Building kernel and deploying to device for LS1028ARDB: kernel configs not saving
ソリューションへジャンプ
2,075件の閲覧回数
noahw
I am trying to build kernel using flex-builder with custom config. I am following instructions in sections 4.3.6 and 4.3.10 of the LSDK v21.08 user guide (https://www.nxp.com/docs/en/user-guide/LSDKUG_Rev21.08.pdf). I edit my config file at components/linux/linux/arch/arm64/configs/defconfig, adding some additional configs like CONFIG_I2C_MPC=y and CONFIG_SENSORS_INA2XX=y. Then I run
bld -c linux
After the kernel build, I am expecting to see my new configs reflected in build/linux/linux/arm64/LS/output/LSDK-21.08/.config. But I don't see them in that file. Am I doing something wrong?
2,009件の閲覧回数
noahw
Thank you, it is working now.
Using a fresh image of the Ubuntu desktop LSDK, I get:
# cat /boot/config-5.10.35 | grep SENSORS_INA2XX
CONFIG_SENSORS_INA2XX=m
So get the ina2xx driver working with lm-sensors, I needed to run the following command first to load the kernel module:
modprobe ina2xx
Now I see:
# sensors
ina220-i2c-3-40
Adapter: i2c-0-mux (chan_id 2)
in0: 3.00 mV
in1: 1.01 V
power1: 4.40 W
curr1: 5.16 A
ddr_controller-virtual-0
Adapter: Virtual device
temp1: +45.0°C (crit = +95.0°C)
core_cluster-virtual-0
4 返答(返信)
2,018件の閲覧回数
June_Lu
Yes, I found the CONFIG_I2C_MPC is unavailable.
Have you enable the CONFIG_SENSORS_INA2XX=y?
If you enable it, you would find logs below after you install the lm-sensors.
root@localhost:/boot/# sensors
ina220-i2c-3-40
in0:           3.00 mV
in1:           1.00 V
power1:        4.40 W
curr1:         4.58 A
2,010件の閲覧回数
noahw
modprobe ina2xx
Now I see:
# sensors
ina220-i2c-3-40
in0: 3.00 mV
in1: 1.01 V
power1: 4.40 W
curr1: 5.16 A
2,051件の閲覧回数
June_Lu
In the linux file
$ vi .config
In the file .config, add
CONFIG_I2C_MPC=y
$ sudo apt-get install gcc-aarch64-linux-gnu
$ export CROSS_COMPILE=aarch64-linux-gnu-
$ export ARCH=arm64
make mrproper;make defconfig;make lsdk.config;make menuconfig;make
2,027件の閲覧回数
noahw
The .config file you refer to is the one in build/linux/linux/arm64/LS/output/LSDK-21.08/, correct?
I tried adding the new CONFIG statements into that file, but after the build when I check the file again, the CONFIG_I2C_MPC line has been automatically removed. Does that seem right?
%3CLINGO-SUB%20id%3D%22lingo-sub-2075556%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%E3%81%A8%20LS1028ARDB%20%E3%81%AE%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%B8%E3%81%AE%E3%83%87%E3%83%97%E3%83%AD%E3%82%A4%3A%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E6%A7%8B%E6%88%90%E3%81%8C%E4%BF%9D%E5%AD%98%E3%81%95%E3%82%8C%E3%81%AA%E3%81%84%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2075556%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%A0%E8%A8%AD%E5%AE%9A%E3%81%A7flex-builder%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82LSDK%20v21.08%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%82%AC%E3%82%A4%E3%83%89(%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fuser-guide%2FLSDKUG_Rev21.08.pdf%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fuser-guide%2FLSDKUG_Rev21.08.pdf%3C%2FA%3E)%E3%81%AE%E3%82%BB%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B34.3.6%E3%81%8A%E3%82%88%E3%81%B34.3.10%E3%81%AE%E6%8C%87%E7%A4%BA%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82components%2Flinux%2Flinux%2Farch%2Farm64%2Fconfigs%2Fdefconfig%E3%81%A7%E8%A8%AD%E5%AE%9A%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E7%B7%A8%E9%9B%86%E3%81%97%E3%80%81CONFIG_I2C_MPC%3Dy%E3%82%84CONFIG_SENSORS_INA2XX%3Dy%E3%81%AA%E3%81%A9%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%9D%E3%82%8C%E3%81%8B%E3%82%89%E7%A7%81%E3%81%AF%E8%B5%B0%E3%82%8A%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Ebld%20-c%20linux%3C%2FP%3E%3CP%3E%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%E5%BE%8C%E3%80%81%E6%96%B0%E3%81%97%E3%81%84%E8%A8%AD%E5%AE%9A%E3%81%8Cbuild%2Flinux%2Flinux%2Farm64%2FLS%2Foutput%2FLSDK-21.08%2F.config%E3%81%AB%E5%8F%8D%E6%98%A0%E3%81%95%E3%82%8C%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E6%9C%9F%E5%BE%85%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E3%81%9D%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AB%E3%81%AF%E3%81%9D%E3%82%8C%E3%82%89%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E7%A7%81%E3%81%AF%E4%BD%95%E3%81%8B%E9%96%93%E9%81%95%E3%81%A3%E3%81%9F%E3%81%93%E3%81%A8%E3%82%92%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2078746%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%E3%81%A8LS1028ARDB%E3%81%AE%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%B8%E3%81%AE%E3%83%87%E3%83%97%E3%83%AD%E3%82%A4%3A%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E6%A7%8B%E6%88%90%E3%81%8C%E4%BF%9D%E5%AD%98%E3%81%95%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2078746%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%80%81%E4%BB%8A%E3%81%AF%E5%8B%95%E3%81%84%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EUbuntu%E3%83%87%E3%82%B9%E3%82%AF%E3%83%88%E3%83%83%E3%83%97LSDK%E3%81%AE%E6%96%B0%E3%81%97%E3%81%84%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%23%20cat%20%2Fboot%2Fconfig-5.10.35%20%7Cgrep%20SENSORS_INA2XX%3CBR%20%2F%3ECONFIG_SENSORS_INA2XX%3D%E3%83%A1%E3%83%BC%E3%83%88%E3%83%AB%3C%2FP%3E%3CP%3E%E3%81%97%E3%81%9F%E3%81%8C%E3%81%A3%E3%81%A6%E3%80%81ina2xx%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%82%92lm-sensors%E3%81%A7%E5%8B%95%E4%BD%9C%E3%81%95%E3%81%9B%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E6%9C%80%E5%88%9D%E3%81%AB%E6%AC%A1%E3%81%AE%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%A6%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%82%92%E3%83%AD%E3%83%BC%E3%83%89%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3Emodprobe%20ina2xx%3C%2FP%3E%3CP%3E%E4%BB%8A%E3%80%81%E7%A7%81%E3%81%AF%E8%A6%8B%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3A%3C%2FP%3E%3CP%3E%23%20%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%BC%3CBR%20%2F%3EINA220-I2C-3-40%3CBR%20%2F%3E%E3%82%A2%E3%83%80%E3%83%97%E3%82%BF%3Ai2c-0-mux%20(chan_id%202)%3CBR%20%2F%3Ein0%3A3.00mV%3CBR%20%2F%3Ein1%3A1.01V%3CBR%20%2F%3E%E3%83%91%E3%83%AF%E3%83%BC1%3A4.40%20W%3CBR%20%2F%3Ecurr1%3A%205.16%20A%3C%2FP%3E%3CP%3Eddr_controller-%E4%BB%AE%E6%83%B3-0%3CBR%20%2F%3E%E3%82%A2%E3%83%80%E3%83%97%E3%82%BF%E3%83%BC%3A%20%E4%BB%AE%E6%83%B3%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%3CBR%20%2F%3Etemp1%3A%20%2B45.0%C2%B0C%20(%E3%82%AF%E3%83%AA%E3%83%86%E3%82%A3%E3%82%AB%E3%83%AB%20%3D%20%2B95.0%C2%B0C)%3C%2FP%3E%3CP%3Ecore_cluster-%E4%BB%AE%E6%83%B3-0%3CBR%20%2F%3E%E3%82%A2%E3%83%80%E3%83%97%E3%82%BF%E3%83%BC%3A%20%E4%BB%AE%E6%83%B3%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%3CBR%20%2F%3Etemp1%3A%20%2B45.0%C2%B0C%20(%E3%82%AF%E3%83%AA%E3%83%86%E3%82%A3%E3%82%AB%E3%83%AB%20%3D%20%2B95.0%C2%B0C)%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2078733%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%E3%81%A8LS1028ARDB%E3%81%AE%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%B8%E3%81%AE%E3%83%87%E3%83%97%E3%83%AD%E3%82%A4%3A%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E6%A7%8B%E6%88%90%E3%81%8C%E4%BF%9D%E5%AD%98%E3%81%95%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2078733%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%AF%E3%81%84%E3%80%81CONFIG_I2C_MPC%E3%81%8C%E5%88%A9%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%84%E3%81%93%E3%81%A8%E3%81%8C%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%0A%3CP%3ECONFIG_SENSORS_INA2XX%3Dy%20%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8B%3F%3C%2FP%3E%0A%3CP%3E%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81lm-sensors%20%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%97%E3%81%9F%E5%BE%8C%E3%80%81%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%83%AD%E3%82%B0%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3Eroot%40localhost%3A%2Fboot%2F%23%20%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%BC%3C%2FP%3E%0A%3CP%3Eina220-i2c-3-40%3C%2FP%3E%0A%3CP%3E%E3%82%A2%E3%83%80%E3%83%97%E3%82%BF%3Ai2c-0-mux%20(chan_id%202)%3C%2FP%3E%0A%3CP%3E%E3%82%A4%E3%83%B30%3A3.00mV%E3%81%AE%3C%2FP%3E%0A%3CP%3E%E3%82%A4%E3%83%B31%3A1.00V%3C%2FP%3E%0A%3CP%3E%E3%83%91%E3%83%AF%E3%83%BC1%3A4.40W%3C%2FP%3E%0A%3CP%3Ecurr1%3A4.58%E3%81%82%E3%82%8B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2078680%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%E3%81%A8LS1028ARDB%E3%81%AE%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%B8%E3%81%AE%E3%83%87%E3%83%97%E3%83%AD%E3%82%A4%3A%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E6%A7%8B%E6%88%90%E3%81%8C%E4%BF%9D%E5%AD%98%E3%81%95%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2078680%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%8F%82%E7%85%A7%E3%81%99%E3%82%8B.config%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AF%E3%80%81build%2Flinux%2Flinux%2Farm64%2FLS%2Foutput%2FLSDK-21.08%2F%E3%81%AB%E3%81%82%E3%82%8B%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%A7%E3%81%99%E3%80%82%E3%81%9D%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%81%9D%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AB%E6%96%B0%E3%81%97%E3%81%84CONFIG%E3%82%B9%E3%83%86%E3%83%BC%E3%83%88%E3%83%A1%E3%83%B3%E3%83%88%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%83%93%E3%83%AB%E3%83%89%E5%BE%8C%E3%81%AB%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E5%86%8D%E5%BA%A6%E7%A2%BA%E8%AA%8D%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81CONFIG_I2C_MPC%E8%A1%8C%E3%81%AF%E8%87%AA%E5%8B%95%E7%9A%84%E3%81%AB%E5%89%8A%E9%99%A4%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%9D%E3%82%8C%E3%81%AF%E6%AD%A3%E3%81%97%E3%81%84%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2076039%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%E3%81%A8LS1028ARDB%E3%81%AE%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%B8%E3%81%AE%E3%83%87%E3%83%97%E3%83%AD%E3%82%A4%3A%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E6%A7%8B%E6%88%90%E3%81%8C%E4%BF%9D%E5%AD%98%E3%81%95%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2076039%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20Calibri%3B%20font-size%3A%2011.0pt%3B%22%20lang%3D%22en-US%22%3Elinux%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E5%86%85%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20Calibri%3B%20font-size%3A%2011.0pt%3B%22%20lang%3D%22en-US%22%3E%24%20vi%20.config%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20Calibri%3B%20font-size%3A%2011.0pt%3B%22%20lang%3D%22en-US%22%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%20.config%20%E3%81%A7%E3%81%AF%E3%80%81%E8%B6%B3%E3%81%99%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20Calibri%3B%20font-size%3A%2011.0pt%3B%22%20lang%3D%22en-US%22%3ECONFIG_I2C_MPC%3Dy%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20Calibri%3B%20font-size%3A%2011.0pt%3B%22%20lang%3D%22en-US%22%3ECONFIG_SENSORS_INA2XX%3Dy%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20Calibri%3B%20font-size%3A%2011.0pt%3B%22%20lang%3D%22en-US%22%3E%24%20sudo%20apt-get%20install%20gcc-aarch64-linux-gnu%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20Calibri%3B%20font-size%3A%2011.0pt%3B%22%20lang%3D%22en-US%22%3E%24%20export%20CROSS_COMPILE%3Daarch64-linux-gnu-%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20Calibri%3B%20font-size%3A%2011.0pt%3B%22%20lang%3D%22en-US%22%3E%24%20export%20ARCH%3Darm64%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20Calibri%3B%20font-size%3A%2011.0pt%3B%22%20lang%3D%22en-US%22%3Emake%20mrproper%3Bmake%20defconfig%3Bmake%20lsdk.config%3Bmake%20menuconfig%3Bmake%3C%2FP%3E%3C%2FLINGO-BODY%3E
