LX2080
LX2080
YY2410
请教个问题,我有一块板子(LX2080)昨天通过仿真器烧写还正常,然后今天在Hard-code模式下烧写就报附件图片这个错误.但是FLASH里边东西还在,正常模式启动可以正常加载。然后这个板子还有另一片flash,切换到另一片flash,现象一样,能正常加载里边文件,但是烧写报错。这个是什么原因,怎么处理?我们这个现象是个例,仅在一块板卡上存在该现象,其余板卡正常着,也就是我们的配置是没有问题的。@LX2080
yipingwang
在CodeWarrior 初始化文件里面,配置flash programmer 运行在DDR 还是OCRAM. 可能是读写DDR 或者OCRAM 出现了问题。
CodeWarrior IDE 里面可以执行Connection Diagnostics, 看看有没有问题。
%3CLINGO-SUB%20id%3D%22lingo-sub-2264561%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ELX2080%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2264561%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3EI%20have%20a%20board%20(LX2080)%20that%20was%20fine%20yesterday%20when%20I%20burned%20it%20through%20the%20emulator%2C%20but%20today%20when%20I%20burned%20it%20in%20Hard-code%20mode%2C%20it%20reported%20the%20error%20in%20the%20attached%20image.%20But%20the%20FLASH%20is%20still%20there%2C%20and%20it%20can%20be%20loaded%20normally%20when%20booting%20in%20normal%20mode.%20Then%20there%20is%20another%20piece%20of%20flash%20on%20this%20board%2C%20switch%20to%20the%20other%20piece%20of%20flash%2C%20the%20phenomenon%20is%20the%20same%2C%20it%20can%20load%20the%20files%20normally%2C%20but%20the%20burn%20error%20is%20reported.%20What%20is%20the%20reason%20for%20this%20and%20how%20to%20deal%20with%20it%3F%3C%2FSPAN%3E%3CSPAN%3E%20This%20is%20an%20isolated%20case%2C%20it%20only%20exists%20on%20one%20board%2C%20the%20rest%20of%20the%20boards%20are%20normal%2C%20that%20is%2C%20our%20configuration%20is%20not%20a%20problem.%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FLayerscape%2FLX2080%2Fm-p%2F2262249%22%20target%3D%22_blank%22%3E%40LX2080%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2265659%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LX2080%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2265659%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%3CP%3EIn%20the%20CodeWarrior%20initialization%20file%2C%20configure%20whether%20the%20flash%20programmer%20runs%20on%20DDR%20or%20OCRAM.%20There%20may%20be%20a%20problem%20reading%20or%20writing%20DDR%20or%20OCRAM.%3C%2FP%3E%0A%3CP%3EYou%20can%20run%20Connection%20Diagnostics%20in%20the%20CodeWarrior%20IDE%20to%20see%20if%20there%20are%20any%20problems.%3C%2FP%3E%3C%2FLINGO-BODY%3E
