LX2080
LX2080
YY2410
LX2080调整核电后导致CPU写保护了,还原核电后,通过Coce-warrior仿真器无法解保护(之前可以解保护),有什么办法解决吗?
After adjusting the VDD power supply for LX2080, the CPU became write-protected. After restoring the VDD power supply, it is impossible to remove the protection using the Coce-warrior simulator (it was possible to remove the protection before). Is there any way to solve this problem?
June_Lu
请详细描述您怎样确认LX2080被锁了,以及之前怎样解保护?
%3CLINGO-SUB%20id%3D%22lingo-sub-2177017%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ELX2080%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2177017%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%3CP%3ELX2080%20adjusted%20the%20core%20power%20caused%20the%20CPU%20write-protected%2C%20after%20restoring%20the%20core%20power%2C%20it%20can't%20be%20unprotected%20by%20Coce-warrior%20emulator%20(before%20it%20can%20be%20unprotected)%2C%20is%20there%20any%20way%20to%20solve%20it%3F%3C%2FP%3E%3CP%3EAfter%20adjusting%20the%20VDD%20power%20supply%20for%20LX2080%2C%20the%20CPU%20became%20write-protected.%20After%20restoring%20the%20VDD%20power%20supply%2C%20it%20is%20impossible%20to%20remove%20the%20protection%20using%20the%20Coce-warrior%20simulator%20(it%20was%20possible%20to%20remove%20the%20protection%20before).%20protection%20before).Is%20there%20any%20way%20to%20solve%20this%20problem%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2177404%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LX2080%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2177404%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%3CP%20style%3D%22margin%3A%200in%3B%20font-size%3A%2011.0pt%3B%22%3E%3CSPAN%3EPlease%20describe%20in%20detail%20how%20you%20confirmed%20the%3C%2FSPAN%3E%3CSPAN%3E%20LX2080%3C%2FSPAN%3E%3CSPAN%3E%20was%20locked%20and%20how%20it%20was%20previously%20unprotected%3F%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
