Ethernet Interface setup for LS1046ARDB
2,581 次查看
rashmitharamesh
I am trying to setup Ethernet interface for LS1046ARDB.
I am not using U-Boot.
I have basic boot code with necessary initialization and a dummy application.
I would like to connect the board to a host PC to be able to perform read/write over ethernet.
Could you please help me with some pointers on getting started with this?
Any references from U-boot would also be helpful.
Rashmitha
标签 (1)
标记 (2)
3 回复数
2,501 次查看
yipingwang
Hello Rashmitha,
Please refer to doc/README.drivers.eth in u-boot source code.
You could refer to Ethernet section in Industrial IoT Baremetal Framework.
Please refer to https://www.nxp.com/docs/en/user-guide/IIOT_BAREMETAL_DG-1-7.pdf .
Yiping
2,501 次查看
rashmitharamesh
Hello Yiping,
Thanks for the links, they are useful.
I also wanted to know if it is byte read/write.
And
Is there a need to halt, is it asynchronous or on-demand?
Thank you,
Rashmitha
2,501 次查看
yipingwang
Hello Rashmitha,
It is byte read/write, asynchronous.
Yiping
