LS1028A: How do I capture frames through port mirroring
1,050 次查看
zhaohengyi
I have 3 custom LS1028A boards, one is used as a switch, and the other two link with the switch. My host PC also link with the switch, and PC installed wireshark which used to capture frames. I want to capture the frames through port mirroring.
0 回复数
