LS1028A power sequencing
ソリューションへジャンプ
1,414件の閲覧回数
mkraj
I am planning to change the power sequence design of LS1028A RDB with an external power sequencer UCD9081( instead of using PMIC and reference board power ICs). Will follow the power sequence as per datasheet.
Is it required to take any special care while changing  the power devices?
mkraj
1,394件の閲覧回数
mrudangshelat-13
Hi @mkraj,
There is no issue to change the power device as long as the power sequence mentioned in the LS1046A is followed.
Mrudang
1,395件の閲覧回数
mrudangshelat-13
Hi @mkraj,
Mrudang
