LX2160 yocto build issue
jackho
I am trying to build Yocto Project for lx2160 platform in ubuntu 18.04,
=>bitbake fsl-image-networking
 In build process, it will show below error, do you have solution for this problem?
Thanks you.
Jack
DNF version: 4.2.2
cachedir: /home/jack_ho/Yocto/build_lx2160ardb-rev2/tmp/work/lx2160ardb_rev2-fsl-linux/fsl-image-networking/1.0-r0/rootfs/var/cache/dnf
Added oe-repo repo from /home/jack_ho/Yocto/build_lx2160ardb-rev2/tmp/work/lx2160ardb_rev2-fsl-linux/fsl-image-networking/1.0-r0/oe-rootfs-repo
repo: using cache for: oe-repo
not found other for:
not found modules for:
not found deltainfo for:
not found updateinfo for:
oe-repo: using metadata from Mon 28 Mar 2022 01:37:45 AM UTC.
Last metadata expiration check: 0:00:01 ago on Mon 28 Mar 2022 01:37:45 AM UTC.
No module defaults found
--> Starting dependency resolution
--> Finished dependency resolution
Error:
 Problem: package packagegroup-fsl-tools-core-1.0-r0.lx2160ardb_rev2 requires cryptodev-module, but none of the providers can be installed
  - package cryptodev-qoriq-module-1.10-r0.aarch64_qoriq requires kernel-module-cryptodev-5.4.3+g134788b16485, but none of the providers can be installed
  - conflicting requests
  - nothing provides kernel-5.4.3+g134788b16485 needed by kernel-module-cryptodev-5.4.3+g134788b16485-1.10-r0.aarch64_qoriq
yipingwang
What version Yocto SDK do you use? dunfell or hardknott?
Would you please attach your whole build console log?
