LX2160A DDR memory connections
ソリューションへジャンプ
1,744件の閲覧回数
kurokawa
Regarding DDR memory connections to the LX2160A
I'm considering connecting nine 8-bit DDR4 memory modules (8 x 9 = 72 bits) to the LX2160, and dividing them into TOP and BOTTOM locations to minimize the implementation area.
In this case, would it be possible to use address mirroring to configure TOP = CS0 as five chips and BOTTOM = CS1 as four chips?
1,685件の閲覧回数
shengzhou_liu
Yes, it is feasible to that using 8-bit chips and one controller to perform address mirroring by placing 9 chips on the TOP and 9 chips on the BOTTOM.
But from the perspective of performance, the bandwidth performance of using dual-controllers with single-rank is better than that of using single-controller with dual-ranks.
3 返答(返信)
1,716件の閲覧回数
shengzhou_liu
Hi  @kurokawa
LX2160A supports DDR address mirroring.
Asymmetric population (5 devices on CS0 and 4 devices on CS1) is not feasible.
Address mirroring should be applied in a balanced topology.
for the specific chip-selection, it should be 64-bit data width, not 8x 5-chip = 40-bits or 8x 4-chips = 32-bits
there are 3 topologies:
way 1: (single-controller and single-rank, without address mirroring)
TOP: 5 x8 DRAM parts for data + 1 x8 DRAM part for ECC with CS0
BOTTOM: 4 x8 DRAM parts for data with CS0
way 2: (single-controller and dual-ranks, with address mirroring)
TOP: 4 x16 DRAM parts for data + 1 x16 DRAM part(only 8-bits used) for ECC with CS0 of DDRC1
BOTTOM: 4 x16 DRAM parts for data + 1 x16 DRAM part(only 8-bits used) for ECC with CS1 of DDRC1
way 3 (dual-controllers and single-rank for better performance):
BOTTOM: 4 x16 DRAM parts for data + 1 x16 DRAM part(only 8-bits used) for ECC with CS0 of DDRC2
if .mirrored_dimm = 1 in mocked SPD way in ATF, DDR driver sets DDR_SDRAM_CFG_2[MD_EN] = 1.
1,711件の閲覧回数
kurokawa
Thank you for your reply.
Just to be sure, let me confirm way 2.
If using 8-bit chips and using one controller, is it possible to perform address mirroring by placing 9 chips on the TOP and 9 chips on the BOTTOM (18 chips in total)?
1,686件の閲覧回数
shengzhou_liu
%3CLINGO-SUB%20id%3D%22lingo-sub-2305059%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ELX2160A%20DDR%E3%83%A1%E3%83%A2%E3%83%AA%E6%8E%A5%E7%B6%9A%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2305059%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3ELX2160A%E3%81%B8%E3%81%AEDDR%E3%83%A1%E3%83%A2%E3%83%AA%E6%8E%A5%E7%B6%9A%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%3C%2FP%3E%3CP%3ELX2160%E3%81%AB8%E3%83%93%E3%83%83%E3%83%88DDR4%E3%83%A1%E3%83%A2%E3%83%AA%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%82%929%E5%80%8B%EF%BC%888%20x%209%20%3D%2072%E3%83%93%E3%83%83%E3%83%88%EF%BC%89%E6%8E%A5%E7%B6%9A%E3%81%97%E3%80%81TOP%E3%81%A8BOTTOM%E3%81%AB%E5%88%86%E5%89%B2%E3%81%97%E3%81%A6%E5%AE%9F%E8%A3%85%E9%A0%98%E5%9F%9F%E3%82%92%E6%9C%80%E5%B0%8F%E9%99%90%E3%81%AB%E6%8A%91%E3%81%88%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E6%A4%9C%E8%A8%8E%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%83%9F%E3%83%A9%E3%83%BC%E3%83%AA%E3%83%B3%E3%82%B0%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%80%81TOP%20%3D%20CS0%20%E3%82%92%205%20%E3%81%A4%E3%81%AE%E3%83%81%E3%83%83%E3%83%97%E3%81%A8%E3%81%97%E3%81%A6%E3%80%81BOTTOM%20%3D%20CS1%20%E3%82%92%204%20%E3%81%A4%E3%81%AE%E3%83%81%E3%83%83%E3%83%97%E3%81%A8%E3%81%97%E3%81%A6%E6%A7%8B%E6%88%90%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E5%8F%AF%E8%83%BD%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2305265%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LX2160A%20DDR%20memory%20connections%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2305265%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%94%E8%BF%94%E4%BF%A1%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E5%BF%B5%E3%81%AE%E3%81%9F%E3%82%81%E3%80%81%E6%96%B9%E6%B3%95%202%20%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%95%E3%81%9B%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E8%20%E3%83%93%E3%83%83%E3%83%88%20%E3%83%81%E3%83%83%E3%83%97%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%80%81%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%82%92%201%20%E3%81%A4%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%E3%80%81TOP%20%E3%81%AB%209%20%E5%80%8B%E3%81%AE%E3%83%81%E3%83%83%E3%83%97%E3%80%81BOTTOM%20%E3%81%AB%209%20%E5%80%8B%E3%81%AE%E3%83%81%E3%83%83%E3%83%97%20(%E5%90%88%E8%A8%88%2018%20%E5%80%8B%E3%81%AE%E3%83%81%E3%83%83%E3%83%97)%20%E3%82%92%E9%85%8D%E7%BD%AE%E3%81%97%E3%81%A6%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%20%E3%83%9F%E3%83%A9%E3%83%BC%E3%83%AA%E3%83%B3%E3%82%B0%E3%82%92%E8%A1%8C%E3%81%86%E3%81%93%E3%81%A8%E3%81%AF%E5%8F%AF%E8%83%BD%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2305203%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%20translate%3D%22no%22%3ERe%3A%20LX2160A%20DDR%20memory%20connections%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2305203%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F214864%22%20target%3D%22_blank%22%3E%40%E9%BB%92%E5%B7%9D%3C%2FA%3E%3C%2FP%3E%0A%3CP%3ELX2160A%20%E3%81%AF%20DDR%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%83%9F%E3%83%A9%E3%83%BC%E3%83%AA%E3%83%B3%E3%82%B0%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E9%9D%9E%E5%AF%BE%E7%A7%B0%E6%A7%8B%E6%88%90%20(CS0%20%E3%81%AB%205%20%E3%81%A4%E3%81%AE%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%80%81CS1%20%E3%81%AB%204%20%E3%81%A4%E3%81%AE%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9)%20%E3%81%AF%E5%AE%9F%E7%8F%BE%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3CBR%20%2F%3E%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%83%9F%E3%83%A9%E3%83%BC%E3%83%AA%E3%83%B3%E3%82%B0%E3%81%AF%E3%83%90%E3%83%A9%E3%83%B3%E3%82%B9%E3%81%AE%E5%8F%96%E3%82%8C%E3%81%9F%E3%83%88%E3%83%9D%E3%83%AD%E3%82%B8%E3%81%A7%E9%81%A9%E7%94%A8%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E7%89%B9%E5%AE%9A%E3%81%AE%E3%83%81%E3%83%83%E3%83%97%E9%81%B8%E6%8A%9E%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%818x5%E3%83%81%E3%83%83%E3%83%97%3D40%E3%83%93%E3%83%83%E3%83%88%E3%82%848x4%E3%83%81%E3%83%83%E3%83%97%3D32%E3%83%93%E3%83%83%E3%83%88%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%8F%E3%80%8164%E3%83%93%E3%83%83%E3%83%88%E3%81%AE%E3%83%87%E3%83%BC%E3%82%BF%E5%B9%85%E3%81%A7%E3%81%82%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E3%E3%81%A4%E3%81%AE%E3%83%88%E3%83%9D%E3%83%AD%E3%82%B8%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%3A%3C%2FP%3E%0A%3CP%3E%E6%96%B9%E6%B3%95%201%3A%20(%E3%82%B7%E3%83%B3%E3%82%B0%E3%83%AB%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%80%81%E3%82%B7%E3%83%B3%E3%82%B0%E3%83%AB%E3%83%A9%E3%83%B3%E3%82%AF%E3%80%81%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%83%9F%E3%83%A9%E3%83%BC%E3%83%AA%E3%83%B3%E3%82%B0%E3%81%AA%E3%81%97)%3CBR%20%2F%3E%20TOP%3A%20%E3%83%87%E3%83%BC%E3%82%BF%E7%94%A8%E3%81%AE%20x8%20DRAM%20%E9%83%A8%E5%93%81%205%20%E5%80%8B%20%2B%20CS0%20%E4%BB%98%E3%81%8D%20ECC%20%E7%94%A8%E3%81%AE%20x8%20DRAM%20%E9%83%A8%E5%93%81%201%20%E5%80%8B%3CBR%20%2F%3E%E4%B8%8B%E9%83%A8%3A%20CS0%E4%BB%98%E3%81%8D%E3%83%87%E3%83%BC%E3%82%BF%E7%94%A84%20x8%20DRAM%E9%83%A8%E5%93%81%3C%2FP%3E%0A%3CP%3E%E6%96%B9%E6%B3%95%202%3A%20(%E3%82%B7%E3%83%B3%E3%82%B0%E3%83%AB%20%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%81%A8%E3%83%87%E3%83%A5%E3%82%A2%E3%83%AB%20%E3%83%A9%E3%83%B3%E3%82%AF%E3%80%81%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%20%E3%83%9F%E3%83%A9%E3%83%BC%E3%83%AA%E3%83%B3%E3%82%B0%E3%82%92%E4%BD%BF%E7%94%A8)%3CBR%20%2F%3E%20TOP%3A%20%E3%83%87%E3%83%BC%E3%82%BF%E7%94%A8%E3%81%AE%204%20%E3%81%A4%E3%81%AE%20x16%20DRAM%20%E3%83%91%E3%83%BC%E3%83%84%20%2B%20ECC%20%E7%94%A8%E3%81%AE%201%20%E3%81%A4%E3%81%AE%20x16%20DRAM%20%E3%83%91%E3%83%BC%E3%83%84%20(8%20%E3%83%93%E3%83%83%E3%83%88%E3%81%AE%E3%81%BF%E4%BD%BF%E7%94%A8)%E3%80%81DDRC1%20%E3%81%AE%20CS0%20%E4%BB%98%E3%81%8D%3CBR%20%2F%3E%E4%B8%8B%E9%83%A8%3A%20%E3%83%87%E3%83%BC%E3%82%BF%E7%94%A8%E3%81%AE%204%20%E3%81%A4%E3%81%AE%20x16%20DRAM%20%E3%83%91%E3%83%BC%E3%83%84%20%2B%20ECC%20%E7%94%A8%E3%81%AE%201%20%E3%81%A4%E3%81%AE%20x16%20DRAM%20%E3%83%91%E3%83%BC%E3%83%84%20(8%20%E3%83%93%E3%83%83%E3%83%88%E3%81%AE%E3%81%BF%E4%BD%BF%E7%94%A8)%E3%80%81DDRC1%20%E3%81%AE%20CS1%20%E4%BB%98%E3%81%8D%3C%2FP%3E%0A%3CP%3E%E6%96%B9%E6%B3%953%EF%BC%88%E3%83%91%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%B3%E3%82%B9%E5%90%91%E4%B8%8A%E3%81%AE%E3%81%9F%E3%82%81%E3%81%AE%E3%83%87%E3%83%A5%E3%82%A2%E3%83%AB%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%81%A8%E3%82%B7%E3%83%B3%E3%82%B0%E3%83%AB%E3%83%A9%E3%83%B3%E3%82%AF%EF%BC%89%3A%3CBR%20%2F%3E%20TOP%3A%20%E3%83%87%E3%83%BC%E3%82%BF%E7%94%A8%E3%81%AE%204%20%E3%81%A4%E3%81%AE%20x16%20DRAM%20%E3%83%91%E3%83%BC%E3%83%84%20%2B%20ECC%20%E7%94%A8%E3%81%AE%201%20%E3%81%A4%E3%81%AE%20x16%20DRAM%20%E3%83%91%E3%83%BC%E3%83%84%20(8%20%E3%83%93%E3%83%83%E3%83%88%E3%81%AE%E3%81%BF%E4%BD%BF%E7%94%A8)%E3%80%81DDRC1%20%E3%81%AE%20CS0%20%E4%BB%98%E3%81%8D%3CBR%20%2F%3E%E4%B8%8B%E9%83%A8%3A%20%E3%83%87%E3%83%BC%E3%82%BF%E7%94%A8%E3%81%AE%204%20%E3%81%A4%E3%81%AE%20x16%20DRAM%20%E3%83%91%E3%83%BC%E3%83%84%20%2B%20DDRC2%20%E3%81%AE%20CS0%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%20ECC%20%E7%94%A8%E3%81%AE%201%20%E3%81%A4%E3%81%AE%20x16%20DRAM%20%E3%83%91%E3%83%BC%E3%83%84%20(8%20%E3%83%93%E3%83%83%E3%83%88%E3%81%AE%E3%81%BF%E4%BD%BF%E7%94%A8)%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3E.mirrored_dimm%E3%81%AE%E5%A0%B4%E5%90%88ATF%20%E3%81%AE%E6%A8%A1%E6%93%AC%20SPD%20%E6%96%B9%E5%BC%8F%E3%81%A7%E3%81%AF%20%3D%201%20%E3%81%A7%E3%81%82%E3%82%8A%E3%80%81DDR%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%AF%20DDR_SDRAM_CFG_2%5BMD_EN%5D%20%3D%201%20%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2306013%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LX2160A%20DDR%20memory%20connections%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2306013%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%AF%E3%81%84%E3%80%818%20%E3%83%93%E3%83%83%E3%83%88%20%E3%83%81%E3%83%83%E3%83%97%E3%81%A8%201%20%E3%81%A4%E3%81%AE%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%83%BC%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%80%819%20%E3%81%A4%E3%81%AE%E3%83%81%E3%83%83%E3%83%97%E3%82%92%20TOP%20%E3%81%AB%E3%80%819%20%E3%81%A4%E3%81%AE%E3%83%81%E3%83%83%E3%83%97%E3%82%92%20BOTTOM%20%E3%81%AB%E9%85%8D%E7%BD%AE%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%20%E3%83%9F%E3%83%A9%E3%83%BC%E3%83%AA%E3%83%B3%E3%82%B0%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E5%8F%AF%E8%83%BD%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E3%83%91%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%B3%E3%82%B9%E3%81%AE%E8%A6%B3%E7%82%B9%E3%81%8B%E3%82%89%E8%A6%8B%E3%82%8B%E3%81%A8%E3%80%81%E3%82%B7%E3%83%B3%E3%82%B0%E3%83%AB%E3%83%A9%E3%83%B3%E3%82%AF%E3%81%AE%E3%83%87%E3%83%A5%E3%82%A2%E3%83%AB%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%83%BC%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E5%A0%B4%E5%90%88%E3%81%AE%E5%B8%AF%E5%9F%9F%E5%B9%85%E3%83%91%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%B3%E3%82%B9%E3%81%AF%E3%80%81%E3%83%87%E3%83%A5%E3%82%A2%E3%83%AB%E3%83%A9%E3%83%B3%E3%82%AF%E3%81%AE%E3%82%B7%E3%83%B3%E3%82%B0%E3%83%AB%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%83%BC%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E5%A0%B4%E5%90%88%E3%82%88%E3%82%8A%E3%82%82%E5%84%AA%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
