LS1046 does not boot from SD card
douglassilva
I am trying to boot from SD card, LS1046 using OK1046A-C2 Single Board Computer from forlinx.
I am flashing the SD card using the following command
flex-installer -i auto -m ls1046ardb -d /dev/sdq -p 4P=128M:2G:8G:-1
And it installs all partitions into SD card successfully(attached file showing instalation finishing successfully)
But then when I connect it to OK1046-C2 board and try to boot these are the kernel messages I get(full boot log attached)
[ 3.108076] mmc0: SDHCI controller on 1560000.esdhc [1560000.esdhc] using ADMA 64-bit
[ 3.108968] Freescale USDPAA process IRQ driver
[ 3.112360] optee: probing for conduit method.
[ 3.125802] optee: revision 2.6
[ 3.126122] optee: initialized driver
[ 3.138321] NET: Registered protocol family 26
[ 3.142792] u32 classifier
[ 3.145510] input device check on
[ 3.149185] Actions configured
[ 3.152903] Initializing XFRM netlink socket
[ 3.157214] NET: Registered protocol family 10
[ 3.162081] Segment Routing with IPv6
[ 3.165785] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[ 3.171894] NET: Registered protocol family 17
[ 3.176352] NET: Registered protocol family 15
[ 3.180809] Bridge firewalling registered
[ 3.184924] 8021q: 802.1Q VLAN Support v1.8
[ 3.189111] lib80211: common routines for IEEE802.11 drivers
[ 3.193552] mmc0: error -110 whilst initialising SD card
[ 3.200103] 9pnet: Installing 9P2000 support
[ 3.204387] tsn generic netlink module v1 init...
[ 3.209119] Key type dns_resolver registered
[ 3.213550] registered taskstats version 1
[ 3.217654] Loading compiled-in X.509 certificates
[ 3.223313] Btrfs loaded, crc32c=crc32c-generic
[ 3.229821] ALSA device list:
[ 3.232784] No soundcards found.
[ 3.236370] Waiting for root device PARTUUID=c52a6a85-04...
[ 3.339452] random: crng init done
Oswalag
Which version of LSDK are you testing?
douglassilva
I am testing with LSDK 2108, but I did not had successfull results with 2012 either.
%3CLINGO-SUB%20id%3D%22lingo-sub-2175961%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ELS1046%20does%20not%20boot%20from%20SD%20card%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2175961%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI%20am%20trying%20to%20boot%20from%20SD%20card%2C%20LS1046%20using%20OK1046A-C2%20Single%20Board%20Computer%20from%20forlinx.%3C%2FP%3E%3CP%3EI%20am%20flashing%20the%20SD%20card%20using%20the%20following%20command%3C%2FP%3E%3CP%3Eflex-installer%20-i%20auto%20-m%20ls1046ardb%20-d%20%2Fdev%2Fsdq%20-p%204P%3D128M%3A2G%3A8G%3A-1%3C%2FP%3E%3CP%3EAnd%20it%20installs%20all%20partitions%20into%20SD%20card%20successfully(attached%20file%20showing%20instalation%20finishing%20successfully)%3C%2FP%3E%3CP%3EBut%20then%20when%20I%20connect%20it%20to%20OK1046-C2%20board%20and%20try%20to%20boot%20these%20are%20the%20kernel%20messages%20I%20get(full%20boot%20log%20attached)%3C%2FP%3E%3CP%3E%5B%203.108076%5D%20mmc0%3A%20SDHCI%20controller%20on%201560000.esdhc%20%5B1560000.esdhc%5D%20using%20ADMA%2064-bit%3CBR%20%2F%3E%5B%203.108968%5D%20Freescale%20USDPAA%20process%20IRQ%20driver%3CBR%20%2F%3E%5B%203.112360%5D%20optee%3A%20probing%20for%20conduit%20method.%3CBR%20%2F%3E%5B%203.125802%5D%20optee%3A%20revision%202.6%3CBR%20%2F%3E%5B%203.126122%5D%20optee%3A%20initialized%20driver%3CBR%20%2F%3E%5B%203.138321%5D%20NET%3A%20Registered%20protocol%20family%2026%3CBR%20%2F%3E%5B%203.142792%5D%20u32%20classifier%3CBR%20%2F%3E%5B%203.145510%5D%20input%20device%20check%20on%3CBR%20%2F%3E%5B%203.149185%5D%20Actions%20configured%3CBR%20%2F%3E%5B%203.152903%5D%20Initializing%20XFRM%20netlink%20socket%3CBR%20%2F%3E%5B%203.157214%5D%20NET%3A%20Registered%20protocol%20family%2010%3CBR%20%2F%3E%5B%203.162081%5D%20Segment%20Routing%20with%20IPv6%3CBR%20%2F%3E%5B%203.165785%5D%20sit%3A%20IPv6%2C%20IPv4%20and%20MPLS%20over%20IPv4%20tunneling%20driver%3CBR%20%2F%3E%5B%203.171894%5D%20NET%3A%20Registered%20protocol%20family%2017%3CBR%20%2F%3E%5B%203.176352%5D%20NET%3A%20Registered%20protocol%20family%2015%3CBR%20%2F%3E%5B%203.180809%5D%20Bridge%20firewalling%20registered%3CBR%20%2F%3E%5B%203.184924%5D%208021q%3A%20802.1Q%20VLAN%20Support%20v1.8%3CBR%20%2F%3E%5B%203.189111%5D%20lib80211%3A%20common%20routines%20for%20IEEE802.11%20drivers%3CBR%20%2F%3E%5B%203.193552%5D%20mmc0%3A%20error%20-110%20whilst%20initialising%20SD%20card%3CBR%20%2F%3E%5B%203.200103%5D%209pnet%3A%20Installing%209P2000%20support%3CBR%20%2F%3E%5B%203.204387%5D%20tsn%20generic%20netlink%20module%20v1%20init...%3CBR%20%2F%3E%5B%203.209119%5D%20Key%20type%20dns_resolver%20registered%3CBR%20%2F%3E%5B%203.213550%5D%20registered%20taskstats%20version%201%3CBR%20%2F%3E%5B%203.217654%5D%20Loading%20compiled-in%20X.509%20certificates%3CBR%20%2F%3E%5B%203.223313%5D%20Btrfs%20loaded%2C%20crc32c%3Dcrc32c-generic%3CBR%20%2F%3E%5B%203.229821%5D%20ALSA%20device%20list%3A%3CBR%20%2F%3E%5B%203.232784%5D%20No%20soundcards%20found.%3CBR%20%2F%3E%5B%203.236370%5D%20Waiting%20for%20root%20device%20PARTUUID%3Dc52a6a85-04...%3CBR%20%2F%3E%5B%203.339452%5D%20random%3A%20crng%20init%20done%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2176273%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LS1046%20does%20not%20boot%20from%20SD%20card%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2176273%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EI%20am%20testing%20with%20LSDK%202108%2C%20but%20I%20did%20not%20had%20successfull%20results%20with%202012%20either.%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2176240%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LS1046%20does%20not%20boot%20from%20SD%20card%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2176240%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%3C%2FP%3E%0A%3CP%3EWhich%20version%20of%20LSDK%20are%20you%20testing%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E
