How to extract kernel, rootfs, and dtb images from Linux ITB image
To extract kernel, rootfs, and dtb images from the Linux ITB (LITB) image:
  1. Browse to the folder containing LITB. For example:
    $ cd flexbuild_lsdk2004/build/images/
  2. To list the header information of LITB, use the following command: $ dumpimage -l <name of the image>
    $ dumpimage -l  lsdk2004_ubuntu_main_LS_arm64.itb
    FIT description: arm64 kernel, ramdisk and FDT blob
    Created:         Tue Feb  2 18:54:19 2021
     Image 0 (kernel)
      Description:  ARM64 Kernel
      Type:         Kernel Image
      Compression:  gzip compressed
      Data Size:    14086432 Bytes = 13756.28 kB = 13.43 MB
      Architecture: AArch64
      OS:           Linux
      Load Address: 0x84080000
      Entry Point:  0x84080000
      Hash algo:    crc32
      Hash value:   1980d6fd
     Image 1 (initrd)
      Description:  initrd for arm64
      Type:         RAMDisk Image
      Compression:  uncompressed
      Data Size:    668988861 Bytes = 653309.43 kB = 638.00 MB
      OS:           Linux
      Load Address: 0x00000000
      Entry Point:  0x00000000
      Hash algo:    crc32
      Hash value:   24aa3c08
     Image 2 (ls1012ardb-dtb)
      Description:  ls1012ardb-dtb
      Type:         Flat Device Tree
      Data Size:    14335 Bytes = 14.00 kB = 0.01 MB
      Hash algo:    crc32
      Hash value:   383a8118
     Image 3 (ls1012aqds-dtb)
      Description:  ls1012aqds-dtb
      Data Size:    15972 Bytes = 15.60 kB = 0.02 MB
      Hash algo:    crc32
      Hash value:   7d133305
     Image 4 (ls1012afrwy-dtb)
      Description:  ls1012afrwy-dtb
      Data Size:    15316 Bytes = 14.96 kB = 0.01 MB
      Hash algo:    crc32
      Hash value:   7c456ca3
     Image 5 (ls1028ardb-dtb)
      Description:  ls1028ardb-dtb
      Data Size:    19767 Bytes = 19.30 kB = 0.02 MB
      Hash algo:    crc32
      Hash value:   db86fa4f
     Image 6 (ls1028aqds-dtb)
      Description:  ls1028aqds-dtb
      Data Size:    24733 Bytes = 24.15 kB = 0.02 MB
      Hash algo:    crc32
      Hash value:   e0b7a722
     Image 7 (ls1043ardb-dtb)
      Description:  ls1043ardb-dtb
      Data Size:    41085 Bytes = 40.12 kB = 0.04 MB
      Hash algo:    crc32
      Hash value:   fcc6502c
     Image 8 (ls1043aqds-dtb)
      Description:  ls1043aqds-dtb
      Data Size:    34544 Bytes = 33.73 kB = 0.03 MB
      Hash algo:    crc32
      Hash value:   45f82fba
     Image 9 (ls1046ardb-dtb)
      Description:  ls1046ardb-dtb
      Data Size:    40270 Bytes = 39.33 kB = 0.04 MB
      Hash algo:    crc32
      Hash value:   013f5024
     Image 10 (ls1046aqds-dtb)
      Description:  ls1046aqds-dtb
      Data Size:    34317 Bytes = 33.51 kB = 0.03 MB
      Hash algo:    crc32
      Hash value:   be066013
     Image 11 (ls1046afrwy-dtb)
      Description:  ls1046afrwy-dtb
      Data Size:    31528 Bytes = 30.79 kB = 0.03 MB
      Hash algo:    crc32
      Hash value:   d872df6c
     Image 12 (ls1088ardb-dtb)
      Description:  ls1088ardb-dtb
      Data Size:    19523 Bytes = 19.07 kB = 0.02 MB
      Hash algo:    crc32
      Hash value:   403066bc
     Image 13 (ls1088aqds-dtb)
      Description:  ls1088aqds-dtb
      Data Size:    19415 Bytes = 18.96 kB = 0.02 MB
      Hash algo:    crc32
      Hash value:   a2bf2786
     Image 14 (ls2088ardb-dtb)
      Description:  ls2088ardb-dtb
      Data Size:    29838 Bytes = 29.14 kB = 0.03 MB
      Hash algo:    crc32
      Hash value:   0069fe03
     Image 15 (ls2088aqds-dtb)
      Description:  ls2088aqds-dtb
      Data Size:    23557 Bytes = 23.00 kB = 0.02 MB
      Hash algo:    crc32
      Hash value:   e8e9dfa7
     Image 16 (lx2160ardb-dtb)
      Description:  lx2160ardb-dtb
      Data Size:    32643 Bytes = 31.88 kB = 0.03 MB
      Hash algo:    crc32
      Hash value:   e5859b31
     Image 17 (lx2160aqds-dtb)
      Description:  lx2160aqds-dtb
      Data Size:    27740 Bytes = 27.09 kB = 0.03 MB
      Hash algo:    crc32
      Hash value:   f644de1e
  3. To extract a particular image from LITB, use the following command:  $ dumpimage -i <name of the image> -T <type> [-p position] [-o outfile] data_file
    For example:
    1. To extract the kernel image:
      $ dumpimage -T flat_dt -i        lsdk2004_ubuntu_main_LS_arm64.itb -p 0 kernel
      Extracted:
       Image 0 (kernel)
        Type:         Kernel Image
        OS:           Linux
        Hash algo:    crc32
    2. To extract the rootfs image:
      $ dumpimage -T flat_dt -i        lsdk2004_ubuntu_main_LS_arm64.itb -p 1 rootfs
      Extracted:
       Image 1 (initrd)
        Type:         RAMDisk Image
        OS:           Linux
        Hash algo:    crc32
    3. To extract ls1012ardb-dtb (at position 2) and ls1012aqds-dtb (at position 3):
      $ dumpimage -T flat_dt -i        lsdk2004_ubuntu_main_LS_arm64.itb -p 2 dtb1
      Extracted:
        Hash algo:    crc32
      $ dumpimage -T flat_dt -i lsdk2004_ubuntu_main_LS_arm64.itb -p 3 dtb2
      Extracted:
        Hash algo:    crc32
%3CLINGO-SUB%20id%3D%22lingo-sub-1225165%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%A6%82%E4%BD%95%E4%BB%8E%20Linux%20ITB%20%E9%95%9C%E5%83%8F%E4%B8%AD%E6%8F%90%E5%8F%96%20kernel%E3%80%81rootfs%20%E5%92%8C%20dtb%20%E9%95%9C%E5%83%8F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1225165%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%0A%3CP%3E%E4%BB%8E%20Linux%20ITB%EF%BC%88LITB%EF%BC%89%E9%95%9C%E5%83%8F%E4%B8%AD%E6%8F%90%E5%8F%96%E5%86%85%E6%A0%B8%E3%80%81%E6%A0%B9%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%EF%BC%88rootfs%EF%BC%89%E5%92%8C%E8%AE%BE%E5%A4%87%E6%A0%91%EF%BC%88dtb%EF%BC%89%E9%95%9C%E5%83%8F%EF%BC%9A%3C%2FP%3E%0A%3COL%3E%0A%3CLI%3E%E6%B5%8F%E8%A7%88%E8%87%B3%E5%8C%85%E5%90%AB%20LITB%20%E7%9A%84%E6%96%87%E4%BB%B6%E5%A4%B9%E3%80%82%E4%BE%8B%E5%A6%82%EF%BC%9A%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3E%24%20cd%20flexbuild_lsdk2004%2Fbuild%2Fimages%2F%0A%3C%2FCODE%3E%3C%2FPRE%3E%3C%2FLI%3E%0A%3CLI%3E%E8%A6%81%E5%88%97%E5%87%BA%20LITB%20%E7%9A%84%E5%A4%B4%E9%83%A8%E4%BF%A1%E6%81%AF%EF%BC%8C%E8%AF%B7%E4%BD%BF%E7%94%A8%E4%BB%A5%E4%B8%8B%E5%91%BD%E4%BB%A4%EF%BC%9A%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%24%20dumpimage%20-l%20%3CNAME%20of%3D%22%22%20the%3D%22%22%20image%3D%22%22%3E%3C%2FNAME%3E%3C%2FFONT%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3E%24%20dumpimage%20-l%20%20lsdk2004_ubuntu_main_LS_arm64.itb%0AFIT%20description%3A%20arm64%20kernel%2C%20ramdisk%20and%20FDT%20blob%0ACreated%3A%20%20%20%20%20%20%20%20%20Tue%20Feb%20%202%2018%3A54%3A19%202021%0A%20Image%200%20(kernel)%0A%20%20Description%3A%20%20ARM64%20Kernel%0A%20%20Created%3A%20%20%20%20%20%20Tue%20Feb%20%202%2018%3A54%3A19%202021%0A%20%20Type%3A%20%20%20%20%20%20%20%20%20Kernel%20Image%0A%20%20Compression%3A%20%20gzip%20compressed%0A%20%20Data%20Size%3A%20%20%20%2014086432%20Bytes%20%3D%2013756.28%20kB%20%3D%2013.43%20MB%0A%20%20Architecture%3A%20AArch64%0A%20%20OS%3A%20%20%20%20%20%20%20%20%20%20%20Linux%0A%20%20Load%20Address%3A%200x84080000%0A%20%20Entry%20Point%3A%20%200x84080000%0A%20%20Hash%20algo%3A%20%20%20%20crc32%0A%20%20Hash%20value%3A%20%20%201980d6fd%0A%20Image%201%20(initrd)%0A%20%20Description%3A%20%20initrd%20for%20arm64%0A%20%20Created%3A%20%20%20%20%20%20Tue%20Feb%20%202%2018%3A54%3A19%202021%0A%20%20Type%3A%20%20%20%20%20%20%20%20%20RAMDisk%20Image%0A%20%20Compression%3A%20%20uncompressed%0A%20%20Data%20Size%3A%20%20%20%20668988861%20Bytes%20%3D%20653309.43%20kB%20%3D%20638.00%20MB%0A%20%20Architecture%3A%20AArch64%0A%20%20OS%3A%20%20%20%20%20%20%20%20%20%20%20Linux%0A%20%20Load%20Address%3A%200x00000000%0A%20%20Entry%20Point%3A%20%200x00000000%0A%20%20Hash%20algo%3A%20%20%20%20crc32%0A%20%20Hash%20value%3A%20%20%2024aa3c08%0A%20Image%202%20(ls1012ardb-dtb)%0A%20%20Description%3A%20%20ls1012ardb-dtb%0A%20%20Created%3A%20%20%20%20%20%20Tue%20Feb%20%202%2018%3A54%3A19%202021%0A%20%20Type%3A%20%20%20%20%20%20%20%20%20Flat%20Device%20Tree%0A%20%20Compression%3A%20%20uncompressed%0A%20%20Data%20Size%3A%20%20%20%2014335%20Bytes%20%3D%2014.00%20kB%20%3D%200.01%20MB%0A%20%20Architecture%3A%20AArch64%0A%20%20Hash%20algo%3A%20%20%20%20crc32%0A%20%20Hash%20value%3A%20%20%20383a8118%0A%20Image%203%20(ls1012aqds-dtb)%0A%20%20Description%3A%20%20ls1012aqds-dtb%0A%20%20Created%3A%20%20%20%20%20%20Tue%20Feb%20%202%2018%3A54%3A19%202021%0A%20%20Type%3A%20%20%20%20%20%20%20%20%20Flat%20Device%20Tree%0A%20%20Compression%3A%20%20uncompressed%0A%20%20Data%20Size%3A%20%20%20%2015972%20Bytes%20%3D%2015.60%20kB%20%3D%200.02%20MB%0A%20%20Architecture%3A%20AArch64%0A%20%20Hash%20algo%3A%20%20%20%20crc32%0A%20%20Hash%20value%3A%20%20%207d133305%0A%20Image%204%20(ls1012afrwy-dtb)%0A%20%20Description%3A%20%20ls1012afrwy-dtb%0A%20%20Created%3A%20%20%20%20%20%20Tue%20Feb%20%202%2018%3A54%3A19%202021%0A%20%20Type%3A%20%20%20%20%20%20%20%20%20Flat%20Device%20Tree%0A%20%20Compression%3A%20%20uncompressed%0A%20%20Data%20Size%3A%20%20%20%2015316%20Bytes%20%3D%2014.96%20kB%20%3D%200.01%20MB%0A%20%20Architecture%3A%20AArch64%0A%20%20Hash%20algo%3A%20%20%20%20crc32%0A%20%20Hash%20value%3A%20%20%207c456ca3%0A%20Image%205%20(ls1028ardb-dtb)%0A%20%20Description%3A%20%20ls1028ardb-dtb%0A%20%20Created%3A%20%20%20%20%20%20Tue%20Feb%20%202%2018%3A54%3A19%202021%0A%20%20Type%3A%20%20%20%20%20%20%20%20%20Flat%20Device%20Tree%0A%20%20Compression%3A%20%20uncompressed%0A%20%20Data%20Size%3A%20%20%20%2019767%20Bytes%20%3D%2019.30%20kB%20%3D%200.02%20MB%0A%20%20Architecture%3A%20AArch64%0A%20%20Hash%20algo%3A%20%20%20%20crc32%0A%20%20Hash%20value%3A%20%20%20db86fa4f%0A%20Image%206%20(ls1028aqds-dtb)%0A%20%20Description%3A%20%20ls1028aqds-dtb%0A%20%20Created%3A%20%20%20%20%20%20Tue%20Feb%20%202%2018%3A54%3A19%202021%0A%20%20Type%3A%20%20%20%20%20%20%20%20%20Flat%20Device%20Tree%0A%20%20Compression%3A%20%20uncompressed%0A%20%20Data%20Size%3A%20%20%20%2024733%20Bytes%20%3D%2024.15%20kB%20%3D%200.02%20MB%0A%20%20Architecture%3A%20AArch64%0A%20%20Hash%20algo%3A%20%20%20%20crc32%0A%20%20Hash%20value%3A%20%20%20e0b7a722%0A%20Image%207%20(ls1043ardb-dtb)%0A%20%20Description%3A%20%20ls1043ardb-dtb%0A%20%20Created%3A%20%20%20%20%20%20Tue%20Feb%20%202%2018%3A54%3A19%202021%0A%20%20Type%3A%20%20%20%20%20%20%20%20%20Flat%20Device%20Tree%0A%20%20Compression%3A%20%20uncompressed%0A%20%20Data%20Size%3A%20%20%20%2041085%20Bytes%20%3D%2040.12%20kB%20%3D%200.04%20MB%0A%20%20Architecture%3A%20AArch64%0A%20%20Hash%20algo%3A%20%20%20%20crc32%0A%20%20Hash%20value%3A%20%20%20fcc6502c%0A%20Image%208%20(ls1043aqds-dtb)%0A%20%20Description%3A%20%20ls1043aqds-dtb%0A%20%20Created%3A%20%20%20%20%20%20Tue%20Feb%20%202%2018%3A54%3A19%202021%0A%20%20Type%3A%20%20%20%20%20%20%20%20%20Flat%20Device%20Tree%0A%20%20Compression%3A%20%20uncompressed%0A%20%20Data%20Size%3A%20%20%20%2034544%20Bytes%20%3D%2033.73%20kB%20%3D%200.03%20MB%0A%20%20Architecture%3A%20AArch64%0A%20%20Hash%20algo%3A%20%20%20%20crc32%0A%20%20Hash%20value%3A%20%20%2045f82fba%0A%20Image%209%20(ls1046ardb-dtb)%0A%20%20Description%3A%20%20ls1046ardb-dtb%0A%20%20Created%3A%20%20%20%20%20%20Tue%20Feb%20%202%2018%3A54%3A19%202021%0A%20%20Type%3A%20%20%20%20%20%20%20%20%20Flat%20Device%20Tree%0A%20%20Compression%3A%20%20uncompressed%0A%20%20Data%20Size%3A%20%20%20%2040270%20Bytes%20%3D%2039.33%20kB%20%3D%200.04%20MB%0A%20%20Architecture%3A%20AArch64%0A%20%20Hash%20algo%3A%20%20%20%20crc32%0A%20%20Hash%20value%3A%20%20%20013f5024%0A%20Image%2010%20(ls1046aqds-dtb)%0A%20%20Description%3A%20%20ls1046aqds-dtb%0A%20%20Created%3A%20%20%20%20%20%20Tue%20Feb%20%202%2018%3A54%3A19%202021%0A%20%20Type%3A%20%20%20%20%20%20%20%20%20Flat%20Device%20Tree%0A%20%20Compression%3A%20%20uncompressed%0A%20%20Data%20Size%3A%20%20%20%2034317%20Bytes%20%3D%2033.51%20kB%20%3D%200.03%20MB%0A%20%20Architecture%3A%20AArch64%0A%20%20Hash%20algo%3A%20%20%20%20crc32%0A%20%20Hash%20value%3A%20%20%20be066013%0A%20Image%2011%20(ls1046afrwy-dtb)%0A%20%20Description%3A%20%20ls1046afrwy-dtb%0A%20%20Created%3A%20%20%20%20%20%20Tue%20Feb%20%202%2018%3A54%3A19%202021%0A%20%20Type%3A%20%20%20%20%20%20%20%20%20Flat%20Device%20Tree%0A%20%20Compression%3A%20%20uncompressed%0A%20%20Data%20Size%3A%20%20%20%2031528%20Bytes%20%3D%2030.79%20kB%20%3D%200.03%20MB%0A%20%20Architecture%3A%20AArch64%0A%20%20Hash%20algo%3A%20%20%20%20crc32%0A%20%20Hash%20value%3A%20%20%20d872df6c%0A%20Image%2012%20(ls1088ardb-dtb)%0A%20%20Description%3A%20%20ls1088ardb-dtb%0A%20%20Created%3A%20%20%20%20%20%20Tue%20Feb%20%202%2018%3A54%3A19%202021%0A%20%20Type%3A%20%20%20%20%20%20%20%20%20Flat%20Device%20Tree%0A%20%20Compression%3A%20%20uncompressed%0A%20%20Data%20Size%3A%20%20%20%2019523%20Bytes%20%3D%2019.07%20kB%20%3D%200.02%20MB%0A%20%20Architecture%3A%20AArch64%0A%20%20Hash%20algo%3A%20%20%20%20crc32%0A%20%20Hash%20value%3A%20%20%20403066bc%0A%20Image%2013%20(ls1088aqds-dtb)%0A%20%20Description%3A%20%20ls1088aqds-dtb%0A%20%20Created%3A%20%20%20%20%20%20Tue%20Feb%20%202%2018%3A54%3A19%202021%0A%20%20Type%3A%20%20%20%20%20%20%20%20%20Flat%20Device%20Tree%0A%20%20Compression%3A%20%20uncompressed%0A%20%20Data%20Size%3A%20%20%20%2019415%20Bytes%20%3D%2018.96%20kB%20%3D%200.02%20MB%0A%20%20Architecture%3A%20AArch64%0A%20%20Hash%20algo%3A%20%20%20%20crc32%0A%20%20Hash%20value%3A%20%20%20a2bf2786%0A%20Image%2014%20(ls2088ardb-dtb)%0A%20%20Description%3A%20%20ls2088ardb-dtb%0A%20%20Created%3A%20%20%20%20%20%20Tue%20Feb%20%202%2018%3A54%3A19%202021%0A%20%20Type%3A%20%20%20%20%20%20%20%20%20Flat%20Device%20Tree%0A%20%20Compression%3A%20%20uncompressed%0A%20%20Data%20Size%3A%20%20%20%2029838%20Bytes%20%3D%2029.14%20kB%20%3D%200.03%20MB%0A%20%20Architecture%3A%20AArch64%0A%20%20Hash%20algo%3A%20%20%20%20crc32%0A%20%20Hash%20value%3A%20%20%200069fe03%0A%20Image%2015%20(ls2088aqds-dtb)%0A%20%20Description%3A%20%20ls2088aqds-dtb%0A%20%20Created%3A%20%20%20%20%20%20Tue%20Feb%20%202%2018%3A54%3A19%202021%0A%20%20Type%3A%20%20%20%20%20%20%20%20%20Flat%20Device%20Tree%0A%20%20Compression%3A%20%20uncompressed%0A%20%20Data%20Size%3A%20%20%20%2023557%20Bytes%20%3D%2023.00%20kB%20%3D%200.02%20MB%0A%20%20Architecture%3A%20AArch64%0A%20%20Hash%20algo%3A%20%20%20%20crc32%0A%20%20Hash%20value%3A%20%20%20e8e9dfa7%0A%20Image%2016%20(lx2160ardb-dtb)%0A%20%20Description%3A%20%20lx2160ardb-dtb%0A%20%20Created%3A%20%20%20%20%20%20Tue%20Feb%20%202%2018%3A54%3A19%202021%0A%20%20Type%3A%20%20%20%20%20%20%20%20%20Flat%20Device%20Tree%0A%20%20Compression%3A%20%20uncompressed%0A%20%20Data%20Size%3A%20%20%20%2032643%20Bytes%20%3D%2031.88%20kB%20%3D%200.03%20MB%0A%20%20Architecture%3A%20AArch64%0A%20%20Hash%20algo%3A%20%20%20%20crc32%0A%20%20Hash%20value%3A%20%20%20e5859b31%0A%20Image%2017%20(lx2160aqds-dtb)%0A%20%20Description%3A%20%20lx2160aqds-dtb%0A%20%20Created%3A%20%20%20%20%20%20Tue%20Feb%20%202%2018%3A54%3A19%202021%0A%20%20Type%3A%20%20%20%20%20%20%20%20%20Flat%20Device%20Tree%0A%20%20Compression%3A%20%20uncompressed%0A%20%20Data%20Size%3A%20%20%20%2027740%20Bytes%20%3D%2027.09%20kB%20%3D%200.03%20MB%0A%20%20Architecture%3A%20AArch64%0A%20%20Hash%20algo%3A%20%20%20%20crc32%0A%20%20Hash%20value%3A%20%20%20f644de1e%0A%3C%2FCODE%3E%3C%2FPRE%3E%3C%2FLI%3E%0A%3CLI%3E%E8%A6%81%E4%BB%8E%20LITB%20%E4%B8%AD%E6%8F%90%E5%8F%96%E7%89%B9%E5%AE%9A%E9%95%9C%E5%83%8F%EF%BC%8C%E8%AF%B7%E4%BD%BF%E7%94%A8%E4%BB%A5%E4%B8%8B%E5%91%BD%E4%BB%A4%EF%BC%9A%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%24%20dumpimage%20-i%20%3CNAME%20of%3D%22%22%20the%3D%22%22%20image%3D%22%22%3E%20-T%20%3CTYPE%3E%20%5B-p%20position%5D%20%5B-o%20outfile%5D%20data_file%3C%2FTYPE%3E%3C%2FNAME%3E%3C%2FFONT%3E%0A%3CP%3E%E4%BE%8B%E5%A6%82%EF%BC%9A%3C%2FP%3E%0A%3COL%3E%0A%3CLI%3E%E8%A6%81%E6%8F%90%E5%8F%96%E5%86%85%E6%A0%B8%E9%95%9C%E5%83%8F%EF%BC%9A%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3E%24%20dumpimage%20-T%20flat_dt%20-i%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20lsdk2004_ubuntu_main_LS_arm64.itb%20-p%200%20kernel%0AExtracted%3A%0A%20Image%200%20(kernel)%0A%20%20Description%3A%20%20ARM64%20Kernel%0A%20%20Created%3A%20%20%20%20%20%20Tue%20Feb%20%202%2018%3A54%3A19%202021%0A%20%20Type%3A%20%20%20%20%20%20%20%20%20Kernel%20Image%0A%20%20Compression%3A%20%20gzip%20compressed%0A%20%20Data%20Size%3A%20%20%20%2014086432%20Bytes%20%3D%2013756.28%20kB%20%3D%2013.43%20MB%0A%20%20Architecture%3A%20AArch64%0A%20%20OS%3A%20%20%20%20%20%20%20%20%20%20%20Linux%0A%20%20Load%20Address%3A%200x84080000%0A%20%20Entry%20Point%3A%20%200x84080000%0A%20%20Hash%20algo%3A%20%20%20%20crc32%0A%20%20Hash%20value%3A%20%20%201980d6fd%0A%3C%2FCODE%3E%3C%2FPRE%3E%3C%2FLI%3E%0A%3CLI%3E%E8%A6%81%E6%8F%90%E5%8F%96%20rootfs%20%E9%95%9C%E5%83%8F%EF%BC%9A%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3E%24%20dumpimage%20-T%20flat_dt%20-i%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20lsdk2004_ubuntu_main_LS_arm64.itb%20-p%201%20rootfs%0AExtracted%3A%0A%20Image%201%20(initrd)%0A%20%20Description%3A%20%20initrd%20for%20arm64%0A%20%20Created%3A%20%20%20%20%20%20Tue%20Feb%20%202%2018%3A54%3A19%202021%0A%20%20Type%3A%20%20%20%20%20%20%20%20%20RAMDisk%20Image%0A%20%20Compression%3A%20%20uncompressed%0A%20%20Data%20Size%3A%20%20%20%20668988861%20Bytes%20%3D%20653309.43%20kB%20%3D%20638.00%20MB%0A%20%20Architecture%3A%20AArch64%0A%20%20OS%3A%20%20%20%20%20%20%20%20%20%20%20Linux%0A%20%20Load%20Address%3A%200x00000000%0A%20%20Entry%20Point%3A%20%200x00000000%0A%20%20Hash%20algo%3A%20%20%20%20crc32%0A%20%20Hash%20value%3A%20%20%2024aa3c08%0A%3C%2FCODE%3E%3C%2FPRE%3E%3C%2FLI%3E%0A%3CLI%3E%E6%8F%90%E5%8F%96%20ls1012ardb-dtb%EF%BC%88%E4%BD%8D%E4%BA%8E%E7%AC%AC%202%20%E4%BD%8D%EF%BC%89%E5%92%8C%20ls1012aqds-dtb%EF%BC%88%E4%BD%8D%E4%BA%8E%E7%AC%AC%203%20%E4%BD%8D%EF%BC%89%EF%BC%9A%3CBR%20%2F%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3E%24%20dumpimage%20-T%20flat_dt%20-i%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20lsdk2004_ubuntu_main_LS_arm64.itb%20-p%202%20dtb1%0AExtracted%3A%0A%20Image%202%20(ls1012ardb-dtb)%0A%20%20Description%3A%20%20ls1012ardb-dtb%0A%20%20Created%3A%20%20%20%20%20%20Tue%20Feb%20%202%2018%3A54%3A19%202021%0A%20%20Type%3A%20%20%20%20%20%20%20%20%20Flat%20Device%20Tree%0A%20%20Compression%3A%20%20uncompressed%0A%20%20Data%20Size%3A%20%20%20%2014335%20Bytes%20%3D%2014.00%20kB%20%3D%200.01%20MB%0A%20%20Architecture%3A%20AArch64%0A%20%20Hash%20algo%3A%20%20%20%20crc32%0A%20%20Hash%20value%3A%20%20%20383a8118%0A%24%20dumpimage%20-T%20flat_dt%20-i%20lsdk2004_ubuntu_main_LS_arm64.itb%20-p%203%20dtb2%0AExtracted%3A%0A%20Image%203%20(ls1012aqds-dtb)%0A%20%20Description%3A%20%20ls1012aqds-dtb%0A%20%20Created%3A%20%20%20%20%20%20Tue%20Feb%20%202%2018%3A54%3A19%202021%0A%20%20Type%3A%20%20%20%20%20%20%20%20%20Flat%20Device%20Tree%0A%20%20Compression%3A%20%20uncompressed%0A%20%20Data%20Size%3A%20%20%20%2015972%20Bytes%20%3D%2015.60%20kB%20%3D%200.02%20MB%0A%20%20Architecture%3A%20AArch64%0A%20%20Hash%20algo%3A%20%20%20%20crc32%0A%20%20Hash%20value%3A%20%20%207d133305%0A%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CBR%20%2F%3E%0A%3C%2FLI%3E%0A%3C%2FOL%3E%0A%3C%2FLI%3E%0A%3C%2FOL%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%0A%3C%2FLINGO-BODY%3E
100% 有帮助 (1/1)
版本历史
最后更新:
‎02-17-2021 03:04 AM
更新人:
