Fan heatsink for LS1046ARDB
2,292件の閲覧回数
ManuPF
We have purchased a LS1046ARDB board.
Regarding the fans, it seems to be different from the one depicted in the NXP webpage.
We have received a board with 2 fans on the side and a passive heatsink over the CPU.
BUT in the NXP webpage it appears to have 3 fans (2 on the side, and an additional one over the CPU).
We would like to know how to obtain the fan which is missing. It is available separately? Can anyone provide the part-number?
Just for curiosity, is it possible to order boards which come with the 3 fans mounted?
I add some pictures for your reference.
2,214件の閲覧回数
Hector_Villarruel
Hello @ManuPF
Hope this post finds you well,
The part number of the fan on the older version of the LS1046A-RDB is: AD0412MB-G76-LF
Please find it on the following link:
https://www.mouser.com/ProductDetail/ADDA/AD0412MB-G76-LF?qs=9dFQwQorgSxr9p2b5oUF0Q%3D%3D
It is part of a heat sink assembly, part number FRE022_C1 from the company Radian Heatsinks in Santa Clara, California. You would need the whole assembly to install this fan. It won’t install over the existing heat sink.
BR,
Hector Villarruel
4 返答(返信)
2,268件の閲覧回数
Hector_Villarruel
Hello @ManuPF ,
Regarding inquire I would like to inform you this is a result of the board being redesigned over time, while the photo on the web page is not updated.
Have a great day.
BR,
Hector Villarruel
2,253件の閲覧回数
ManuPF
Thanks for your reply.
I understand that the design has changed. However, can you please point to the Part Number of the Fan Heatsink that was used in the old design?
Best,
Manuel
2,215件の閲覧回数
Hector_Villarruel
Hello @ManuPF
BR,
Hector Villarruel
2,278件の閲覧回数
Hector_Villarruel
Hello @ManuPF
This post is to inform you that we keep working in order to answer your questions.
I will keep you informed.
Have a great day.
BR,
Hector
