How to dynamically adjust MC log level using restool
Prerequisites: The board should be running Linux and connected to terminal console.
Note: For log level debug support, the restool version should be LSDK-2003-RC1 or above and MC version should be 10.20.0 or above.
To check restool version:
$ root@localhost:~# restool -v
restool LSDK-20.04
To check MC version:
root@localhost:~# restool -m
MC firmware version: 10.24.0
For debugging, use the ls-debug script available in the LSDK rootfs. There is no need to create the debug object.
ls-debug -h
ls-debug options
-h, --help ls-debug help information
-ts, --timestamp=X Enable/Disable timestamp printing, X is ON or OFF
-c, --console=X Enable/Disable printing in UART console, X is ON or OFF
-l, --log=X Enable/Disable printing in DDR log, X is ON or OF
-u, --uart=X Set UART ID of the console, X = [0 - 4], 0 = OFF
-ll, --level=X
Set logging level, X = [0 - 5]
  • 0: Global
  • 1: Debug
  • 2: Info
  • 3: Warning
  • 4: Error
  • 5: Critical
-m, mem, --memory
Dump information about memory modules available
dpxy.z
Dump information about MC respective object
For example, to enable logging in console with log level INFO:
$ ls-debug --log=on --console=on --level=2
dpdbg.0 created
DDR log printing ON
UART console printing ON
Log level set to 2
$ root@localhost:~# ls-debug --memory
Memory dumped information available in MC log/console
$ root@localhost:~# cat `find /dev/ -name "*mc_console"`
[I, RESMAN]  Handling command: dprc_get_obj for DPRC 1 on portal id 0
[I, RESMAN]  Handling command: dpdbg_open on DPDBG
[I, RESMAN]  Handling command: dpdbg_dump on DPDBG
[I, DPNI]  Memory info:
[I, DPNI]  MC DDR #1 cacheable memory
[I, DPNI]        Total: 134217728 bytes
[I, DPNI]        Used: 14802708 bytes
[I, DPNI]        Free: 119415020 bytes
[I, DPNI]  MC DDR #1 non-cacheable memory
[I, DPNI]        Total: 50331648 bytes
[I, DPNI]        Used: 27680 bytes
[I, DPNI]        Free: 50303968 bytes
[I, DPNI]  DMEM1 memory
[I, DPNI]        Total: 81920 bytes
[I, DPNI]        Used: 27168 bytes
[I, DPNI]        Free: 54752 bytes
[I, DPNI]  DMEM2 memory
[I, DPNI]  DDR #1 memory
[I, DPNI]        Total: 1610612736 bytes
[I, DPNI]        Used: 143163392 bytes
[I, DPNI]        Free: 1467449344 bytes
[I, DPNI]  PEB memory
[I, DPNI]        Total: 2097152 bytes
[I, DPNI]        Used: 524288 bytes
[I, DPNI]        Free: 1572864 bytes
[I, DPNI]  DP-DDR memory
[I, DPNI]        Total: 4294967296 bytes
[I, DPNI]        Used: 0 bytes
[I, DPNI]        Free: 4294967296 bytes
[I, RESMAN]  Handling command: dpdbg_close on DPDBG
[I, RESMAN]  Handling command: dprc_close for DPRC 1 on portal id 0
[I, RESMAN]  Handling command: dprc_set_irq_mask for DPRC 1 on portal id 0
[I, RESMAN]  Handling command: dprc_set_irq_enable for DPRC 1 on portal id 0
root@localhost:~#
%3CLINGO-SUB%20id%3D%22lingo-sub-1178784%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%A6%82%E4%BD%95%E4%BD%BF%E7%94%A8%20restool%20%E5%8A%A8%E6%80%81%E8%B0%83%E6%95%B4%20MC%20%E6%97%A5%E5%BF%97%E7%BA%A7%E5%88%AB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1178784%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%0A%3CP%3E%3CSTRONG%3E%E5%85%88%E5%86%B3%E6%9D%A1%E4%BB%B6%EF%BC%9A%3C%2FSTRONG%3E%E4%B8%BB%E6%9D%BF%E5%BA%94%E8%BF%90%E8%A1%8C%20Linux%20%E5%B9%B6%E8%BF%9E%E6%8E%A5%E5%88%B0%E7%BB%88%E7%AB%AF%E6%8E%A7%E5%88%B6%E5%8F%B0%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3E%E6%B3%A8%E6%84%8F%EF%BC%9A%3C%2FSTRONG%3E%E8%A6%81%E6%94%AF%E6%8C%81%E6%97%A5%E5%BF%97%E7%BA%A7%E5%88%AB%E8%B0%83%E8%AF%95%EF%BC%8Crestool%20%E7%89%88%E6%9C%AC%E5%BA%94%E4%B8%BA%20LSDK-2003-RC1%20%E6%88%96%E6%9B%B4%E9%AB%98%E7%89%88%E6%9C%AC%EF%BC%8CMC%20%E7%89%88%E6%9C%AC%E5%BA%94%E4%B8%BA%2010.20.0%20%E6%88%96%E6%9B%B4%E9%AB%98%E7%89%88%E6%9C%AC%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%A3%80%E6%9F%A5%20restool%20%E7%89%88%E6%9C%AC%EF%BC%9A%3C%2FP%3E%0A%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3E%24%20root%40localhost%3A~%23%20restool%20-v%0Arestool%20LSDK-20.04%0A%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CP%3E%E6%A3%80%E6%9F%A5%20MC%20%E7%89%88%E6%9C%AC%EF%BC%9A%3C%2FP%3E%0A%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3Eroot%40localhost%3A~%23%20restool%20-m%0AMC%20firmware%20version%3A%2010.24.0%0A%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CP%3E%E4%B8%BA%E4%BA%86%E8%BF%9B%E8%A1%8C%E8%B0%83%E8%AF%95%EF%BC%8C%E8%AF%B7%E4%BD%BF%E7%94%A8%20LSDK%20rootfs%20%E4%B8%AD%E6%8F%90%E4%BE%9B%E7%9A%84%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3Els-debug%3C%2FFONT%3E%E8%84%9A%E6%9C%AC%E3%80%82%E6%97%A0%E9%9C%80%E5%88%9B%E5%BB%BA%E8%B0%83%E8%AF%95%E5%AF%B9%E8%B1%A1%E3%80%82%3C%2FP%3E%0A%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3Els-debug%20-h%20%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CTABLE%20class%3D%22lia-align-left%22%20style%3D%22height%3A%20380px%3B%20width%3A%20100%25%3B%22%20border%3D%221%22%20width%3D%22100%25%22%20style%3D%22text-align%20%3A%20left%3B%22%20style%3D%22text-align%20%3A%20left%3B%22%3E%3CCAPTION%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3Els-debug%3C%2FFONT%3E%E9%80%89%E9%A1%B9%3C%2FCAPTION%3E%0A%3CTBODY%3E%0A%3CTR%3E%0A%3CTD%20width%3D%2225%25%22%20height%3D%2224px%22%3E-h%2C%20--help%3C%2FTD%3E%0A%3CTD%20width%3D%2275%25%22%20height%3D%2224px%22%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3Els-debug%3C%2FFONT%3E%E5%B8%AE%E5%8A%A9%E4%BF%A1%E6%81%AF%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%2225%25%22%20height%3D%2224px%22%3E-ts%EF%BC%8C--%E6%97%B6%E9%97%B4%E6%88%B3%3DX%3C%2FTD%3E%0A%3CTD%20width%3D%2275%25%22%20height%3D%2224px%22%3E%E5%90%AF%E7%94%A8%2F%E7%A6%81%E7%94%A8%E6%97%B6%E9%97%B4%E6%88%B3%E6%89%93%E5%8D%B0%EF%BC%8CX%20%E8%A1%A8%E7%A4%BA%E5%BC%80%E5%90%AF%E6%88%96%E5%85%B3%E9%97%AD%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%2225%25%22%20height%3D%2224px%22%3E-c%2C%20--console%3DX%3C%2FTD%3E%0A%3CTD%20width%3D%2275%25%22%20height%3D%2224px%22%3E%E5%90%AF%E7%94%A8%2F%E7%A6%81%E7%94%A8%20UART%20%E6%8E%A7%E5%88%B6%E5%8F%B0%E4%B8%AD%E7%9A%84%E6%89%93%E5%8D%B0%EF%BC%8CX%20%E8%A1%A8%E7%A4%BA%E5%BC%80%E5%90%AF%E6%88%96%E5%85%B3%E9%97%AD%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%2225%25%22%20height%3D%2224px%22%3E-l%EF%BC%8C--log%3DX%3C%2FTD%3E%0A%3CTD%20width%3D%2275%25%22%20height%3D%2224px%22%3E%E5%90%AF%E7%94%A8%2F%E7%A6%81%E7%94%A8%20DDR%20%E6%97%A5%E5%BF%97%E6%89%93%E5%8D%B0%EF%BC%8CX%20%E4%B8%BA%20ON%20%E6%88%96%20OF%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%2225%25%22%20height%3D%2224px%22%3E-u%EF%BC%8C--uart%3DX%3C%2FTD%3E%0A%3CTD%20width%3D%2275%25%22%20height%3D%2224px%22%3E%E8%AE%BE%E7%BD%AE%E6%8E%A7%E5%88%B6%E5%8F%B0%E7%9A%84%20UART%20ID%EF%BC%8CX%20%3D%20%5B0%20-%204%5D%EF%BC%8C0%20%3D%20%E5%85%B3%E9%97%AD%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%2225%25%22%20height%3D%22182px%22%3E-ll%2C%20--level%3DX%3C%2FTD%3E%0A%3CTD%20width%3D%2275%25%22%20height%3D%22182px%22%3E%0A%3CP%3E%E8%AE%BE%E7%BD%AE%E6%97%A5%E5%BF%97%E8%AE%B0%E5%BD%95%E7%BA%A7%E5%88%AB%EF%BC%8CX%20%3D%20%5B0%20-%205%5D%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3E0%EF%BC%9A%E5%85%A8%E5%B1%80%3C%2FLI%3E%0A%3CLI%3E1%3A%20Debug%3C%2FLI%3E%0A%3CLI%3E2%EF%BC%9A%E4%BF%A1%E6%81%AF%3C%2FLI%3E%0A%3CLI%3E3%EF%BC%9A%E8%AD%A6%E5%91%8A%3C%2FLI%3E%0A%3CLI%3E4%EF%BC%9A%E9%94%99%E8%AF%AF%3C%2FLI%3E%0A%3CLI%3E5%EF%BC%9A%E4%B8%A5%E9%87%8D%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20height%3D%2239px%22%3E-m%2C%20mem%2C%20--memory%3C%2FTD%3E%0A%3CTD%20height%3D%2239px%22%3E%0A%3CP%3E%E6%9C%89%E5%85%B3%E5%8F%AF%E7%94%A8%E5%86%85%E5%AD%98%E6%A8%A1%E5%9D%97%E7%9A%84%E8%BD%AC%E5%82%A8%E4%BF%A1%E6%81%AF%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20height%3D%2239px%22%3Edpxy.z%3C%2FTD%3E%0A%3CTD%20height%3D%2239px%22%3E%0A%3CP%3E%E8%BD%AC%E5%82%A8%E6%9C%89%E5%85%B3%20MC%20%E7%9B%B8%E5%BA%94%E5%AF%B9%E8%B1%A1%E7%9A%84%E4%BF%A1%E6%81%AF%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3C%2FTBODY%3E%0A%3C%2FTABLE%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E4%BE%8B%E5%A6%82%EF%BC%8C%E8%A6%81%E5%90%AF%E7%94%A8%E6%97%A5%E5%BF%97%E7%BA%A7%E5%88%AB%E4%B8%BA%20INFO%20%E7%9A%84%E6%8E%A7%E5%88%B6%E5%8F%B0%E6%97%A5%E5%BF%97%EF%BC%9A%3C%2FP%3E%0A%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3E%24%20ls-debug%20--log%3Don%20--console%3Don%20--level%3D2%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0Adpdbg.0%20created%0ADDR%20log%20printing%20ON%0AUART%20console%20printing%20ON%0ALog%20level%20set%20to%202%0A%24%20root%40localhost%3A~%23%20ls-debug%20--memory%0AMemory%20dumped%20information%20available%20in%20MC%20log%2Fconsole%0A%24%20root%40localhost%3A~%23%20cat%20%60find%20%2Fdev%2F%20-name%20%22*mc_console%22%60%0A%5BI%2C%20RESMAN%5D%20%20Handling%20command%3A%20dprc_get_obj%20for%20DPRC%201%20on%20portal%20id%200%0A%5BI%2C%20RESMAN%5D%20%20Handling%20command%3A%20dprc_get_obj%20for%20DPRC%201%20on%20portal%20id%200%0A%5BI%2C%20RESMAN%5D%20%20Handling%20command%3A%20dprc_get_obj%20for%20DPRC%201%20on%20portal%20id%200%0A%5BI%2C%20RESMAN%5D%20%20Handling%20command%3A%20dprc_get_obj%20for%20DPRC%201%20on%20portal%20id%200%0A%5BI%2C%20RESMAN%5D%20%20Handling%20command%3A%20dprc_get_obj%20for%20DPRC%201%20on%20portal%20id%200%0A%5BI%2C%20RESMAN%5D%20%20Handling%20command%3A%20dprc_get_obj%20for%20DPRC%201%20on%20portal%20id%200%0A%5BI%2C%20RESMAN%5D%20%20Handling%20command%3A%20dprc_get_obj%20for%20DPRC%201%20on%20portal%20id%200%0A%5BI%2C%20RESMAN%5D%20%20Handling%20command%3A%20dprc_get_obj%20for%20DPRC%201%20on%20portal%20id%200%0A%5BI%2C%20RESMAN%5D%20%20Handling%20command%3A%20dprc_get_obj%20for%20DPRC%201%20on%20portal%20id%200%0A%5BI%2C%20RESMAN%5D%20%20Handling%20command%3A%20dprc_get_obj%20for%20DPRC%201%20on%20portal%20id%200%0A%5BI%2C%20RESMAN%5D%20%20Handling%20command%3A%20dprc_get_obj%20for%20DPRC%201%20on%20portal%20id%200%0A%5BI%2C%20RESMAN%5D%20%20Handling%20command%3A%20dprc_get_obj%20for%20DPRC%201%20on%20portal%20id%200%0A%5BI%2C%20RESMAN%5D%20%20Handling%20command%3A%20dprc_get_obj%20for%20DPRC%201%20on%20portal%20id%200%0A%5BI%2C%20RESMAN%5D%20%20Handling%20command%3A%20dprc_get_obj%20for%20DPRC%201%20on%20portal%20id%200%0A%5BI%2C%20RESMAN%5D%20%20Handling%20command%3A%20dprc_get_obj%20for%20DPRC%201%20on%20portal%20id%200%0A%5BI%2C%20RESMAN%5D%20%20Handling%20command%3A%20dprc_get_obj%20for%20DPRC%201%20on%20portal%20id%200%0A%5BI%2C%20RESMAN%5D%20%20Handling%20command%3A%20dprc_get_obj%20for%20DPRC%201%20on%20portal%20id%200%0A%5BI%2C%20RESMAN%5D%20%20Handling%20command%3A%20dprc_get_obj%20for%20DPRC%201%20on%20portal%20id%200%0A%5BI%2C%20RESMAN%5D%20%20Handling%20command%3A%20dprc_get_obj%20for%20DPRC%201%20on%20portal%20id%200%0A%5BI%2C%20RESMAN%5D%20%20Handling%20command%3A%20dprc_get_obj%20for%20DPRC%201%20on%20portal%20id%200%0A%5BI%2C%20RESMAN%5D%20%20Handling%20command%3A%20dprc_get_obj%20for%20DPRC%201%20on%20portal%20id%200%0A%5BI%2C%20RESMAN%5D%20%20Handling%20command%3A%20dprc_get_obj%20for%20DPRC%201%20on%20portal%20id%200%0A%5BI%2C%20RESMAN%5D%20%20Handling%20command%3A%20dprc_get_obj%20for%20DPRC%201%20on%20portal%20id%200%0A%5BI%2C%20RESMAN%5D%20%20Handling%20command%3A%20dprc_get_obj%20for%20DPRC%201%20on%20portal%20id%200%0A%5BI%2C%20RESMAN%5D%20%20Handling%20command%3A%20dprc_get_obj%20for%20DPRC%201%20on%20portal%20id%200%0A%5BI%2C%20RESMAN%5D%20%20Handling%20command%3A%20dpdbg_open%20on%20DPDBG%0A%5BI%2C%20RESMAN%5D%20%20Handling%20command%3A%20dpdbg_dump%20on%20DPDBG%0A%5BI%2C%20DPNI%5D%20%20Memory%20info%3A%0A%5BI%2C%20DPNI%5D%20%20MC%20DDR%20%231%20cacheable%20memory%0A%5BI%2C%20DPNI%5D%20%20%20%20%20%20%20%20Total%3A%20134217728%20bytes%0A%5BI%2C%20DPNI%5D%20%20%20%20%20%20%20%20Used%3A%2014802708%20bytes%0A%5BI%2C%20DPNI%5D%20%20%20%20%20%20%20%20Free%3A%20119415020%20bytes%0A%5BI%2C%20DPNI%5D%20%20MC%20DDR%20%231%20non-cacheable%20memory%0A%5BI%2C%20DPNI%5D%20%20%20%20%20%20%20%20Total%3A%2050331648%20bytes%0A%5BI%2C%20DPNI%5D%20%20%20%20%20%20%20%20Used%3A%2027680%20bytes%0A%5BI%2C%20DPNI%5D%20%20%20%20%20%20%20%20Free%3A%2050303968%20bytes%0A%5BI%2C%20DPNI%5D%20%20DMEM1%20memory%0A%5BI%2C%20DPNI%5D%20%20%20%20%20%20%20%20Total%3A%2081920%20bytes%0A%5BI%2C%20DPNI%5D%20%20%20%20%20%20%20%20Used%3A%2027168%20bytes%0A%5BI%2C%20DPNI%5D%20%20%20%20%20%20%20%20Free%3A%2054752%20bytes%0A%5BI%2C%20DPNI%5D%20%20DMEM2%20memory%0A%5BI%2C%20DPNI%5D%20%20%20%20%20%20%20%20Total%3A%2081920%20bytes%0A%5BI%2C%20DPNI%5D%20%20%20%20%20%20%20%20Used%3A%2027168%20bytes%0A%5BI%2C%20DPNI%5D%20%20%20%20%20%20%20%20Free%3A%2054752%20bytes%0A%5BI%2C%20DPNI%5D%20%20DDR%20%231%20memory%0A%5BI%2C%20DPNI%5D%20%20%20%20%20%20%20%20Total%3A%201610612736%20bytes%0A%5BI%2C%20DPNI%5D%20%20%20%20%20%20%20%20Used%3A%20143163392%20bytes%0A%5BI%2C%20DPNI%5D%20%20%20%20%20%20%20%20Free%3A%201467449344%20bytes%0A%5BI%2C%20DPNI%5D%20%20PEB%20memory%0A%5BI%2C%20DPNI%5D%20%20%20%20%20%20%20%20Total%3A%202097152%20bytes%0A%5BI%2C%20DPNI%5D%20%20%20%20%20%20%20%20Used%3A%20524288%20bytes%0A%5BI%2C%20DPNI%5D%20%20%20%20%20%20%20%20Free%3A%201572864%20bytes%0A%5BI%2C%20DPNI%5D%20%20DP-DDR%20memory%0A%5BI%2C%20DPNI%5D%20%20%20%20%20%20%20%20Total%3A%204294967296%20bytes%0A%5BI%2C%20DPNI%5D%20%20%20%20%20%20%20%20Used%3A%200%20bytes%0A%5BI%2C%20DPNI%5D%20%20%20%20%20%20%20%20Free%3A%204294967296%20bytes%0A%5BI%2C%20RESMAN%5D%20%20Handling%20command%3A%20dpdbg_close%20on%20DPDBG%0A%5BI%2C%20RESMAN%5D%20%20Handling%20command%3A%20dprc_close%20for%20DPRC%201%20on%20portal%20id%200%0A%5BI%2C%20RESMAN%5D%20%20Handling%20command%3A%20dprc_set_irq_mask%20for%20DPRC%201%20on%20portal%20id%200%0A%5BI%2C%20RESMAN%5D%20%20Handling%20command%3A%20dprc_set_irq_enable%20for%20DPRC%201%20on%20portal%20id%200%0Aroot%40localhost%3A~%23%0A%3C%2FCODE%3E%3C%2FPRE%3E%3C%2FLINGO-BODY%3E
无评分
版本历史
最后更新:
‎02-18-2021 03:54 AM
更新人:
