DDR4 calibration issues on LS1046 custom board
ソリューションへジャンプ
1,665件の閲覧回数
altu
Good day!
We are trying to bring up our custom LS1046-based board up and stucked with DDR4 calibration procedure.
SPD data of the modules is red successfully, calibration process starts successfully too, but after that it fails with this reason(log from CodeWarrior
############################### Run 1
Result for: wrlvl_searcher
Test result: [
Updated:
WRLVL_CNTL = 0x8655F605, WRLVL_CNTL_2 = 0x00000000,
WRLVL_CNTL_3 = 0x00000000, SDRAM_CLK_CNTL = 0x02800000
Updated:
WRLVL_CNTL = 0x8655F60A, WRLVL_CNTL_2 = 0x0B0B0C0F,
WRLVL_CNTL_3 = 0x0F10110D, SDRAM_CLK_CNTL = 0x02800000
Updated:
WRLVL_CNTL_3 = 0x0F101115, SDRAM_CLK_CNTL = 0x02800000
Updated:
WRLVL_CNTL_3 = 0x0F10111D, SDRAM_CLK_CNTL = 0x02800000
Write Leveling start values are correct and require no further modification,
but the test failed due to other issues.
Most common failure causes:
-incorrect values configured in DDR4 DQn_MAP registers
-incorrect ODT values
-incorrect driver strength selected
-incorrect timing values selected for Timing Configuration 0 properties (TIMING_CFG_0 register)
<<Test failed!>>
{{Write Leveling start values are correct and require no further modification,
but the test failed due to other issues.}}
Err. capture registers:
0xE20, 0xDEADBEEF
0xE24, 0xDEADBEEF
0xE28, 0x00000000
0xE40, 0x00000000
0xE44, 0x00000000
0xE48, 0x0000001D
0xE4C, 0x60FF2001
0xE50, 0x00001FC0
0xE54, 0x00000000
0xE58, 0x00010000
DQ mapping seems to be OK - we have 1:1 mapping from CPU to DDR slot, so we use DQ mappings from DDR module SPD without changing.
What can be the problem?
タグ(3)
1,519件の閲覧回数
altu
The problem was solved by updating to new version of QCVS(4.27.0)
3 返答(返信)
1,579件の閲覧回数
June_Lu
1.The QCVS does not support hardcoded RCW official, valid RCW has to be presented in the RCW source flash or SD card.
Would you kindly program the RCW into the flash first, and then do the QCVS DDR validation.
2.Run the command below in the CCS:
(bin) 42 % delete all
(bin) 43 % config cc cwtap
(bin) 44 % show cc
(bin) 45 % ccs::config_chain {ls1043a dap sap2}
(bin) 46 % display ::ccs::get_config_chain
(bin) 47 % ccs::reset_to_debug
Send the logs to me.
3.would you kindly share the schematics and confirm the layout follow the
AN5097, Hardware and Layout Design Considerations for DDR4 SDRAM Memory Interfaces
1,614件の閲覧回数
June_Lu
Is there available RCW on the customer board?
Has the ASLEEP led turned on and off?
What's the frequency of the DDR clock?
1,520件の閲覧回数
altu
%3CLINGO-SUB%20id%3D%22lingo-sub-2314063%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ELS1046%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%A0%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E3%81%8A%E3%81%91%E3%82%8BDDR4%E3%82%AD%E3%83%A3%E3%83%AA%E3%83%96%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AE%E5%95%8F%E9%A1%8C%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2314063%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%89%AF%E3%81%84%E4%B8%80%E6%97%A5%EF%BC%81%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%9F%E3%81%A1%E3%81%AF%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%A0%20LS1046%20%E3%83%99%E3%83%BC%E3%82%B9%E3%81%AE%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E7%AB%8B%E3%81%A1%E4%B8%8A%E3%81%92%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81DDR4%20%E3%81%AE%E3%82%AD%E3%83%A3%E3%83%AA%E3%83%96%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E6%89%8B%E9%A0%86%E3%81%AB%E8%A1%8C%E3%81%8D%E8%A9%B0%E3%81%BE%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%AESPD%E3%83%87%E3%83%BC%E3%82%BF%E3%81%AF%E6%AD%A3%E5%B8%B8%E3%81%AB%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%80%81%E3%82%AD%E3%83%A3%E3%83%AA%E3%83%96%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%E3%82%82%E6%AD%A3%E5%B8%B8%E3%81%AB%E9%96%8B%E5%A7%8B%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%81%9D%E3%81%AE%E5%BE%8C%E3%80%81%E3%81%93%E3%81%AE%E7%90%86%E7%94%B1%E3%81%A7%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%99%EF%BC%88CodeWarrior%E3%81%AE%E3%83%AD%E3%82%B0%20%3CLI-EMOJI%20id%3D%22lia_disappointed-face%22%20title%3D%22%3Adisappointed_face%3A%22%3E%3C%2FLI-EMOJI%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%20%E5%AE%9F%E8%A1%8C%201%3C%2FP%3E%3CP%3E%E6%A4%9C%E7%B4%A2%E7%B5%90%E6%9E%9C%3A%20wrlvl_searcher%3C%2FP%3E%3CP%3E%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%3C%2FP%3E%3CP%3E%E3%83%86%E3%82%B9%E3%83%88%E7%B5%90%E6%9E%9C%3A%20%5B%3C%2FP%3E%3CP%3E%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3C%2FP%3E%3CP%3E%E6%9B%B4%E6%96%B0%E6%97%A5%3A%3C%2FP%3E%3CP%3EWRLVL_CNTL%20%3D%200x8655F605%E3%80%81WRLVL_CNTL_2%20%3D%200x00000000%E3%80%81%3CBR%20%2F%3E%20WRLVL_CNTL_3%20%3D%200x00000000%E3%80%81SDRAM_CLK_CNTL%20%3D%200x02800000%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3C%2FP%3E%3CP%3E%E6%9B%B4%E6%96%B0%E6%97%A5%3A%3C%2FP%3E%3CP%3EWRLVL_CNTL%20%3D%200x8655F60A%E3%80%81WRLVL_CNTL_2%20%3D%200x0B0B0C0F%E3%80%81%3CBR%20%2F%3E%20WRLVL_CNTL_3%20%3D%200x0F10110D%E3%80%81SDRAM_CLK_CNTL%20%3D%200x02800000%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3C%2FP%3E%3CP%3E%E6%9B%B4%E6%96%B0%E6%97%A5%3A%3C%2FP%3E%3CP%3EWRLVL_CNTL%20%3D%200x8655F60A%E3%80%81WRLVL_CNTL_2%20%3D%200x0B0B0C0F%E3%80%81%3CBR%20%2F%3E%20WRLVL_CNTL_3%20%3D%200x0F101115%E3%80%81SDRAM_CLK_CNTL%20%3D%200x02800000%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3C%2FP%3E%3CP%3E%E6%9B%B4%E6%96%B0%E6%97%A5%3A%3C%2FP%3E%3CP%3EWRLVL_CNTL%20%3D%200x8655F60A%E3%80%81WRLVL_CNTL_2%20%3D%200x0B0B0C0F%E3%80%81%3CBR%20%2F%3E%20WRLVL_CNTL_3%20%3D%200x0F10111D%E3%80%81SDRAM_CLK_CNTL%20%3D%200x02800000%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%83%AC%E3%83%99%E3%83%AA%E3%83%B3%E3%82%B0%E3%81%AE%E9%96%8B%E5%A7%8B%E5%80%A4%E3%81%AF%E6%AD%A3%E3%81%97%E3%81%84%E3%81%AE%E3%81%A7%E3%80%81%E3%81%93%E3%82%8C%E4%BB%A5%E4%B8%8A%E3%81%AE%E5%A4%89%E6%9B%B4%E3%81%AF%E5%BF%85%E8%A6%81%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3CBR%20%2F%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E4%BB%96%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AB%E3%82%88%E3%82%8A%E3%83%86%E3%82%B9%E3%83%88%E3%81%AF%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E6%9C%80%E3%82%82%E4%B8%80%E8%88%AC%E7%9A%84%E3%81%AA%E9%9A%9C%E5%AE%B3%E3%81%AE%E5%8E%9F%E5%9B%A0%3A%3C%2FP%3E%3CP%3E-DDR4%20DQn_MAP%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%9F%E5%80%A4%E3%81%8C%E6%AD%A3%E3%81%97%E3%81%8F%E3%81%AA%E3%81%84%3CBR%20%2F%3E-ODT%E5%80%A4%E3%81%8C%E6%AD%A3%E3%81%97%E3%81%8F%E3%81%AA%E3%81%84%3CBR%20%2F%3E-%20%E9%96%93%E9%81%95%E3%81%A3%E3%81%9F%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E5%BC%B7%E5%BA%A6%E3%81%8C%E9%81%B8%E6%8A%9E%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E-%E3%82%BF%E3%82%A4%E3%83%9F%E3%83%B3%E3%82%B0%E6%A7%8B%E6%88%900%E3%83%97%E3%83%AD%E3%83%91%E3%83%86%E3%82%A3%EF%BC%88TIMING_CFG_0%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%EF%BC%89%E3%81%AB%E9%81%B8%E6%8A%9E%E3%81%95%E3%82%8C%E3%81%9F%E3%82%BF%E3%82%A4%E3%83%9F%E3%83%B3%E3%82%B0%E5%80%A4%E3%81%8C%E6%AD%A3%E3%81%97%E3%81%8F%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3C%2FP%3E%3CP%3E%26lt%3B%26lt%3B%E3%83%86%E3%82%B9%E3%83%88%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F!%26gt%3B%26gt%3B%3C%2FP%3E%3CP%3E%7B%7BWrite%20Leveling%20start%20values%20are%20correct%20and%20require%20no%20further%20modification%2C%3CBR%20%2F%3Ebut%20the%20test%20failed%20due%20to%20other%20issues.%7D%7D%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%E3%81%88%E3%83%BC%E3%81%A3%E3%81%A8%E3%80%82%E3%82%AD%E3%83%A3%E3%83%97%E3%83%81%E3%83%A3%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%3A%3C%2FP%3E%3CP%3E0xE20%2C%200xDEADBEEF%3CBR%20%2F%3E%200xE24%E3%80%810xDEADBEEF%3CBR%20%2F%3E%200xE28%2C%200x00000000%3CBR%20%2F%3E%200xE40%2C%200x00000000%3CBR%20%2F%3E%200xE44%2C%200x00000000%3CBR%20%2F%3E%200xE48%2C%200x0000001D%3CBR%20%2F%3E%200xE4C%E3%80%810x60FF2001%3CBR%20%2F%3E%200xE50%2C%200x00001FC0%3CBR%20%2F%3E%200xE54%2C%200x00000000%3CBR%20%2F%3E%200xE58%2C%200x00010000%3C%2FP%3E%3CP%3E%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%3C%2FP%3E%3CP%3EDQ%20%E3%83%9E%E3%83%83%E3%83%94%E3%83%B3%E3%82%B0%E3%81%AF%E5%95%8F%E9%A1%8C%E3%81%AA%E3%81%84%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82CPU%20%E3%81%8B%E3%82%89%20DDR%20%E3%82%B9%E3%83%AD%E3%83%83%E3%83%88%E3%81%B8%E3%81%AE%E3%83%9E%E3%83%83%E3%83%94%E3%83%B3%E3%82%B0%E3%81%AF%201%3A1%20SO%E3%80%81DDR%20%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%20SPD%20%E3%81%8B%E3%82%89%E3%81%AE%20DQ%20%E3%83%9E%E3%83%83%E3%83%94%E3%83%B3%E3%82%B0%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%9B%E3%81%9A%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E4%BD%95%E3%81%8C%E5%95%8F%E9%A1%8C%E3%81%AA%E3%81%AE%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2314621%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20DDR4%20calibration%20issues%20on%20LS1046%20custom%20board%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2314621%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20'Microsoft%20YaHei'%3B%20font-size%3A%2011.0pt%3B%22%20lang%3D%22en-US%22%3E%E3%81%8A%E5%AE%A2%E6%A7%98%E3%83%9C%E3%83%BC%E3%83%89%E4%B8%8A%E3%81%A7%E5%88%A9%E7%94%A8%E5%8F%AF%E8%83%BD%E3%81%AA%20RCW%20%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20'Microsoft%20YaHei'%3B%20font-size%3A%2011.0pt%3B%22%20lang%3D%22en-US%22%3EASLEEP%20LED%20%E3%81%AF%E7%82%B9%E7%81%AF%E3%81%97%E3%81%9F%E3%82%8A%E6%B6%88%E3%81%88%E3%81%9F%E3%82%8A%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8B%3F%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20'Microsoft%20YaHei'%3B%20font-size%3A%2011.0pt%3B%22%20lang%3D%22en-US%22%3EDDR%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%81%AE%E5%91%A8%E6%B3%A2%E6%95%B0%E3%81%AF%E3%81%A9%E3%82%8C%E3%81%8F%E3%82%89%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20'Microsoft%20YaHei'%3B%20font-size%3A%2011.0pt%3B%22%20lang%3D%22en-US%22%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2314720%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20DDR4%20calibration%20issues%20on%20LS1046%20custom%20board%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2314720%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EDDR%20%E3%82%AD%E3%83%A3%E3%83%AA%E3%83%96%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AF%E3%80%81%E3%83%8F%E3%83%BC%E3%83%89%E3%82%B3%E3%83%BC%E3%83%89%E3%81%95%E3%82%8C%E3%81%9F%20RCW%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E5%AE%9F%E8%A1%8C%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%20-%20100%20MHz%20DDR%E3%83%90%E3%82%B9%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%20-%20800%20MHz%E3%80%81DDR%E3%83%87%E3%83%BC%E3%82%BF%E3%83%AC%E3%83%BC%E3%83%88%20-%201600%20mt%2Fs%3C%2FP%3E%3CP%3E%E3%83%A1%E3%83%A2%E3%83%AA%20%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%20-%20%E9%9D%9E%20ECC%E3%80%82%3C%2FP%3E%3CP%3E%E8%88%88%E5%91%B3%E6%B7%B1%E3%81%84%E7%82%B9%E3%81%AE%201%20%E3%81%A4%E3%81%AF%E3%80%81%E3%82%BF%E3%82%A4%E3%83%9E%E3%83%BC%E3%81%8B%E3%82%89%E6%99%82%E9%96%93%E3%81%BE%E3%81%A7%E3%80%81%E3%82%AD%E3%83%A3%E3%83%AA%E3%83%96%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AE%E7%AC%AC%201%20%E6%AE%B5%E9%9A%8E%20(wrtlvl%20%E6%A4%9C%E7%B4%A2)%20%E3%81%8C%E6%AD%A3%E5%B8%B8%E3%81%AB%E9%80%9A%E9%81%8E%E3%81%97%E3%81%9F%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E4%BE%8B%EF%BC%9A%3C%2FP%3E%3CP%20class%3D%22%22%3E%E3%83%86%E3%82%B9%E3%83%88%E7%B5%90%E6%9E%9C%3A%20%5B%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3C%2FP%3E%3CP%20class%3D%22%22%3E%E6%9B%B4%E6%96%B0%E6%97%A5%3A%3C%2FP%3E%3CP%20class%3D%22%22%3EWRLVL_CNTL%20%3D%200x8655F605%E3%80%81WRLVL_CNTL_2%20%3D%200x00000000%E3%80%81%3C%2FP%3E%3CP%20class%3D%22%22%3EWRLVL_CNTL_3%20%3D%200x00000000%E3%80%81SDRAM_CLK_CNTL%20%3D%200x02800000%3C%2FP%3E%3CP%20class%3D%22%22%3E%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3C%2FP%3E%3CP%20class%3D%22%22%3E%E6%9B%B4%E6%96%B0%E6%97%A5%3A%3C%2FP%3E%3CP%20class%3D%22%22%3EWRLVL_CNTL%20%3D%200x8655F609%E3%80%81WRLVL_CNTL_2%20%3D%200x0A0B0C0E%E3%80%81%3C%2FP%3E%3CP%20class%3D%22%22%3EWRLVL_CNTL_3%20%3D%200x0F10110D%E3%80%81SDRAM_CLK_CNTL%20%3D%200x02800000%3C%2FP%3E%3CP%20class%3D%22%22%3E%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3C%2FP%3E%3CP%20class%3D%22%22%3E%E6%9B%B4%E6%96%B0%E6%97%A5%3A%3C%2FP%3E%3CP%20class%3D%22%22%3EWRLVL_CNTL%20%3D%200x8655F609%E3%80%81WRLVL_CNTL_2%20%3D%200x0A0B0C0E%E3%80%81%3C%2FP%3E%3CP%20class%3D%22%22%3EWRLVL_CNTL_3%20%3D%200x0F101115%E3%80%81SDRAM_CLK_CNTL%20%3D%200x02800000%3C%2FP%3E%3CP%20class%3D%22%22%3E%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3C%2FP%3E%3CP%20class%3D%22%22%3E%E6%9B%B4%E6%96%B0%E6%97%A5%3A%3C%2FP%3E%3CP%20class%3D%22%22%3EWRLVL_CNTL%20%3D%200x8655F609%E3%80%81WRLVL_CNTL_2%20%3D%200x0A0B0C0F%E3%80%81%3C%2FP%3E%3CP%20class%3D%22%22%3EWRLVL_CNTL_3%20%3D%200x0F10111D%E3%80%81SDRAM_CLK_CNTL%20%3D%200x02800000%3C%2FP%3E%3CP%20class%3D%22%22%3E%E3%80%8A%E3%83%86%E3%82%B9%E3%83%88%E5%90%88%E6%A0%BC%EF%BC%81%E3%80%8B%3C%2FP%3E%3CP%20class%3D%22%22%3EErr.capture%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%3A%3C%2FP%3E%3CP%20class%3D%22%22%3E0xE20%2C%200x00000000%200xE24%2C%200x00000000%200xE28%2C0x00000000%3C%2FP%3E%3CP%20class%3D%22%22%3E0xE40%2C0x00000000%200xE44%2C0x00000000%200xE48%2C%200x0000001D%3C%2FP%3E%3CP%20class%3D%22%22%3E0xE4C%2C%200x00000000%200xE50%2C0x00000000%200xE54%2C0x00000000%3C%2FP%3E%3CP%20class%3D%22%22%3E0xE58%2C%200x00010000%3C%2FP%3E%3CP%20class%3D%22%22%3E%E3%81%94%E3%81%BF%EF%BC%9A%3C%2FP%3E%3CP%20class%3D%22%22%3E0xF00%2C0x00000000%200xF04%2C%200x00000002%200xF08%2C%200x0000000F%3C%2FP%3E%3CP%20class%3D%22%22%3E0xF0C%2C0x14000C20%200xF10%2C%200x00000000%200xF14%2C%200x00000000%3C%2FP%3E%3CP%20class%3D%22%22%3E0xF18%2C%200x00000000%200xF1C%2C%200x00000000%200xF20%2C%200x00000000%3C%2FP%3E%3CP%20class%3D%22%22%3E0xF24%2C%200x2F003000%200xF28%2C%200x32003400%200xF2C%2C%200x39003B00%3C%2FP%3E%3CP%20class%3D%22%22%3E0xF30%2C%200x3C003E00%200xF34%2C%200x00005000%200xF38%2C%200x00000000%3C%2FP%3E%3CP%20class%3D%22%22%3E0xF3C%2C%200x00000000%200xF40%2C%200x00000000%200xF44%2C%200x00000000%3C%2FP%3E%3CP%20class%3D%22%22%3E0xF48%2C%200x00000001%200xF4C%2C%200xD4000000%200xF50%2C%200x13001500%3C%2FP%3E%3CP%20class%3D%22%22%3E0xF54%2C%200x17001900%200xF58%2C%200x1D001F00%200xF5C%2C%200x21002200%3C%2FP%3E%3CP%20class%3D%22%22%3E0xF60%2C%200x3A000000%200xF64%2C%200x00009000%200xF68%2C%200x00000020%3C%2FP%3E%3CP%20class%3D%22%22%3E0xF6C%2C%200x00000000%200xF70%2C%200x0070006F%200xF74%2C%200x00000000%3C%2FP%3E%3CP%20class%3D%22%22%3E0xF78%2C%200x00000000%200xF7C%2C%200x00000000%200xF80%2C%200x00000000%3C%2FP%3E%3CP%20class%3D%22%22%3E0xF84%2C%200x00000000%200xF88%2C%200x00000000%200xF8C%2C%200x00000000%3C%2FP%3E%3CP%20class%3D%22%22%3E0xF90%2C%200x00000000%200xF94%2C%200x80000000%200xF98%2C%200x00000000%3C%2FP%3E%3CP%20class%3D%22%22%3E0xF9C%2C%200x34043104%200xFA0%2C%200x35043304%200xFA4%2C%200x31043304%3C%2FP%3E%3CP%20class%3D%22%22%3E0xFA8%2C%200x2F043104%200xFAC%2C%200x04040000%200xFB0%2C%200x00000003%3C%2FP%3E%3CP%20class%3D%22%22%3E0xFB4%2C%200x1F1E1F21%200xFB8%2C%200x1E1C1F1D%200xFBC%2C%200x1F1B1D1E%3C%2FP%3E%3CP%20class%3D%22%22%3E0xFC0%2C%200x1C1B1C1C%200xFC4%2C%200x1F1E1F22%200xFC8%2C%200x1F1F2120%3C%2FP%3E%3CP%20class%3D%22%22%3E0xFCC%2C%200x1F1E1F20%200xFD0%2C%200x1C1D201F%200xFD4%2C%200x1F1B1B1E%3C%2FP%3E%3CP%20class%3D%22%22%3E0xFD8%2C%200x1F1D1E1C%200xFDC%2C%200x1F1F1D1F%200xFE0%2C%200x1F1D1E1C%3C%2FP%3E%3CP%20class%3D%22%22%3E0xFE4%E3%80%810x1F1C191A%200xFE8%E3%80%810x1C1D1C1A%200xFEC%E3%80%810x1F1E1C1E%3C%2FP%3E%3CP%20class%3D%22%22%3E0xFF0%2C%200x1E1F1E1A%200xFF4%2C%200x1F1F1F1F%200xFF8%2C%200x1F1F1F1F%3C%2FP%3E%3CP%20class%3D%22%22%3E0xFFC%E3%80%810x1F000000%3C%2FP%3E%3CP%20class%3D%22%22%3E%E3%83%87%E3%83%BC%E3%82%BF%EF%BC%9A%3C%2FP%3E%3CP%20class%3D%22%22%3E0x00000009%200x0000000a%200x0000000b%200x0000000c%200x0000000f%3C%2FP%3E%3CP%20class%3D%22%22%3E0x0000000f%200x00000010%200x00000011%200x0000001d%3C%2FP%3E%3CP%20class%3D%22%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20class%3D%22%22%3E%E3%81%9D%E3%81%AE%E7%9B%B4%E5%BE%8C%E3%81%AB%E3%80%81%EF%BC%88%E8%A8%AD%E5%AE%9A%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%9B%E3%81%9A%E3%81%AB%EF%BC%89%E3%82%AD%E3%83%A3%E3%83%AA%E3%83%96%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%20%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%E3%82%92%E5%86%8D%E5%BA%A6%E9%96%8B%E5%A7%8B%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%20class%3D%22%22%3E%23%23%23%23%23%23%23%23%20%23%23%20Result%20for%3A%20wrlvl_searcher%20%23%23%20%23%23%23%23%3C%2FP%3E%3CP%20class%3D%22%22%3E%E3%83%86%E3%82%B9%E3%83%88%E7%B5%90%E6%9E%9C%3A%20%5B%3C%2FP%3E%3CP%20class%3D%22%22%3E%E6%9B%B4%E6%96%B0%3A%20WRLVL_CNTL%20%3D%200x8655F605%E3%80%81WRLVL_CNTL_2%20%3D%200x00000000%E3%80%81%3C%2FP%3E%3CP%20class%3D%22%22%3EWRLVL_CNTL_3%20%3D%200x00000000%E3%80%81SDRAM_CLK_CNTL%20%3D%200x02800000%3C%2FP%3E%3CP%20class%3D%22%22%3E%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3C%2FP%3E%3CP%20class%3D%22%22%3E%E6%9B%B4%E6%96%B0%3A%20WRLVL_CNTL%20%3D%200x8655F609%E3%80%81WRLVL_CNTL_2%20%3D%200x0A0B0C0E%E3%80%81%3C%2FP%3E%3CP%20class%3D%22%22%3EWRLVL_CNTL_3%20%3D%200x0F10110D%E3%80%81SDRAM_CLK_CNTL%20%3D%200x02800000%3C%2FP%3E%3CP%20class%3D%22%22%3E%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3C%2FP%3E%3CP%20class%3D%22%22%3E%E6%9B%B4%E6%96%B0%3A%20WRLVL_CNTL%20%3D%200x8655F609%E3%80%81WRLVL_CNTL_2%20%3D%200x0A0B0C0E%E3%80%81%3C%2FP%3E%3CP%20class%3D%22%22%3EWRLVL_CNTL_3%20%3D%200x0F101115%E3%80%81SDRAM_CLK_CNTL%20%3D%200x02800000%3C%2FP%3E%3CP%20class%3D%22%22%3E%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3C%2FP%3E%3CP%20class%3D%22%22%3E%E6%9B%B4%E6%96%B0%3A%20WRLVL_CNTL%20%3D%200x8655F609%E3%80%81WRLVL_CNTL_2%20%3D%200x0A0B0C0E%E3%80%81%3C%2FP%3E%3CP%20class%3D%22%22%3EWRLVL_CNTL_3%20%3D%200x0F10111D%E3%80%81SDRAM_CLK_CNTL%20%3D%200x02800000%3C%2FP%3E%3CP%20class%3D%22%22%3E%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%83%AC%E3%83%99%E3%83%AA%E3%83%B3%E3%82%B0%E3%81%AE%E9%96%8B%E5%A7%8B%E5%80%A4%E3%81%AF%E6%AD%A3%E3%81%97%E3%81%8F%E3%80%81%E3%81%9D%E3%82%8C%E4%BB%A5%E4%B8%8A%E3%81%AE%E5%A4%89%E6%9B%B4%E3%81%AF%E5%BF%85%E8%A6%81%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81%E3%83%86%E3%82%B9%E3%83%88%3C%2FP%3E%3CP%20class%3D%22%22%3E%E3%81%9D%E3%81%AE%E4%BB%96%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AB%E3%82%88%E3%82%8A%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E6%9C%80%E3%82%82%E4%B8%80%E8%88%AC%E7%9A%84%E3%81%AA%E9%9A%9C%E5%AE%B3%E3%81%AE%E5%8E%9F%E5%9B%A0%3A%3C%2FP%3E%3CP%20class%3D%22%22%3E-%20DDR4%20DQn_MAP%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%9F%E5%80%A4%E3%81%8C%E6%AD%A3%E3%81%97%E3%81%8F%E3%81%AA%E3%81%84%3C%2FP%3E%3CP%20class%3D%22%22%3E-%20ODT%E5%80%A4%E3%81%8C%E6%AD%A3%E3%81%97%E3%81%8F%E3%81%AA%E3%81%84%3C%2FP%3E%3CP%20class%3D%22%22%3E-%20%E9%96%93%E9%81%95%E3%81%A3%E3%81%9F%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E5%BC%B7%E5%BA%A6%E3%81%8C%E9%81%B8%E6%8A%9E%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%20class%3D%22%22%3E-%20%E3%82%BF%E3%82%A4%E3%83%9F%E3%83%B3%E3%82%B0%E6%A7%8B%E6%88%900%E3%83%97%E3%83%AD%E3%83%91%E3%83%86%E3%82%A3%EF%BC%88TIMING_CFG_0%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%EF%BC%89%E3%81%AB%E9%81%B8%E6%8A%9E%E3%81%95%E3%82%8C%E3%81%9F%E3%82%BF%E3%82%A4%E3%83%9F%E3%83%B3%E3%82%B0%E5%80%A4%E3%81%8C%E6%AD%A3%E3%81%97%E3%81%8F%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3C%2FP%3E%3CP%20class%3D%22%22%3E%26lt%3B%26lt%3B%E3%83%86%E3%82%B9%E3%83%88%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F!%26gt%3B%26gt%3B%3C%2FP%3E%3CP%20class%3D%22%22%3E%7B%7BWrite%20Leveling%20start%20values%20are%20correct%20and%20require%20no%20further%20modification%2C%20but%20the%20test%20failed%20due%20to%20other%20issues.%7D%7D%3C%2FP%3E%3CP%20class%3D%22%22%3E%E3%82%A8%E3%83%A9%E3%83%BC%E3%82%AD%E3%83%A3%E3%83%97%E3%83%81%E3%83%A3%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%3A%3C%2FP%3E%3CP%20class%3D%22%22%3E0xE20%2C%200xDEADBEEF%200xE24%2C%200xDEADBEEF%200xE28%2C%200x00000000%200xE40%2C%200x00000000%3C%2FP%3E%3CP%20class%3D%22%22%3E0xE44%2C%200x00000000%200xE48%2C%200x0000001D%200xE4C%2C%200x60FF2001%200xE50%2C%200x00001FC0%3C%2FP%3E%3CP%20class%3D%22%22%3E0xE54%2C%200x00000000%200xE58%2C%200x00010000%3C%2FP%3E%3CP%20class%3D%22%22%3E%E3%81%94%E3%81%BF%EF%BC%9A%3C%2FP%3E%3CP%20class%3D%22%22%3E0xF00%2C%200x00000000%200xF04%2C%200x00000002%200xF08%2C%200x0000000E%200xF0C%2C%200x14000C20%3C%2FP%3E%3CP%20class%3D%22%22%3E0xF10%2C%200x00000000%200xF14%2C%200x00000000%200xF18%2C%200x00000000%200xF1C%2C%200x00000000%3C%2FP%3E%3CP%20class%3D%22%22%3E0xF20%2C%200x00000000%200xF24%2C%200x2F003100%200xF28%2C%200x33003400%200xF2C%2C%200x3A003A00%3C%2FP%3E%3CP%20class%3D%22%22%3E0xF30%2C%200x3C003E00%200xF34%2C%200x00005000%200xF38%2C%200x00000000%200xF3C%2C%200x00000000%3C%2FP%3E%3CP%20class%3D%22%22%3E0xF40%2C%200x00000000%200xF44%2C%200x00000000%200xF48%2C%200x00000001%200xF4C%2C%200xD4000000%3C%2FP%3E%3CP%20class%3D%22%22%3E0xF50%2C%200x13001500%200xF54%2C%200x17001900%200xF58%2C%200x1D001F00%200xF5C%2C%200x21002200%3C%2FP%3E%3CP%20class%3D%22%22%3E0xF60%2C%200x3A000000%200xF64%2C%200x00009000%200xF68%2C%200x00000020%200xF6C%2C%200x00000000%3C%2FP%3E%3CP%20class%3D%22%22%3E0xF70%2C%200x0070006F%200xF74%2C%200x00000000%200xF78%2C%200x00000000%200xF7C%2C%200x00000000%3C%2FP%3E%3CP%20class%3D%22%22%3E0xF80%2C%200x00000000%200xF84%2C%200x00000000%200xF88%2C%200x00000000%200xF8C%2C%200x00000000%3C%2FP%3E%3CP%20class%3D%22%22%3E0xF90%2C%200x00000000%200xF94%2C%200x80000000%200xF98%2C%200x00000000%200xF9C%2C%200x31022F02%3C%2FP%3E%3CP%20class%3D%22%22%3E0xFA0%2C%200x33023102%200xFA4%2C%200x30023102%200xFA8%2C%200x2E022F02%200xFAC%2C%200x02020000%3C%2FP%3E%3CP%20class%3D%22%22%3E0xFB0%2C%200x10000003%200xFB4%2C%200x46444650%200xFB8%2C%200x45445142%200xFBC%2C%200x51445052%3C%2FP%3E%3CP%20class%3D%22%22%3E0xFC0%2C%200x46454544%200xFC4%2C%200x45434651%200xFC8%2C%200x44455045%200xFCC%2C%200x46455051%3C%2FP%3E%3CP%20class%3D%22%22%3E0xFD0%2C%200x45455146%200xFD4%2C%200x52505052%200xFD8%2C%200x52505246%200xFDC%2C%200x50464546%3C%2FP%3E%3CP%20class%3D%22%22%3E0xFE0%2C%200x51465042%200xFE4%2C%200x53464650%200xFE8%2C%200x52515145%200xFEC%2C%200x50454546%3C%2FP%3E%3CP%20class%3D%22%22%3E0xFF0%2C%200x45505142%200xFF4%2C%200x46464646%200xFF8%2C%200x52515350%200xFFC%2C%200x00000000%3C%2FP%3E%3CP%20class%3D%22%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20class%3D%22%22%3E%E3%83%87%E3%83%BC%E3%82%BF%EF%BC%9A%3C%2FP%3E%3CP%20class%3D%22%22%3E0x00000009%200x0000000a%200x0000000b%200x0000000c%200x0000000e%200x0000000f%200x00000010%200x00000011%200x00000025%3C%2FP%3E%3CP%20class%3D%22%22%3E%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%3C%2FP%3E%3CP%20class%3D%22%22%3E%E3%81%BE%E3%81%9F%E3%80%81DDR%20%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%8C%E9%9D%9E%20ECC%20%E3%81%A7%E3%81%82%E3%82%8A%E3%80%81%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E8%A8%AD%E5%AE%9A%E3%81%A7%20ECC%20%E3%81%8C%E7%84%A1%E5%8A%B9%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AB%E3%82%82%E3%81%8B%E3%81%8B%E3%82%8F%E3%82%89%E3%81%9A%E3%80%81%E3%82%AD%E3%83%A3%E3%83%AA%E3%83%96%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%20%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%E4%B8%AD%E3%81%AB%E3%83%AC%E3%83%BC%E3%83%B3%208%20%E3%81%8C%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AB%E6%B0%97%E4%BB%98%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%20class%3D%22%22%3E%26nbsp%3B%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2315296%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20DDR4%20calibration%20issues%20on%20LS1046%20custom%20board%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2315296%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20Calibri%3B%20font-size%3A%2011.0pt%3B%22%3E%3CSPAN%3E1.%3C%2FSPAN%3E%20%3CSPAN%3EQCVS%20%E3%81%AF%E3%83%8F%E3%83%BC%E3%83%89%E3%82%B3%E3%83%BC%E3%83%89%E3%81%95%E3%82%8C%E3%81%9F%20RCW%3C%2FSPAN%3E%3CSPAN%3E%E3%82%AA%E3%83%95%E3%82%A3%E3%82%B7%E3%83%A3%E3%83%AB%3C%2FSPAN%3E%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%9F%E3%82%81%3CSPAN%3E%E3%80%81%E6%9C%89%E5%8A%B9%E3%81%AA%20RCW%20%E3%81%8C%3C%2FSPAN%3E%3CSPAN%3ERCW%20%E3%82%BD%E3%83%BC%E3%82%B9%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%BE%E3%81%9F%E3%81%AF%20SD%20%E3%82%AB%E3%83%BC%E3%83%89%E3%81%AB%3C%2FSPAN%3E%E5%AD%98%E5%9C%A8%E3%81%97%3CSPAN%3E%E3%81%A6%3C%2FSPAN%3E%E3%81%84%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20Calibri%3B%20font-size%3A%2011.0pt%3B%22%3E%E3%81%BE%E3%81%9A%20RCW%20%E3%82%92%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%AB%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%97%E3%80%81%E6%AC%A1%E3%81%AB%20QCVS%20DDR%20%E6%A4%9C%E8%A8%BC%E3%82%92%E8%A1%8C%E3%81%A3%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20Calibri%3B%20font-size%3A%2011.0pt%3B%22%20lang%3D%22en-US%22%3E2.%20CCS%20%E3%81%A7%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20Calibri%3B%20font-size%3A%2011.0pt%3B%22%3E%EF%BC%88%E3%83%93%E3%83%B3%EF%BC%8942%EF%BC%85%E3%81%99%E3%81%B9%E3%81%A6%E5%89%8A%E9%99%A4%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20Calibri%3B%20font-size%3A%2011.0pt%3B%22%3E%EF%BC%88bin%EF%BC%8943%EF%BC%85config%20cc%20cwtap%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20Calibri%3B%20font-size%3A%2011.0pt%3B%22%3E%EF%BC%88%E3%83%93%E3%83%B3%EF%BC%8944%EF%BC%85cc%E3%82%92%E8%A1%A8%E7%A4%BA%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20Calibri%3B%20font-size%3A%2011.0pt%3B%22%3E(bin)%2045%20%25%20ccs%3A%3Aconfig_chain%20%7Bls1043a%20dap%20sap2%7D%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20Calibri%3B%20font-size%3A%2011.0pt%3B%22%3E(bin)%2046%20%25%20%E8%A1%A8%E7%A4%BA%20%3A%3Accs%3A%3Aget_config_chain%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20Calibri%3B%20font-size%3A%2011.0pt%3B%22%3E(bin)%2047%20%25%20ccs%3A%3Areset_to_debug%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20Calibri%3B%20font-size%3A%2011.0pt%3B%22%20lang%3D%22en-US%22%3E%E3%83%AD%E3%82%B0%E3%82%92%E7%A7%81%E3%81%AB%E9%80%81%E3%81%A3%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20Calibri%3B%20font-size%3A%2011.0pt%3B%22%20lang%3D%22en-US%22%3E3.%E5%9B%9E%E8%B7%AF%E5%9B%B3%E3%82%92%E5%85%B1%E6%9C%89%E3%81%97%E3%81%A6%E3%83%AC%E3%82%A4%E3%82%A2%E3%82%A6%E3%83%88%E3%81%8C%E4%BB%A5%E4%B8%8B%E3%81%AE%E9%80%9A%E3%82%8A%E3%81%A7%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20Calibri%3B%20font-size%3A%2011.0pt%3B%22%20lang%3D%22en-US%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fwebapp%2FDownload%3FcolCode%3DAN5097%26amp%3Blocation%3Dnull%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EAN5097%E3%80%81DDR4%20SDRAM%E3%83%A1%E3%83%A2%E3%83%AA%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%81%AE%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%8A%E3%82%88%E3%81%B3%E3%83%AC%E3%82%A4%E3%82%A2%E3%82%A6%E3%83%88%E8%A8%AD%E8%A8%88%E3%81%AE%E8%80%83%E6%85%AE%E4%BA%8B%E9%A0%85%3C%2FA%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20Calibri%3B%20font-size%3A%2011.0pt%3B%22%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2317389%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20DDR4%20calibration%20issues%20on%20LS1046%20custom%20board%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2317389%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AF%E3%80%81QCVS%20%E3%81%AE%E6%96%B0%E3%81%97%E3%81%84%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%20(4.27.0)%20%E3%81%AB%E3%82%A2%E3%83%83%E3%83%97%E3%83%87%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E8%A7%A3%E6%B1%BA%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
