DPAA2 DPDK RTE FLOW
DPAA2 DPDK RTE FLOW
519件の閲覧回数
dehml
I'm trying to create DPDK RTE FLOW on a DPAA2 SolidRun LX2160A Clearfog CX without success.
Is it normal that it doesn't work ?
What could be done to make it works ?
I'm quite newbie with NXP DPAA2 and NXP in general, so can you please explain your technical words.
Thanks.
testpmd> flow create 0 ingress pattern eth / ipv4 / end actions rss queues 0 1 end types ip ipv4 end / end
DPAA2_NET: Add entry(0) to table(0) failed
DPAA2_NET: Create flow failed (-22)
port_flow_complain(): Caught PMD error type 1 (cause unspecified): cause: 0xfffff340a300, unknown: Operation not permitted
タグ(5)
2 返答(返信)
476件の閲覧回数
yipingwang
Check how the DPNI behind your DPDK port was created. From the Linux shell on the board:
restool dprc show dprc.1 --resources          # find the dpni.X your DPDK port uses
restool dpni info dpni.X                      # look at the "options" line and "num_queues"
If options shows DPNI_OPT_NO_FS , or does not show DPNI_OPT_HAS_KEY_MASKING , that's your problem.
Recreate the DPNI with the right options. Either edit dynamic_dpl.sh (or the environment it reads — on NXP LSDK it is typically the DPNI_OPTIONS variable) so the create call looks like this :
restool dpni create \
    --options=DPNI_OPT_HAS_KEY_MASKING \
    --num-queues=2 \
    --num-tcs=1 \
    --container=dprc.2
Key points:
    • Do not include DPNI_OPT_NO_FS .
    • Do include DPNI_OPT_HAS_KEY_MASKING .
    • Set --num-queues to at least the number of queues your RSS action references (you asked for queues 0 and 1, so ≥ 2).
Then attach that DPNI to the DPDK container ( restool dprc assign … ) and rerun testpmd.
If you use a static DPL file , add the same to the dpni@X node :
 dpni@1 {
  options = "DPNI_OPT_HAS_KEY_MASKING";
    num_queues = <2>;
and reflash the DPL via fsl_mc apply dpl … in U‑Boot.
Sanity‑check with a simpler rule first. Before RSS, confirm plain steering works:
 testpmd> flow create 0 ingress pattern eth / ipv4 src is 10.0.0.1 / end \
                     actions queue index 1 / end
If this passes but the RSS variant still fails, the remaining issue is queue count / distribution config, not the DPNI options.
499件の閲覧回数
db16122
https://www.nxp.com/webapp/Download?colCode=DPAA2UM&location=null
DPAA2 User Manual could be helpful
BTW. what kind of BSP or SDK is used? Any resource from official websit?
%3CLINGO-SUB%20id%3D%22lingo-sub-2399170%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EDPAA2%20DPDK%20RTE%20%E3%83%95%E3%83%AD%E3%83%BC%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2399170%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%3CP%3EDPAA2%20SolidRun%20LX2160A%20Clearfog%20CX%E4%B8%8A%E3%81%A7DPDK%20RTE%20FLOW%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%81%86%E3%81%BE%E3%81%8F%E3%81%84%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3CBR%20%2F%3E%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%AA%E3%81%84%E3%81%AE%E3%81%AF%E6%99%AE%E9%80%9A%E3%81%AE%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%81%8B%EF%BC%9F%3CBR%20%2F%3E%E3%81%86%E3%81%BE%E3%81%8F%E3%81%84%E3%81%8F%E3%81%AB%E3%81%AF%E4%BD%95%E3%81%8C%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%3F%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AFNXP%20DPAA2%E3%82%84NXP%E5%85%A8%E8%88%AC%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%8B%E3%81%AA%E3%82%8A%E5%88%9D%E5%BF%83%E8%80%85%E3%81%AA%E3%81%AE%E3%81%A7%E3%80%81%E6%8A%80%E8%A1%93%E7%9A%84%E3%81%AA%E8%A8%80%E8%91%89%E3%82%92%E6%95%99%E3%81%88%E3%81%A6%E3%82%82%E3%82%89%E3%81%88%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3Etestpmd%26gt%3B%20flow%20create%200%20ingress%20pattern%20eth%20%2F%20ipv4%20%2F%20end%20actions%20rss%20queues%200%201%20end%20types%20ip%20ipv4%20end%20%2F%20end%0ADPAA2_NET%3A%20Add%20entry(0)%20to%20table(0)%20failed%0ADPAA2_NET%3A%20Create%20flow%20failed%20(-22)%0Aport_flow_complain()%3A%20Caught%20PMD%20error%20type%201%20(cause%20unspecified)%3A%20cause%3A%200xfffff340a300%2C%20unknown%3A%20Operation%20not%20permitted%20%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2399459%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20DPAA2%20DPDK%20RTE%20FLOW%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2399459%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSTRONG%3EDPDK%E3%83%9D%E3%83%BC%E3%83%88%E3%81%AE%E8%83%8C%E5%BE%8C%E3%81%AB%E3%81%82%E3%82%8BDPNI%E3%81%8C%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E4%BD%9C%E6%88%90%E3%81%95%E3%82%8C%E3%81%9F%E3%81%8B%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSTRONG%3E%E5%9F%BA%E6%9D%BF%E4%B8%8A%E3%81%AELinux%E3%82%B7%E3%82%A7%E3%83%AB%E3%81%8B%E3%82%89%3A%3C%2FP%3E%0A%3CP%3Erestool%20dprc%20show%20dprc.1%20--resources%20%23%20DPDK%E3%83%9D%E3%83%BC%E3%83%88%E3%81%8C%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8Bdpni.X%E3%82%92%E8%A6%8B%E3%81%A4%E3%81%91%E3%81%BE%E3%81%99%3C%2FP%3E%0A%3CP%3Erestool%20dpni%20info%20dpni.X%20%23%20%22options%22%20%E8%A1%8C%E3%81%A8%20%22num_queues%22%20%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3C%2FP%3E%0A%3CP%3E%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AB%20DPNI_OPT_NO_FS%20%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%82%8B%E5%A0%B4%E5%90%88%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AF%20DPNI_OPT_HAS_KEY_MASKING%20%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%3CSTRONG%3E%E3%81%AA%E3%81%84%3C%2FSTRONG%3E%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E3%81%9D%E3%82%8C%E3%81%8C%E5%95%8F%E9%A1%8C%E3%81%AE%E5%8E%9F%E5%9B%A0%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3E%E9%81%A9%E5%88%87%E3%81%AA%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6DPNI%E3%82%92%E5%86%8D%E4%BD%9C%E6%88%90%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSTRONG%3Edynamic_dpl.sh%20%E3%82%92%E7%B7%A8%E9%9B%86%E3%81%99%E3%82%8B%E3%81%8B%E3%80%81(%E3%81%BE%E3%81%9F%E3%81%AF%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8B%E7%92%B0%E5%A2%83%20%E2%80%94%20NXP%20LSDK%20%E3%81%A7%E3%81%AF%E9%80%9A%E5%B8%B8%20DPNI_OPTIONS%20%E5%A4%89%E6%95%B0%E3%81%A7%E3%81%99)%E3%81%AA%E3%81%AE%E3%81%A7%E3%80%81Create%20%E3%82%B3%E3%83%BC%E3%83%AB%E3%81%AF%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%3A%3C%2FP%3E%0A%3CP%3Erestool%20dpni%20create%20%5C%3C%2FP%3E%0A%3CP%3E--options%3DDPNI_OPT_HAS_KEY_MASKING%20%5C%3C%2FP%3E%0A%3CP%3E--num-queues%3D2%20%5C%3C%2FP%3E%0A%3CP%3E--num-tcs%3D1%20%5C%3C%2FP%3E%0A%3CP%3E--container%3Ddprc.2%3C%2FP%3E%0A%3CP%3E%E8%A6%81%E7%82%B9%EF%BC%9A%3C%2FP%3E%0A%3CUL%3E%0A%3CUL%3E%0A%3CLI%3EDPNI_OPT_NO_FS%3CSTRONG%3E%E3%82%92%E5%90%AB%E3%82%81%E3%81%AA%E3%81%84%E3%81%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3C%2FSTRONG%3E%E3%80%82%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3C%2FUL%3E%0A%3CUL%3E%0A%3CUL%3E%0A%3CLI%3EDPNI_OPT_HAS_KEY_MASKING%3CSTRONG%3E%E3%82%92%E5%90%AB%E3%82%81%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3C%2FSTRONG%3E%E3%80%82%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3C%2FUL%3E%0A%3CUL%3E%0A%3CUL%3E%0A%3CLI%3E--num-queues%E3%82%92RSS%E3%82%A2%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%8C%E5%8F%82%E7%85%A7%E3%81%99%E3%82%8B%E3%82%AD%E3%83%A5%E3%83%BC%E3%81%AE%E6%95%B0%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84(%E3%82%AD%E3%83%A5%E3%83%BC0%E3%81%A81%E3%82%92%E6%8C%87%E5%AE%9A%E3%81%97%E3%81%9F%E3%81%AE%E3%81%A7%E3%80%812%E2%89%A5%E3%81%A7%E3%81%99)%E3%80%82%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3C%2FUL%3E%0A%3CP%3E%E6%AC%A1%E3%81%AB%E3%80%81%E3%81%9D%E3%81%AE%20DPNI%20%E3%82%92%20DPDK%20%E3%82%B3%E3%83%B3%E3%83%86%E3%83%8A%E3%81%AB%E3%82%A2%E3%82%BF%E3%83%83%E3%83%81%E3%81%97%20(restool%20dprc%20assign%20%E2%80%A6)%E3%80%81testpmd%20%E3%82%92%E5%86%8D%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3E%E9%9D%99%E7%9A%84DPL%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%3C%2FSTRONG%3E%E3%80%81%E5%90%8C%E3%81%98%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92dpni%40X%E3%83%8E%E3%83%BC%E3%83%89%E3%81%AB%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CP%3Edpni%401%20%7B%3C%2FP%3E%0A%3CP%3E%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%20%3D%20%22DPNI_OPT_HAS_KEY_MASKING%22%3B%3C%2FP%3E%0A%3CP%3Enum_queues%20%3D%20%26lt%3B2%26gt%3B%3B%3C%2FP%3E%0A%3CP%3E...%3C%2FP%3E%0A%3CP%3E%7D%3B%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%81%9D%E3%81%97%E3%81%A6%E3%80%81U-Boot%E3%81%A7fsl_mc%20apply%20dpl%20%E2%80%A6%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6DPL%E3%82%92%E5%86%8D%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3E%E3%81%BE%E3%81%9A%E3%81%AF%E3%82%82%E3%81%A3%E3%81%A8%E7%B0%A1%E5%8D%98%E3%81%AA%E3%83%AB%E3%83%BC%E3%83%AB%E3%81%A7%E5%A6%A5%E5%BD%93%E6%80%A7%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%BF%E3%81%BE%E3%81%97%E3%82%87%E3%81%86%E3%80%82%3C%2FSTRONG%3ERSS%E3%81%AE%E5%89%8D%E3%81%AB%E3%80%81%E3%83%97%E3%83%AC%E3%83%BC%E3%83%B3%E3%82%B9%E3%83%86%E3%82%A2%E3%83%AA%E3%83%B3%E3%82%B0%E3%81%8C%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%8B%95%E4%BD%9C%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CP%3Etestpmd%26gt%3B%20flow%20create%200%20ingress%20pattern%20eth%20%2F%20ipv4%20src%20is%2010.0.0.1%20%2F%20end%20%5C%3C%2FP%3E%0A%3CP%3E%E3%82%A2%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%AD%E3%83%A5%E3%83%BC%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9%201%20%2F%20%E7%B5%82%E4%BA%86%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%81%93%E3%82%8C%E3%81%8C%E6%88%90%E5%8A%9F%E3%81%97%E3%81%A6%E3%82%82RSS%E3%83%90%E3%83%AA%E3%82%A2%E3%83%B3%E3%83%88%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E6%AE%8B%E3%82%8A%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AFDPNI%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%8F%E3%80%81%E3%82%AD%E3%83%A5%E3%83%BC%E6%95%B0%2F%E9%85%8D%E4%BF%A1%E6%A7%8B%E6%88%90%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2399194%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20DPAA2%20DPDK%20RTE%20FLOW%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2399194%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fwebapp%2FDownload%3FcolCode%3DDPAA2UM%26amp%3Blocation%3Dnull%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fwebapp%2FDownload%3FcolCode%3DDPAA2UM%26amp%3Blocation%3Dnull%3C%2FA%3E%3C%2FP%3E%3CP%3EDPAA2%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%83%9E%E3%83%8B%E3%83%A5%E3%82%A2%E3%83%AB%E3%81%8C%E5%BD%B9%E7%AB%8B%E3%81%A4%E3%81%8B%E3%82%82%E3%81%97%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%3C%2FP%3E%3CP%3E%E3%81%A1%E3%81%AA%E3%81%BF%E3%81%AB%E3%80%82%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AABSP%E3%82%84SDK%E3%81%8C%E4%BD%BF%E3%82%8F%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%E5%85%AC%E5%BC%8F%E3%82%A6%E3%82%A7%E3%83%96%E3%82%B5%E3%82%A4%E3%83%88%E3%81%8B%E3%82%89%E3%81%AE%E6%83%85%E5%A0%B1%E6%BA%90%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E
