LA1224 LS-DCS & TBGen
已解决
跳至解决方案
945 次查看
flappy
Hello!
Could you tell me how to enable continuous synchronous operation of 4T4R on the LA1224-RDB-LS?
I'm using 0-3 VSPA cores to run LS-DCS0 and LS-DCS1.
1DAC and 1ADC are running on each core.
I have interrupt handlers for TBGEN, and I configured TBGEN in FDD mode. But I'm not receiving interrupts from it on the VSPA.
I was able to run 2T2R synchronously, but in this case, either the ADC or DAC is running on each core.
Perhaps I haven't configured all the TBGEn timers?
I'm transmitting a single-tone signal generated using NCO with 8192 samples. I'm sure I generated the NCO parameters correctly.
But why do I see phase jumps on the ADC during loopback?
1 解答
931 次查看
Bio_TICFSL
The key point is that TBGEN timed-interrupt timers 1–11 are VSPA trigger sources, not VSPA interrupt sources . Only Timed Interrupt Timer 0 can generate an MCU interrupt through INTSTAT[TI] and CNTRL1[TIIE] ; timers 1–11 only generate VSP platform triggers and set TISTAT[TITRIG1..11] . So if you configured TBGEN in FDD mode and are waiting for a TBGEN “interrupt” on a VSPA core, that expectation does not match with TBGEN/VSPA interface.
For LA1224 4T4R, TBGEN timers 1–11 are VSPA trigger sources via ext_go rather than VSPA interrupt sources, so the most likely issue is trigger routing/enablement ( TMREN , correct TBGEN1/2 ext_go input, and TISTAT verification) rather than a missing VSPA ISR.
在原帖中查看解决方案
2 回复数
841 次查看
flappy
@Bio_TICFSL Thank you, the problem is solved
932 次查看
Bio_TICFSL
%3CLINGO-SUB%20id%3D%22lingo-sub-2366928%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ELA1224%20LS-DCS%26amp%3B%20TBGen%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2366928%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E5%A5%BD%EF%BC%81%3CBR%20%2F%3E%E8%AF%B7%E9%97%AE%E5%A6%82%E4%BD%95%E5%9C%A8%20LA1224-RDB-LS%20%E4%B8%8A%E5%90%AF%E7%94%A8%204T4R%20%E7%9A%84%E8%BF%9E%E7%BB%AD%E5%90%8C%E6%AD%A5%E6%93%8D%E4%BD%9C%EF%BC%9F%3CBR%20%2F%3E%E6%88%91%E4%BD%BF%E7%94%A8%200-3%20%E4%B8%AA%20VSPA%20%E5%86%85%E6%A0%B8%E8%BF%90%E8%A1%8C%20LS-DCS0%20%E5%92%8C%20LS-DCS1%E3%80%82%3CBR%20%2F%3E%E6%AF%8F%E4%B8%AA%E5%86%85%E6%A0%B8%E4%B8%8A%E8%BF%90%E8%A1%8C%201DAC%20%E5%92%8C%201ADC%E3%80%82%3CBR%20%2F%3E%E6%88%91%E4%B8%BA%20TBGEN%20%E8%AE%BE%E7%BD%AE%E4%BA%86%E4%B8%AD%E6%96%AD%E5%A4%84%E7%90%86%E7%A8%8B%E5%BA%8F%EF%BC%8C%E5%B9%B6%E5%B0%86%20TBGEN%20%E9%85%8D%E7%BD%AE%E4%B8%BA%20FDD%20%E6%A8%A1%E5%BC%8F%E3%80%82%E4%BD%86%E6%88%91%E5%9C%A8%20VSPA%20%E4%B8%8A%E6%B2%A1%E6%9C%89%E6%94%B6%E5%88%B0%E5%AE%83%E7%9A%84%E4%B8%AD%E6%96%AD%E3%80%82%3CBR%20%2F%3E%E6%88%91%E8%83%BD%E5%A4%9F%E5%90%8C%E6%AD%A5%E8%BF%90%E8%A1%8C%202T2R%EF%BC%8C%E4%BD%86%E5%9C%A8%E8%BF%99%E7%A7%8D%E6%83%85%E5%86%B5%E4%B8%8B%EF%BC%8CADC%20%E6%88%96%20DAC%20%E4%BC%9A%E5%9C%A8%E6%AF%8F%E4%B8%AA%E5%86%85%E6%A0%B8%E4%B8%8A%E8%BF%90%E8%A1%8C%E3%80%82%3CBR%20%2F%3E%E4%B9%9F%E8%AE%B8%E6%88%91%E6%B2%A1%E6%9C%89%E9%85%8D%E7%BD%AE%E6%89%80%E6%9C%89%E7%9A%84%20TBGEn%20%E5%AE%9A%E6%97%B6%E5%99%A8%EF%BC%9F%3CBR%20%2F%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E4%BC%A0%E8%BE%93%E4%BD%BF%E7%94%A8%20NCO%20%E7%94%9F%E6%88%90%E7%9A%84%208192%20%E4%B8%AA%E9%87%87%E6%A0%B7%E7%82%B9%E7%9A%84%E5%8D%95%E9%9F%B3%E4%BF%A1%E5%8F%B7%E3%80%82%E6%88%91%E7%A1%AE%E5%AE%9A%E6%88%91%E6%AD%A3%E7%A1%AE%E7%94%9F%E6%88%90%E4%BA%86%20NCO%20%E5%8F%82%E6%95%B0%E3%80%82%3CBR%20%2F%3E%E4%BD%86%E4%B8%BA%E4%BB%80%E4%B9%88%E5%9C%A8%E7%8E%AF%E5%9B%9E%E6%9C%9F%E9%97%B4%20ADC%20%E4%BC%9A%E5%87%BA%E7%8E%B0%E7%9B%B8%E4%BD%8D%E8%B7%B3%E5%8F%98%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2367394%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LA1224%20LS-DCS%20%26amp%3B%20TBGen%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2367394%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%98%AF%E7%9A%84%EF%BC%8C%E4%BD%A0%E8%AF%B4%E5%BE%97%E5%AF%B9%EF%BC%8C%E6%88%91%E8%AF%B4%E5%BE%97%E4%B8%8D%E5%AE%8C%E5%85%A8%E6%AD%A3%E7%A1%AE%E3%80%82%E6%98%AF%20ext_go%20%E5%AE%9A%E6%97%B6%E5%99%A8%E6%B2%A1%E6%9C%89%E8%BE%BE%E5%88%B0%20VSPA%E3%80%82%E5%8F%AF%E8%83%BD%E6%9C%89%E5%BF%85%E8%A6%81%E5%90%AF%E7%94%A8%20TimedCTRL_0%20-%20TimedCTRL_11%20%E5%AE%9A%E6%97%B6%E5%99%A8%E3%80%82%E7%8E%B0%E5%9C%A8%EF%BC%8C%E6%88%91%E5%8F%AA%E5%88%9D%E5%A7%8B%E5%8C%96%E4%BA%86%20TDD0_CTRL%20-%20TDD7_CTRL%EF%BC%9B%E8%AF%B7%E5%8F%82%E9%98%85%E6%88%91%E7%9A%84%E8%BD%AC%E5%82%A8%E3%80%82%E6%88%91%E4%B8%8D%E6%98%8E%E7%99%BD%E5%A6%82%E4%BD%95%E6%AD%A3%E7%A1%AE%E8%AE%BE%E7%BD%AE%20TimedINTRVL0%20-%20TimedINTRVL11%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2366977%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LA1224%20LS-DCS%20%26amp%3B%20TBGen%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2366977%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3C%2FP%3E%0A%3CP%3E%E5%85%B3%E9%94%AE%E5%9C%A8%E4%BA%8E%EF%BC%8CTBGEN%20%E5%AE%9A%E6%97%B6%E4%B8%AD%E6%96%AD%E8%AE%A1%E6%97%B6%E5%99%A8%201%E2%80%9411%20%E6%98%AF%20VSPA%20%E8%A7%A6%E5%8F%91%E6%BA%90%EF%BC%8C%E8%80%8C%E4%B8%8D%E6%98%AF%20VSPA%20%E4%B8%AD%E6%96%AD%E6%BA%90%E3%80%82%E5%8F%AA%E6%9C%89%E5%AE%9A%E6%97%B6%E4%B8%AD%E6%96%AD%E5%AE%9A%E6%97%B6%E5%99%A8%200%20%E6%89%8D%E8%83%BD%E9%80%9A%E8%BF%87%20%3CCODE%20class%3D%22%22%3EINTSTAT%5BTI%5D%3C%2FCODE%3E%20%E5%92%8C%20%3CCODE%20class%3D%22%22%3ECNTRL1%5BTIIE%5D%3C%2FCODE%3E%20%E7%94%9F%E6%88%90%20MCU%20%E4%B8%AD%E6%96%AD%EF%BC%9B%E8%AE%A1%E6%97%B6%E5%99%A8%201%E2%80%9311%20%E5%8F%AA%E8%83%BD%E7%94%9F%E6%88%90%20VSP%20%E5%B9%B3%E5%8F%B0%E8%A7%A6%E5%8F%91%E4%BF%A1%E5%8F%B7%E5%B9%B6%E8%AE%BE%E7%BD%AE%20%3CCODE%20class%3D%22%22%3ETISTAT%5BTITRIG1..11%5D%3C%2FCODE%3E%E3%80%82%E5%9B%A0%E6%AD%A4%EF%BC%8C%E5%A6%82%E6%9E%9C%E6%82%A8%E5%9C%A8%20FDD%20%E6%A8%A1%E5%BC%8F%E4%B8%8B%E9%85%8D%E7%BD%AE%E4%BA%86%20TBGEN%EF%BC%8C%E5%B9%B6%E5%9C%A8%20VSPA%20%E5%86%85%E6%A0%B8%E4%B8%8A%E7%AD%89%E5%BE%85%20TBGEN%20%22%E4%B8%AD%E6%96%AD%22%EF%BC%8C%E8%BF%99%E7%A7%8D%E6%9C%9F%E6%9C%9B%E4%B8%8E%20TBGEN%2FVSPA%20%E6%8E%A5%E5%8F%A3%E4%B8%8D%E7%AC%A6%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%AF%B9%E4%BA%8E%20LA1224%204T4R%EF%BC%8CTBGEN%20%E8%AE%A1%E6%97%B6%E5%99%A8%201%E2%80%9411%20%E6%98%AF%E9%80%9A%E8%BF%87%3CCODE%20class%3D%22%22%3E%20ext_go%3C%2FCODE%3E%20%E7%9A%84%20VSPA%20%E8%A7%A6%E5%8F%91%E6%BA%90%EF%BC%8C%E8%80%8C%E4%B8%8D%E6%98%AF%20VSPA%3CCODE%20class%3D%22%22%3E%20%E4%B8%AD%E6%96%AD%E6%BA%90%EF%BC%8C%E5%9B%A0%E6%AD%A4%E6%9C%80%E6%9C%89%E5%8F%AF%E8%83%BD%E7%9A%84%E9%97%AE%E9%A2%98%E6%98%AF%E8%A7%A6%E5%8F%91%E5%99%A8%E8%B7%AF%E7%94%B1%2F%E5%90%AF%E7%94%A8%EF%BC%88TMREN%E3%80%81%E6%AD%A3%E7%A1%AE%E7%9A%84%3C%2FCODE%3E%20TBG%20EN1%2F2%3CCODE%20class%3D%22%22%3E%20ext_go%3C%2FCODE%3E%20%E8%BE%93%E5%85%A5%E5%92%8C%3CCODE%20class%3D%22%22%3E%20T%3C%2FCODE%3E%20ISTAT%20%E9%AA%8C%E8%AF%81%EF%BC%89%EF%BC%8C%E8%80%8C%E4%B8%8D%E6%98%AF%E7%BC%BA%E5%B0%91%E7%9A%84%20VSPA%20ISR%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%AD%A4%E8%87%B4%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2369465%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LA1224%20LS-DCS%20%26amp%3B%20TBGen%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2369465%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F34846%22%20target%3D%22_blank%22%3E%40Bio_TICFSL%3C%2FA%3E%E8%B0%A2%E8%B0%A2%EF%BC%8C%E9%97%AE%E9%A2%98%E8%A7%A3%E5%86%B3%E4%BA%86%3C%2FP%3E%3C%2FLINGO-BODY%3E
