%22%3E%20%3D%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22base%22%3E%3CSPAN%20class%3D%22mord%22%3E%3CSPAN%20class%3D%22mfrac%22%3E%3CSPAN%20class%3D%22vlist-t%20vlist-t2%22%3E%3CSPAN%20class%3D%22vlist-r%22%3E%3CSPAN%20class%3D%22vlist%22%3E%3CSPAN%3E%20%CE%94%3CSPAN%20class%3D%22mord%20mathnormal%22%3E%20I%3C%2FSPAN%3E%3CSPAN%20class%3D%22msupsub%22%3E%3CSPAN%20class%3D%22sizing%20reset-size6%20size3%20mtight%22%3E%3CSPAN%20class%3D%22mord%20mtight%22%3E%3CSPAN%20class%3D%22mord%20mathnormal%20mtight%22%3E%20m%3C%2FSPAN%3E%3CSPAN%20class%3D%22mord%20mathnormal%20mtight%22%3E%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22vlist-s%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%3Ea%20x%20%CE%94%3CSPAN%20class%3D%22mord%20mathnormal%22%3E%20V%3C%2FSPAN%3E%3CSPAN%20class%3D%22msupsub%22%3E%3CSPAN%20class%3D%22sizing%20reset-size6%20size3%20mtight%22%3E%3CSPAN%20class%3D%22mord%20mtight%22%3E%3CSPAN%20class%3D%22mord%20mathnormal%20mtight%22%3E%20a%3C%2FSPAN%3E%3CSPAN%20class%3D%22mord%20mathnormal%20mtight%22%3E%20l%3C%2FSPAN%3E%3CSPAN%20class%3D%22mord%20mathnormal%20mtight%22%3E%20l%3C%2FSPAN%3E%3CSPAN%20class%3D%22mord%20mathnormal%20mtight%22%3E%20o%3C%2FSPAN%3E%3CSPAN%20class%3D%22mord%20mathnormal%20mtight%22%3E%20w%3C%2FSPAN%3E%3CSPAN%20class%3D%22mord%20mathnormal%20mtight%22%3E%20a%20b%3C%2FSPAN%3E%3CSPAN%20class%3D%22mord%20mathnormal%20mtight%22%3E%20l%3C%2FSPAN%3E%3CSPAN%20class%3D%22mord%20mathnormal%20mtight%22%3E%20e%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22vlist-s%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22vlist-s%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CP%3ENXP%E3%81%AF%E4%B8%80%E8%88%AC%E7%9A%84%E3%81%AB%E3%80%81Layerscape%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AE%E3%82%B3%E3%82%A2%E5%9E%8B%E9%9B%BB%E6%BA%90%E3%83%AC%E3%83%BC%E3%83%AB%E3%81%AB%E3%81%8A%E3%81%91%E3%82%8B%3CSTRONG%3E%E3%83%AA%E3%83%83%E3%83%97%E3%83%AB%E7%8E%87%E3%82%923%EF%BD%9E5%25%E4%BB%A5%E4%B8%8B%E3%81%AB%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%3C%2FSTRONG%3E%E3%82%92%E6%8E%A8%E5%A5%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%EF%BC%88%E8%A8%AD%E8%A8%88%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%83%AA%E3%82%B9%E3%83%88%E3%81%8A%E3%82%88%E3%81%B3%E3%83%AA%E3%83%95%E3%82%A1%E3%83%AC%E3%83%B3%E3%82%B9%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%8F%EF%BC%89%E3%80%82%3CA%20href%3D%22https%3A%2F%2Fstatic.chipdip.ru%2Flib%2F001%2FDOC013001682.pdf%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%5Bstatic.chipdip.ru%5D%3C%2FA%3E%20%E3%80%81%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FLayerscape%2Fnquiry-Regarding-Power-Consumption-of-NXP-LX2160A-Processor%2Fm-p%2F1828705%22%20target%3D%22_blank%22%3E%5Bcommunity.nxp.com%5D%3C%2FA%3E%3C%2FP%3E%0A%3CH3%20id%3D%22toc-hId--1583825063%22%20id%3D%22toc-hId--1584628424%22%3E%E5%AE%9F%E7%94%A8%E7%9A%84%E3%81%AA%E7%9B%AE%E6%A8%99%E3%82%A4%E3%83%B3%E3%83%94%E3%83%BC%E3%83%80%E3%83%B3%E3%82%B9%E5%80%A4%3C%2FH3%3E%0A%3CDIV%20class%3D%22___i31lg00%20f10pi13n%20f14t3ns0%20f1nbblvp%20fat0sn4%20f1ov4xf1%20fekwl8i%20f1lmfglv%20f1oz7aqm%20f1abmfm4%20f1w619qj%20f16h0jq8%22%3E%0A%3CTABLE%20class%3D%22___1hm93bs%20f1ddd56o%20f16vktn6%20f1enuhaj%20fdclmfp%20f1ev3kgc%20ftgm304%20f1uinfot%20fibjyge%20fvueend%20f9yszdx%20f1fu4s3n%20f3l3pb3%20f1s2k7dp%20f8fmt76%20fjvbh62%20fysh76l%20fic4ptz%20f1yenhzu%20f1yn6nvh%20f14tj6oe%20f1jq587y%20f1el8yx3%20f1pymoxg%20f1ofu761%20fe6itr%20f7coize%20f1794535%20f70r78m%20f4zgifc%20fk1v6el%20f16pyhcb%20fo436u6%20fzy4j18%20fc43013%20f1hmrcvb%20fc4t9fq%20fgp09rh%20fjnyn6r%22%20tabindex%3D%220%22%3E%0A%3CTBODY%3E%0A%3CTR%3E%0A%3CTH%3E%E3%83%AC%E3%83%BC%E3%83%AB%3C%2FTH%3E%0A%3CTH%3E%E8%A8%B1%E5%AE%B9%E3%83%AA%E3%83%83%E3%83%97%E3%83%AB%3C%2FTH%3E%0A%3CTH%3E%E6%8E%A8%E5%AE%9A%CE%94I%3C%2FTH%3E%0A%3CTH%3E%E6%8E%A8%E5%A5%A8Z_TARGET%3C%2FTH%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTH%20scope%3D%22row%22%3E%3CSTRONG%3E%E3%82%B3%E3%82%A2%EF%BC%88VDD%EF%BC%89%3C%2FSTRONG%3E%3C%2FTH%3E%0A%3CTD%3E%C2%B13%25%EF%BC%88%E7%B4%8425mV%EF%BC%89%3C%2FTD%3E%0A%3CTD%3E8%EF%BD%9E12%E6%AD%B3%3C%2FTD%3E%0A%3CTD%3E%3CSTRONG%3E2%EF%BD%9E3%20m%CE%A9%3C%2FSTRONG%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%EF%BC%8FSRAM%3C%2FTD%3E%0A%3CTD%3E%C2%B13%25%EF%BC%88%E7%B4%8430mV%EF%BC%89%3C%2FTD%3E%0A%3CTD%3E4%EF%BD%9E6%20A%3C%2FTD%3E%0A%3CTD%3E%3CSTRONG%3E5%EF%BD%9E8%20m%CE%A9%3C%2FSTRONG%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%3ESerDes%20Digital%3C%2FTD%3E%0A%3CTD%3E%C2%B15%25%3C%2FTD%3E%0A%3CTD%3E1%EF%BD%9E2%20A%3C%2FTD%3E%0A%3CTD%3E%3CSTRONG%3E25%EF%BD%9E40%20m%CE%A9%3C%2FSTRONG%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%3ESerDes%E3%82%A2%E3%83%8A%E3%83%AD%E3%82%B0%3C%2FTD%3E%0A%3CTD%3E%C2%B15%25%3C%2FTD%3E%0A%3CTD%3E%26lt%3B1%20A%3C%2FTD%3E%0A%3CTD%3E%3CSTRONG%3E%26gt%3B50%20m%CE%A9%3C%2FSTRONG%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%3EDDR%20VDD%3C%2FTD%3E%0A%3CTD%3EJEDEC%3C%2FTD%3E%0A%3CTD%3E3%EF%BD%9E5%20A%3C%2FTD%3E%0A%3CTD%3E%3CSTRONG%3E20%EF%BD%9E30%20m%CE%A9%3C%2FSTRONG%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%3E%E5%85%A5%E5%87%BA%E5%8A%9B%E3%83%AC%E3%83%BC%E3%83%AB%3C%2FTD%3E%0A%3CTD%3E%C2%B15%EF%BD%9E10%25%3C%2FTD%3E%0A%3CTD%3E%26lt%3B2%20A%3C%2FTD%3E%0A%3CTD%3E%3CSTRONG%3E%26gt%3B50%20m%CE%A9%3C%2FSTRONG%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3C%2FTBODY%3E%0A%3C%2FTABLE%3E%0A%3C%2FDIV%3E%0A%3CP%3E%3CLI-EMOJI%20id%3D%22lia_white-heavy-check-mark%22%20title%3D%22%3Awhite_heavy_check_mark%3A%22%3E%3C%2FLI-EMOJI%3E%20%3CSTRONG%3E%E9%87%8D%E8%A6%81%E3%81%AA%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%EF%BC%9A%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%E3%82%B3%E3%82%A2%E3%83%AC%E3%83%BC%E3%83%AB%E3%81%A8SRAM%E3%83%AC%E3%83%BC%E3%83%AB%3C%2FSTRONG%3E%E3%81%AE%E3%81%BF%E3%81%8C%E3%80%81%E4%BD%8E%E3%83%9F%E3%83%AA%E3%82%AA%E3%83%BC%E3%83%A0%E7%AF%84%E5%9B%B2%E3%81%BE%E3%81%A7%3CSTRONG%3E%E9%9D%9E%E5%B8%B8%E3%81%AB%E7%A9%8D%E6%A5%B5%E7%9A%84%E3%81%AAPDN%E8%A8%AD%E8%A8%88%E3%82%92%3C%2FSTRONG%3E%E5%BF%85%E8%A6%81%E3%81%A8%E3%81%99%E3%82%8B%E3%80%82%3C%2FP%3E%0A%3CHR%20%2F%3E%0A%3CH2%20id%3D%22toc-hId--1594328167%22%20id%3D%22toc-hId--1595131528%22%3E3.%20%E9%81%8E%E6%B8%A1%E9%9B%BB%E6%B5%81%2Fdi%2Fdt%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E4%BB%AE%E5%AE%9A%3C%2FH2%3E%0A%3CH3%20id%3D%22toc-hId--903766693%22%20id%3D%22toc-hId--904570054%22%3E%E3%82%B3%E3%82%A2%E3%83%AC%E3%83%BC%E3%83%AB%EF%BC%88%E9%87%8D%E8%A6%81%EF%BC%89%3C%2FH3%3E%0A%3CP%3EPI%E3%82%B7%E3%83%9F%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AB%E3%81%8A%E3%81%91%E3%82%8B%E6%9C%80%E6%82%AA%E3%82%B1%E3%83%BC%E3%82%B9%E3%81%AE%E9%81%8E%E6%B8%A1%E7%8F%BE%E8%B1%A1%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E4%BB%AE%E5%AE%9A%E3%81%AF%E3%80%81%E4%B8%80%E8%88%AC%E7%9A%84%E3%81%AB%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3E%3CSTRONG%3E%CE%94I%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%3C%2FSTRONG%3E%EF%BC%9A5%EF%BD%9E8A%3C%2FLI%3E%0A%3CLI%3E%3CSTRONG%3E%E3%82%A8%E3%83%83%E3%82%B8%E3%83%AC%E3%83%BC%E3%83%88%3C%2FSTRONG%3E%EF%BC%9A1%EF%BD%9E5%E3%83%8A%E3%83%8E%E7%A7%92%3C%2FLI%3E%0A%3CLI%3E%3CSTRONG%3Edi%2Fdt%3C%2FSTRONG%3E%20%3A%201%EF%BD%9E5%20A%2Fns%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3E%E3%81%93%E3%82%8C%E3%82%89%E3%81%AF%E4%BB%A5%E4%B8%8B%E3%82%92%E8%A1%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3E%E8%A4%87%E6%95%B0%E3%81%AECortex-A72%E3%82%B3%E3%82%A2%E3%81%AE%E5%90%8C%E6%99%82%E5%88%87%E3%82%8A%E6%9B%BF%E3%81%88%3C%2FLI%3E%0A%3CLI%3E%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%EF%BC%8B%E3%83%87%E3%83%BC%E3%82%BF%E3%83%91%E3%82%B9%E3%82%A2%E3%82%AF%E3%82%BB%E3%83%A9%E3%83%AC%E3%83%BC%E3%82%BF%E3%81%AE%E5%8B%95%E4%BD%9C%EF%BC%88DPAA2%E3%80%81DCE%E3%80%81SEC%EF%BC%89%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3E%E3%81%93%E3%82%8C%E3%81%AF%E3%80%81NXP%E3%81%AE%3CSTRONG%3E%E3%83%AA%E3%83%95%E3%82%A1%E3%83%AC%E3%83%B3%E3%82%B9%E3%83%9C%E3%83%BC%E3%83%89%3C%2FSTRONG%3E%E3%82%84%3CSTRONG%3E%E8%A8%AD%E8%A8%88%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%83%AA%E3%82%B9%E3%83%88%E3%81%AB%E3%81%8A%E3%81%91%E3%82%8B%3C%2FSTRONG%3E%E3%83%90%E3%83%AB%E3%82%AF%EF%BC%8B%E9%AB%98%E5%91%A8%E6%B3%A2%E3%83%87%E3%82%AB%E3%83%83%E3%83%97%E3%83%AA%E3%83%B3%E3%82%B0%E3%81%AE%E3%82%B5%E3%82%A4%E3%82%BA%E6%B1%BA%E5%AE%9A%E6%96%B9%E6%B3%95%E3%81%A8%E4%B8%80%E8%87%B4%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CA%20href%3D%22https%3A%2F%2Fstatic.chipdip.ru%2Flib%2F001%2FDOC013001682.pdf%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%5Bstatic.chipdip.ru%5D%3C%2FA%3E%20%E3%80%81%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FLayerscape%2Fnquiry-Regarding-Power-Consumption-of-NXP-LX2160A-Processor%2Fm-p%2F1828705%22%20target%3D%22_blank%22%3E%5Bcommunity.nxp.com%5D%3C%2FA%3E%3C%2FP%3E%0A%3CHR%20%2F%3E%0A%3CH3%20id%3D%22toc-hId-1583746140%22%20id%3D%22toc-hId-1582942779%22%3E%E3%81%9D%E3%81%AE%E4%BB%96%E3%81%AE%E3%83%AC%E3%83%BC%E3%83%AB%3C%2FH3%3E%0A%3CDIV%20class%3D%22___i31lg00%20f10pi13n%20f14t3ns0%20f1nbblvp%20fat0sn4%20f1ov4xf1%20fekwl8i%20f1lmfglv%20f1oz7aqm%20f1abmfm4%20f1w619qj%20f16h0jq8%22%3E%0A%3CTABLE%20class%3D%22___1hm93bs%20f1ddd56o%20f16vktn6%20f1enuhaj%20fdclmfp%20f1ev3kgc%20ftgm304%20f1uinfot%20fibjyge%20fvueend%20f9yszdx%20f1fu4s3n%20f3l3pb3%20f1s2k7dp%20f8fmt76%20fjvbh62%20fysh76l%20fic4ptz%20f1yenhzu%20f1yn6nvh%20f14tj6oe%20f1jq587y%20f1el8yx3%20f1pymoxg%20f1ofu761%20fe6itr%20f7coize%20f1794535%20f70r78m%20f4zgifc%20fk1v6el%20f16pyhcb%20fo436u6%20fzy4j18%20fc43013%20f1hmrcvb%20fc4t9fq%20fgp09rh%20fjnyn6r%22%3E%0A%3CTBODY%3E%0A%3CTR%3E%0A%3CTH%3E%E3%83%AC%E3%83%BC%E3%83%AB%3C%2FTH%3E%0A%3CTH%3E%CE%94I%E3%81%AE%E4%BB%AE%E5%AE%9A%3C%2FTH%3E%0A%3CTH%3Edi%2Fdt%3C%2FTH%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%EF%BC%8FSRAM%3C%2FTD%3E%0A%3CTD%3E2%EF%BD%9E4%20A%3C%2FTD%3E%0A%3CTD%3E0.5%EF%BD%9E1%20A%2Fns%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%3ESerDes%20Digital%3C%2FTD%3E%0A%3CTD%3E0.5%EF%BD%9E1%20A%3C%2FTD%3E%0A%3CTD%3E0.1%EF%BD%9E0.3%E5%9B%9E%E7%AD%94%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%3EDDR%20VDD%3C%2FTD%3E%0A%3CTD%3EJEDEC%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E7%AE%A1%E7%90%86%E3%81%95%E3%82%8C%E3%82%8B%E3%83%90%E3%83%BC%E3%82%B9%E3%83%88%3C%2FTD%3E%0A%3CTD%3E%E3%82%88%E3%82%8A%E9%81%85%E3%81%84%E3%80%81%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E3%83%BC%E4%B8%BB%E5%B0%8E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%3EI%2FO%3C%2FTD%3E%0A%3CTD%3E%26lt%3B0.5%20A%3C%2FTD%3E%0A%3CTD%3E%E9%9D%9E%E5%B8%B8%E3%81%AB%E4%BD%8E%E3%81%84%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3C%2FTBODY%3E%0A%3C%2FTABLE%3E%0A%3C%2FDIV%3E%0A%3CHR%20%2F%3E%0A%3CH2%20id%3D%22toc-hId-1573243036%22%20id%3D%22toc-hId-1572439675%22%3E4.%20%E5%88%86%E6%9E%90%E5%AF%BE%E8%B1%A1%E5%91%A8%E6%B3%A2%E6%95%B0%E7%AF%84%E5%9B%B2%3C%2FH2%3E%0A%3CP%3ELX2160A%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81PI%E8%A7%A3%E6%9E%90%E3%81%A7%E3%81%AF%E4%BB%A5%E4%B8%8B%E3%81%AE%E9%A0%85%E7%9B%AE%E3%82%92%E5%AF%BE%E8%B1%A1%E3%81%A8%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3E%3CSTRONG%3EDC%20%E2%86%92%20100%20MHz%3C%2FSTRONG%3E%20%EF%BC%88%E6%9C%80%E5%B0%8F%EF%BC%89%3C%2FLI%3E%0A%3CLI%3E%E3%82%AA%E3%83%B3%E3%83%80%E3%82%A4L%2FC%E5%8A%B9%E6%9E%9C%E3%81%AE%E3%81%9F%E3%82%81%E3%80%81%E3%82%B3%E3%82%A2%E3%83%AC%E3%83%BC%E3%83%AB%E3%81%AB%E3%81%AF%3CSTRONG%3E%E6%9C%80%E5%A4%A7300%EF%BD%9E500MHz%E3%81%8C%3C%2FSTRONG%3E%E6%8E%A8%E5%A5%A8%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3E%E7%B4%841MHz%E4%BB%A5%E4%B8%8B%EF%BC%9A%3CBR%20%2F%3E%3CLI-EMOJI%20id%3D%22lia_white-heavy-check-mark%22%20title%3D%22%3Awhite_heavy_check_mark%3A%22%3E%3C%2FLI-EMOJI%3E%20VRM%E3%81%A8%E3%83%90%E3%83%AB%E3%82%AF%E3%82%B3%E3%83%B3%E3%83%87%E3%83%B3%E3%82%B5%E3%81%8C%E5%A4%A7%E9%83%A8%E5%88%86%E3%82%92%E5%8D%A0%E3%82%81%E3%82%8B%3C%2FP%3E%0A%3CP%3E1%EF%BD%9E100MHz%3A%3CBR%20%2F%3E%3CLI-EMOJI%20id%3D%22lia_white-heavy-check-mark%22%20title%3D%22%3Awhite_heavy_check_mark%3A%22%3E%3C%2FLI-EMOJI%3E%20%E3%83%9C%E3%83%BC%E3%83%89%E3%83%AC%E3%83%99%E3%83%AB%E3%81%AEMLCC%E3%81%A8%E3%83%97%E3%83%AC%E3%83%BC%E3%83%B3%3C%2FP%3E%0A%3CBLOCKQUOTE%3E%0A%3CP%3E100%20MHz%3A%3CBR%20%2F%3E%3CLI-EMOJI%20id%3D%22lia_white-heavy-check-mark%22%20title%3D%22%3Awhite_heavy_check_mark%3A%22%3E%3C%2FLI-EMOJI%3E%20%E3%82%AA%E3%83%B3%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%EF%BC%8B%E3%82%AA%E3%83%B3%E3%83%80%E3%82%A4%E9%9D%99%E9%9B%BB%E5%AE%B9%E9%87%8F%EF%BC%88%E5%88%A9%E7%94%A8%E5%8F%AF%E8%83%BD%E3%81%AA%E5%A0%B4%E5%90%88%E3%81%AF%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8S%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%83%A2%E3%83%87%E3%83%AB%E5%8C%96%EF%BC%89%3C%2FP%3E%0A%3C%2FBLOCKQUOTE%3E%0A%3CHR%20%2F%3E%0A%3CH2%20id%3D%22toc-hId--234211427%22%20id%3D%22toc-hId--235014788%22%3E5.%20%E3%83%87%E3%82%AB%E3%83%83%E3%83%97%E3%83%AA%E3%83%B3%E3%82%B0%E6%88%A6%E7%95%A5%EF%BC%88%E5%8F%82%E7%85%A7%E3%83%99%E3%83%BC%E3%82%B9%EF%BC%89%3C%2FH2%3E%0A%3CP%3ENXP%E3%81%AE%E3%83%AA%E3%83%95%E3%82%A1%E3%83%AC%E3%83%B3%E3%82%B9%E3%83%87%E3%82%B6%E3%82%A4%E3%83%B3%E3%81%AF%3CSTRONG%3E%E3%80%813%E5%B1%A4%E6%A7%8B%E9%80%A0%E3%81%AE%E3%82%A2%E3%83%97%E3%83%AD%E3%83%BC%E3%83%81%3C%2FSTRONG%3E%E3%82%92%E7%A4%BA%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3COL%3E%0A%3CLI%3E%3CSTRONG%3E%E3%83%90%E3%83%AB%E3%82%AF%3C%2FSTRONG%3E%0A%3CUL%3E%0A%3CLI%3E%E3%82%B3%E3%82%A2%E3%83%AC%E3%83%BC%E3%83%AB%E3%81%82%E3%81%9F%E3%82%8A47%EF%BD%9E330%CE%BCF%E3%81%AE%E3%83%9D%E3%83%AA%E3%83%9E%E3%83%BC%E3%81%BE%E3%81%9F%E3%81%AF%E3%82%BF%E3%83%B3%E3%82%BF%E3%83%AB%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3C%2FLI%3E%0A%3CLI%3E%3CSTRONG%3E%E4%B8%AD%E5%91%A8%E6%B3%A2MLCC%3C%2FSTRONG%3E%0A%3CUL%3E%0A%3CLI%3E1%EF%BD%9E10%20%C2%B5F%E3%80%81X7R%E3%80%81%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E5%A4%96%E5%91%A8%E5%85%A8%E4%BD%93%E3%81%AB%E5%88%86%E5%B8%83%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3C%2FLI%3E%0A%3CLI%3E%3CSTRONG%3E%E9%AB%98%E5%91%A8%E6%B3%A2MLCC%3C%2FSTRONG%3E%0A%3CUL%3E%0A%3CLI%3EBGA%E7%9B%B4%E4%B8%8B%E3%81%AB0.01%EF%BD%9E0.1%CE%BCF%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3C%2FLI%3E%0A%3C%2FOL%3E%0A%3CP%3E%E3%81%93%E3%81%AE%E6%96%B9%E6%B3%95%E3%81%AF%E3%80%81Layerscape%E3%81%AERDB%E3%83%AC%E3%82%A4%E3%82%A2%E3%82%A6%E3%83%88%E3%81%A8%E6%95%B4%E5%90%88%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3CA%20href%3D%22https%3A%2F%2Fstatic.chipdip.ru%2Flib%2F001%2FDOC013001682.pdf%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%5Bstatic.chipdip.ru%5D%3C%2FA%3E%3C%2FP%3E%0A%3CHR%20%2F%3E%0A%3CH2%20id%3D%22toc-hId--2041665890%22%20id%3D%22toc-hId--2042469251%22%3E6.%20%E6%8E%A8%E5%A5%A8PI%E3%83%84%E3%83%BC%E3%83%AB%3C%2FH2%3E%0A%3CP%3ELX2160A%E3%82%AF%E3%83%A9%E3%82%B9%E3%81%AESoC%E3%81%A7%E3%81%86%E3%81%BE%E3%81%8F%E6%A9%9F%E8%83%BD%E3%81%99%E3%82%8B%E3%80%81%E5%BA%83%E3%81%8F%E4%BD%BF%E3%82%8F%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%83%84%E3%83%BC%E3%83%AB%EF%BC%9A%3C%2FP%3E%0A%3CH3%20id%3D%22toc-hId--1351104416%22%20id%3D%22toc-hId--1351907777%22%3E%E3%82%B7%E3%83%9F%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%3C%2FH3%3E%0A%3CUL%3E%0A%3CLI%3E%3CSTRONG%3E%E3%82%B1%E3%82%A4%E3%83%87%E3%83%B3%E3%82%B9%20%E3%82%B7%E3%82%B0%E3%83%AA%E3%83%86%E3%82%A3%20%E3%83%91%E3%83%AF%E3%83%BCSI%3C%2FSTRONG%3E%3C%2FLI%3E%0A%3CLI%3E%3CSTRONG%3EAnsys%20SIwave%3C%2FSTRONG%3E%3C%2FLI%3E%0A%3CLI%3E%3CSTRONG%3EKeysight%20PIPro%3C%2FSTRONG%3E%3C%2FLI%3E%0A%3CLI%3E%3CSTRONG%3EAltium%20PDN%E3%82%A2%E3%83%8A%E3%83%A9%E3%82%A4%E3%82%B6%E3%83%BC%3C%2FSTRONG%3E%EF%BC%88%E5%88%9D%E6%9C%9F%E6%AE%B5%E9%9A%8E%E3%81%AE%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%EF%BC%89%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CH3%20id%3D%22toc-hId-441244938%22%20id%3D%22toc-hId-440441577%22%3E%E6%B8%AC%E5%AE%9A%EF%BC%88%E3%83%9D%E3%82%B9%E3%83%88%E3%82%B7%E3%83%AA%E3%82%B3%E3%83%B3%EF%BC%89%3C%2FH3%3E%0A%3CUL%3E%0A%3CLI%3EVNA%E3%82%92%E7%94%A8%E3%81%84%E3%81%9FPDN%E3%82%A4%E3%83%B3%E3%83%94%E3%83%BC%E3%83%80%E3%83%B3%E3%82%B9%E6%B8%AC%E5%AE%9A%EF%BC%882%E3%83%9D%E3%83%BC%E3%83%88%E3%82%B7%E3%83%A3%E3%83%B3%E3%83%88%E3%82%B9%E3%83%AB%E3%83%BC%E6%96%B9%E5%BC%8F%EF%BC%89%3C%2FLI%3E%0A%3CLI%3EBGA%E3%83%96%E3%83%AC%E3%83%BC%E3%82%AF%E3%82%A2%E3%82%A6%E3%83%88%E3%83%86%E3%82%B9%E3%83%88%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%E3%81%AB%E3%81%8A%E3%81%91%E3%82%8B%E9%AB%98%E5%B8%AF%E5%9F%9F%E5%B9%85%E3%83%97%E3%83%AD%E3%83%BC%E3%83%93%E3%83%B3%E3%82%B0%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CHR%20%2F%3E%0A%3CH2%20id%3D%22toc-hId--1495292244%22%20id%3D%22toc-hId--1496095605%22%3E7%EF%BC%8E%E6%96%B9%E6%B3%95%E8%AB%96%E3%81%AE%E6%A6%82%E8%A6%81%EF%BC%88%E3%83%99%E3%82%B9%E3%83%88%E3%83%97%E3%83%A9%E3%82%AF%E3%83%86%E3%82%A3%E3%82%B9%EF%BC%89%3C%2FH2%3E%0A%3COL%3E%0A%3CLI%3E%3CSTRONG%3EZ_TARGET%E3%83%99%E3%83%BC%E3%82%B9%E3%81%AEPDN%E8%A8%AD%E8%A8%88%3C%2FSTRONG%3E%E3%81%8B%E3%82%89%E5%A7%8B%E3%82%81%E3%81%BE%E3%81%97%E3%82%87%E3%81%86%3C%2FLI%3E%0A%3CLI%3E%3CSTRONG%3E%E3%82%B9%E3%82%A4%E3%83%BC%E3%83%97%E3%82%A4%E3%83%B3%E3%83%94%E3%83%BC%E3%83%80%E3%83%B3%E3%82%B9%E3%83%97%E3%83%AD%E3%83%83%E3%83%88%EF%BC%88%E5%AF%BE%E6%95%B0-%E5%AF%BE%E6%95%B0%EF%BC%89%3C%2FSTRONG%3E%E3%82%92%E4%BD%9C%E6%88%90%E3%81%99%E3%82%8B%3C%2FLI%3E%0A%3CLI%3EZ_TARGET%E4%BB%A5%E4%B8%8B%E3%81%AE%E5%8F%8D%E5%85%B1%E9%B3%B4%E3%83%94%E3%83%BC%E3%82%AF%E3%82%92%E9%99%A4%E5%8E%BB%E3%81%99%E3%82%8B%3C%2FLI%3E%0A%3CLI%3E%E6%A4%9C%E8%A8%BC%E6%96%B9%E6%B3%95%EF%BC%9A%0A%3CUL%3E%0A%3CLI%3E%E6%9C%80%E6%82%AA%E3%81%AE%E5%A0%B4%E5%90%88%E3%81%AE%E7%8F%BE%E5%9C%A8%E3%81%AE%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%3C%2FLI%3E%0A%3CLI%3E%E8%B2%A0%E8%8D%B7%E9%81%8E%E6%B8%A1%E3%82%B7%E3%83%9F%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3C%2FLI%3E%0A%3CLI%3E%E5%8F%AF%E8%83%BD%E3%81%A7%E3%81%82%E3%82%8C%E3%81%B0%3CSTRONG%3ERDB%E3%81%AE%E6%8C%99%E5%8B%95%3C%2FSTRONG%3E%E3%81%A8%E7%9B%B8%E9%96%A2%E9%96%A2%E4%BF%82%E3%82%92%E5%88%86%E6%9E%90%E3%81%99%E3%82%8B%3C%2FLI%3E%0A%3C%2FOL%3E%0A%3CHR%20%2F%3E%0A%3CH2%20id%3D%22toc-hId-992220589%22%20id%3D%22toc-hId-991417228%22%3E8.%20NXP%E5%9B%BA%E6%9C%89%E3%81%AE%E6%8E%A8%E5%A5%A8%E4%BA%8B%E9%A0%85%3C%2FH2%3E%0A%3CP%3ENXP%E3%81%AF%E3%80%81%E7%A4%BE%E5%86%85%E3%81%A7PDN%E3%82%B5%E3%82%A4%E3%82%B8%E3%83%B3%E3%82%B0%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%82%8B%3CSTRONG%3E%E9%9B%BB%E5%8A%9B%E4%BD%BF%E7%94%A8%E4%BA%8B%E4%BE%8B%E3%82%84%E3%83%AC%E3%83%BC%E3%83%AB%E9%9B%BB%E6%B5%81%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E3%82%AC%E3%82%A4%E3%83%80%E3%83%B3%E3%82%B9%3C%2FSTRONG%3E%E3%82%92%E5%90%AB%E3%82%80%3CSTRONG%3EAN5407%20%E2%80%93%20LX2160A%2FLX2162A%E8%A8%AD%E8%A8%88%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%83%AA%E3%82%B9%E3%83%88%3C%2FSTRONG%3E%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E5%BC%B7%E3%81%8F%E6%8E%A8%E5%A5%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FLayerscape%2Fnquiry-Regarding-Power-Consumption-of-NXP-LX2160A-Processor%2Fm-p%2F1828705%22%20target%3D%22_blank%22%3E%5Bcommunity.nxp.com%5D%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3ENXP%E3%83%97%E3%83%AC%E3%83%9F%E3%82%A2%E3%83%A0%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%3C%2FSTRONG%3E%E3%82%92%E3%81%94%E5%88%A9%E7%94%A8%E3%81%AE%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%83%AA%E3%82%AF%E3%82%A8%E3%82%B9%E3%83%88%E3%82%82%E5%8F%AF%E8%83%BD%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3E%E9%89%84%E9%81%93%E3%81%94%E3%81%A8%E3%81%AE%E6%9C%80%E6%82%AA%E3%82%B7%E3%83%8A%E3%83%AA%E3%82%AA%E3%81%AE%E9%9B%BB%E6%B5%81%E8%A1%A8%3C%2FLI%3E%0A%3CLI%3E%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8PDN%E3%83%A2%E3%83%87%E3%83%AB%EF%BC%88%E5%88%A9%E7%94%A8%E5%8F%AF%E8%83%BD%E3%81%AA%E5%A0%B4%E5%90%88%EF%BC%89%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3C%2FDIV%3E%3C%2FLINGO-BODY%3E
