DRAM bus speed optimization test ls1021a
2,380件の閲覧回数
winstonjacob
I am using LS1021atwr board, here I need to do the DRAM bus speed optimization, please support me to do this test in LS1021atwr EVK board.
Winston
3 返答(返信)
2,374件の閲覧回数
Bulat
Please clarify what means "DRAM bus speed optimization"?
Why do you think the DRAM bus speed is not optimized?
Bulat
2,362件の閲覧回数
winstonjacob
Thanks for your reply @Bulat
      I need to test the DRAM in various frequencies and various speed, is their any procedure available for this.
Winston
2,346件の閲覧回数
Bulat
Default DDR speed of the LS1021ATWR is 1600MT/s, this is a maximum possible speed for the LS1021A DDR controller. U-boot software provides setup for this speed.
If maximum possible speed is not "optimal" for you, you can test other speeds using DDR Validation tool, that is a part of QCVS. Note that DDR speed is defined by RCW, so for each DDR bus speed you will need to change RCW with desired MEM_PLL_RAT ratio. The tool will help with timing parameters for chosen bus frequency.
Bulat
