LS1021A Core Soft Reset Mechanic
895 次查看
Xi-nanWang
Im using LS1021A on bareboard with a RTOS which using FTM for OS tick. However, the FTM isnot working after core1 reboots from a core soft reset,  no interrupt generated.I tried to leave the FTM alone or do the same config step as the POR, neither work. Generally speaking, What is the Mechanic of a core soft reset and How to reinitialize the core and corresponding  peripherals?
0 回复数
