LS1043A Debug APB Slave Address Map
Xiemens
HI, I had found Address Map for APB-AP mapped debug modules in Table 79-5. of  S32V234RM.pdf https://www.nxp.com.cn/webapp/Download?colCode=S32V234RM&docLang=en
But I can't found Address Map for APB-AP mapped debug modules in LS1043ARM.pdf   https://www.nxp.com.cn/webapp/Download?colCode=LS1043ARM&lang_cd=zh
Where I can get it?
BR.
yipingwang
Please refer to "Appendix C EPU register descriptions" in LS1043ARM.
Xiemens
@yipingwang
Thanks to reply.
The "Appendix C EPU register descriptions" mentioned Event Processor Debug Reservation Register n (EPRSRV0 - EPRSRV7) , Is it similar to Table 79-5. of  S32V234RM?
Debug APB Component         System Address
Cortex-A53A ROM Table         0x40089000
Cortex-A53 A0 Debug              0x4008A000
Cortex-A53 A0 CTI                   0x40089000
For a = 0 to 7:
($DCSR_BASE + $EPU_BASE + EPRSRVa) = 0x07_0000_0000 + 0x6_0000 +
FECh + (a × -4h) = 0x07_0006_0FECh +(a × -4h)
Cortex-A53 A0 Debug              7_0006_0FECh +(0 × -4h)
Cortex-A53 A0 CTI                  7_0006_0FECh + (1 × -4h)
Cortex-A53 A1 Debug              7_0006_0FECh +(2 × -4h)
Cortex-A53 A1 CTI                  7_0006_0FECh + (3 × -4h)
Is that correct ??
yipingwang
I will discuss with the AE team, will provide more update later.
Xiemens
@yipingwang  Hi,What about the Latest progress of Debug Adress Map?
I have another question about CodeWarrior TAP support for Eclipse IDE and where can I get the reference document?
yipingwang
Please refer to the following update from the AE team.
The LS1043A does not have an APB AP module in it.
yipingwang
For CodeWarrior TAP, you need to install the latest CodeWarrior for ARMv8 11.5.12.
The attached is CodeWarrior for ARMv8 user manual.
