Is LS1046 SGMII @ QSGMII not support half mode?
已解决
跳至解决方案
2,086 次查看
Hmc510
env:PC ----  (SGMII)LS1046
when I set PC autoneg off,I fond that LS1046 PHY(SGMII) can not link.
PHY(RGMII) is good.
I see that in code: Is LS1046 SGMII @ QSGMII not support half mode?
1 解答
1,979 次查看
mrudangshelat-13
Hi @Hmc510,
I suggest not to block those lines as the half duplex is not support to avoid any unnecessary errors because the half duplex was not thoroughly tested during the SDK implementation.
Mrudang
在原帖中查看解决方案
3 回复数
2,056 次查看
mrudangshelat-13
Hi @Hmc510,
The SGMII protocol doesn't support half duplex.
Please feel free to raise a new ticket for any other new queries.
Mrudang
2,017 次查看
Hmc510
I have blocked the code here line 343 ~ 347, may I ask if there are any risks. Not considering packet loss
1,980 次查看
mrudangshelat-13
Hi @Hmc510,
Mrudang
