LS1043A interface with DDR4
2,151 次查看
Pamid
We would like to use   LS1043A custom board with  DDR4 in 16bit mode. Regarding this  Please confirm the interface connections between LS1043A and  DDR4 as per attached doc.
What is the use of  MA14\MBG1 in 16 bit mode.
2,110 次查看
yipingwang
the diagram looks correct. MA14/MBG1 is used when x8 DDR4 DRAM chips are used (x8 has 4 bank groups). x16 DDR4 does not use the BG1 (it has two bank groups)
