QDMA Data Transfer between PCIe Endpoint and DDR Memory on LX2160A Platform
Introduction
The qDMA controller transfers blocks of data between one source and one destination. The blocks of data transferred can be represented in memory as contiguous or noncontiguous using scatter/gather table(s). Channel virtualization is supported through enqueuing of DMA jobs to, or dequeuing DMA jobs from, different work queues. QDMA can support LX2160A with DPAA2.
The attached patch is used for QDMA data transfer between PCIe Endpoint and DDR memory on LX2160A Platform.
Apply the patch and rebuild Kernel image in LSDK 21.08
Go to LSDK 21.08 Linux Kernel source folder components/linux/linux/
Apply the attached patch.
$ patch -p1 < 0001-QDMA-Performance-test.patch
$ flex-builder -c linux:custom -a arm64
Enable CONFIG_FSL_DPAA2_QDMA=y
$ Rebuild Linux Kernel.
$ flex-builder -c linux -a arm64
Transfer data from Memory to Memory
root@localhost:~# restool dpdmai create --num-queues=8 --priorities=2,5
dpdmai.0 is created under dprc.1
root@localhost:~# restool dprc assign dprc.1 --object=dpdmai.0 --plugged=1
root@localhost:~# echo "dpdmai.0" > /sys/module/dmatest/parameters/device
root@localhost:~# echo '7       4       1       7' > /proc/sys/kernel/printk
root@localhost:~# echo 1 > /sys/module/dmatest/parameters/dmatest_option
root@localhost:~# echo 10 > /sys/module/dmatest/parameters/iterations
root@localhost:~# echo 4096 > /sys/module/dmatest/parameters/test_buf_size
root@localhost:~# echo 1 > /sys/module/dmatest/parameters/threads_per_chan
root@localhost:~# echo 1 > /sys/module/dmatest/parameters/run
[  177.903819] dmatest: current_mask 1
root@localhost:~# [  177.907636] dmatest: len 11         save_mask ffff  tmp_mask 2
[  178.927396] dmatest: qdma-test-task: summary 10 tests, 0 failures 303030 iops 1212121 KB/s 1241212121 B/s (0)
[  178.937308] dmatest: total_len 40960  len 4096
[  178.941870] dmatest: runtime 33
[  178.941870]
root@localhost:~# echo 8 > /sys/module/dmatest/parameters/threads_per_chan
[  273.731698] dmatest: current_mask 1
root@localhost:~# [  273.735625] dmatest: len 11         save_mask ffff  tmp_mask 2
[  274.767409] dmatest: qdma-test-task: summary 10 tests, 0 failures 357142 iops 1428571 KB/s 1462857142 B/s (0)
[  274.777315] dmatest: total_len 40960  len 4096
[  274.781875] dmatest: runtime 28
[  274.781875]
Transfer data from Memory to PCIe
root@lx2160ardb-rev2:~# restool dpdmai create --num-queues=8 --priorities=2,5
root@lx2160ardb-rev2:~# restool dprc assign dprc.1 --object=dpdmai.0 --plugged=1
root@lx2160ardb-rev2:~# echo "dpdmai.0" > /sys/module/dmatest/parameters/device
root@lx2160ardb-rev2:~# echo '7       4       1       7' > /proc/sys/kernel/printk
root@lx2160ardb-rev2:~# echo 4096 > /sys/module/dmatest/parameters/test_buf_size
root@lx2160ardb-rev2:~#  echo 10 > /sys/module/dmatest/parameters/iterations
root@lx2160ardb-rev2:~# echo 2 > /sys/module/dmatest/parameters/dmatest_option
root@lx2160ardb-rev2:~# echo 0x9040000000 > /sys/module/dmatest/parameters/pci_phys_addr
root@lx2160ardb-rev2:~# echo 1 > /sys/module/dmatest/parameters/produ_task_number
root@lx2160ardb-rev2:~# echo 1 > /sys/module/dmatest/parameters/run
[  214.319248] dmatest: current_mask 1
root@lx2160ardb-rev2:~# [  214.322864] dmatest: len 11   save_mask ffff  tmp_mask 2
[  214.330187] dmatest: pcie_phy_base : 9040000000       pcie_virt_base : 0000000014415a49
[  215.355448] dmatest: qdma-test-task: summary 10 tests, 0 failures 26737 iops 106951 KB/s 109518716 B/s (0)
[  215.365093] dmatest: total_len 40960  len 4096
[  215.369529] dmatest: runtime 374
[  215.369529]
%3CLINGO-SUB%20id%3D%22lingo-sub-2312516%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EQDMA%20Data%20Transfer%20between%20PCIe%20Endpoint%20and%20DDR%20Memory%20on%20LX2160A%20Platform%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2312516%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%0A%3CH2%20id%3D%22toc-hId--470716456%22%20id%3D%22toc-hId--470716431%22%3EIntroduction%3C%2FH2%3E%0A%3CP%3EThe%20qDMA%20controller%20transfers%20blocks%20of%20data%20between%20one%20source%20and%20one%20destination.%20The%20blocks%20of%20data%20transferred%20can%20be%20represented%20in%20memory%20as%20contiguous%20or%20noncontiguous%20using%20scatter%2Fgather%20table(s).%20Channel%20virtualization%20is%20supported%20through%20enqueuing%20of%20DMA%20jobs%20to%2C%20or%20dequeuing%20DMA%20jobs%20from%2C%20different%20work%20queues.%20QDMA%20can%20support%20LX2160A%20with%20DPAA2.%3C%2FP%3E%0A%3CP%3EThe%20attached%20patch%20is%20used%20for%20QDMA%20data%20transfer%20between%20PCIe%20Endpoint%20and%20DDR%20memory%20on%20LX2160A%20Platform.%3C%2FP%3E%0A%3CH2%20id%3D%22toc-hId-2016796377%22%20id%3D%22toc-hId-2016796402%22%3EApply%20the%20patch%20and%20rebuild%20Kernel%20image%20in%20LSDK%2021.08%3C%2FH2%3E%0A%3CP%3EGo%20to%20LSDK%2021.08%20Linux%20Kernel%20source%20folder%26nbsp%3Bcomponents%2Flinux%2Flinux%2F%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EApply%20the%20attached%20patch.%3C%2FP%3E%0A%3CP%3E%24%20patch%20-p1%20%26lt%3B%200001-QDMA-Performance-test.patch%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%24%20flex-builder%20-c%20linux%3Acustom%20-a%20arm64%3C%2FP%3E%0A%3CP%3EEnable%20CONFIG_FSL_DPAA2_QDMA%3Dy%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%24%20Rebuild%20Linux%20Kernel.%3C%2FP%3E%0A%3CP%3E%24%20flex-builder%20-c%20linux%20-a%20arm64%3C%2FP%3E%0A%3CH2%20id%3D%22toc-hId-209341914%22%20id%3D%22toc-hId-209341939%22%3E%26nbsp%3B%3C%2FH2%3E%0A%3CH2%20id%3D%22toc-hId--1598112549%22%20id%3D%22toc-hId--1598112524%22%3ETransfer%20data%20from%20Memory%20to%20Memory%3C%2FH2%3E%0A%3CP%3Eroot%40localhost%3A~%23%20restool%20dpdmai%20create%20--num-queues%3D8%20--priorities%3D2%2C5%3C%2FP%3E%0A%3CP%3Edpdmai.0%20is%20created%20under%20dprc.1%3C%2FP%3E%0A%3CP%3Eroot%40localhost%3A~%23%20restool%20dprc%20assign%20dprc.1%20--object%3Ddpdmai.0%20--plugged%3D1%3C%2FP%3E%0A%3CP%3Eroot%40localhost%3A~%23%20echo%20%22dpdmai.0%22%20%26gt%3B%20%2Fsys%2Fmodule%2Fdmatest%2Fparameters%2Fdevice%3C%2FP%3E%0A%3CP%3Eroot%40localhost%3A~%23%20echo%20'7%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%204%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%207'%20%26gt%3B%20%2Fproc%2Fsys%2Fkernel%2Fprintk%3C%2FP%3E%0A%3CP%3Eroot%40localhost%3A~%23%20echo%201%20%26gt%3B%20%2Fsys%2Fmodule%2Fdmatest%2Fparameters%2Fdmatest_option%3C%2FP%3E%0A%3CP%3Eroot%40localhost%3A~%23%20echo%2010%20%26gt%3B%20%2Fsys%2Fmodule%2Fdmatest%2Fparameters%2Fiterations%3C%2FP%3E%0A%3CP%3Eroot%40localhost%3A~%23%20echo%204096%20%26gt%3B%20%2Fsys%2Fmodule%2Fdmatest%2Fparameters%2Ftest_buf_size%3C%2FP%3E%0A%3CP%3Eroot%40localhost%3A~%23%20echo%201%20%26gt%3B%20%2Fsys%2Fmodule%2Fdmatest%2Fparameters%2Fthreads_per_chan%3C%2FP%3E%0A%3CP%3Eroot%40localhost%3A~%23%20echo%201%20%26gt%3B%20%2Fsys%2Fmodule%2Fdmatest%2Fparameters%2Frun%3C%2FP%3E%0A%3CP%3E%5B%26nbsp%3B%20177.903819%5D%20dmatest%3A%20current_mask%201%3C%2FP%3E%0A%3CP%3Eroot%40localhost%3A~%23%20%5B%26nbsp%3B%20177.907636%5D%20dmatest%3A%20len%2011%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20save_mask%20ffff%26nbsp%3B%20tmp_mask%202%3C%2FP%3E%0A%3CP%3E%5B%26nbsp%3B%20178.927396%5D%20dmatest%3A%20qdma-test-task%3A%20summary%2010%20tests%2C%200%20failures%20303030%20iops%201212121%20KB%2Fs%201241212121%20B%2Fs%20(0)%3C%2FP%3E%0A%3CP%3E%5B%26nbsp%3B%20178.937308%5D%20dmatest%3A%20total_len%2040960%26nbsp%3B%20len%204096%3C%2FP%3E%0A%3CP%3E%5B%26nbsp%3B%20178.941870%5D%20dmatest%3A%20runtime%2033%3C%2FP%3E%0A%3CP%3E%5B%26nbsp%3B%20178.941870%5D%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3Eroot%40localhost%3A~%23%20echo%208%20%26gt%3B%20%2Fsys%2Fmodule%2Fdmatest%2Fparameters%2Fthreads_per_chan%3C%2FP%3E%0A%3CP%3Eroot%40localhost%3A~%23%20echo%201%20%26gt%3B%20%2Fsys%2Fmodule%2Fdmatest%2Fparameters%2Frun%3C%2FP%3E%0A%3CP%3E%5B%26nbsp%3B%20273.731698%5D%20dmatest%3A%20current_mask%201%3C%2FP%3E%0A%3CP%3Eroot%40localhost%3A~%23%20%5B%26nbsp%3B%20273.735625%5D%20dmatest%3A%20len%2011%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20save_mask%20ffff%26nbsp%3B%20tmp_mask%202%3C%2FP%3E%0A%3CP%3E%5B%26nbsp%3B%20274.767409%5D%20dmatest%3A%20qdma-test-task%3A%20summary%2010%20tests%2C%200%20failures%20357142%20iops%201428571%20KB%2Fs%201462857142%20B%2Fs%20(0)%3C%2FP%3E%0A%3CP%3E%5B%26nbsp%3B%20274.777315%5D%20dmatest%3A%20total_len%2040960%26nbsp%3B%20len%204096%3C%2FP%3E%0A%3CP%3E%5B%26nbsp%3B%20274.781875%5D%20dmatest%3A%20runtime%2028%3C%2FP%3E%0A%3CP%3E%5B%26nbsp%3B%20274.781875%5D%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CH2%20id%3D%22toc-hId-889400284%22%20id%3D%22toc-hId-889400309%22%3ETransfer%20data%20from%20Memory%20to%20PCIe%26nbsp%3B%3C%2FH2%3E%0A%3CP%3Eroot%40lx2160ardb-rev2%3A~%23%20restool%20dpdmai%20create%20--num-queues%3D8%20--priorities%3D2%2C5%3C%2FP%3E%0A%3CP%3Edpdmai.0%20is%20created%20under%20dprc.1%3C%2FP%3E%0A%3CP%3Eroot%40lx2160ardb-rev2%3A~%23%20restool%20dprc%20assign%20dprc.1%20--object%3Ddpdmai.0%20--plugged%3D1%3C%2FP%3E%0A%3CP%3Eroot%40lx2160ardb-rev2%3A~%23%20echo%20%22dpdmai.0%22%20%26gt%3B%20%2Fsys%2Fmodule%2Fdmatest%2Fparameters%2Fdevice%3C%2FP%3E%0A%3CP%3Eroot%40lx2160ardb-rev2%3A~%23%20echo%20'7%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%204%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%207'%20%26gt%3B%20%2Fproc%2Fsys%2Fkernel%2Fprintk%3C%2FP%3E%0A%3CP%3Eroot%40lx2160ardb-rev2%3A~%23%20echo%204096%20%26gt%3B%20%2Fsys%2Fmodule%2Fdmatest%2Fparameters%2Ftest_buf_size%3C%2FP%3E%0A%3CP%3Eroot%40lx2160ardb-rev2%3A~%23%26nbsp%3B%20echo%2010%20%26gt%3B%20%2Fsys%2Fmodule%2Fdmatest%2Fparameters%2Fiterations%3C%2FP%3E%0A%3CP%3Eroot%40lx2160ardb-rev2%3A~%23%26nbsp%3Becho%202%20%26gt%3B%20%2Fsys%2Fmodule%2Fdmatest%2Fparameters%2Fdmatest_option%3C%2FP%3E%0A%3CP%3Eroot%40lx2160ardb-rev2%3A~%23%26nbsp%3Becho%200x9040000000%20%26gt%3B%20%2Fsys%2Fmodule%2Fdmatest%2Fparameters%2Fpci_phys_addr%3C%2FP%3E%0A%3CP%3Eroot%40lx2160ardb-rev2%3A~%23%20echo%201%20%26gt%3B%20%2Fsys%2Fmodule%2Fdmatest%2Fparameters%2Fprodu_task_number%3C%2FP%3E%0A%3CP%3Eroot%40lx2160ardb-rev2%3A~%23%20echo%201%20%26gt%3B%20%2Fsys%2Fmodule%2Fdmatest%2Fparameters%2Frun%3C%2FP%3E%0A%3CP%3E%5B%26nbsp%3B%20214.319248%5D%20dmatest%3A%20current_mask%201%3C%2FP%3E%0A%3CP%3Eroot%40lx2160ardb-rev2%3A~%23%20%5B%26nbsp%3B%20214.322864%5D%20dmatest%3A%20len%2011%26nbsp%3B%26nbsp%3B%20save_mask%20ffff%26nbsp%3B%20tmp_mask%202%3C%2FP%3E%0A%3CP%3E%5B%26nbsp%3B%20214.330187%5D%20dmatest%3A%20pcie_phy_base%20%3A%209040000000%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20pcie_virt_base%20%3A%200000000014415a49%3C%2FP%3E%0A%3CP%3E%5B%26nbsp%3B%20215.355448%5D%20dmatest%3A%20qdma-test-task%3A%20summary%2010%20tests%2C%200%20failures%2026737%20iops%20106951%20KB%2Fs%20109518716%20B%2Fs%20(0)%3C%2FP%3E%0A%3CP%3E%5B%26nbsp%3B%20215.365093%5D%20dmatest%3A%20total_len%2040960%26nbsp%3B%20len%204096%3C%2FP%3E%0A%3CP%3E%5B%26nbsp%3B%20215.369529%5D%20dmatest%3A%20runtime%20374%3C%2FP%3E%0A%3CP%3E%5B%26nbsp%3B%20215.369529%5D%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3C%2FLINGO-BODY%3E
No ratings
Version history
Last update:
‎02-04-2026 08:27 PM
Updated by:
