USB with NXP Microcontrollers
Introduction
The Universal Serial Bus (USB) is the most-successful interface in personal computing today. Fast, reliable, and easy-to-use, you will find this interface everywhere — on personal computers, computer peripherals, monitors, mobile devices, audio and video equipment, and most other consumer electronic products.
NXP leads the market in USB-equipped ARM microcontrollers providing more than 80 options for Cortex-M4, Cortex-M3, Cortex-M0, ARM9, and ARM7 microcontrollers (see comparison table and products below). NXP's portfolio of high-speed and full-speed device/host/OTG USB-enabled microcontrollers offers special USB features (like on-chip HS PHY and ROM drivers), free software, and comprehensive support to help you move quickly from design concept to production.
NXP Advantages
NXP's microcontroller portfolio features the latest USB technologies, including full- and high-speed USB 2.0 device, host, and On-The-Go (OTG) functions. NXP supports all four transfer types: control, interrupt, bulk, and, in particular, isochronous, which is required for streaming audio. NXP MCUs provide designers a range of special USB features that improve overall performance and speed time-to-market:
  • Fully-Certified USB Products
  • On-Chip ROM Drivers
  • Integrated Hi-Speed and/or Full-Speed PHY
  • Free USB Host and Device Software
  • Additional USB Features
NXP is a leading member of the USB-IF, the organization that maintains the USB specifications and verifies USB compliance. NXP's USB-equipped ARM MCUs are submitted for certification, so designers can be certain that their systems will deliver the best in reliability and plug-and-play operation. As of the end of 2008, most of our USB 2.0-based processors with host and device functions have been certified; the OTG function is in-process. A complete list of compliant products appears on the USB-IF web site, www.usb.org.
On-Chip USB ROM Drivers
NXP's on-board USB ROM drivers pack the entire USB stack, USB classes, and low-level drivers right into the microcontroller's ROM, eliminating the need to develop and debug this complex software yourself. Placing the USB drivers in the ROM frees up valuable memory space that you can then use for your application. These drivers have been thoroughly tested by NXP and outside test houses and are used to gain USB logo certification after passing the rigorous testing requirements at USB-IF.
A full-speed or high-speed PHY is integrated into NXP's USB microcontrollers and provides the bridge between the digital and modulated parts of the interface. The integration of the PHY on the MCU saves component cost and simplifies system design. For example, the LPC1800 and LPC4300 microcontrollers support two channels of High-Speed USB 2.0 Host/Device/OTG and have an on-chip High-Speed PHY.
USB development doesn't have to be expensive or difficult. To help you save time and money, NXP provides complete ready-to-go USB example applications for host and device modes that work out of the box on multiple tool chains — all at no charge. In addition to NXP's own complimentary USB packages, NXP partners with leading software companies to provide state-of-the-art USB firmware. For a complete list of USB software options, please see the Support section of this page.
NXP's additional USB features include the following:
  • Host controllers are OHCI-/EHCI-compliant.
  • Dedicated DMA lets the USB interface operate with minimal CPU intervention.
  • SoftConnect™ uses software to determine when a USB device will connect to the bus.
  • GoodLink™ uses an LED to indicate that a USB device has been enumerated and configured on the bus. (To save power, the LED is turned off during suspend.)
  • Double-buffering maximizes throughput on bulk and isochronous endpoints.
  • Multiple USB ports let devices be configured as hosts, devices, or both.
  • USB data buffer provides flexible configuration of endpoint FIFO sizes.
Products
NXP offers more than 80 USB MCU options for Cortex-M0, Cortex-M3, Cortex-M4, ARM9, and ARM7 microcontrollers (see the comparison table and products below). NXP MCUs special USB features include:
Comparison Table
CoreProductOn-Chip ControllerNo. of CntrlsNo. of PortsOn-chip PHYCertified
Device Host OTG
ARM7TDMI-SLPC2141FS--11DeviceFS
LPC2142FS--11DeviceFS
LPC2144FS--11Device-
LPC2146FS--11Device-
LPC2148FS--11DeviceFS
LPC2158FS--11Device-
LPC2361FSFSFS11Device, HostFS
LPC2362FSFSFS11Device, HostFS
LPC2364FS--11DeviceFS
LPC2366FS--11DeviceFS
LPC2368FS--11DeviceFS
LPC2378FS--11DeviceFS
LPC2387FSFSFS11Device, HostFS
LPC2388FSFSFS12Device, HostFS
LPC2420FSFSFS12Device, Host-
LPC2458FSFSFS12Device, Host-
LPC2460FSFSFS12Device, Host-
LPC2468FSFSFS12Device, HostFS
LPC2470FSFSFS12Device, Host-
LPC2478FSFSFS12Device, Host-
LPC2880HS--11DeviceHS
LPC2888HS--11DeviceHS
ARM720TLH79524FS--11Device-
LH79525FS--11Device-
ARM922TLH7A404FSFS-13 (2 host)Device, Host-
LH7A400FS--11Device-
ARM968LPC2921FS--11Device-
LPC2923FS--11Device-
LPC2925FS--11Device-
LPC2926FS FS11Device
LPC2927FS-FS11Device-
LPC2929FS-FS11DeviceFS
LPC2930FSFSFS12Device, Host-
LPC2939FSFSFS12Device, Host-
ARM926EJ-SLPC3180/01FSFSFS11--
LPC3220FSFSFS11--
LPC3230FSFSFS11--
LPC3240FSFSFS11--
LPC3250FSFSFS11--
LPC3130HSHSHS11Device, Host, OTG-
LPC3131HSHSHS11Device, Host, OTGHS
LPC3151HSHSHS11Device, Host, OTG-
LPC3152HSHSHS11Device, Host, OTGHS
LPC3153HSHSHS11Device, Host, OTG-
LPC3154HSHSHS11Device, Host, OTG-
Cortex-M3LPC1342FS--11DeviceFS
LPC1343FS--11DeviceFS
LPC1345FS--11Device-
LPC1346FS--11Device-
LPC1347FS--11Device-
LPC1547FS--11Device-
LPC1548FS--11Device-
LPC1549FS--11DeviceFS
LPC1751FS--11DeviceFS
LPC1752FS--11Device-
LPC1754FSFSFS11Device, Host-
LPC1756FSFSFS11Device, Host-
LPC1758FSFSFS11Device, Host-
LPC1759FSFSFS11Device, Host-
LPC1764FS--11Device-
LPC1765FSFSFS11Device, Host-
LPC1766FSFSFS11Device, Host-
LPC1768FSFSFS11Device, HostFS
LPC1769FSFSFS11Device, Host-
LPC1774FS--11Device-
LPC1776FSFSFS11Device, Host-
LPC1777FSFSFS11Device, Host-
LPC1778FSFSFS11Device, Host-
LPC1785FSFSFS11Device, Host-
LPC1786FSFSFS11Device, Host-
LPC1787FSFSFS11Device, Host-
LPC1788FSFSFS11Device, Host-
LPC1820HSHSHS11Device, Host-
LPC1822HSHSHS11Device, Host-
LPC1823HSHSHS11Device, Host-
LPC1825HSHSHS11Device, Host-
LPC1827HSHSHS11Device, Host-
LPC1830HSHSHS22Device, Host-
LPC1833HSHSHS22Device, Host-
LPC1837HSHSHS22Device, HostFS
LPC1850HSHSHS22Device, HostFS
LPC1853HSHSHS22Device, HostFS
LPC1857HSHSHS22Device, HostFS
Cortex-M4LPC4072FSFSFS12Device, Host, OTG-
LPC4074FSFSFS12Device, Host, OTG-
LPC4076FSFSFS12Device, Host, OTG-
LPC4078FSFSFS12Device, Host, OTG-
LPC4088FSFSFS12Device, Host, OTG-
LPC4320HSHSHS11Device, Host, OTG-
LPC4322HSHSHS11Device, Host, OTG-
LPC4323HSHSHS11Device, Host, OTG-
LPC4325HSHSHS11Device, Host, OTG-
LPC4327HSHSHS11Device, Host, OTG-
LPC4330HSHSHS22Device, Host, OTG-
LPC4333HSHSHS22Device, Host, OTG-
LPC4337HSHSHS22Device, Host, OTG-
LPC4350HSHSHS22Device, Host, OTG-
LPC4353HSHSHS22Device, Host, OTG-
LPC4357HSHSHS22Device, Host, OTG-
Cortex-M0LPC11U12FS--11Device-
LPC11U13FS--11Device-
LPC11U14FS--11DeviceFS
LPC11U23FS--11Device-
LPC11U24FS--11DeviceLS, FS
LPC11U34FS--11Device-
LPC11U35FS--11Device-
LPC11U36FS--11Device-
LPC11U37FS--11DeviceFS
LPC11U37HFS--11Device-
Cortex-M0+LPC11U67FS--11Device-
LPC11U68FS--11DeviceLS, FS
Support
Software
Application Notes
Articles
Links
%3CLINGO-SUB%20id%3D%22lingo-sub-1129055%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EUSB%20with%20NXP%20Microcontrollers%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1129055%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CH1%20class%3D%22h2off%22%20style%3D%22font-size%3A%2026px%3B%20font-weight%3A%20400%3B%20color%3A%20%23333333%3B%20font-family%3A%20Lato%2C%20sans-serif%3B%22%20title%3D%22Back%20to%20top%22%20id%3D%22toc-hId-382600296%22%20id%3D%22toc-hId-1297782601%22%3EIntroduction%3C%2FH1%3E%3CP%20style%3D%22color%3A%20%23646464%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%20font-size%3A%2012px%3B%22%3EThe%20Universal%20Serial%20Bus%20(USB)%20is%20the%20most-successful%20interface%20in%20personal%20computing%20today.%20Fast%2C%20reliable%2C%20and%20easy-to-use%2C%20you%20will%20find%20this%20interface%20everywhere%20%E2%80%94%20on%20personal%20computers%2C%20computer%20peripherals%2C%20monitors%2C%20mobile%20devices%2C%20audio%20and%20video%20equipment%2C%20and%20most%20other%20consumer%20electronic%20products.%3C%2FP%3E%3CP%20align%3D%22left%22%20class%3D%22indent%22%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%20color%3A%20%23646464%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%20font-size%3A%2012px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CDIV%20class%3D%22indent%22%3ENXP%20leads%20the%20market%20in%20USB-equipped%20ARM%20microcontrollers%20providing%20more%20than%2080%20options%20for%20Cortex-M4%2C%20Cortex-M3%2C%20Cortex-M0%2C%20ARM9%2C%20and%20ARM7%20microcontrollers%20(see%20comparison%20table%20and%20products%20below).%20NXP's%20portfolio%20of%20high-speed%20and%20full-speed%20device%2Fhost%2FOTG%20USB-enabled%20microcontrollers%20offers%20special%20USB%20features%20(like%20on-chip%20HS%20PHY%20and%20ROM%20drivers)%2C%20free%20software%2C%20and%20comprehensive%20support%20to%20help%20you%20move%20quickly%20from%20design%20concept%20to%20production.%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CBR%20%2F%3E%3CUL%3E%3CLI%3E%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%22%3E%3CSTRONG%3E%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttp%253A%252F%252Fwww.eetimes.com%252Felectrical-engineers%252Feducation-training%252Fwebinars%252F4218732%252FRapid-USB-development-on-Cortex-M-microcontrollers%22%20target%3D%22_blank%22%3ETechOnLine%20Rapid%20USB%20development%20on%20Cortex-M%20microcontrollers%20webinar%3C%2FA%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%20(Sep%207%2C%202011)%3C%2FLI%3E%3C%2FUL%3E%20%3CH1%20class%3D%22h2off%22%20style%3D%22font-size%3A%2026px%3B%20font-weight%3A%20400%3B%20color%3A%20%23333333%3B%20font-family%3A%20Lato%2C%20sans-serif%3B%22%20title%3D%22Back%20to%20top%22%20id%3D%22toc-hId--1424854167%22%20id%3D%22toc-hId--509671862%22%3ENXP%20Advantages%3C%2FH1%3E%3CSPAN%20class%3D%22indent%22%3ENXP's%20microcontroller%20portfolio%20features%20the%20latest%20USB%20technologies%2C%20including%20full-%20and%20high-speed%20USB%202.0%20device%2C%20host%2C%20and%20On-The-Go%20(OTG)%20functions.%20NXP%20supports%20all%20four%20transfer%20types%3A%20control%2C%20interrupt%2C%20bulk%2C%20and%2C%20in%20particular%2C%20isochronous%2C%20which%20is%20required%20for%20streaming%20audio.%20NXP%20MCUs%20provide%20designers%20a%20range%20of%20special%20USB%20features%20that%20improve%20overall%20performance%20and%20speed%20time-to-market%3A%3C%2FSPAN%3E%3CUL%3E%3CLI%3EFully-Certified%20USB%20Products%3C%2FLI%3E%3CLI%3EOn-Chip%20ROM%20Drivers%3C%2FLI%3E%3CLI%3EIntegrated%20Hi-Speed%20and%2For%20Full-Speed%20PHY%3C%2FLI%3E%3CLI%3EFree%20USB%20Host%20and%20Device%20Software%3C%2FLI%3E%3CLI%3EAdditional%20USB%20Features%3C%2FLI%3E%3C%2FUL%3E%3CSPAN%20class%3D%22indent%22%3E%20%3C%2FSPAN%3E%3CH3%20style%3D%22font-family%3A%20Lato%2C%20sans-serif%3B%20color%3A%20%23333333%3B%22%20id%3D%22toc-hId-1763723244%22%20id%3D%22toc-hId--1616061747%22%3EFully-Certified%20USB%20Products%3C%2FH3%3E%3CSPAN%20class%3D%22indent%22%3ENXP%20is%20a%20leading%20member%20of%20the%20USB-IF%2C%20the%20organization%20that%20maintains%20the%20USB%20specifications%20and%20verifies%20USB%20compliance.%20NXP's%20USB-equipped%20ARM%20MCUs%20are%20submitted%20for%20certification%2C%20so%20designers%20can%20be%20certain%20that%20their%20systems%20will%20deliver%20the%20best%20in%20reliability%20and%20plug-and-play%20operation.%20As%20of%20the%20end%20of%202008%2C%20most%20of%20our%20USB%202.0-based%20processors%20with%20host%20and%20device%20functions%20have%20been%20certified%3B%20the%20OTG%20function%20is%20in-process.%20A%20complete%20list%20of%20compliant%20products%20appears%20on%20the%20USB-IF%20web%20site%2C%20%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttp%253A%252F%252Fwww.usb.org%252F%22%20target%3D%22_blank%22%3E%3CSTRONG%3E%3C%2FSTRONG%3E%3C%2FA%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fwww.usb.org%22%20target%3D%22test_blank%22%3Ewww.usb.org%3C%2FA%3E.%3C%2FSPAN%3E%3CH3%20style%3D%22font-family%3A%20Lato%2C%20sans-serif%3B%20color%3A%20%23333333%3B%22%20id%3D%22toc-hId--43731219%22%20id%3D%22toc-hId-871451086%22%3EOn-Chip%20USB%20ROM%20Drivers%3C%2FH3%3E%3CSPAN%20class%3D%22indent%22%3ENXP's%20on-board%20USB%20ROM%20drivers%20pack%20the%20entire%20USB%20stack%2C%20USB%20classes%2C%20and%20low-level%20drivers%20right%20into%20the%20microcontroller's%20ROM%2C%20eliminating%20the%20need%20to%20develop%20and%20debug%20this%20complex%20software%20yourself.%20Placing%20the%20USB%20drivers%20in%20the%20ROM%20frees%20up%20valuable%20memory%20space%20that%20you%20can%20then%20use%20for%20your%20application.%20These%20drivers%20have%20been%20thoroughly%20tested%20by%20NXP%20and%20outside%20test%20houses%20and%20are%20used%20to%20gain%20USB%20logo%20certification%20after%20passing%20the%20rigorous%20testing%20requirements%20at%20USB-IF.%3C%2FSPAN%3E%3CH3%20style%3D%22font-family%3A%20Lato%2C%20sans-serif%3B%20color%3A%20%23333333%3B%22%20id%3D%22toc-hId--1851185682%22%20id%3D%22toc-hId--936003377%22%3EIntegrated%20Hi-Speed%20and%2For%20Full-Speed%20PHY%3C%2FH3%3E%3CSPAN%20class%3D%22indent%22%3EA%20full-speed%20or%20high-speed%20PHY%20is%20integrated%20into%20NXP's%20USB%20microcontrollers%20and%20provides%20the%20bridge%20between%20the%20digital%20and%20modulated%20parts%20of%20the%20interface.%20The%20integration%20of%20the%20PHY%20on%20the%20MCU%20saves%20component%20cost%20and%20simplifies%20system%20design.%20For%20example%2C%20the%20LPC1800%20and%20LPC4300%20microcontrollers%20support%20two%20channels%20of%20High-Speed%20USB%202.0%20Host%2FDevice%2FOTG%20and%20have%20an%20on-chip%20High-Speed%20PHY.%3C%2FSPAN%3E%3CH3%20style%3D%22font-family%3A%20Lato%2C%20sans-serif%3B%20color%3A%20%23333333%3B%22%20id%3D%22toc-hId-636327151%22%20id%3D%22toc-hId-1551509456%22%3EFree%20USB%20Host%20and%20Device%20Software%3C%2FH3%3E%3CSPAN%20class%3D%22indent%22%3EUSB%20development%20doesn't%20have%20to%20be%20expensive%20or%20difficult.%20To%20help%20you%20save%20time%20and%20money%2C%20NXP%20provides%20complete%20ready-to-go%20USB%20example%20applications%20for%20host%20and%20device%20modes%20that%20work%20out%20of%20the%20box%20on%20multiple%20tool%20chains%20%E2%80%94%20all%20at%20no%20charge.%20In%20addition%20to%20NXP's%20own%20complimentary%20USB%20packages%2C%20NXP%20partners%20with%20leading%20software%20companies%20to%20provide%20state-of-the-art%20USB%20firmware.%20For%20a%20complete%20list%20of%20USB%20software%20options%2C%20please%20see%20the%20%3CSTRONG%3ESupport%20section%3C%2FSTRONG%3E%20of%20this%20page.%3C%2FSPAN%3E%3CH3%20style%3D%22font-family%3A%20Lato%2C%20sans-serif%3B%20color%3A%20%23333333%3B%22%20id%3D%22toc-hId--1171127312%22%20id%3D%22toc-hId--255945007%22%3EAdditional%20USB%20Features%3C%2FH3%3E%3CSPAN%20class%3D%22indent%22%3ENXP's%20additional%20USB%20features%20include%20the%20following%3A%3C%2FSPAN%3E%3CUL%3E%3CLI%3EHost%20controllers%20are%20OHCI-%2FEHCI-compliant.%3C%2FLI%3E%3CLI%3EDedicated%20DMA%20lets%20the%20USB%20interface%20operate%20with%20minimal%20CPU%20intervention.%3C%2FLI%3E%3CLI%3ESoftConnect%E2%84%A2%20uses%20software%20to%20determine%20when%20a%20USB%20device%20will%20connect%20to%20the%20bus.%3C%2FLI%3E%3CLI%3EGoodLink%E2%84%A2%20uses%20an%20LED%20to%20indicate%20that%20a%20USB%20device%20has%20been%20enumerated%20and%20configured%20on%20the%20bus.%20(To%20save%20power%2C%20the%20LED%20is%20turned%20off%20during%20suspend.)%3C%2FLI%3E%3CLI%3EDouble-buffering%20maximizes%20throughput%20on%20bulk%20and%20isochronous%20endpoints.%3C%2FLI%3E%3CLI%3EMultiple%20USB%20ports%20let%20devices%20be%20configured%20as%20hosts%2C%20devices%2C%20or%20both.%3C%2FLI%3E%3CLI%3EUSB%20data%20buffer%20provides%20flexible%20configuration%20of%20endpoint%20FIFO%20sizes.%3C%2FLI%3E%3C%2FUL%3E%3CH1%20class%3D%22h2off%22%20style%3D%22font-size%3A%2026px%3B%20font-weight%3A%20400%3B%20color%3A%20%23333333%3B%20font-family%3A%20Lato%2C%20sans-serif%3B%22%20title%3D%22Back%20to%20top%22%20id%3D%22toc-hId-615320943%22%20id%3D%22toc-hId-1530503248%22%3EProducts%3C%2FH1%3E%3CSPAN%20class%3D%22indent%22%3ENXP%20offers%20more%20than%2080%20USB%20MCU%20options%20for%20Cortex-M0%2C%20Cortex-M3%2C%20Cortex-M4%2C%20ARM9%2C%20and%20ARM7%20microcontrollers%20(see%20the%20comparison%20table%20and%20products%20below).%20NXP%20MCUs%20special%20USB%20features%20include%3A%3C%2FSPAN%3E%3CH3%20style%3D%22font-family%3A%20Lato%2C%20sans-serif%3B%20color%3A%20%23333333%3B%22%20id%3D%22toc-hId--491068942%22%20id%3D%22toc-hId-424113363%22%3EComparison%20Table%3C%2FH3%3E%3CDIV%20class%3D%22j-rte-table%22%3E%3CTABLE%20border%3D%225%22%20cellpadding%3D%220%22%20cellspacing%3D%225%22%20style%3D%22border-width%3A%200px%3B%22%3E%3CTBODY%20style%3D%22border-top-color%3A%20%23cccccc%3B%22%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20bgcolor%3D%22%23ffcccc%22%20rowspan%3D%222%22%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%23ffcccc%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3ECore%3C%2FTD%3E%3CTD%20bgcolor%3D%22%23ffcccc%22%20rowspan%3D%222%22%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%23ffcccc%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EProduct%3C%2FTD%3E%3CTD%20bgcolor%3D%22%23ffcccc%22%20colspan%3D%223%22%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%23ffcccc%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EOn-Chip%20Controller%3C%2FTD%3E%3CTD%20bgcolor%3D%22%23ffcccc%22%20rowspan%3D%222%22%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%23ffcccc%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3ENo.%20of%20Cntrls%3C%2FTD%3E%3CTD%20bgcolor%3D%22%23ffcccc%22%20rowspan%3D%222%22%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%23ffcccc%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3ENo.%20of%20Ports%3C%2FTD%3E%3CTD%20bgcolor%3D%22%23ffcccc%22%20rowspan%3D%222%22%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%23ffcccc%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EOn-chip%20PHY%3C%2FTD%3E%3CTD%20bgcolor%3D%22%23ffcccc%22%20rowspan%3D%222%22%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%23ffcccc%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3ECertified%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20bgcolor%3D%22%23ffcccc%22%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%23ffcccc%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EDevice%20%3C%2FTD%3E%3CTD%20bgcolor%3D%22%23ffcccc%22%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%23ffcccc%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EHost%20%3C%2FTD%3E%3CTD%20bgcolor%3D%22%23ffcccc%22%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%23ffcccc%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EOTG%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20bgcolor%3D%22%23ffcccc%22%20rowspan%3D%2226%22%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%23ffcccc%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EARM7TDMI-S%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3ELPC2141%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EDevice%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3ELPC2142%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EDevice%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3ELPC2144%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EDevice%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3ELPC2146%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EDevice%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3ELPC2148%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EDevice%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3ELPC2158%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EDevice%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20bgcolor%3D%22%23ffcccc%22%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%23ffcccc%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%20%3C%2FTD%3E%3CTD%20bgcolor%3D%22%23ffcccc%22%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%23ffcccc%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%20%3C%2FTD%3E%3CTD%20bgcolor%3D%22%23ffcccc%22%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%23ffcccc%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%20%3C%2FTD%3E%3CTD%20bgcolor%3D%22%23ffcccc%22%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%23ffcccc%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%20%3C%2FTD%3E%3CTD%20bgcolor%3D%22%23ffcccc%22%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%23ffcccc%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%20%3C%2FTD%3E%3CTD%20bgcolor%3D%22%23ffcccc%22%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%23ffcccc%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%20%3C%2FTD%3E%3CTD%20bgcolor%3D%22%23ffcccc%22%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%23ffcccc%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%20%3C%2FTD%3E%3CTD%20bgcolor%3D%22%23ffcccc%22%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%23ffcccc%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%20%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3ELPC2361%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EDevice%2C%20Host%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3ELPC2362%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EDevice%2C%20Host%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3ELPC2364%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EDevice%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3ELPC2366%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EDevice%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3ELPC2368%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EDevice%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3ELPC2378%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EDevice%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3ELPC2387%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EDevice%2C%20Host%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3ELPC2388%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E2%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EDevice%2C%20Host%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20bgcolor%3D%22%23ffcccc%22%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%23ffcccc%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%20%3C%2FTD%3E%3CTD%20bgcolor%3D%22%23ffcccc%22%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%23ffcccc%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%20%3C%2FTD%3E%3CTD%20bgcolor%3D%22%23ffcccc%22%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%23ffcccc%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%20%3C%2FTD%3E%3CTD%20bgcolor%3D%22%23ffcccc%22%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%23ffcccc%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%20%3C%2FTD%3E%3CTD%20bgcolor%3D%22%23ffcccc%22%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%23ffcccc%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%20%3C%2FTD%3E%3CTD%20bgcolor%3D%22%23ffcccc%22%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%23ffcccc%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%20%3C%2FTD%3E%3CTD%20bgcolor%3D%22%23ffcccc%22%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%23ffcccc%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%20%3C%2FTD%3E%3CTD%20bgcolor%3D%22%23ffcccc%22%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%23ffcccc%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%20%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3ELPC2420%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E2%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EDevice%2C%20Host%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3ELPC2458%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E2%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EDevice%2C%20Host%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3ELPC2460%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E2%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EDevice%2C%20Host%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3ELPC2468%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E2%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EDevice%2C%20Host%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3ELPC2470%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E2%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EDevice%2C%20Host%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3ELPC2478%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E2%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EDevice%2C%20Host%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20bgcolor%3D%22%23ffcccc%22%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%23ffcccc%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%20%3C%2FTD%3E%3CTD%20bgcolor%3D%22%23ffcccc%22%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%23ffcccc%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%20%3C%2FTD%3E%3CTD%20bgcolor%3D%22%23ffcccc%22%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%23ffcccc%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%20%3C%2FTD%3E%3CTD%20bgcolor%3D%22%23ffcccc%22%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%23ffcccc%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%20%3C%2FTD%3E%3CTD%20bgcolor%3D%22%23ffcccc%22%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%23ffcccc%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%20%3C%2FTD%3E%3CTD%20bgcolor%3D%22%23ffcccc%22%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%23ffcccc%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%20%3C%2FTD%3E%3CTD%20bgcolor%3D%22%23ffcccc%22%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%23ffcccc%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%20%3C%2FTD%3E%3CTD%20bgcolor%3D%22%23ffcccc%22%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%23ffcccc%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%20%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3ELPC2880%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EHS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EDevice%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EHS%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3ELPC2888%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EHS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EDevice%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EHS%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20bgcolor%3D%22%23ffcccc%22%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%23ffcccc%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%20%3C%2FTD%3E%3CTD%20bgcolor%3D%22%23ffcccc%22%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%23ffcccc%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%20%3C%2FTD%3E%3CTD%20bgcolor%3D%22%23ffcccc%22%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%23ffcccc%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%20%3C%2FTD%3E%3CTD%20bgcolor%3D%22%23ffcccc%22%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%23ffcccc%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%20%3C%2FTD%3E%3CTD%20bgcolor%3D%22%23ffcccc%22%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%23ffcccc%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%20%3C%2FTD%3E%3CTD%20bgcolor%3D%22%23ffcccc%22%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%23ffcccc%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%20%3C%2FTD%3E%3CTD%20bgcolor%3D%22%23ffcccc%22%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%23ffcccc%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%20%3C%2FTD%3E%3CTD%20bgcolor%3D%22%23ffcccc%22%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%23ffcccc%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%20%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20bgcolor%3D%22%23ffcccc%22%20rowspan%3D%223%22%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%23ffcccc%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EARM720T%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3ELH79524%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EDevice%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3ELH79525%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EDevice%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20bgcolor%3D%22%23ffcccc%22%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%23ffcccc%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%20%3C%2FTD%3E%3CTD%20bgcolor%3D%22%23ffcccc%22%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%23ffcccc%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%20%3C%2FTD%3E%3CTD%20bgcolor%3D%22%23ffcccc%22%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%23ffcccc%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%20%3C%2FTD%3E%3CTD%20bgcolor%3D%22%23ffcccc%22%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%23ffcccc%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%20%3C%2FTD%3E%3CTD%20bgcolor%3D%22%23ffcccc%22%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%23ffcccc%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%20%3C%2FTD%3E%3CTD%20bgcolor%3D%22%23ffcccc%22%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%23ffcccc%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%20%3C%2FTD%3E%3CTD%20bgcolor%3D%22%23ffcccc%22%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%23ffcccc%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%20%3C%2FTD%3E%3CTD%20bgcolor%3D%22%23ffcccc%22%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%23ffcccc%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%20%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20bgcolor%3D%22%23ffcccc%22%20rowspan%3D%223%22%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%23ffcccc%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EARM922T%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3ELH7A404%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E3%20(2%20host)%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EDevice%2C%20Host%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3ELH7A400%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EDevice%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20bgcolor%3D%22%23ffcccc%22%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%23ffcccc%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%20%3C%2FTD%3E%3CTD%20bgcolor%3D%22%23ffcccc%22%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%23ffcccc%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%20%3C%2FTD%3E%3CTD%20bgcolor%3D%22%23ffcccc%22%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%23ffcccc%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%20%3C%2FTD%3E%3CTD%20bgcolor%3D%22%23ffcccc%22%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%23ffcccc%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%20%3C%2FTD%3E%3CTD%20bgcolor%3D%22%23ffcccc%22%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%23ffcccc%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%20%3C%2FTD%3E%3CTD%20bgcolor%3D%22%23ffcccc%22%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%23ffcccc%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%20%3C%2FTD%3E%3CTD%20bgcolor%3D%22%23ffcccc%22%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%23ffcccc%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%20%3C%2FTD%3E%3CTD%20bgcolor%3D%22%23ffcccc%22%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%23ffcccc%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%20%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20bgcolor%3D%22%23ffcccc%22%20rowspan%3D%229%22%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%23ffcccc%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EARM968%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3ELPC2921%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EDevice%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3ELPC2923%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EDevice%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3ELPC2925%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EDevice%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3ELPC2926%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%20%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EDevice%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%20%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3ELPC2927%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EDevice%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3ELPC2929%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EDevice%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3ELPC2930%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E2%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EDevice%2C%20Host%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3ELPC2939%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E2%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EDevice%2C%20Host%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20bgcolor%3D%22%23ffcccc%22%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%23ffcccc%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%20%3C%2FTD%3E%3CTD%20bgcolor%3D%22%23ffcccc%22%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%23ffcccc%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%20%3C%2FTD%3E%3CTD%20bgcolor%3D%22%23ffcccc%22%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%23ffcccc%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%20%3C%2FTD%3E%3CTD%20bgcolor%3D%22%23ffcccc%22%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%23ffcccc%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%20%3C%2FTD%3E%3CTD%20bgcolor%3D%22%23ffcccc%22%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%23ffcccc%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%20%3C%2FTD%3E%3CTD%20bgcolor%3D%22%23ffcccc%22%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%23ffcccc%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%20%3C%2FTD%3E%3CTD%20bgcolor%3D%22%23ffcccc%22%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%23ffcccc%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%20%3C%2FTD%3E%3CTD%20bgcolor%3D%22%23ffcccc%22%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%23ffcccc%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%20%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20bgcolor%3D%22%23ffcccc%22%20rowspan%3D%2213%22%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%23ffcccc%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EARM926EJ-S%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3ELPC3180%2F01%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3ELPC3220%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3ELPC3230%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3ELPC3240%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3ELPC3250%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20bgcolor%3D%22%23ffcccc%22%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%23ffcccc%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%20%3C%2FTD%3E%3CTD%20bgcolor%3D%22%23ffcccc%22%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%23ffcccc%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%20%3C%2FTD%3E%3CTD%20bgcolor%3D%22%23ffcccc%22%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%23ffcccc%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%20%3C%2FTD%3E%3CTD%20bgcolor%3D%22%23ffcccc%22%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%23ffcccc%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%20%3C%2FTD%3E%3CTD%20bgcolor%3D%22%23ffcccc%22%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%23ffcccc%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%20%3C%2FTD%3E%3CTD%20bgcolor%3D%22%23ffcccc%22%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%23ffcccc%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%20%3C%2FTD%3E%3CTD%20bgcolor%3D%22%23ffcccc%22%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%23ffcccc%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%20%3C%2FTD%3E%3CTD%20bgcolor%3D%22%23ffcccc%22%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%23ffcccc%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%20%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3ELPC3130%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EHS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EHS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EHS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EDevice%2C%20Host%2C%20OTG%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3ELPC3131%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EHS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EHS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EHS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EDevice%2C%20Host%2C%20OTG%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EHS%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3ELPC3151%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EHS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EHS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EHS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EDevice%2C%20Host%2C%20OTG%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3ELPC3152%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EHS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EHS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EHS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EDevice%2C%20Host%2C%20OTG%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EHS%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3ELPC3153%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EHS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EHS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EHS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EDevice%2C%20Host%2C%20OTG%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3ELPC3154%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EHS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EHS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EHS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EDevice%2C%20Host%2C%20OTG%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20bgcolor%3D%22%23ffcccc%22%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%23ffcccc%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%20%3C%2FTD%3E%3CTD%20bgcolor%3D%22%23ffcccc%22%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%23ffcccc%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%20%3C%2FTD%3E%3CTD%20bgcolor%3D%22%23ffcccc%22%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%23ffcccc%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%20%3C%2FTD%3E%3CTD%20bgcolor%3D%22%23ffcccc%22%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%23ffcccc%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%20%3C%2FTD%3E%3CTD%20bgcolor%3D%22%23ffcccc%22%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%23ffcccc%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%20%3C%2FTD%3E%3CTD%20bgcolor%3D%22%23ffcccc%22%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%23ffcccc%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%20%3C%2FTD%3E%3CTD%20bgcolor%3D%22%23ffcccc%22%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%23ffcccc%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%20%3C%2FTD%3E%3CTD%20bgcolor%3D%22%23ffcccc%22%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%23ffcccc%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%20%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20bgcolor%3D%22%23ffcccc%22%20rowspan%3D%2239%22%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%23ffcccc%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3ECortex-M3%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3ELPC1342%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EDevice%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3ELPC1343%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EDevice%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3ELPC1345%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EDevice%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3ELPC1346%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EDevice%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3ELPC1347%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EDevice%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3ELPC1547%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EDevice%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3ELPC1548%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EDevice%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3ELPC1549%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EDevice%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3ELPC1751%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EDevice%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3ELPC1752%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EDevice%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3ELPC1754%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EDevice%2C%20Host%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3ELPC1756%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EDevice%2C%20Host%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3ELPC1758%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EDevice%2C%20Host%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3ELPC1759%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EDevice%2C%20Host%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3ELPC1764%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EDevice%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3ELPC1765%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EDevice%2C%20Host%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3ELPC1766%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EDevice%2C%20Host%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3ELPC1768%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EDevice%2C%20Host%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3ELPC1769%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EDevice%2C%20Host%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3ELPC1774%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EDevice%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3ELPC1776%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EDevice%2C%20Host%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3ELPC1777%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EDevice%2C%20Host%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3ELPC1778%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EDevice%2C%20Host%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3ELPC1785%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EDevice%2C%20Host%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3ELPC1786%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EDevice%2C%20Host%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3ELPC1787%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EDevice%2C%20Host%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3ELPC1788%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EDevice%2C%20Host%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3ELPC1820%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EHS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EHS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EHS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EDevice%2C%20Host%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3ELPC1822%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EHS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EHS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EHS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EDevice%2C%20Host%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3ELPC1823%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EHS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EHS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EHS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EDevice%2C%20Host%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3ELPC1825%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EHS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EHS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EHS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EDevice%2C%20Host%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3ELPC1827%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EHS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EHS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EHS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EDevice%2C%20Host%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3ELPC1830%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EHS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EHS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EHS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E2%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E2%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EDevice%2C%20Host%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3ELPC1833%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EHS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EHS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EHS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E2%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E2%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EDevice%2C%20Host%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3ELPC1837%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EHS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EHS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EHS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E2%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E2%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EDevice%2C%20Host%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3ELPC1850%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EHS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EHS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EHS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E2%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E2%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EDevice%2C%20Host%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3ELPC1853%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EHS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EHS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EHS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E2%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E2%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EDevice%2C%20Host%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3ELPC1857%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EHS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EHS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EHS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E2%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E2%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EDevice%2C%20Host%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20bgcolor%3D%22%23ffcccc%22%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%23ffcccc%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%20%3C%2FTD%3E%3CTD%20bgcolor%3D%22%23ffcccc%22%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%23ffcccc%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%20%3C%2FTD%3E%3CTD%20bgcolor%3D%22%23ffcccc%22%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%23ffcccc%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%20%3C%2FTD%3E%3CTD%20bgcolor%3D%22%23ffcccc%22%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%23ffcccc%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%20%3C%2FTD%3E%3CTD%20bgcolor%3D%22%23ffcccc%22%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%23ffcccc%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%20%3C%2FTD%3E%3CTD%20bgcolor%3D%22%23ffcccc%22%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%23ffcccc%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%20%3C%2FTD%3E%3CTD%20bgcolor%3D%22%23ffcccc%22%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%23ffcccc%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%20%3C%2FTD%3E%3CTD%20bgcolor%3D%22%23ffcccc%22%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%23ffcccc%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%20%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20bgcolor%3D%22%23ffcccc%22%20rowspan%3D%2218%22%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%23ffcccc%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3ECortex-M4%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3ELPC4072%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E2%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EDevice%2C%20Host%2C%20OTG%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3ELPC4074%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E2%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EDevice%2C%20Host%2C%20OTG%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3ELPC4076%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E2%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EDevice%2C%20Host%2C%20OTG%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3ELPC4078%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E2%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EDevice%2C%20Host%2C%20OTG%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3ELPC4088%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E2%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EDevice%2C%20Host%2C%20OTG%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3ELPC4320%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EHS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EHS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EHS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EDevice%2C%20Host%2C%20OTG%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3ELPC4320%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EHS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EHS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EHS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EDevice%2C%20Host%2C%20OTG%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%20%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3ELPC4322%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EHS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EHS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EHS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EDevice%2C%20Host%2C%20OTG%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3ELPC4323%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EHS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EHS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EHS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EDevice%2C%20Host%2C%20OTG%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3ELPC4325%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EHS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EHS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EHS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EDevice%2C%20Host%2C%20OTG%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3ELPC4327%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EHS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EHS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EHS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EDevice%2C%20Host%2C%20OTG%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3ELPC4330%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EHS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EHS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EHS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E2%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E2%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EDevice%2C%20Host%2C%20OTG%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3ELPC4333%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EHS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EHS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EHS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E2%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E2%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EDevice%2C%20Host%2C%20OTG%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3ELPC4337%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EHS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EHS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EHS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E2%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E2%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EDevice%2C%20Host%2C%20OTG%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3ELPC4350%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EHS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EHS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EHS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E2%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E2%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EDevice%2C%20Host%2C%20OTG%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3ELPC4353%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EHS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EHS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EHS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E2%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E2%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EDevice%2C%20Host%2C%20OTG%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3ELPC4357%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EHS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EHS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EHS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E2%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E2%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EDevice%2C%20Host%2C%20OTG%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20bgcolor%3D%22%23ffcccc%22%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%23ffcccc%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%20%3C%2FTD%3E%3CTD%20bgcolor%3D%22%23ffcccc%22%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%23ffcccc%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%20%3C%2FTD%3E%3CTD%20bgcolor%3D%22%23ffcccc%22%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%23ffcccc%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%20%3C%2FTD%3E%3CTD%20bgcolor%3D%22%23ffcccc%22%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%23ffcccc%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%20%3C%2FTD%3E%3CTD%20bgcolor%3D%22%23ffcccc%22%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%23ffcccc%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%20%3C%2FTD%3E%3CTD%20bgcolor%3D%22%23ffcccc%22%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%23ffcccc%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%20%3C%2FTD%3E%3CTD%20bgcolor%3D%22%23ffcccc%22%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%23ffcccc%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%20%3C%2FTD%3E%3CTD%20bgcolor%3D%22%23ffcccc%22%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%23ffcccc%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%20%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20bgcolor%3D%22%23ffcccc%22%20colspan%3D%221%22%20rowspan%3D%2211%22%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%23ffcccc%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3ECortex-M0%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3ELPC11U12%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EDevice%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3ELPC11U13%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EDevice%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3ELPC11U14%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EDevice%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3ELPC11U23%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EDevice%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3ELPC11U24%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EDevice%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3ELS%2C%20FS%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3ELPC11U34%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EDevice%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3ELPC11U35%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EDevice%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3ELPC11U36%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EDevice%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3ELPC11U37%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EDevice%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3ELPC11U37H%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EDevice%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20bgcolor%3D%22%23ffcccc%22%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%23ffcccc%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%20%3C%2FTD%3E%3CTD%20bgcolor%3D%22%23ffcccc%22%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%23ffcccc%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%20%3C%2FTD%3E%3CTD%20bgcolor%3D%22%23ffcccc%22%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%23ffcccc%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%20%3C%2FTD%3E%3CTD%20bgcolor%3D%22%23ffcccc%22%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%23ffcccc%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%20%3C%2FTD%3E%3CTD%20bgcolor%3D%22%23ffcccc%22%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%23ffcccc%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%20%3C%2FTD%3E%3CTD%20bgcolor%3D%22%23ffcccc%22%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%23ffcccc%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%20%3C%2FTD%3E%3CTD%20bgcolor%3D%22%23ffcccc%22%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%23ffcccc%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%20%3C%2FTD%3E%3CTD%20bgcolor%3D%22%23ffcccc%22%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%23ffcccc%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%20%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20bgcolor%3D%22%23ffcccc%22%20rowspan%3D%223%22%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%23ffcccc%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3ECortex-M0%2B%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3ELPC11U67%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EDevice%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3ELPC11U68%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EFS%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E-%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3EDevice%3C%2FTD%3E%3CTD%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3ELS%2C%20FS%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20bgcolor%3D%22%23ffcccc%22%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%23ffcccc%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%20%3C%2FTD%3E%3CTD%20bgcolor%3D%22%23ffcccc%22%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%23ffcccc%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%20%3C%2FTD%3E%3CTD%20bgcolor%3D%22%23ffcccc%22%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%23ffcccc%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%20%3C%2FTD%3E%3CTD%20bgcolor%3D%22%23ffcccc%22%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%23ffcccc%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%20%3C%2FTD%3E%3CTD%20bgcolor%3D%22%23ffcccc%22%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%23ffcccc%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%20%3C%2FTD%3E%3CTD%20bgcolor%3D%22%23ffcccc%22%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%23ffcccc%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%20%3C%2FTD%3E%3CTD%20bgcolor%3D%22%23ffcccc%22%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%23ffcccc%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%20%3C%2FTD%3E%3CTD%20bgcolor%3D%22%23ffcccc%22%20style%3D%22border%3A5px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%23ffcccc%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%20%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3C%2FDIV%3E%3CH2%20class%3D%22h2off%22%20style%3D%22font-family%3A%20Lato%2C%20sans-serif%3B%20color%3A%20%23e66e08%3B%20font-size%3A%2018px%3B%20background%3A%200%2050%25%3B%22%20title%3D%22Back%20to%20top%22%20id%3D%22toc-hId--501572046%22%20id%3D%22toc-hId-413610259%22%3E%20%3C%2FH2%3E%3CH2%20class%3D%22h2off%22%20style%3D%22font-family%3A%20Lato%2C%20sans-serif%3B%20color%3A%20%23e66e08%3B%20font-size%3A%2018px%3B%20background%3A%200%2050%25%3B%22%20title%3D%22Back%20to%20top%22%20id%3D%22toc-hId--635256770%22%20id%3D%22toc-hId-279925535%22%3ESupport%3C%2FH2%3E%3CH3%20style%3D%22font-family%3A%20Lato%2C%20sans-serif%3B%20color%3A%20%23333333%3B%22%20id%3D%22toc-hId-1981338782%22%20id%3D%22toc-hId--1398446209%22%3ESoftware%3C%2FH3%3E%3CUL%3E%3CLI%3E%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%22%3E%3CSTRONG%3E%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttp%253A%252F%252Fwww.cmx.com%252Fcmx_usb_device.htm%22%20target%3D%22_blank%22%3ECMX-USB%20Device%20Stack%20(by%20CMX%20Systems)%3C%2FA%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%22%3E%3CSTRONG%3E%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttp%253A%252F%252Fwww.cmx.com%252Fcmx_usb_host.htm%22%20target%3D%22_blank%22%3ECMX-USB%20Host%20Stack%20(by%20CMX%20Systems)%3C%2FA%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%22%3E%3CSTRONG%3E%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttp%253A%252F%252Fwww.segger.com%252Femusb.html%22%20target%3D%22_blank%22%3EemUSB%20Device%20Stack%20(by%20SEGGER)%3C%2FA%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%22%3E%3CSTRONG%3E%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttp%253A%252F%252Fwww.hcc-embedded.com%252Fen%252Fproducts%252Fusb%252Fusb_device_new%22%20target%3D%22_blank%22%3EEUSBD%20(Embedded%20USB%20Device)%20Stack%20(by%20HCC-Embedded)%3C%2FA%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%22%3E%3CSTRONG%3E%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttp%253A%252F%252Fwww.hcc-embedded.com%252Fen%252Fproducts%252Fusb%252Fusb_host_new%22%20target%3D%22_blank%22%3EEUSBH%20(Embedded%20USB%20Host)%20Stack%20(by%20HCC-Embedded)%3C%2FA%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%22%3E%3CSTRONG%3E%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttp%253A%252F%252Fics.nxp.com%252Fsupport%252Fdocuments%252Fmicrocontrollers%252Fzip%252Fi2s.usb.audio.demo.zip%22%20target%3D%22_blank%22%3EI%3CSPAN%20style%3D%22font-size%3A%209px%3B%22%3E2%3C%2FSPAN%3ES%20-%20USB%20Audio%20Demo%3C%2FA%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%20(Oct%2019%2C%202007)%3C%2FLI%3E%3C%2FUL%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CUL%3E%3CLI%3E%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%22%3E%3CSTRONG%3E%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttp%253A%252F%252Fwww.onchiptech.com%252F%253FProducts%252BOT-USB%22%20target%3D%22_blank%22%3EOT-USB%20USB%20Device%2FHost%2FOTG%20Stack%20(by%20OnChip%20Technologies)%3C%2FA%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%22%3E%3CSTRONG%3E%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttp%253A%252F%252Fwww.smxrtos.com%252Frtos%252Fusb%252Fsmxusbd.htm%22%20target%3D%22_blank%22%3EsmxUSBD%20Device%20Stack%20(by%20Micro%20Digital)%3C%2FA%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%22%3E%3CSTRONG%3E%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttp%253A%252F%252Fwww.smxrtos.com%252Frtos%252Fusb%252Fsmxusbh.htm%22%20target%3D%22_blank%22%3EsmxUSBH%20Host%20Stack%20(by%20Micro%20Digital)%3C%2FA%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%22%3E%3CSTRONG%3E%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttp%253A%252F%252Fwww.smxrtos.com%252Frtos%252Fusb%252Fsmxusbo.htm%22%20target%3D%22_blank%22%3EsmxUSBO%20OTG%20Software%20(by%20Micro%20Digital)%3C%2FA%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%22%3E%3CSTRONG%3E%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttp%253A%252F%252Fwww.micrium.com%252Fproducts%252Fusb%252Fusb-device%252Fdrivers.html%22%20target%3D%22_blank%22%3E%C2%B5C%2FUSB%20Device%20Stack%20(by%20Micrium)%3C%2FA%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%22%3E%3CSTRONG%3E%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttp%253A%252F%252Fwww.micrium.com%252Fproducts%252Fusb%252Fusb-host%252Fusb-host.html%22%20target%3D%22_blank%22%3E%C2%B5C%2FUSB%20Host%20Stack%20(by%20Micrium)%3C%2FA%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%22%3E%3CSTRONG%3E%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttp%253A%252F%252Fwww.keil.com%252Fdownload%252Fdocs%252F308.asp%22%20target%3D%22_blank%22%3EUSB%20Audio%20Device%20Example%20for%20LPC214x%20(by%20Keil)%3C%2FA%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%20(Feb%206%2C%202006)%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%22%3E%3CSTRONG%3E%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttp%253A%252F%252Fwww.keil.com%252Fdownload%252Fdocs%252F334.asp%22%20target%3D%22_blank%22%3EUSB%20Audio%20Device%20Example%20for%20LPC23xx%2FLPC24xx%20(by%20Keil)%3C%2FA%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%20(Jun%2019%2C%202007)%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%22%3E%3CSTRONG%3E%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttp%253A%252F%252Fwww.thesycon.de%252Feng%252Fembusbdevice.shtml%22%20target%3D%22_blank%22%3EUSB%20Device%20Stack%20(by%20Thesycon)%3C%2FA%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%22%3E%3CSTRONG%3E%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttp%253A%252F%252Fwww.thesycon.de%252Feng%252Fembusbhost.shtml%22%20target%3D%22_blank%22%3EUSB%20Host%20Stack%20(by%20Thesycon)%3C%2FA%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%22%3E%3CSTRONG%3E%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttp%253A%252F%252Fics.nxp.com%252Fsupport%252Fdocuments%252Fmicrocontrollers%252Fzip%252Fcode.lpc214x.usb.hid.iar.zip%22%20target%3D%22_blank%22%3EUSB%20Human%20Interface%20Device%20(HID)%20Example%20for%20LPC214x%20(by%20IAR%20Systems)%3C%2FA%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%20(Aug%2011%2C%202005)%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%22%3E%3CSTRONG%3E%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttp%253A%252F%252Fwww.keil.com%252Fdownload%252Fdocs%252F306.asp%22%20target%3D%22_blank%22%3EUSB%20Human%20Interface%20Device%20(HID)%20Example%20for%20LPC214x%20(by%20Keil)%3C%2FA%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%20(Feb%206%2C%202006)%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%22%3E%3CSTRONG%3E%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttp%253A%252F%252Fwww.keil.com%252Fdownload%252Fdocs%252F335.asp%22%20target%3D%22_blank%22%3EUSB%20Human%20Interface%20Device%20(HID)%20Example%20for%20LPC23xx%2FLPC24xx%20(by%20Keil)%3C%2FA%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%20(Jun%2019%2C%202007)%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%22%3E%3CSTRONG%3E%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttp%253A%252F%252Fwww.keil.com%252Fdownload%252Fdocs%252F307.asp%22%20target%3D%22_blank%22%3EUSB%20Mass%20Storage%20Device%20Example%20for%20LPC214x%20(by%20Keil)%3C%2FA%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%20(Feb%206%2C%202006)%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%22%3E%3CSTRONG%3E%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttp%253A%252F%252Fwww.keil.com%252Fdownload%252Fdocs%252F336.asp%22%20target%3D%22_blank%22%3EUSB%20Mass%20Storage%20Device%20Example%20for%20LPC23xx%2FLPC24xx%20(by%20Keil)%3C%2FA%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%20(Jun%2019%2C%202007)%3C%2FLI%3E%3C%2FUL%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CUL%3E%3CLI%3E%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%22%3E%3CSTRONG%3E%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttp%253A%252F%252Fwww.adeneo-embedded.com%252Fsrt%252Fen%252Fdocument%252Fshow%253Flocation.id%253A%253D1364%22%20target%3D%22_blank%22%3EWindows%20Embedded%20CE%20BSP%20for%20NXP%20LH7A404%20(by%20Adeneo)%3C%2FA%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%22%3E%3CSTRONG%3E%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttp%253A%252F%252Fwww.adeneo-embedded.com%252Fsrt%252Fen%252Fdocument%252Fshow%253Flocation.id%253A%253D1353%22%20target%3D%22_blank%22%3EWindows%20Embedded%20CE%20BSP%20for%20NXP%20LPC3180%20(by%20Adeneo)%3C%2FA%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%22%3E%3CSTRONG%3E%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttp%253A%252F%252Fwww.lpcware.com%252Fcontent%252Fproject%252Fnxp-peripherals%252Fusb-nxp-microcontrollers%252Fadeneo-embedded-lpc32xx-wince-60-board-supp%22%20target%3D%22_blank%22%3EWindows%20Embedded%20CE%20BSP%20for%20NXP%20LPC32x0%20(by%20Adeneo)%3C%2FA%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3CH3%20style%3D%22font-family%3A%20Lato%2C%20sans-serif%3B%20color%3A%20%23333333%3B%22%20id%3D%22toc-hId-173884319%22%20id%3D%22toc-hId-1089066624%22%3EApplication%20Notes%3C%2FH3%3E%3CUL%3E%3CLI%3E%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%22%3E%3CSTRONG%3E%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttp%253A%252F%252Fwww.lpcware.com%252Fcontent%252Fproject%252Fnxp-peripherals%252Fusb-nxp-microcontrollers%252Fusb-host-mass-storage-class-msc-example%22%20target%3D%22_blank%22%3EAN10703%20NXP%20USB%20host%20lite%3C%2FA%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%20V1%20(Jul%2014%2C%202008)%3C%2FLI%3E%3C%2FUL%3E%3CH3%20style%3D%22font-family%3A%20Lato%2C%20sans-serif%3B%20color%3A%20%23333333%3B%22%20id%3D%22toc-hId--1633570144%22%20id%3D%22toc-hId--718387839%22%3EArticles%3C%2FH3%3E%3CUL%3E%3CLI%3E%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%22%3E%3CSTRONG%3E%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttp%253A%252F%252Fwww.electronicproducts.com%252FShowPage.asp%253FSECTION%253D3700%2526PRIMID%253D%2526FileName%253Dicjh10.aug2005.html%22%20target%3D%22_blank%22%3EARM7%20%C2%B5Cs%20Feature%20True%20Full-Speed%20USB%20(in%20Electronic%20Products)%3C%2FA%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%20(Aug%202005)%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%22%3E%3CSTRONG%3E%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttp%253A%252F%252Fwww2.electronicproducts.com%252FCortex_M0_based_MCUs_have_flexible_USB_port-article-HLJH01_Jun2011-html.aspx%22%20target%3D%22_blank%22%3ECortex-M0%20based%20MCUs%20have%20flexible%20USB%20port%20(in%20Electronic%20Products)%3C%2FA%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%20(Apr%2011%2C%202011)%3C%2FLI%3E%3C%2FUL%3E%3CH3%20style%3D%22font-family%3A%20Lato%2C%20sans-serif%3B%20color%3A%20%23333333%3B%22%20id%3D%22toc-hId-853942689%22%20id%3D%22toc-hId-1769124994%22%3ELinks%3C%2FH3%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CUL%3E%3CLI%3E%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%22%3E%3CSTRONG%3E%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttp%253A%252F%252Fwww.usb.org%252F%22%20target%3D%22_blank%22%3EUSB%20Implementers%20Forum%2C%20Inc.%3C%2FA%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E
No ratings
Version history
Last update:
‎04-25-2016 05:04 PM
Updated by:
