LS1012A SATA CAPACITY
1,177 次查看
kaan1
I used LS1012A in my custom board.I routed out SATA 3.0 interface to SATA connector. What is the maximum memory capacity for SATA 3.0 of LS1012A  ?
Thanks in advance
标签 (1)
1 回复
1,171 次查看
ufedor
The ATA standard allows 48 bits for accessing drives in LBA mode, so the theoretical maximum capacity is:
2^48 sectors x 512 bytes per sector = 131072 TiB = 128 PiB
