LS1043ARDB - LSDK application for hardware diagnostics
ソリューションへジャンプ
2,358件の閲覧回数
ts1234
Is there any LSDK application to perform the hardware diagnostics on LS1043ARDB?
2,332件の閲覧回数
yipingwang
"lspci -v"  for PCI
"lsusb", "fdisk", "mkfs.ext4", "mount", "dd", "cp" for USB device.
"ping", "iperf", "netperf" for Ethernet.
4 返答(返信)
2,311件の閲覧回数
ts1234
Thanks for providing the open source tools info for HW diagnosis.
I was also looking for something that is developed by NXP, specially for layerscape products.
2,350件の閲覧回数
yipingwang
There are many applications in LSDK can provide hardware diagnostics, for example commands to check hardware information https://www.binarytides.com/linux-commands-hardware-info/
Hardware test application i2c, nand, Lm-sensors, memtester, lmbench, fdisk,etc.
Which hardware block do you focus on?
2,346件の閲覧回数
ts1234
Is there a proprietary application for diagnosis of the PCIe, USB and Network Interfaces on LS1043ARDB?
2,333件の閲覧回数
yipingwang
"lspci -v"  for PCI
