LS1021ARM manual
2,015件の閲覧回数
renaud
LS1021A manual Rev 3.1 has some errors in the  description of the PCIe registers.
For instance, in  LNnGCR1:
bits 12-13 and 14-15 are two pairs of bits but the values assigned have 3 bits.
2,010件の閲覧回数
mrudangshelat-13
Hi @renaud,
Please check the register's description which is as follow, Exit electrical idle filter select = {REIDL_EX_MSB,REIDL_EX_SEL}. Check the both field for the needful setting.
Mrudang Shelat
2 返答(返信)
2,011件の閲覧回数
mrudangshelat-13
Hi @renaud,
Mrudang Shelat
2,014件の閲覧回数
renaud
Correction, it is the SerDes registers.
