How to program an empty eMMC with LS1046A Processor
1,735 次查看
maxime_guillot
I have a custom board with the LS1046A processor and a switch to select eMMC boot or SD Card boot.
SD card boot is ok.
I was wondering how to program the empty eMMC without ethernet. Is there a document which explain how to do? I did not find anything on your website but there are a lot of documents, maybe I did not find it.
Thank you
1 回复
1,727 次查看
ufedor
It is recommended to use CodeWarrior Flash Programmer tool.
Please refer to the attached presentation starting from page 28.
