Building QorIQ Linux SDK 2.0 for LS1046ARDB
Jayasurya
Hi ,
I would like to build QorIQ Linux SDK 2.0 for LS1046ARDB.
Installed below sdks.
QorIQ Linux SDK v2.0 AARCH64 Yocto Cache.iso
QorIQ Linux SDK v2.0 SOURCE.iso
and ran . /fsl-setup-env -h and observe that only below platforms are supported
Supported machines:
b4420qds-64b b4420qds b4860qds-64b b4860qds c293pcie ls1021atwr ls1043aqds ls1043ardb ls2080ardb p2041rdb p3041ds p4080ds p5020ds-64b p5020ds p5040ds-64b p5040ds t1023rdb-64b t1023rdb t1024rdb-64b t1024rdb t1040d4rdb-64b t1040d4rdb t1042d4rdb-64b t1042d4rdb t2080qds-64b t2080qds t2080rdb-64b t2080rdb t4160qds-64b t4160qds t4240qds-64b t4240qds t4240rdb-64b t4240rdb
Could you please let me know what target should I use to build image for LS1046ARDB ? Am I using the right sdk?
Thanks and Regards,
Jayasurya
yipingwang
You also need to install Patch tar ball "QorIQ Linux SDK v2.0-1703", which could be downloaded from https://www.nxp.com/design/software/embedded-software/linux-software-and-development-tools/linux-sdk...
In addition, for Layerscape processors we recommend customer to use LSDK 21.08 which could be downloaded from
https://www.nxp.com/design/software/embedded-software/linux-software-and-development-tools/layerscap...
yipingwang
