Did support MSI/MSIX interrupts on LS2088ARDB?
Hans-Bings
I install irqbalance service on LS2088ARDB, and irqbalance service say below:
/usr/local/sbin/irqbalance[1755]: IRQ dpni.5(129) guessed as class 0
/usr/local/sbin/irqbalance[1755]: IRQ dpni.4(130) guessed as class 0
/usr/local/sbin/irqbalance[1755]: IRQ dpni.3(131) guessed as class 0
/usr/local/sbin/irqbalance[1755]: IRQ dpni.2(132) guessed as class 0
/usr/local/sbin/irqbalance[1755]: IRQ dpni.1(133) guessed as class 0
/usr/local/sbin/irqbalance[1755]: IRQ dpni.0(134) guessed as class 0
/usr/local/sbin/irqbalance[1755]: WARNING: MSI interrupts found in /proc/interrupts
/usr/local/sbin/irqbalance[1755]: But none found in sysfs, you need to update your kernel
usr/local/sbin/irqbalance[1755]: Until then, IRQs will be improperly classified
/usr/local/sbin/irqbalance[1755]: Daemon couldn't be bound to the file-based socket.
so did support MSI/MSIX interrupts on LS2088ARDB?
I use Linux kernel 5.10.9
yipingwang
MSI/MSIX interrupts are supported on LS2088ARDB in Linux kernel 5.10.9.
Hans-Bings
But why kernel say can't find any MSI device in sys fs?
Any help please?
yipingwang
Please refer to the root cause provided in https://access.redhat.com/solutions/677073.
