How to test customized u-boot on LS1043ARDB?
yong_zou
I have 1043ardb,  I built customized u-boot, can anyone tell how to test it on NOR flash and DSPI flash?
Yong
yipingwang
Hello Yong Zou,
What have you modified in your customized u-boot? If you modified DDR configuration or IFC timing configuration, the customized u-boot cannot run on LS1043ARDB demo board.
You could refer to https://community.nxp.com/docs/DOC-331981  to program u-boot to NOR flash with CodeWarrior and debug u-boot with CodeWarrior for ARMv8.
Yiping
yong_zou
Hi Yiping,
Thanks a lot for your quick feedback. I tested my u-boot by using NOR Bank-4 and it can be boot up.
Yong
