Improving Network Packet Processing Efficiency on QorIQ Systems
656件の閲覧回数
jeremiranner
We are currently using a QorIQ platform in a networking application where traffic load becomes fairly heavy during peak operation. The system itself is stable, but once throughput increases, CPU utilization rises faster than expected and packet latency becomes a little inconsistent.
After spending some time profiling the system, I found that a lot of the slowdown was coming from unnecessary memory copies and queue handling overhead. Reducing some of those operations helped more than I initially expected. I also noticed that cache behavior starts to matter quite a bit once traffic bursts become continuous.
Another thing that improved performance was distributing interrupts more carefully across cores instead of letting everything stack onto a single processing path.
The platform still performs well overall, but I am interested in hearing how others are optimizing packet processing efficiency on QorIQ or Layerscape systems, especially in low-latency or high-throughput
613件の閲覧回数
Bio_TICFSL
Yes, on QorIQ/Layerscape, packet efficiency is typically optimized by preserving flow-to-core affinity, balancing queues and interrupts across cores, and reducing copies with scatter-gather/zero-copy paths, because those are the main levers NXP documents as improving CPU load, cache locality, and latency consistency.
One important caveat from the retrieved material: I could find strong guidance on the mechanisms, but not a single universal “best” recipe for all QorIQ/Layerscape systems, because the right mix depends on whether you are running the Linux networking stack, DPAA private drivers, or DPDK/DPAA2 userspace, and on whether the bottleneck is copy overhead, hash skew, interrupt concentration, or queue imbalance. The documentation consistently points to queue/core symmetry, affinity preservation, and copy reduction as the highest-value first steps.
%3CLINGO-SUB%20id%3D%22lingo-sub-2365731%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EQorIQ%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AB%E3%81%8A%E3%81%91%E3%82%8B%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%E3%83%91%E3%82%B1%E3%83%83%E3%83%88%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B7%E3%83%B3%E3%82%B0%E5%8A%B9%E7%8E%87%E3%81%AE%E5%90%91%E4%B8%8A%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2365731%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E7%8F%BE%E5%9C%A8%E3%80%81%E5%BD%93%E7%A4%BE%E3%81%A7%E3%81%AFQorIQ%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E3%82%92%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%A7%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%83%94%E3%83%BC%E3%82%AF%E6%99%82%E3%81%AB%E3%81%AF%E3%83%88%E3%83%A9%E3%83%95%E3%82%A3%E3%83%83%E3%82%AF%E8%B2%A0%E8%8D%B7%E3%81%8C%E3%81%8B%E3%81%AA%E3%82%8A%E9%AB%98%E3%81%8F%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E8%87%AA%E4%BD%93%E3%81%AF%E5%AE%89%E5%AE%9A%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%8C%E3%80%81%E3%82%B9%E3%83%AB%E3%83%BC%E3%83%97%E3%83%83%E3%83%88%E3%81%8C%E5%A2%97%E5%8A%A0%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81CPU%E4%BD%BF%E7%94%A8%E7%8E%87%E3%81%8C%E4%BA%88%E6%83%B3%E4%BB%A5%E4%B8%8A%E3%81%AB%E9%80%9F%E3%81%8F%E4%B8%8A%E6%98%87%E3%81%97%E3%80%81%E3%83%91%E3%82%B1%E3%83%83%E3%83%88%E3%83%AC%E3%82%A4%E3%83%86%E3%83%B3%E3%82%B7%E3%81%8C%E3%82%84%E3%82%84%E4%B8%8D%E5%AE%89%E5%AE%9A%E3%81%AB%E3%81%AA%E3%82%8B%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%92%E3%83%97%E3%83%AD%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AA%E3%83%B3%E3%82%B0%E3%81%97%E3%81%9F%E7%B5%90%E6%9E%9C%E3%80%81%E5%87%A6%E7%90%86%E9%80%9F%E5%BA%A6%E3%81%AE%E4%BD%8E%E4%B8%8B%E3%81%AE%E5%A4%9A%E3%81%8F%E3%81%AF%E3%80%81%E4%B8%8D%E8%A6%81%E3%81%AA%E3%83%A1%E3%83%A2%E3%83%AA%E3%82%B3%E3%83%94%E3%83%BC%E3%81%A8%E3%82%AD%E3%83%A5%E3%83%BC%E5%87%A6%E7%90%86%E3%81%AE%E3%82%AA%E3%83%BC%E3%83%90%E3%83%BC%E3%83%98%E3%83%83%E3%83%89%E3%81%AB%E8%B5%B7%E5%9B%A0%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E5%88%86%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%9D%E3%82%8C%E3%82%89%E3%81%AE%E6%A5%AD%E5%8B%99%E3%81%AE%E4%B8%80%E9%83%A8%E3%82%92%E5%89%8A%E6%B8%9B%E3%81%97%E3%81%9F%E3%81%93%E3%81%A8%E3%81%AF%E3%80%81%E5%BD%93%E5%88%9D%E4%BA%88%E6%83%B3%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E4%BB%A5%E4%B8%8A%E3%81%AB%E5%8A%B9%E6%9E%9C%E3%81%8C%E3%81%82%E3%81%A3%E3%81%9F%E3%80%82%E3%81%BE%E3%81%9F%E3%80%81%E3%83%88%E3%83%A9%E3%83%95%E3%82%A3%E3%83%83%E3%82%AF%E3%81%AE%E6%80%A5%E5%A2%97%E3%81%8C%E7%B6%99%E7%B6%9A%E7%9A%84%E3%81%AB%E3%81%AA%E3%82%8B%E3%81%A8%E3%80%81%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%E3%81%AE%E5%8B%95%E4%BD%9C%E3%81%8C%E9%9D%9E%E5%B8%B8%E3%81%AB%E9%87%8D%E8%A6%81%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%8F%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AB%E3%82%82%E6%B0%97%E3%81%A5%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%91%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%B3%E3%82%B9%E5%90%91%E4%B8%8A%E3%81%AB%E8%B2%A2%E7%8C%AE%E3%81%97%E3%81%9F%E3%82%82%E3%81%86%E4%B8%80%E3%81%A4%E3%81%AE%E8%A6%81%E5%9B%A0%E3%81%AF%E3%80%81%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%82%92%E5%8D%98%E4%B8%80%E3%81%AE%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B7%E3%83%B3%E3%82%B0%E3%83%91%E3%82%B9%E3%81%AB%E9%9B%86%E4%B8%AD%E3%81%95%E3%81%9B%E3%82%8B%E3%81%AE%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%8F%E3%80%81%E3%82%B3%E3%82%A2%E9%96%93%E3%81%A7%E3%82%88%E3%82%8A%E6%85%8E%E9%87%8D%E3%81%AB%E5%88%86%E6%95%A3%E3%81%95%E3%81%9B%E3%81%9F%E3%81%93%E3%81%A8%E3%81%A7%E3%81%82%E3%82%8B%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E5%85%A8%E4%BD%93%E3%81%A8%E3%81%97%E3%81%A6%E3%81%AF%E4%BE%9D%E7%84%B6%E3%81%A8%E3%81%97%E3%81%A6%E8%89%AF%E5%A5%BD%E3%81%AA%E3%83%91%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%B3%E3%82%B9%E3%82%92%E7%99%BA%E6%8F%AE%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E7%89%B9%E3%81%AB%E4%BD%8E%E3%83%AC%E3%82%A4%E3%83%86%E3%83%B3%E3%82%B7%E3%81%BE%E3%81%9F%E3%81%AF%E9%AB%98%E3%82%B9%E3%83%AB%E3%83%BC%E3%83%97%E3%83%83%E3%83%88%E3%81%AE%E7%92%B0%E5%A2%83%E3%81%AB%E3%81%8A%E3%81%84%E3%81%A6%E3%80%81QorIQ%E3%81%BE%E3%81%9F%E3%81%AFLayerscape%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%A7%E3%83%91%E3%82%B1%E3%83%83%E3%83%88%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B7%E3%83%B3%E3%82%B0%E5%8A%B9%E7%8E%87%E3%82%92%E6%9C%80%E9%81%A9%E5%8C%96%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%80%81%E4%BB%96%E3%81%AE%E6%96%B9%E3%80%85%E3%81%AE%E5%8F%96%E3%82%8A%E7%B5%84%E3%81%BF%E3%82%92%E3%81%9C%E3%81%B2%E3%81%8A%E8%81%9E%E3%81%8D%E3%81%97%E3%81%9F%E3%81%84%E3%81%A8%E6%80%9D%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2366269%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Improving%20Network%20Packet%20Processing%20Efficiency%20on%20QorIQ%20Systems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2366269%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%0A%3CP%3E%E3%81%AF%E3%81%84%E3%80%81QorIQ%2FLayerscape%E3%81%A7%E3%81%AF%E3%80%81%E3%83%91%E3%82%B1%E3%83%83%E3%83%88%E5%8A%B9%E7%8E%87%E3%81%AF%E9%80%9A%E5%B8%B8%E3%80%81%E3%83%95%E3%83%AD%E3%83%BC%E3%81%A8%E3%82%B3%E3%82%A2%E3%81%AE%E8%A6%AA%E5%92%8C%E6%80%A7%E3%82%92%E7%B6%AD%E6%8C%81%E3%81%97%E3%80%81%E3%82%B3%E3%82%A2%E9%96%93%E3%81%A7%E3%82%AD%E3%83%A5%E3%83%BC%E3%81%A8%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%81%AE%E3%83%90%E3%83%A9%E3%83%B3%E3%82%B9%E3%82%92%E5%8F%96%E3%82%8A%E3%80%81%E3%82%B9%E3%82%AD%E3%83%A3%E3%83%83%E3%82%BF%E3%83%BC%E3%82%AE%E3%83%A3%E3%82%B6%E3%83%BC%2F%E3%82%BC%E3%83%AD%E3%82%B3%E3%83%94%E3%83%BC%E3%83%91%E3%82%B9%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%82%B3%E3%83%94%E3%83%BC%E3%82%92%E5%89%8A%E6%B8%9B%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E6%9C%80%E9%81%A9%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%AF%E3%80%81NXP%E3%81%8CCPU%E8%B2%A0%E8%8D%B7%E3%80%81%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%E3%81%AE%E5%B1%80%E6%89%80%E6%80%A7%E3%80%81%E3%81%8A%E3%82%88%E3%81%B3%E3%83%AC%E3%82%A4%E3%83%86%E3%83%B3%E3%82%B7%E3%81%AE%E4%B8%80%E8%B2%AB%E6%80%A7%E3%82%92%E5%90%91%E4%B8%8A%E3%81%95%E3%81%9B%E3%82%8B%E4%B8%BB%E8%A6%81%E3%81%AA%E6%89%8B%E6%AE%B5%E3%81%A8%E3%81%97%E3%81%A6%E6%8C%99%E3%81%92%E3%81%A6%E3%81%84%E3%82%8B%E3%82%82%E3%81%AE%E3%81%A0%E3%81%8B%E3%82%89%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%85%A5%E6%89%8B%E3%81%97%E3%81%9F%E8%B3%87%E6%96%99%E3%81%8B%E3%82%89%E9%87%8D%E8%A6%81%E3%81%AA%E6%B3%A8%E6%84%8F%E7%82%B9%E3%81%8C1%E3%81%A4%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%83%A1%E3%82%AB%E3%83%8B%E3%82%BA%E3%83%A0%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E5%BC%B7%E5%8A%9B%E3%81%AA%E3%82%AC%E3%82%A4%E3%83%80%E3%83%B3%E3%82%B9%E3%81%AF%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AEQorIQ%2FLayerscape%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AB%E9%81%A9%E7%94%A8%E3%81%A7%E3%81%8D%E3%82%8B%E6%99%AE%E9%81%8D%E7%9A%84%E3%81%AA%E3%80%8C%E6%9C%80%E5%96%84%E3%80%8D%E3%81%AE%E3%83%AC%E3%82%B7%E3%83%94%E3%81%AF%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%E3%81%AA%E3%81%9C%E3%81%AA%E3%82%89%E3%80%81%E6%9C%80%E9%81%A9%E3%81%AA%E7%B5%84%E3%81%BF%E5%90%88%E3%82%8F%E3%81%9B%E3%81%AF%E3%80%81Linux%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%E3%82%B9%E3%82%BF%E3%83%83%E3%82%AF%E3%80%81DPAA%E3%83%97%E3%83%A9%E3%82%A4%E3%83%99%E3%83%BC%E3%83%88%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AFDPDK%2FDPAA2%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%82%B9%E3%83%9A%E3%83%BC%E3%82%B9%E3%81%AE%E3%81%84%E3%81%9A%E3%82%8C%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%8B%E3%80%81%E3%81%BE%E3%81%9F%E3%83%9C%E3%83%88%E3%83%AB%E3%83%8D%E3%83%83%E3%82%AF%E3%81%8C%E3%82%B3%E3%83%94%E3%83%BC%E3%82%AA%E3%83%BC%E3%83%90%E3%83%BC%E3%83%98%E3%83%83%E3%83%89%E3%80%81%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%E3%82%B9%E3%82%AD%E3%83%A5%E3%83%BC%E3%80%81%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E9%9B%86%E4%B8%AD%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AF%E3%82%AD%E3%83%A5%E3%83%BC%E3%81%AE%E4%B8%8D%E5%9D%87%E8%A1%A1%E3%81%AE%E3%81%84%E3%81%9A%E3%82%8C%E3%81%A7%E3%81%82%E3%82%8B%E3%81%8B%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E7%95%B0%E3%81%AA%E3%82%8B%E3%81%8B%E3%82%89%E3%81%A7%E3%81%99%E3%80%82%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%A7%E3%81%AF%E4%B8%80%E8%B2%AB%E3%81%97%E3%81%A6%E3%80%81%E3%82%AD%E3%83%A5%E3%83%BC%2F%E3%82%B3%E3%82%A2%E3%81%AE%E5%AF%BE%E7%A7%B0%E6%80%A7%E3%80%81%E3%82%A2%E3%83%95%E3%82%A3%E3%83%8B%E3%83%86%E3%82%A3%E3%81%AE%E7%B6%AD%E6%8C%81%E3%80%81%E3%82%B3%E3%83%94%E3%83%BC%E6%95%B0%E3%81%AE%E5%89%8A%E6%B8%9B%E3%81%8C%E3%80%81%E6%9C%80%E3%82%82%E4%BE%A1%E5%80%A4%E3%81%AE%E9%AB%98%E3%81%84%E6%9C%80%E5%88%9D%E3%81%AE%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E3%81%A7%E3%81%82%E3%82%8B%E3%81%A8%E6%8C%87%E6%91%98%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
