Code warrior Tap
Code warrior Tap
rashmikj
Am using LS1046A Processor. For JTAG debugging using code warrior, which connector pinouts do i need to use - CodeWarrior TAP probe for JTAG-COP connector pinout or CodeWarrior TAP probe for ARM connector pinout. what is the difference ?
ufedor
For LS1046A it is needed to use CodeWarrior TAP Probe Tip for ARM:
https://www.nxp.com/design/software/development-software/codewarrior-development-tools/run-control-d...
Also please refer to the AN5252 - QorIQ LS1046A Design Checklist, 5.28.1 JTAG system-level recommendations.
