DDR4 without ECC
DDR4 without ECC
1,178 次查看
Ellu24
Can I use interface 4 DDR4 MT40A512M16(instead of 5) with LS1046 without connecting ECC lines? Is this affect my system performance?
Thanks in advance
1 回复
1,152 次查看
yipingwang
When customer is not using EEC DDR then customer will not be able to use ECC feature (i.e. single bit error correction etc.) in system. I don't see any issue in system performance
