LS1021AIOT - Yocto/OpenIL/RTE/OpenWRT Booting from QSPI
1,968件の閲覧回数
Kensou
Hello everybody, I am trying to implement on of Linux options (such as Yocto/OpenIL/Real Time Edge/OpenWRT)  in LS1021A-IOT Boards.
Unfortunately, it seems that none of these implement booting from QSPI Nor in LS1021A-IOT boards (LS1021A-TWR, which QSPI boot is supported, seems to be unavailable anywhere).
Is there a simple way for having at least uboot with spl from QSPI in LS1021A-IOT?
Thank you in advance
5 返答(返信)
1,946件の閲覧回数
yipingwang
In u-boot source code, configs/ls1021aiot_qspi_defconfig is provided, please build image with this configuration.
1,925件の閲覧回数
Kensou
With ls1021aiot_qspi_defconfig i am able to generate uboot-spl.bin or I have to change RCW too?
1,896件の閲覧回数
yipingwang
You need to generate separate RCW booting from QSPI.
1,894件の閲覧回数
Kensou
Is there a tutorial, or did someone already make the RCW for the LS1021AIOT board?
1,882件の閲覧回数
yipingwang
You could use CodeWarrior QCVS tool to assist you to generate RCW booting from QSPI.
Then refer to https://community.nxp.com/t5/QorIQ-Knowledge-Base/Booting-from-QSPI-on-LS102xA/ta-p/1099418
