LS1028ARDB IEEE1588 Test
NanWang
Hi, NXP guys
I want to test IEEE1588 on LS1028ARDB. I can only find documentation about "Quick Start for IEEE 1588" and use linuxptp software for IEEE1588. But I don't know how to use J11, J12 and J13 for IEEE1588 on LS1028ARDB (PCB board). I don't find any documentation for LS1028ARDB 1588 1PPS test. Can you provide any good suggestions for us? Thank you very much.
BRs.
yipingwang
Please refer to section "8.7.7 Quick start for external signals" in LSDK 21.08 user manual.
NanWang
I have executed the following commands on LS1028ARDB:
ethtool -T  eno0
ptp4l -i eno0 -m &
echo 1 > /sys/class/ptp/ptp0/pps_enable
cat /sys/class/pps/pps0/assert   # check latest timestamp of PPS event
But I can't get PPS waveform on digital oscilloscope through J12 (IEEE1588) on LS1028ARDB. In other words, there is nothing happened on oscilloscope. Is there any good suggestions? Thanks.
By the way, I just want to check PPS waveform on digital oscilloscope through J12.
BRs.
yipingwang
You need to modify the dts according to Documentation/devicetree/bindings/ptp/ptp-qoriq.txt.
