LS1043A USB compliance test
2,020 次查看
CurtisChen
      Is there any LS1043A USB certification note for doing USB 2.0/3.0 compliance test?
      I am not sure is there any tool or method to do full USB compliance test? (eg. USB PHY register ...etc)
      Please share me the related document for my reference.
      Thanks.
标记 (2)
2 回复数
1,620 次查看
micha
Hello
DId you get an answer from NXP ?
I want to test a LS1046 USB interface,
it was easy with an T1046, just setting two register and we could measure eye diagram's
Mike
1,816 次查看
Vivekn92
I have the same question as above, are there any guidelines on setting LS1043 registers to force the USB into different states to perform compliance testing and check the eye diagram?
Vivek
