LS1046ARDB accessories -RJ45-to-DB9F compatibility and pin configuration.
ソリューションへジャンプ
1,461件の閲覧回数
Kavinravi
We are developing a module with an LS1046A processor. We use a micro-D (D-Sub) 9-pin connector (instead of RJ45) to achieve 1GbE. We also have an LS1046ARDB which comes with a RJ45-to-DB9F cable. I was wondering if we could use the cable assembly (RJ45-to-DB9F) in our module to communicate with the PC through Ethernet protocol.
RJ45-to-DB9F cable setup:-The RJ45 UTP will be connected to the RJ45 Female jack on the PC and the DB9F will be connected to a micro-D connector in our module.
Would you please provide us with the pin configuration of the RJ45-to-DB9F cable? It helps us to configure the micro-D connector in our module.
Thank you for your support.
