How to deploy image to SD Card?
已解决
跳至解决方案
2,362 次查看
bladerunner1010
标记 (1)
1 解答
2,345 次查看
yipingwang
Use "fdisk" to create 4 partitions.
Please use "mkfs.ext4" to format the second and the fourth partition.
$ mkfs.ext4 /dev/sdc2
$ mkfs.ext4 /dev/sdc4
dd firmware_ls1043ardb_sdboot.img to SD card.
$ dd if=firmware_ls1043ardb_sdboot.img of=/dev/sdc bs=512 seek=8
Write boot_LS_arm64_lts_5.10.tgz to the second partition of SD card.
$ mount /dev/sdc2 /mnt
$ cp boot_LS_arm64_lts_5.10.tgz /mnt
$ tar -xzvf  boot_LS_arm64_lts_5.10.tgz
$ rm boot_LS_arm64_lts_5.10.tgz
$umount /mnt
Write rootfs_lsdk2108_buildroot_tiny_arm64.tgz to the fourth partition of SD card.
$ mount /dev/sdc4 /mnt
$ cp rootfs_lsdk2108_buildroot_tiny_arm64.tgz /mnt
$ tar -xzvf  rootfs_lsdk2108_buildroot_tiny_arm64.tgz
$ rm rootfs_lsdk2108_buildroot_tiny_arm64.tgz
$umount /mnt
在原帖中查看解决方案
1 回复
2,346 次查看
yipingwang
$umount /mnt
$umount /mnt
