LX2080
LX2080
1,071 次查看
YY2410
LX2080释放复位瞬间启动电流过大,导致核电输出被拉掉,有什么办法让CPU核缓启动或者8个核分时依次启动吗?谢谢!
When the LX2080 releases its reset signal, the inrush current is too high, causing the core power output to be pulled down. Is there a way to enable a soft start for the CPU cores or stagger the startup of the eight cores sequentially?
thanks!
标记 (2)
1 回复
995 次查看
yipingwang
There is no your required function, you need to modify your hardware design for power supply.
%3CLINGO-SUB%20id%3D%22lingo-sub-2184435%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ELX2080%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2184435%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%3CP%3ELX2080%E9%87%8A%E6%94%BE%E5%A4%8D%E4%BD%8D%E7%9E%AC%E9%97%B4%E5%90%AF%E5%8A%A8%E7%94%B5%E6%B5%81%E8%BF%87%E5%A4%A7%EF%BC%8C%E5%AF%BC%E8%87%B4%E6%A0%B8%E7%94%B5%E8%BE%93%E5%87%BA%E8%A2%AB%E6%8B%89%E6%8E%89%EF%BC%8C%E6%9C%89%E4%BB%80%E4%B9%88%E5%8A%9E%E6%B3%95%E8%AE%A9CPU%E6%A0%B8%E7%BC%93%E5%90%AF%E5%8A%A8%E6%88%96%E8%80%858%E4%B8%AA%E6%A0%B8%E5%88%86%E6%97%B6%E4%BE%9D%E6%AC%A1%E5%90%AF%E5%8A%A8%E5%90%97%EF%BC%9F%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3CP%3E%3CSPAN%3EWhen%20the%20LX2080%20releases%20its%20reset%20signal%2C%20the%20inrush%20current%20is%20too%20high%2C%20causing%20the%20core%20power%20output%20to%20be%20pulled%20down.%20Is%20there%20a%20way%20to%20enable%20a%20soft%20start%20for%20the%20CPU%20cores%20or%20stagger%20the%20startup%20of%20the%20eight%20cores%20sequentially%3F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Ethanks!%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2189482%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LX2080%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2189482%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%B2%A1%E6%9C%89%E6%82%A8%E6%89%80%E9%9C%80%E7%9A%84%E5%8A%9F%E8%83%BD%EF%BC%8C%E6%82%A8%E9%9C%80%E8%A6%81%E4%BF%AE%E6%94%B9%E7%A1%AC%E4%BB%B6%E8%AE%BE%E8%AE%A1%E4%BB%A5%E8%8E%B7%E5%BE%97%E7%94%B5%E6%BA%90%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
