CodeWarrior USB TAP
CodeWarrior USB TAP
Vivicv
I am using a legacy Code Warrior USB TAP to debug L1046A board, but when the Code Warrior USB TAP is connected with PC (OS: Windows 10), it seems it is not recognized by PC. Here is the question:
1. Is there any driver i need to install first?
2. Does this legacy CW USB TAP support to debug LS1046A board?
Thanks a lot.
ufedor
2) Sorry, USB TAP is not supported.
Vivicv
ok, so now i have 2 questions, pls help me to deal with them, thanks a lot.
1. For CW USB TAP, currently my PC(Win10) does not recognize it, could you share the linkage of driver? I want to fix this issue even though it does not support this type of processor.
2. Which debugger could support LS1046A debug?
ufedor
LS1046A is supported by CodeWarrior for ARMv8.
CodeWarrior for ARMv8 supports only CodeWarrior TAP (there is no driver for USB TAP):
https://www.nxp.com/design/software/development-software/codewarrior-development-tools/run-control-d...
