LS1046 ethernet
LS1046 ethernet
SimonRo
My custom LS1046 board has an Ethernet interface with DP83867 phy connected to EC1_RGMII.
This appears correctly in uboot as fm1-mac3 and I can successfully ping.
However, when linux boots (flexbuild image ubuntu:main) I have the device fm1-mac1 and it fails to come up/ping.
Can anyone please suggest where I need to look to fix this mapping?
SimonRo
I found the problem - my fsl-ls1046-board-sdk.dts did not have the correct ethernet interfaces disabled. Now that 0 and 1 are disabled and 2 is enabled, and configs/linux/linux_arm64_LS.its references the sdk.dts file, ethernet works.
SimonRo
SimonRo
On a working LS1046ARDB EC1 RGMII comes up like this:
[    6.448783] fsl_dpa soc:fsl,dpaa:ethernet@2 fm1-mac3: renamed from eth0
[  110.759302] IPv6: ADDRCONF(NETDEV_CHANGE): fm1-mac3: link becomes ready
My non working board which should be using EC1 RGMII says this:
[    7.905061] fsl_dpa soc:fsl,dpaa:ethernet@0 fm1-mac1: renamed from eth0
[   12.176080] IPv6: ADDRCONF(NETDEV_CHANGE): fm1-mac1: link becomes ready
even though it uses fm1-mac3 correctly in uboot.
What in the flexbuild build controls which device is used?
SimonRo
My Linux device tree looks like:
&fman0 {
	ethernet@e0000 {
		phy-handle = <&rgmii_phy1>;
		phy-connection-type = "rgmii-id";
	mdio@fc000 {
		rgmii_phy1: ethernet-phy@1 {
			compatible = "ethernet-phy-ieee802.3-c22";
			reg = <0x1>;
			ti,rx-internal-delay = <DP83867_RGMIIDCTL_2_00_NS>;
			ti,tx-internal-delay = <DP83867_RGMIIDCTL_2_00_NS>;
			ti,fifo-depth = <DP83867_PHYCR_FIFO_DEPTH_4_B_NIB>;
			ti,clk-output-sel = <DP83867_CLK_O_SEL_CHN_A_RCLK>;
			enet-phy-lane-no-swap;
SimonRo
That's not my problem. In u-boot the ethernet interface appears as fm1-mac3. The device tree for this is:
&fman0 {
	ethernet@e4000 {
		status = "okay";
	mdio@fc000 {
			reg = <0x1>;
			ti,clk-output-sel = <0x0>;
When subsequently booted to an ubuntu:main image built by flexbuilder LSDK21.10 the system detects and configures fm1-mac1 only. I can configure this device but it won't ping. Oscilloscope shows no data on the rgmii lines at this point.
If I use a device tree for Linux similar to the above I get:
[ 2.357640] Freescale FM module, FMD API version 21.1.0
[ 2.365586] Freescale FM Ports module
[ 2.369254] fsl_mac: fsl_mac: FSL FMan MAC API based driver
[ 2.375016] fsl_mac 1ae0000.ethernet: Cannot read PHY connection type of mac node ethernet@e0000 from device tree. Defaulting to MII
[ 2.386945] Unable to handle kernel NULL pointer dereference at virtual address 0000000000000000
It feels like linux should also be using the e4000 device.
Oswalag
Hello.
You may enable the desired port in /etc/network/interfaces file. You may try first with static IP by adding the information below in such file.
For a DHCP client:
auto eth1 (the name of the interface)
iface eth1 inet dhcp
For a Static IP (of course this is an example, your numbers will be different):
auto eth1
iface eth1 inet static
address 192.168.0.100
network 192.168.0.0
netmask 255.255.255.0
broadcast 192.168.0.255
gateway 192.168.0.1
%3CLINGO-SUB%20id%3D%22lingo-sub-2035224%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ELS1046%20ethernet%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2035224%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EMy%20custom%20LS1046%20board%20has%20an%20Ethernet%20interface%20with%20DP83867%20phy%20connected%20to%20EC1_RGMII.%26nbsp%3B%26nbsp%3B%3C%2FP%3E%3CP%3EThis%20appears%20correctly%20in%20uboot%20as%20fm1-mac3%20and%20I%20can%20successfully%20ping.%3C%2FP%3E%3CP%3EHowever%2C%20when%20linux%20boots%20(flexbuild%20image%20ubuntu%3Amain)%20I%20have%20the%20device%20fm1-mac1%20and%20it%20fails%20to%20come%20up%2Fping.%26nbsp%3B%3C%2FP%3E%3CP%3ECan%20anyone%20please%20suggest%20where%20I%20need%20to%20look%20to%20fix%20this%20mapping%3F%3C%2FP%3E%3CP%3EThanks%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2039183%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20LS1046%20ethernet%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2039183%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI%20found%20the%20problem%20-%20my%20fsl-ls1046-board-sdk.dts%20did%20not%20have%20the%20correct%20ethernet%20interfaces%20disabled.%20Now%20that%200%20and%201%20are%20disabled%20and%202%20is%20enabled%2C%20and%20configs%2Flinux%2Flinux_arm64_LS.its%20references%20the%20sdk.dts%20file%2C%20ethernet%20works.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2038670%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20LS1046%20ethernet%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2038670%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EOn%20a%20working%20LS1046ARDB%20EC1%20RGMII%20comes%20up%20like%20this%3A%3C%2FP%3E%3CP%3E%3CSPAN%3E%5B%20%26nbsp%3B%20%26nbsp%3B6.448783%5D%20fsl_dpa%20soc%3Afsl%2Cdpaa%3Aethernet%402%20fm1-mac3%3A%20renamed%20from%20eth0%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3E%5B%20%26nbsp%3B110.759302%5D%20IPv6%3A%20ADDRCONF(NETDEV_CHANGE)%3A%20fm1-mac3%3A%20link%20becomes%20ready%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3EMy%20non%20working%20board%20which%20should%20be%20using%20EC1%20RGMII%20says%20this%3A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%5B%20%26nbsp%3B%20%26nbsp%3B7.905061%5D%20fsl_dpa%20soc%3Afsl%2Cdpaa%3Aethernet%400%20fm1-mac1%3A%20renamed%20from%20eth0%26nbsp%3B%3CBR%20%2F%3E%5B%20%26nbsp%3B%2012.176080%5D%20IPv6%3A%20ADDRCONF(NETDEV_CHANGE)%3A%20fm1-mac1%3A%20link%20becomes%20ready%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3Eeven%20though%20it%20uses%20fm1-mac3%20correctly%20in%20uboot.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EWhat%20in%20the%20flexbuild%20build%20controls%20which%20device%20is%20used%3F%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2038643%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20LS1046%20ethernet%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2038643%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EMy%20Linux%20device%20tree%20looks%20like%3A%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%3E%26amp%3Bfman0%20%7B%0A%09ethernet%40e0000%20%7B%0A%09%09phy-handle%20%3D%20%26lt%3B%26amp%3Brgmii_phy1%26gt%3B%3B%0A%09%09phy-connection-type%20%3D%20%22rgmii-id%22%3B%0A%09%7D%3B%0A%0A%09mdio%40fc000%20%7B%0A%09%09rgmii_phy1%3A%20ethernet-phy%401%20%7B%0A%09%09%09compatible%20%3D%20%22ethernet-phy-ieee802.3-c22%22%3B%0A%09%09%09reg%20%3D%20%26lt%3B0x1%26gt%3B%3B%0A%09%09%09ti%2Crx-internal-delay%20%3D%20%3CDP83867_RGMIIDCTL_2_00_NS%3E%3B%0A%09%09%09ti%2Ctx-internal-delay%20%3D%20%3CDP83867_RGMIIDCTL_2_00_NS%3E%3B%0A%09%09%09ti%2Cfifo-depth%20%3D%20%3CDP83867_PHYCR_FIFO_DEPTH_4_B_NIB%3E%3B%0A%09%09%09ti%2Cclk-output-sel%20%3D%20%3CDP83867_CLK_O_SEL_CHN_A_RCLK%3E%3B%0A%09%09%09enet-phy-lane-no-swap%3B%0A%09%09%7D%3B%3C%2FDP83867_CLK_O_SEL_CHN_A_RCLK%3E%3C%2FDP83867_PHYCR_FIFO_DEPTH_4_B_NIB%3E%3C%2FDP83867_RGMIIDCTL_2_00_NS%3E%3C%2FDP83867_RGMIIDCTL_2_00_NS%3E%3C%2FCODE%3E%3C%2FPRE%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2038640%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20LS1046%20ethernet%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2038640%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThat's%20not%20my%20problem.%20In%20u-boot%20the%20ethernet%20interface%20appears%20as%26nbsp%3B%3CSPAN%3Efm1-mac3.%20The%20device%20tree%20for%20this%20is%3A%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%3E%26amp%3Bfman0%20%7B%0A%09ethernet%40e4000%20%7B%0A%09%09phy-handle%20%3D%20%26lt%3B%26amp%3Brgmii_phy1%26gt%3B%3B%0A%09%09phy-connection-type%20%3D%20%22rgmii-id%22%3B%0A%09%09status%20%3D%20%22okay%22%3B%0A%09%7D%3B%0A%09%0A%09mdio%40fc000%20%7B%0A%09%09rgmii_phy1%3A%20ethernet-phy%401%20%7B%0A%09%09%09reg%20%3D%20%26lt%3B0x1%26gt%3B%3B%0A%09%09%09ti%2Cclk-output-sel%20%3D%20%26lt%3B0x0%26gt%3B%3B%0A%09%09%7D%3B%0A%09%7D%3B%0A%7D%3B%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CP%3EWhen%20subsequently%20booted%20to%20an%20ubuntu%3Amain%20image%20built%20by%20flexbuilder%20LSDK21.10%20the%20system%20detects%20and%20configures%20fm1-mac1%20only.%20I%20can%20configure%20this%20device%20but%20it%20won't%20ping.%20Oscilloscope%20shows%20no%20data%20on%20the%20rgmii%20lines%20at%20this%20point.%3C%2FP%3E%3CP%3EIf%20I%20use%20a%20device%20tree%20for%20Linux%20similar%20to%20the%20above%20I%20get%3A%3C%2FP%3E%3CP%3E%5B%202.357640%5D%20Freescale%20FM%20module%2C%20FMD%20API%20version%2021.1.0%3CBR%20%2F%3E%5B%202.365586%5D%20Freescale%20FM%20Ports%20module%3CBR%20%2F%3E%5B%202.369254%5D%20fsl_mac%3A%20fsl_mac%3A%20FSL%20FMan%20MAC%20API%20based%20driver%3CBR%20%2F%3E%5B%202.375016%5D%20fsl_mac%201ae0000.ethernet%3A%20Cannot%20read%20PHY%20connection%20type%20of%20mac%20node%20ethernet%40e0000%20from%20device%20tree.%20Defaulting%20to%20MII%3CBR%20%2F%3E%5B%202.386945%5D%20Unable%20to%20handle%20kernel%20NULL%20pointer%20dereference%20at%20virtual%20address%200000000000000000%3C%2FP%3E%3CP%3EIt%20feels%20like%20linux%20should%20also%20be%20using%20the%20e4000%20device.%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2035248%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20LS1046%20ethernet%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2035248%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EYou%20may%20enable%20the%20desired%20port%20in%20%2Fetc%2Fnetwork%2Finterfaces%20file.%20You%20may%20try%20first%20with%20static%20IP%20by%20adding%20the%20information%20below%20in%20such%20file.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EFor%20a%20DHCP%20client%3A%3C%2FP%3E%0A%3CP%3Eauto%20eth1%20(the%20name%20of%20the%20interface)%3C%2FP%3E%0A%3CP%3Eiface%20eth1%20inet%20dhcp%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EFor%20a%20Static%20IP%20(of%20course%20this%20is%20an%20example%2C%20your%20numbers%20will%20be%20different)%3A%3C%2FP%3E%0A%3CP%3Eauto%20eth1%3C%2FP%3E%0A%3CP%3Eiface%20eth1%20inet%20static%3C%2FP%3E%0A%3CP%3Eaddress%20192.168.0.100%3C%2FP%3E%0A%3CP%3Enetwork%20192.168.0.0%3C%2FP%3E%0A%3CP%3Enetmask%20255.255.255.0%3C%2FP%3E%0A%3CP%3Ebroadcast%20192.168.0.255%3C%2FP%3E%0A%3CP%3Egateway%20192.168.0.1%3C%2FP%3E%3C%2FLINGO-BODY%3E
