LX2080/2160,Serial port
1,092件の閲覧回数
YY2410
LX2080 processor. Among a batch of boards, only one exhibits probabilistic gibberish on the serial port at power-on, while the others function normally. What could be the cause of this issue, and where should troubleshooting begin?
thanks!
タグ(3)
1,025件の閲覧回数
yipingwang
If only one LX2080-based board in a batch shows probabilistic gibberish on the serial port at power‑on, while all others behave normally, the issue is almost certainly hardware‑related, not firmware‑related.
Below are the most common root causes and where to start troubleshooting—ranked by likelihood based on similar FPGA/SoC/MCU board behavior.
Most Likely Root Causes
  1. UART clock source instability (crystal / oscillator issue)
If the CPU/UART clock is unstable at early boot, the UART baud rate is wrong temporarily → resulting in random characters.
Common suspects:
  • A defective crystal oscillator (main XO or UART-related PLL reference).
  • Bad solder joints → intermittent oscillation.
  • Wrong or drifting load capacitors.
  • Power‑on ramp too slow for the oscillator.
  1. Power rail instability at startup
If core/IO power rails dip or ramp too slowly, early‑boot logic runs unstable.
Possible issues:
  • Bad PMIC / DC‑DC converter.
  • Bad LDO on that board.
  • Weak or damaged decoupling capacitor (missing, broken, wrong value).
  • Inrush current different from other boards.
UART is often among the first peripherals to show instability.
  1. Poor soldering on the LX2080 or surrounding passives
Symptoms:
  • Intermittent TX pin drive.
  • Clock pin or reset pin connection intermittent.
  • Unstable boot ROM execution.
Causes:
  • BGA solder voids / cold joints.
  • Marginally soldered passives around the UART or oscillator.
This explains the probabilistic nature.
  1. Reset circuit not meeting timing
If reset is released too early or bounces, the chip may start running before power/clock is fully stable.
Check:
  • Reset supervisor IC
  • Reset pull-up/pull-down resistors
  • RC delay components
  1. Damaged or marginal UART transceiver (if external)
If the board uses:
  • RS‑232 transceiver (e.g., MAX3232)
  • USB‑to‑UART chip (e.g., CP2102, CH340, FT232) any marginal chip can scramble output.
Common symptoms:
  • Random characters.
  • Works sometimes after multiple power cycles.
%3CLINGO-SUB%20id%3D%22lingo-sub-2324602%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ELX2080%2F2160%E3%80%81%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%E3%83%9D%E3%83%BC%E3%83%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2324602%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3ELX2080%20%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%E3%80%82%E4%B8%80%E9%80%A3%E3%81%AE%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AE%E3%81%86%E3%81%A1%E3%80%81%E9%9B%BB%E6%BA%90%E6%8A%95%E5%85%A5%E6%99%82%E3%81%AB%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%20%E3%83%9D%E3%83%BC%E3%83%88%E4%B8%8A%E3%81%A7%E7%A2%BA%E7%8E%87%E7%9A%84%E3%81%AA%E6%84%8F%E5%91%B3%E4%B8%8D%E6%98%8E%E3%81%AA%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%82%8B%E3%81%AE%E3%81%AF%201%20%E6%9E%9A%E3%81%A0%E3%81%91%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E3%81%9D%E3%81%AE%E4%BB%96%E3%81%AE%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AF%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AE%E5%8E%9F%E5%9B%A0%E3%81%AF%E4%BD%95%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%3F%20%E3%81%BE%E3%81%9F%E3%80%81%E3%83%88%E3%83%A9%E3%83%96%E3%83%AB%E3%82%B7%E3%83%A5%E3%83%BC%E3%83%86%E3%82%A3%E3%83%B3%E3%82%B0%E3%81%AF%E3%81%A9%E3%81%93%E3%81%8B%E3%82%89%E5%A7%8B%E3%82%81%E3%82%8B%E3%81%B9%E3%81%8D%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%3F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%EF%BC%81%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2325493%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LX2080%2F2160%2CSerial%20port%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2325493%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%83%90%E3%83%83%E3%83%81%E5%86%85%E3%81%AE%3CSTRONG%3E1%20%E3%81%A4%E3%81%AE%3C%2FSTRONG%3ELX2080%20%E3%83%99%E3%83%BC%E3%82%B9%E3%81%AE%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AE%E3%81%BF%E3%81%8C%3CSTRONG%3E%E9%9B%BB%E6%BA%90%E6%8A%95%E5%85%A5%E6%99%82%E3%81%AB%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%20%E3%83%9D%E3%83%BC%E3%83%88%E4%B8%8A%E3%81%A7%E7%A2%BA%E7%8E%87%E7%9A%84%E3%81%AA%E6%84%8F%E5%91%B3%E4%B8%8D%E6%98%8E%E3%81%AA%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%3C%2FSTRONG%3E%E3%82%92%E8%A1%A8%E7%A4%BA%E3%81%97%E3%80%81%E4%BB%96%E3%81%AE%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AF%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%8B%95%E4%BD%9C%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%E3%80%81%E5%95%8F%E9%A1%8C%E3%81%AF%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%3CSTRONG%3E%E9%96%A2%E9%80%A3%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%8F%E3%80%81%E3%83%8F%E3%83%BC%E3%83%89%3C%2FSTRONG%3E%E3%82%A6%E3%82%A7%E3%82%A2%E9%96%A2%E9%80%A3%E3%81%A7%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%BB%E3%81%BC%E7%A2%BA%E5%AE%9F%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E4%BB%A5%E4%B8%8B%E3%81%AF%E3%80%81%3CSTRONG%3E%E6%9C%80%E3%82%82%E4%B8%80%E8%88%AC%E7%9A%84%E3%81%AA%E6%A0%B9%E6%9C%AC%E5%8E%9F%E5%9B%A0%3C%2FSTRONG%3E%E3%81%A8%3CSTRONG%3E%E3%83%88%E3%83%A9%E3%83%96%E3%83%AB%E3%82%B7%E3%83%A5%E3%83%BC%E3%83%86%E3%82%A3%E3%83%B3%E3%82%B0%E3%82%92%E9%96%8B%E5%A7%8B%E3%81%99%E3%82%8B%E5%A0%B4%E6%89%80%3C%2FSTRONG%3E%E3%81%A7%E3%81%82%E3%82%8A%E3%80%81%E5%90%8C%E6%A7%98%E3%81%AE%20FPGA%2FSoC%2FMCU%20%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AE%E5%8B%95%E4%BD%9C%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%84%E3%81%A6%E5%8F%AF%E8%83%BD%E6%80%A7%E9%A0%86%E3%81%AB%E3%83%A9%E3%83%B3%E3%82%AF%E4%BB%98%E3%81%91%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3E%E6%9C%80%E3%82%82%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%AE%E9%AB%98%E3%81%84%E6%A0%B9%E6%9C%AC%E5%8E%9F%E5%9B%A0%3C%2FSTRONG%3E%3C%2FP%3E%0A%3COL%3E%0A%3CLI%3E%3CSTRONG%3E%20UART%20%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%20%E3%82%BD%E3%83%BC%E3%82%B9%E3%81%AE%E4%B8%8D%E5%AE%89%E5%AE%9A%E6%80%A7%20(%E6%B0%B4%E6%99%B6%20%2F%20%E7%99%BA%E6%8C%AF%E5%99%A8%E3%81%AE%E5%95%8F%E9%A1%8C)%3C%2FSTRONG%3E%3C%2FLI%3E%0A%3C%2FOL%3E%0A%3CP%3E%E8%B5%B7%E5%8B%95%E5%88%9D%E6%9C%9F%E3%81%AB%20CPU%2FUART%20%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%81%8C%E4%B8%8D%E5%AE%89%E5%AE%9A%E3%81%AA%E5%A0%B4%E5%90%88%E3%80%81UART%20%E3%83%9C%E3%83%BC%E3%83%AC%E3%83%BC%E3%83%88%E3%81%8C%E4%B8%80%E6%99%82%E7%9A%84%E3%81%AB%E9%96%93%E9%81%95%E3%81%A3%E3%81%A6%E3%81%97%E3%81%BE%E3%81%84%E3%80%81%E3%83%A9%E3%83%B3%E3%83%80%E3%83%A0%E3%81%AA%E6%96%87%E5%AD%97%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%82%88%E3%81%8F%E3%81%82%E3%82%8B%E5%AE%B9%E7%96%91%E8%80%85%3A%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3E%3CSTRONG%3E%E6%B0%B4%E6%99%B6%E7%99%BA%E6%8C%AF%E5%99%A8%3C%2FSTRONG%3E(%E3%83%A1%E3%82%A4%E3%83%B3%20XO%20%E3%81%BE%E3%81%9F%E3%81%AF%20UART%20%E9%96%A2%E9%80%A3%E3%81%AE%20PLL%20%E3%83%AA%E3%83%95%E3%82%A1%E3%83%AC%E3%83%B3%E3%82%B9)%20%E3%81%AB%E6%AC%A0%E9%99%A5%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FLI%3E%0A%3CLI%3E%E3%81%AF%E3%82%93%E3%81%A0%E6%8E%A5%E5%90%88%E4%B8%8D%E8%89%AF%20%E2%86%92%20%E6%96%AD%E7%B6%9A%E7%9A%84%E3%81%AA%E6%8C%AF%E5%8B%95%E3%80%82%3C%2FLI%3E%0A%3CLI%3E%E8%B2%A0%E8%8D%B7%E3%82%B3%E3%83%B3%E3%83%87%E3%83%B3%E3%82%B5%E3%81%8C%E9%96%93%E9%81%95%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%81%8B%E3%83%89%E3%83%AA%E3%83%95%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FLI%3E%0A%3CLI%3E%E9%9B%BB%E6%BA%90%E6%8A%95%E5%85%A5%E3%83%A9%E3%83%B3%E3%83%97%E3%81%8C%E7%99%BA%E6%8C%AF%E5%99%A8%E3%81%AB%E5%AF%BE%E3%81%97%E3%81%A6%E9%81%85%E3%81%99%E3%81%8E%E3%81%BE%E3%81%99%E3%80%82%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CBR%20%2F%3E%0A%3COL%20start%3D%222%22%3E%0A%3CLI%3E%3CSTRONG%3E%20%E8%B5%B7%E5%8B%95%E6%99%82%E3%81%AE%E9%9B%BB%E6%BA%90%E3%83%AC%E3%83%BC%E3%83%AB%E3%81%AE%E4%B8%8D%E5%AE%89%E5%AE%9A%E6%80%A7%3C%2FSTRONG%3E%3C%2FLI%3E%0A%3C%2FOL%3E%0A%3CP%3E%E3%82%B3%E3%82%A2%2FIO%20%E9%9B%BB%E6%BA%90%E3%83%AC%E3%83%BC%E3%83%AB%E3%81%AE%E4%BD%8E%E4%B8%8B%E3%81%BE%E3%81%9F%E3%81%AF%E4%B8%8A%E6%98%87%E3%81%8C%E9%81%85%E3%81%99%E3%81%8E%E3%82%8B%E3%81%A8%E3%80%81%E5%88%9D%E6%9C%9F%E3%83%96%E3%83%BC%E3%83%88%20%E3%83%AD%E3%82%B8%E3%83%83%E3%82%AF%E3%81%8C%E4%B8%8D%E5%AE%89%E5%AE%9A%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E8%80%83%E3%81%88%E3%82%89%E3%82%8C%E3%82%8B%E5%95%8F%E9%A1%8C%3A%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3EPMIC%20%2F%20DC-DC%E3%82%B3%E3%83%B3%E3%83%90%E3%83%BC%E3%82%BF%E3%81%AE%E4%B8%8D%E8%89%AF%E3%81%A7%E3%81%99%E3%80%82%3C%2FLI%3E%0A%3CLI%3E%E3%81%9D%E3%81%AE%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AE%20LDO%20%E3%81%8C%E4%B8%8D%E8%89%AF%E3%81%A7%E3%81%99%E3%80%82%3C%2FLI%3E%0A%3CLI%3E%E3%83%87%E3%82%AB%E3%83%83%E3%83%97%E3%83%AA%E3%83%B3%E3%82%B0%20%E3%82%B3%E3%83%B3%E3%83%87%E3%83%B3%E3%82%B5%E3%81%8C%E5%BC%B1%E3%81%84%E3%81%8B%E6%90%8D%E5%82%B7%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%20(%E6%AC%A0%E8%90%BD%E3%80%81%E7%A0%B4%E6%90%8D%E3%80%81%E9%96%93%E9%81%95%E3%81%A3%E3%81%9F%E5%80%A4)%E3%80%82%3C%2FLI%3E%0A%3CLI%3E%E7%AA%81%E5%85%A5%E9%9B%BB%E6%B5%81%E3%81%8C%E4%BB%96%E3%81%AE%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A8%E7%95%B0%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3EUART%20%E3%81%AF%E3%80%81%E4%B8%8D%E5%AE%89%E5%AE%9A%E6%80%A7%E3%81%8C%E6%9C%80%E5%88%9D%E3%81%AB%E7%8F%BE%E3%82%8C%E3%82%8B%E3%83%9A%E3%83%AA%E3%83%95%E3%82%A7%E3%83%A9%E3%83%AB%E3%81%AE%201%20%E3%81%A4%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3COL%20start%3D%223%22%3E%0A%3CLI%3E%3CSTRONG%3E%20LX2080%E3%81%BE%E3%81%9F%E3%81%AF%E5%91%A8%E5%9B%B2%E3%81%AE%E5%8F%97%E5%8B%95%E9%83%A8%E5%93%81%E3%81%AE%E3%81%AF%E3%82%93%E3%81%A0%E4%BB%98%E3%81%91%E4%B8%8D%E8%89%AF%3C%2FSTRONG%3E%3C%2FLI%3E%0A%3C%2FOL%3E%0A%3CP%3E%E7%97%87%E7%8A%B6%EF%BC%9A%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3E%E6%96%AD%E7%B6%9A%E7%9A%84%E3%81%AA%20TX%20%E3%83%94%E3%83%B3%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%96%E3%80%82%3C%2FLI%3E%0A%3CLI%3E%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%20%E3%83%94%E3%83%B3%E3%81%BE%E3%81%9F%E3%81%AF%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%20%E3%83%94%E3%83%B3%E3%81%AE%E6%8E%A5%E7%B6%9A%E3%81%8C%E6%96%AD%E7%B6%9A%E7%9A%84%E3%81%A7%E3%81%99%E3%80%82%3C%2FLI%3E%0A%3CLI%3E%E3%83%96%E3%83%BC%E3%83%88%20ROM%20%E3%81%AE%E5%AE%9F%E8%A1%8C%E3%81%8C%E4%B8%8D%E5%AE%89%E5%AE%9A%E3%81%A7%E3%81%99%E3%80%82%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3E%E5%8E%9F%E5%9B%A0%3A%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3EBGA%20%E3%81%AF%E3%82%93%E3%81%A0%E3%83%9C%E3%82%A4%E3%83%89%2F%E3%82%B3%E3%83%BC%E3%83%AB%E3%83%89%E3%82%B8%E3%83%A7%E3%82%A4%E3%83%B3%E3%83%88%E3%80%82%3C%2FLI%3E%0A%3CLI%3EUART%20%E3%81%BE%E3%81%9F%E3%81%AF%E7%99%BA%E6%8C%AF%E5%99%A8%E3%81%AE%E5%91%A8%E5%9B%B2%E3%81%AB%E5%8F%97%E5%8B%95%E9%83%A8%E5%93%81%E3%82%92%E3%82%8F%E3%81%9A%E3%81%8B%E3%81%AB%E3%81%AF%E3%82%93%E3%81%A0%E4%BB%98%E3%81%91%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3E%E3%81%93%E3%82%8C%E3%81%AF%3CSTRONG%3E%E7%A2%BA%E7%8E%87%E7%9A%84%E3%81%AA%3C%2FSTRONG%3E%E6%80%A7%E8%B3%AA%E3%82%92%E8%AA%AC%E6%98%8E%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3COL%20start%3D%224%22%3E%0A%3CLI%3E%3CSTRONG%3E%20%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E5%9B%9E%E8%B7%AF%E3%81%8C%E3%82%BF%E3%82%A4%E3%83%9F%E3%83%B3%E3%82%B0%E3%82%92%E6%BA%80%E3%81%9F%E3%81%97%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%3C%2FSTRONG%3E%3C%2FLI%3E%0A%3C%2FOL%3E%0A%3CP%3E%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%81%8C%E6%97%A9%E3%81%99%E3%81%8E%E3%82%8B%E3%82%BF%E3%82%A4%E3%83%9F%E3%83%B3%E3%82%B0%E3%81%A7%E8%A7%A3%E9%99%A4%E3%81%95%E3%82%8C%E3%81%9F%E3%82%8A%E3%80%81%E3%83%90%E3%82%A6%E3%83%B3%E3%82%B9%E3%81%97%E3%81%9F%E3%82%8A%E3%81%97%E3%81%9F%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E9%9B%BB%E6%BA%90%2F%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%81%8C%E5%AE%8C%E5%85%A8%E3%81%AB%E5%AE%89%E5%AE%9A%E3%81%99%E3%82%8B%E5%89%8D%E3%81%AB%E3%83%81%E3%83%83%E3%83%97%E3%81%8C%E5%8B%95%E4%BD%9C%E3%82%92%E9%96%8B%E5%A7%8B%E3%81%99%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E7%A2%BA%E8%AA%8D%EF%BC%9A%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3E%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%82%B9%E3%83%BC%E3%83%91%E3%83%BC%E3%83%90%E3%82%A4%E3%82%B6IC%3C%2FLI%3E%0A%3CLI%3E%E3%83%97%E3%83%AB%E3%82%A2%E3%83%83%E3%83%97%2F%E3%83%97%E3%83%AB%E3%83%80%E3%82%A6%E3%83%B3%E6%8A%B5%E6%8A%97%E3%82%92%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%81%99%E3%82%8B%3C%2FLI%3E%0A%3CLI%3ERC%E9%81%85%E5%BB%B6%E9%83%A8%E5%93%81%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CBR%20%2F%3E%0A%3COL%20start%3D%225%22%3E%0A%3CLI%3E%3CSTRONG%3E%20%E6%90%8D%E5%82%B7%E3%81%97%E3%81%9F%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AF%E9%99%90%E7%95%8C%E7%8A%B6%E6%85%8B%E3%81%AE%20UART%20%E3%83%88%E3%83%A9%E3%83%B3%E3%82%B7%E3%83%BC%E3%83%90%20(%E5%A4%96%E9%83%A8%E3%81%AE%E5%A0%B4%E5%90%88)%3C%2FSTRONG%3E%3C%2FLI%3E%0A%3C%2FOL%3E%0A%3CP%3E%E3%83%9C%E3%83%BC%E3%83%89%E3%81%8C%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%82%82%E3%81%AE%3A%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3ERS-232%E3%83%88%E3%83%A9%E3%83%B3%E3%82%B7%E3%83%BC%E3%83%90%EF%BC%88%E4%BE%8B%EF%BC%9AMAX3232%EF%BC%89%3C%2FLI%3E%0A%3CLI%3EUSB-UART%20%E3%83%81%E3%83%83%E3%83%97%20(%E4%BE%8B%3A%20CP2102%E3%80%81CH340%E3%80%81FT232)%20%E3%81%AE%E9%99%90%E7%95%8C%E3%83%81%E3%83%83%E3%83%97%E3%81%AF%E5%87%BA%E5%8A%9B%E3%82%92%E3%82%B9%E3%82%AF%E3%83%A9%E3%83%B3%E3%83%96%E3%83%AB%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3E%E4%B8%80%E8%88%AC%E7%9A%84%E3%81%AA%E7%97%87%E7%8A%B6%3A%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3E%E3%83%A9%E3%83%B3%E3%83%80%E3%83%A0%E3%81%AA%E6%96%87%E5%AD%97%E3%80%82%3C%2FLI%3E%0A%3CLI%3E%E9%9B%BB%E6%BA%90%E3%82%92%E8%A4%87%E6%95%B0%E5%9B%9E%E5%85%A5%E3%82%8C%E7%9B%B4%E3%81%97%E3%81%9F%E5%BE%8C%E3%81%A7%E3%82%82%E6%99%82%E3%80%85%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
