Mass Storage Host example
Description
This example implements a mass storage class host mode device that enumerates a mass storage class device (USB flash drive). It reads the first sector of the device and displays a hexdump style listing of that data on a terminal.
Compiler build configurations
The software that makes up this example is designed to run on many different development boards. Therefore the compiler must be configured to build an image that is targeted to the development board you are using. This section explains how to set these build configurations for each of the supported compilers.
LPCXpresso IDE
Configure projects
  right click on the BSP project in the project explorer window
  click Build Configurations->Set Active->(see configuration in table below)
  repeat these steps with the CDL, nxpUSBlib, and Example_MassStorageHost
Configure MCU
  right click on the Example_MassStorageHost project in the project explorer window
  click Properties->C/C++ Build->MCU settings->(see configuration in table below)
Configure the indexer
   click Window->Preferences->C/C++->Indexer->Use active build configuration
BSP
CDL
nxpUSBlib
Example_MassStorageDevice
MCU
LPC1850  / Hitex
LPC18xx_HITEX
LPC18xx
LPC18xx_Host
LPC18xx
LPC1850
LPC4330  / Xplorer
LPC4330_Xplorer
LPC18xx
LPC18xx_Host
LPC18xx
LPC4330
LPC4350  / Element14
LPC1435_ELEMENT14
LPC18xx
LPC18xx_Host
LPC18xx
LPC4350
LPC1768  / MCB1700
LPC1768_MCB1700
LPC17xx
LPC17xx_Host
LPC17xx
LPC1768
LPC1768  / LPCXpresso
LPC17xx_LPCXpressoRevB
LPC17xx
LPC17xx_Host
LPC17xx
LPC1768
NOTE:
The LPC18xx CDL is used with boards that hold LPC43xx parts. This is done because the LPC43xx CDL is currently experimental. The LPC18xx USB library is used because both parts share the same controller.
Keil uVision 4 IDE
Configure a Batch Build
  click on Project->Batch Build...
  expand the BSP project to display a list of project targets
  select the project target by checking the appropriate checkbox (see target list in table below)
  repeat these steps with the CDL, nxpUSBlib_Host, and Example_MassStorageDevice
BSP
CDL
nxpUSBlib_Host
LPC1850  / Hitex
HITEX1800
LPC18xx
LPC18xx_Host
HITEX1800
LPC1768  / MCB1700
MCB1700
LPC17xx
LPC17xx_Host
MCB1700
Board connections and configurations
LPC18xx_HITEX (LPC1850 Hitex Evaluation Board)  older A2 design
schematic ./BSP/schematics/HITEX_SCM_LPC1850EVA-A2-2.pdf
Connect the JTAG to the 20 pin receptacle marked X4 JTAG
Connect a USB flash drive into the type A receptacle marked X10
Connect a 9-pin serial cable into the receptacle marked UART X1. Connect the other end of this cable into a PC running a terminal program.
To power the board:
  Connect the type-B end of a powered USB cable into the receptacle marked X13
  or
  Supply 5v to the DC connector labeled X14
LPC18xx_HITEX (LPC1850 Hitex Evaluation Board)  newer A3 design
schematic ./BSP/schematics/HITEX_Final_LPC1850EVA-A3.pdf
LPC1768_MCB1700 (Keil MCB1700 development board)
schematic: ./BSP/schematics/mcb1700-schematics.pdf
JumperSetting
  E/U1-2
UMODE1-2
D-Host
D+Host
VBUS1-2
VDDIO1-2
VDDREG1-2
ISPremoved
Connect the JTAG debugger to the 20 pin JTAG or 10 pin Cortex Debug connector
Connect a 9 pin serial cable between COM0 on the board and a PC running a terminal program. Baud rate = 9600
Plug a USB flash drive into the type A receptacle marked HOST
To power the board:
  Connect the type-B end of a powered USB cable to the type-B receptacle labeled 'Device'
  or
  Supply 5v to the -VIN+ pins between the JTAG and COM0 receptacles
Once the board is powered the following LEDs should be illuminated:
    Power
    100MHz
    USC
LPC17xx_LPCXpressoRevB (LPCXpresso LPC17xx on the LPCXpresso Rev B base board)
schematic: ./BSP/schematics/LPCXpressoLPC1769revB.pdf
Plug the LPCXpresso LPC1769 board into the connector labeled J4 on a
  LPCXpresso base board
Connect the JTAG to the mini USB receptacle labeled J3 on the LPCXpresso LPC1769
  board
Configure the base board according to the users guide from Embedded Artists
Install jumpers 1-2, 3-4, 5-6 on the jumper block marked J61 on the base board
Plug a USB flash drive into the type A receptacle marked J60 on the base board
Connect the mini type-B end of a USB cable to the USB-to-serial receptacle on
  the base board labeled X3 and the type-A end to the USB receptacle on a PC.
Once the USB cable is connected to the board the following LEDs should be
  illuminated:
    LED25  (vbus)
    LED26  (3.3v rail)
PC configuration
Use a PC running Windows XP, Vista or 7 to display runtime diagnostics that can be viewed with a terminal emulation program like Teraterm or Hyperterm. The baud rate in these programs should be set to 9600.
Build and debug the example
LPCXpresso IDE
In the project explorer window of the IDE right click on the Example_MassStorageHost project and select Debug As->C/C++ MCU Application
In the main window of the IDE click Run->Resume to start running the application
Keil uVision 4 IDE
In the Batch Build window, select the project targets as described in Compiler Build Configurations and then click Build
In the main window of the IDE click Debug->Start/Stop Debug Session click Debug->Run
How this example runs and what to look for
When the example is first run the terminal window will display:
Mass Storage Host Demo running.
When a flash drive is plugged in the terminal window will display
  something similar to this:
Device Attached.
Total LUNs: 1 - Using first LUN in device.
Vendor "USB     ", Product "Flash Disk      "
Mass Storage Device Enumerated.
Waiting until ready...
Retrieving Capacity...
1957887 blocks of 512 bytes.
Contents of first block:
33 C0 8E D0 BC 00 7C FB 50 07 50 1F FC BE 1B 7C     3.....|.P.P....|
BF 1B 06 50 57 B9 E5 01 F3 A4 CB BD BE 07 B1 04     ...PW...........
38 6E 00 7C 09 75 13 83 C5 10 E2 F4 CD 18 8B F5     8n.|.u..........
83 C6 10 49 74 19 38 2C 74 F6 A0 B5 07 B4 07 8B     ...It.8,t.......
F0 AC 3C 00 74 FC BB 07 00 B4 0E CD 10 EB F2 88     ..<.t...........
4E 10 E8 46 00 73 2A FE 46 10 80 7E 04 0B 74 0B     N..F.s*.F..~..t.
80 7E 04 0C 74 05 A0 B6 07 75 D2 80 46 02 06 83     .~..t....u..F...
46 08 06 83 56 0A 00 E8 21 00 73 05 A0 B6 07 EB     F...V...!.s.....
BC 81 3E FE 7D 55 AA 74 0B 80 7E 10 00 74 C8 A0     ..>.}U.t..~..t..
B7 07 EB A9 8B FC 1E 57 8B F5 CB BF 05 00 8A 56     .......W.......V
00 B4 08 CD 13 72 23 8A C1 24 3F 98 8A DE 8A FC     .....r#..$?.....
43 F7 E3 8B D1 86 D6 B1 06 D2 EE 42 F7 E2 39 56     C..........B..9V
0A 77 23 72 05 39 46 08 73 1C B8 01 02 BB 00 7C     .w#r.9F.s......|
8B 4E 02 8B 56 00 CD 13 73 51 4F 74 4E 32 E4 8A     .N..V...sQOtN2..
56 00 CD 13 EB E4 8A 56 00 60 BB AA 55 B4 41 CD     V......V.`..U.A.
13 72 36 81 FB 55 AA 75 30 F6 C1 01 74 2B 61 60     .r6..U.u0...t+a`
6A 00 6A 00 FF 76 0A FF 76 08 6A 00 68 00 7C 6A     j.j..v..v.j.h.|j
01 6A 10 B4 42 8B F4 CD 13 61 61 73 0E 4F 74 0B     .j..B....aas.Ot.
32 E4 8A 56 00 CD 13 EB D6 61 F9 C3 49 6E 76 61     2..V.....a..Inva
6C 69 64 20 70 61 72 74 69 74 69 6F 6E 20 74 61     lid partition ta
62 6C 65 00 45 72 72 6F 72 20 6C 6F 61 64 69 6E     ble.Error loadin
67 20 6F 70 65 72 61 74 69 6E 67 20 73 79 73 74     g operating syst
65 6D 00 4D 69 73 73 69 6E 67 20 6F 70 65 72 61     em.Missing opera
74 69 6E 67 20 73 79 73 74 65 6D 00 00 00 00 00     ting system.....
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00     ................
00 00 00 00 00 2C 44 63 18 2E 07 C3 00 00 80 01     .....,Dc........
01 00 06 20 00 77 00 02 00 00 00 DE 1D 00 00 00     ... .w..........
00 00 00 00 00 00 00 00 00 00 00 00 00 00 55 AA     ..............U.
When the flash drive is unplugged the ternimal window will display:
Device Unattached.
%3CLINGO-SUB%20id%3D%22lingo-sub-1125544%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%A4%A7%E5%AE%B9%E9%87%8F%E5%AD%98%E5%82%A8%E4%B8%BB%E6%9C%BA%E7%A4%BA%E4%BE%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1125544%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CH1%20style%3D%22font-size%3A%2026px%3B%20font-weight%3A%20400%3B%20color%3A%20%23333333%3B%20font-family%3A%20Lato%2C%20sans-serif%3B%22%20id%3D%22toc-hId-382485905%22%20id%3D%22toc-hId-1303209590%22%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3E%3CSTRONG%3E%3CBIG%3E%E6%8F%8F%E8%BF%B0%3C%2FBIG%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FH1%3E%3CP%20style%3D%22color%3A%20%23646464%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%20font-size%3A%2012px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3E%E6%AD%A4%E7%A4%BA%E4%BE%8B%E5%AE%9E%E7%8E%B0%E4%BA%86%E5%A4%A7%E5%AE%B9%E9%87%8F%E5%AD%98%E5%82%A8%E7%B1%BB%E4%B8%BB%E6%9C%BA%E6%A8%A1%E5%BC%8F%E8%AE%BE%E5%A4%87%EF%BC%8C%E8%AF%A5%E8%AE%BE%E5%A4%87%E6%9E%9A%E4%B8%BE%E5%A4%A7%E5%AE%B9%E9%87%8F%E5%AD%98%E5%82%A8%E7%B1%BB%E8%AE%BE%E5%A4%87%EF%BC%88USB%20%E9%97%AA%E5%AD%98%E9%A9%B1%E5%8A%A8%E5%99%A8%EF%BC%89%E3%80%82%E5%AE%83%E8%AF%BB%E5%8F%96%E8%AE%BE%E5%A4%87%E7%9A%84%E7%AC%AC%E4%B8%80%E4%B8%AA%E6%89%87%E5%8C%BA%E5%B9%B6%E5%9C%A8%E7%BB%88%E7%AB%AF%E4%B8%8A%E6%98%BE%E7%A4%BA%E8%AF%A5%E6%95%B0%E6%8D%AE%E7%9A%84%E5%8D%81%E5%85%AD%E8%BF%9B%E5%88%B6%E8%BD%AC%E5%82%A8%E6%A0%B7%E5%BC%8F%E5%88%97%E8%A1%A8%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%23646464%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%20font-size%3A%2012px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3E%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FP%3E%3CH1%20style%3D%22font-size%3A%2026px%3B%20font-weight%3A%20400%3B%20color%3A%20%23333333%3B%20font-family%3A%20Lato%2C%20sans-serif%3B%22%20id%3D%22toc-hId--1424968558%22%20id%3D%22toc-hId--504244873%22%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3E%3CBIG%3E%3CSTRONG%3E%E7%BC%96%E8%AF%91%E5%99%A8%E6%9E%84%E5%BB%BA%E9%85%8D%E7%BD%AE%3C%2FSTRONG%3E%3C%2FBIG%3E%3C%2FSPAN%3E%3C%2FH1%3E%3CP%20style%3D%22color%3A%20%23646464%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%20font-size%3A%2012px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3E%E6%9E%84%E6%88%90%E6%AD%A4%E7%A4%BA%E4%BE%8B%E7%9A%84%E8%BD%AF%E4%BB%B6%E8%AE%BE%E8%AE%A1%E7%94%A8%E4%BA%8E%E5%9C%A8%E8%AE%B8%E5%A4%9A%E4%B8%8D%E5%90%8C%E7%9A%84%E5%BC%80%E5%8F%91%E6%9D%BF%E4%B8%8A%E8%BF%90%E8%A1%8C%E3%80%82%E5%9B%A0%E6%AD%A4%EF%BC%8C%E5%BF%85%E9%A1%BB%E9%85%8D%E7%BD%AE%E7%BC%96%E8%AF%91%E5%99%A8%E6%9D%A5%E6%9E%84%E5%BB%BA%E9%92%88%E5%AF%B9%E6%82%A8%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8%E7%9A%84%E5%BC%80%E5%8F%91%E6%9D%BF%E7%9A%84%E5%9B%BE%E5%83%8F%E3%80%82%E6%9C%AC%E8%8A%82%E4%BB%8B%E7%BB%8D%E5%A6%82%E4%BD%95%E4%B8%BA%E6%AF%8F%E4%B8%AA%E6%94%AF%E6%8C%81%E7%9A%84%E7%BC%96%E8%AF%91%E5%99%A8%E8%AE%BE%E7%BD%AE%E8%BF%99%E4%BA%9B%E6%9E%84%E5%BB%BA%E9%85%8D%E7%BD%AE%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%20color%3A%20%23646464%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%20font-size%3A%2012px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3E%20%3C%2FSPAN%3E%26nbsp%3B%3C%2FP%3E%3CH2%20style%3D%22font-family%3A%20Lato%2C%20sans-serif%3B%20color%3A%20%23e66e08%3B%20font-size%3A%2018px%3B%20background%3A%200%2050%25%20%23ffffff%3B%22%20id%3D%22toc-hId--734407084%22%20id%3D%22toc-hId-186316601%22%3E%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%20font-family%3A%20helvetica%3B%22%3ELPCXpresso%20IDE%3C%2FSPAN%3E%3C%2FH2%3E%3CP%20style%3D%22color%3A%20%23646464%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%20font-size%3A%2012px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3E%20%3CSTRONG%3E%E9%85%8D%E7%BD%AE%E9%A1%B9%E7%9B%AE%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%23646464%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%20font-size%3A%2012px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3E%E5%9C%A8%E9%A1%B9%E7%9B%AE%E8%B5%84%E6%BA%90%E7%AE%A1%E7%90%86%E5%99%A8%E7%AA%97%E5%8F%A3%E4%B8%AD%E5%8F%B3%E9%94%AE%E5%8D%95%E5%87%BB%20BSP%20%E9%A1%B9%E7%9B%AE%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3E%E7%82%B9%E5%87%BBBuild%20Configurations-%26gt%3BSet%20Active-%26gt%3B%EF%BC%88%E8%A7%81%E4%B8%8B%E8%A1%A8%E9%85%8D%E7%BD%AE%EF%BC%89%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3E%E4%BD%BF%E7%94%A8%20CDL%E3%80%81nxpUSBlib%20%E5%92%8C%20Example_MassStorageHost%20%E9%87%8D%E5%A4%8D%E8%BF%99%E4%BA%9B%E6%AD%A5%E9%AA%A4%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3E%20%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3E%3CSTRONG%3E%E9%85%8D%E7%BD%AE%20MCU%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3E%E5%9C%A8%E9%A1%B9%E7%9B%AE%E8%B5%84%E6%BA%90%E7%AE%A1%E7%90%86%E5%99%A8%E7%AA%97%E5%8F%A3%E4%B8%AD%E5%8F%B3%E9%94%AE%E5%8D%95%E5%87%BB%20Example_MassStorageHost%20%E9%A1%B9%E7%9B%AE%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3E%E7%82%B9%E5%87%BB%E5%B1%9E%E6%80%A7-%26gt%3BC%2FC%2B%2B%20Build-%26gt%3BMCU%E8%AE%BE%E7%BD%AE-%26gt%3B%EF%BC%88%E8%A7%81%E4%B8%8B%E8%A1%A8%E9%85%8D%E7%BD%AE%EF%BC%89%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3E%20%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3E%3CSTRONG%3E%E9%85%8D%E7%BD%AE%E7%B4%A2%E5%BC%95%E5%99%A8%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3E%E5%8D%95%E5%87%BB%E7%AA%97%E5%8F%A3-%26gt%3B%E9%A6%96%E9%80%89%E9%A1%B9-%26gt%3BC%2FC%2B%2B-%26gt%3B%E7%B4%A2%E5%BC%95%E5%99%A8-%26gt%3B%E4%BD%BF%E7%94%A8%E6%B4%BB%E5%8A%A8%E6%9E%84%E5%BB%BA%E9%85%8D%E7%BD%AE%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%20color%3A%20%23646464%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%20font-size%3A%2012px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3E%20%3C%2FSPAN%3E%26nbsp%3B%3C%2FP%3E%3CDIV%20class%3D%22j-rte-table%22%3E%3CTABLE%20border%3D%221%22%20cellpadding%3D%222%22%20cellspacing%3D%228%22%20style%3D%22border-width%3A%200px%3B%20color%3A%20%23646464%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%20font-size%3A%2012px%3B%22%3E%3CTBODY%20style%3D%22border-top-color%3A%20%23cccccc%3B%22%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%20%23ffcc99%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%20valign%3D%22middle%22%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3E%20%3C%2FSPAN%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%20%23ffcc99%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%20valign%3D%22middle%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3EBSP%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%20%23ffcc99%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%20valign%3D%22middle%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3ECDL%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%20%23ffcc99%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%20valign%3D%22middle%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3EnxpUSBlib%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%20%23ffcc99%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3E%E7%A4%BA%E4%BE%8B_%E5%A4%A7%E5%AE%B9%E9%87%8F%E5%AD%98%E5%82%A8%E8%AE%BE%E5%A4%87%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%20%23ffcc99%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%20valign%3D%22middle%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3EMCU%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%20%23ffcc99%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%20valign%3D%22middle%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3ELPC1850%26nbsp%3B%20%2F%20Hitex%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%20valign%3D%22middle%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3ELPC18xx_HITEX%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%20valign%3D%22middle%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3ELPC18xx%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%20valign%3D%22middle%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3ELPC18xx_Host%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%20valign%3D%22middle%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3ELPC18xx%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%20valign%3D%22middle%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3ELPC1850%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%20%23ffcc99%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%20valign%3D%22middle%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3ELPC4330%26nbsp%3B%20%2F%20Xplorer%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%20valign%3D%22middle%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3ELPC4330_Xplorer%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%20valign%3D%22middle%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3ELPC18xx%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%20valign%3D%22middle%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3ELPC18xx_Host%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%20valign%3D%22middle%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3ELPC18xx%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%20valign%3D%22middle%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3ELPC4330%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%20%23ffcc99%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%20valign%3D%22middle%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3ELPC4350%26nbsp%3B%20%2F%20Element14%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%20valign%3D%22middle%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3ELPC1435_ELEMENT14%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%20valign%3D%22middle%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3ELPC18xx%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%20valign%3D%22middle%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3ELPC18xx_Host%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3ELPC18xx%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%20valign%3D%22middle%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3ELPC4350%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%20%23ffcc99%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%20valign%3D%22middle%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3ELPC1768%2FMCB1700%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%20valign%3D%22middle%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3ELPC1768_MCB1700%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%20valign%3D%22middle%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3ELPC17xx%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%20valign%3D%22middle%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3ELPC17xx_Host%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3ELPC17xx%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%20valign%3D%22middle%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3ELPC1768%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%20%23ffcc99%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%20valign%3D%22middle%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3ELPC1768%26nbsp%3B%20%2F%20LPCXpresso%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%20valign%3D%22middle%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3ELPC17xx_LPCXpressoRevB%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%20valign%3D%22middle%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3ELPC17xx%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%20valign%3D%22middle%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3ELPC17xx_Host%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%20valign%3D%22middle%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3ELPC17xx%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%20valign%3D%22middle%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3ELPC1768%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3C%2FDIV%3E%3CP%20style%3D%22color%3A%20%23646464%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%20font-size%3A%2012px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3E%3CSPAN%20style%3D%22font-weight%3A%20bold%3B%22%3E%3CBR%20%2F%3E%E6%B3%A8%E6%84%8F%EF%BC%9A%3C%2FSPAN%3E%20LPC18xx%20CDL%20%E4%B8%8E%E8%A3%85%E6%9C%89%20LPC43xx%20%E9%83%A8%E4%BB%B6%E7%9A%84%E7%94%B5%E8%B7%AF%E6%9D%BF%E4%B8%80%E8%B5%B7%E4%BD%BF%E7%94%A8%E3%80%82%E8%BF%99%E6%A0%B7%E5%81%9A%E6%98%AF%E5%9B%A0%E4%B8%BA%20LPC43xx%20CDL%20%E7%9B%AE%E5%89%8D%E5%A4%84%E4%BA%8E%E5%AE%9E%E9%AA%8C%E9%98%B6%E6%AE%B5%E3%80%82%E4%BD%BF%E7%94%A8%20LPC18xx%20USB%20%E5%BA%93%E6%98%AF%E5%9B%A0%E4%B8%BA%E4%B8%A4%E4%B8%AA%E9%83%A8%E5%88%86%E5%85%B1%E4%BA%AB%E7%9B%B8%E5%90%8C%E7%9A%84%E6%8E%A7%E5%88%B6%E5%99%A8%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CH2%20style%3D%22font-family%3A%20Lato%2C%20sans-serif%3B%20color%3A%20%23e66e08%3B%20font-size%3A%2018px%3B%20background%3A%200%2050%25%20%23ffffff%3B%22%20id%3D%22toc-hId-1753105749%22%20id%3D%22toc-hId--1621137862%22%3E%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%20font-family%3A%20helvetica%3B%22%3EKeil%20uVision%204%20IDE%3C%2FSPAN%3E%3C%2FH2%3E%3CP%20style%3D%22color%3A%20%23646464%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%20font-size%3A%2012px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3E%20%3CSTRONG%3E%E9%85%8D%E7%BD%AE%E6%89%B9%E9%87%8F%E6%9E%84%E5%BB%BA%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3E%E7%82%B9%E5%87%BB%E9%A1%B9%E7%9B%AE-%26gt%3B%E6%89%B9%E9%87%8F%E6%9E%84%E5%BB%BA...%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3E%E5%B1%95%E5%BC%80%20BSP%20%E9%A1%B9%E7%9B%AE%E4%BB%A5%E6%98%BE%E7%A4%BA%E9%A1%B9%E7%9B%AE%E7%9B%AE%E6%A0%87%E5%88%97%E8%A1%A8%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3E%E9%80%9A%E8%BF%87%E9%80%89%E4%B8%AD%E7%9B%B8%E5%BA%94%E7%9A%84%E5%A4%8D%E9%80%89%E6%A1%86%E6%9D%A5%E9%80%89%E6%8B%A9%E9%A1%B9%E7%9B%AE%E7%9B%AE%E6%A0%87%EF%BC%88%E8%AF%B7%E5%8F%82%E9%98%85%E4%B8%8B%E8%A1%A8%E4%B8%AD%E7%9A%84%E7%9B%AE%E6%A0%87%E5%88%97%E8%A1%A8%EF%BC%89%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3E%E4%BD%BF%E7%94%A8%20CDL%E3%80%81nxpUSBlib_Host%20%E5%92%8C%20Example_MassStorageDevice%20%E9%87%8D%E5%A4%8D%E8%BF%99%E4%BA%9B%E6%AD%A5%E9%AA%A4%3C%2FSPAN%3E%3C%2FP%3E%3CDIV%20class%3D%22j-rte-table%22%3E%3CTABLE%20border%3D%221%22%20cellpadding%3D%222%22%20cellspacing%3D%228%22%20style%3D%22border-width%3A%200px%3B%20color%3A%20%23646464%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%20font-size%3A%2012px%3B%22%3E%3CTBODY%20style%3D%22border-top-color%3A%20%23cccccc%3B%22%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%20%23ffcc99%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3E%20%3C%2FSPAN%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%20%23ffcc99%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3EBSP%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%20%23ffcc99%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3ECDL%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%20%23ffcc99%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3EnxpUSBlib_Host%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%20%23ffcc99%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3E%E7%A4%BA%E4%BE%8B_%E5%A4%A7%E5%AE%B9%E9%87%8F%E5%AD%98%E5%82%A8%E8%AE%BE%E5%A4%87%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%20%23ffcc99%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3ELPC1850%26nbsp%3B%20%2F%20Hitex%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3EHITEX1800%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3ELPC18xx%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3ELPC18xx_Host%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3EHITEX1800%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%20%23ffcc99%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3ELPC1768%2FMCB1700%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3EMCB1700%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3ELPC17xx%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3ELPC17xx_Host%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3EMCB1700%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3C%2FDIV%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%20color%3A%20%23646464%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%20font-size%3A%2012px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3E%20%3C%2FSPAN%3E%26nbsp%3B%3C%2FP%3E%3CH1%20style%3D%22font-size%3A%2026px%3B%20font-weight%3A%20400%3B%20color%3A%20%23333333%3B%20font-family%3A%20Lato%2C%20sans-serif%3B%22%20id%3D%22toc-hId-1742602645%22%20id%3D%22toc-hId--1631640966%22%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3E%3CBIG%3E%3CSTRONG%3E%E7%94%B5%E8%B7%AF%E6%9D%BF%E8%BF%9E%E6%8E%A5%E5%92%8C%E9%85%8D%E7%BD%AE%3C%2FSTRONG%3E%3C%2FBIG%3E%3C%2FSPAN%3E%3C%2FH1%3E%3CH2%20style%3D%22font-family%3A%20Lato%2C%20sans-serif%3B%20color%3A%20%23e66e08%3B%20font-size%3A%2018px%3B%20background%3A%200%2050%25%20%23ffffff%3B%22%20id%3D%22toc-hId--1861803177%22%20id%3D%22toc-hId--941079492%22%3E%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%20font-family%3A%20helvetica%3B%22%3ELPC18xx_HITEX%EF%BC%88LPC1850%20Hitex%20%E8%AF%84%E4%BC%B0%E6%9D%BF%EF%BC%89%E6%97%A7%E6%AC%BE%20A2%20%E8%AE%BE%E8%AE%A1%3C%2FSPAN%3E%3C%2FH2%3E%3CP%20style%3D%22color%3A%20%23646464%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%20font-size%3A%2012px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3E%3CSPAN%20style%3D%22font-weight%3A%20bold%3B%22%3E%E5%8E%9F%E7%90%86%E5%9B%BE%3C%2FSPAN%3E.%2FBSP%2Fschematics%2FHITEX_SCM_LPC1850EVA-A2-2.pdf%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3E%20%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3E%E5%B0%86%20JTAG%20%E8%BF%9E%E6%8E%A5%E5%88%B0%E6%A0%87%E6%9C%89%20X4%20JTAG%20%E7%9A%84%2020%20%E9%92%88%E6%8F%92%E5%BA%A7%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3E%E5%B0%86%20USB%20%E9%97%AA%E5%AD%98%E9%A9%B1%E5%8A%A8%E5%99%A8%E8%BF%9E%E6%8E%A5%E5%88%B0%E6%A0%87%E6%9C%89%20X10%20%E7%9A%84%20A%20%E5%9E%8B%E6%8F%92%E5%BA%A7%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3E%E5%B0%86%209%20%E9%92%88%E4%B8%B2%E8%A1%8C%E7%94%B5%E7%BC%86%E8%BF%9E%E6%8E%A5%E5%88%B0%E6%A0%87%E6%9C%89%20UART%20X1%20%E7%9A%84%E6%8F%92%E5%BA%A7%E3%80%82%E5%B0%86%E8%AF%A5%E7%94%B5%E7%BC%86%E7%9A%84%E5%8F%A6%E4%B8%80%E7%AB%AF%E8%BF%9E%E6%8E%A5%E5%88%B0%E8%BF%90%E8%A1%8C%E7%BB%88%E7%AB%AF%E7%A8%8B%E5%BA%8F%E7%9A%84%20PC%E3%80%82%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3E%E4%B8%BA%E7%94%B5%E8%B7%AF%E6%9D%BF%E4%BE%9B%E7%94%B5%EF%BC%9A%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3E%E5%B0%86%E6%9C%89%E6%BA%90%20USB%20%E7%94%B5%E7%BC%86%E7%9A%84%20B%20%E5%9E%8B%E7%AB%AF%E8%BF%9E%E6%8E%A5%E5%88%B0%E6%A0%87%E6%9C%89%20X13%20%E7%9A%84%E6%8F%92%E5%BA%A7%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3E%E6%88%96%E8%80%85%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3E%E5%90%91%E6%A0%87%E6%9C%89%20X14%20%E7%9A%84%E7%9B%B4%E6%B5%81%E8%BF%9E%E6%8E%A5%E5%99%A8%E6%8F%90%E4%BE%9B%205V%20%E7%94%B5%E6%BA%90%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%20color%3A%20%23646464%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%20font-size%3A%2012px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3E%20%3C%2FSPAN%3E%26nbsp%3B%3C%2FP%3E%3CH2%20style%3D%22font-family%3A%20Lato%2C%20sans-serif%3B%20color%3A%20%23e66e08%3B%20font-size%3A%2018px%3B%20background%3A%200%2050%25%20%23ffffff%3B%22%20id%3D%22toc-hId-625709656%22%20id%3D%22toc-hId-1546433341%22%3E%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%20font-family%3A%20helvetica%3B%22%3ELPC18xx_HITEX%EF%BC%88LPC1850%20Hitex%20%E8%AF%84%E4%BC%B0%E6%9D%BF%EF%BC%89%E8%BE%83%E6%96%B0%E7%9A%84%20A3%20%E8%AE%BE%E8%AE%A1%3C%2FSPAN%3E%3C%2FH2%3E%3CP%20style%3D%22color%3A%20%23646464%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%20font-size%3A%2012px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3E%20%3CSPAN%20style%3D%22font-weight%3A%20bold%3B%22%3E%E5%8E%9F%E7%90%86%E5%9B%BE%3C%2FSPAN%3E.%2FBSP%2Fschematics%2FHITEX_Final_LPC1850EVA-A3.pdf%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%20color%3A%20%23646464%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%20font-size%3A%2012px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3E%20%3C%2FSPAN%3E%26nbsp%3B%3C%2FP%3E%3CH2%20style%3D%22font-family%3A%20Lato%2C%20sans-serif%3B%20color%3A%20%23e66e08%3B%20font-size%3A%2018px%3B%20text-decoration%3A%20underline%3B%20background%3A%200%2050%25%20%23ffffff%3B%22%20id%3D%22toc-hId--1181744807%22%20id%3D%22toc-hId--261021122%22%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3ELPC1768_MCB1700%EF%BC%88Keil%20MCB1700%E5%BC%80%E5%8F%91%E6%9D%BF%EF%BC%89%3C%2FSPAN%3E%3C%2FH2%3E%3CP%20style%3D%22color%3A%20%23646464%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%20font-size%3A%2012px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3E%3CSPAN%20style%3D%22font-weight%3A%20bold%3B%22%3E%E5%8E%9F%E7%90%86%E5%9B%BE%EF%BC%9A%3C%2FSPAN%3E%20.%2FBSP%2Fschematics%2Fmcb1700-schematics.pdf%3C%2FSPAN%3E%3C%2FP%3E%3CDIV%20class%3D%22j-rte-table%22%3E%3CTABLE%20border%3D%221%22%20cellpadding%3D%222%22%20cellspacing%3D%222%22%20style%3D%22border-width%3A%200px%3B%20color%3A%20%23646464%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%20font-size%3A%2012px%3B%22%3E%3CTBODY%20style%3D%22border-top-color%3A%20%23cccccc%3B%22%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%20%23ffcc99%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3E%E8%B7%B3%E7%BA%BF%3C%2FSPAN%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%20%23ffcc99%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3E%E8%AE%BE%E7%BD%AE%3C%2FSPAN%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3E%26nbsp%3B%20E%2FU%3C%2FSPAN%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3E1-2%3C%2FSPAN%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3EUMODE%3C%2FSPAN%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3E1-2%3C%2FSPAN%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3ED-%3C%2FSPAN%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3E%E4%B8%BB%E6%9C%BA%3C%2FSPAN%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3ED%2B%3C%2FSPAN%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3E%E4%B8%BB%E6%9C%BA%3C%2FSPAN%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3EVBUS%3C%2FSPAN%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3E1-2%3C%2FSPAN%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3EVDDIO%3C%2FSPAN%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3E1-2%3C%2FSPAN%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3EVDDREG%3C%2FSPAN%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3E1-2%3C%2FSPAN%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3EISP%3C%2FSPAN%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3E%E5%B7%B2%E5%88%A0%E9%99%A4%3C%2FSPAN%3E%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3C%2FDIV%3E%3CP%20style%3D%22color%3A%20%23646464%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%20font-size%3A%2012px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3E%E5%B0%86%20JTAG%20%E8%B0%83%E8%AF%95%E5%99%A8%E8%BF%9E%E6%8E%A5%E5%88%B0%2020%20%E9%92%88%20JTAG%20%E6%88%96%2010%20%E9%92%88%20Cortex%20%E8%B0%83%E8%AF%95%E8%BF%9E%E6%8E%A5%E5%99%A8%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3E%E4%BD%BF%E7%94%A8%209%20%E9%92%88%E4%B8%B2%E8%A1%8C%E7%94%B5%E7%BC%86%E8%BF%9E%E6%8E%A5%E5%BC%80%E5%8F%91%E6%9D%BF%E7%9A%84%20COM0%20%E5%92%8C%E8%BF%90%E8%A1%8C%E7%BB%88%E7%AB%AF%E7%A8%8B%E5%BA%8F%E7%9A%84%20PC%E3%80%82%E6%B3%A2%E7%89%B9%E7%8E%87%20%3D%209600%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3E%E5%B0%86%20USB%20%E9%97%AA%E5%AD%98%E7%9B%98%E6%8F%92%E5%85%A5%E6%A0%87%E6%9C%89%20HOST%20%E7%9A%84%20A%20%E5%9E%8B%E6%8F%92%E5%BA%A7%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3E%E4%B8%BA%E7%94%B5%E8%B7%AF%E6%9D%BF%E4%BE%9B%E7%94%B5%EF%BC%9A%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3E%E5%B0%86%E6%9C%89%E6%BA%90%20USB%20%E7%BA%BF%E7%BC%86%E7%9A%84%20B%20%E5%9E%8B%E7%AB%AF%E8%BF%9E%E6%8E%A5%E5%88%B0%E6%A0%87%E6%9C%89%E2%80%9C%E8%AE%BE%E5%A4%87%E2%80%9D%E7%9A%84%20B%20%E5%9E%8B%E6%8F%92%E5%BA%A7%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3E%E6%88%96%E8%80%85%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3E%E4%B8%BA%20JTAG%20%E5%92%8C%20COM0%20%E6%8F%92%E5%BA%A7%E4%B9%8B%E9%97%B4%E7%9A%84%20-VIN%2B%20%E5%BC%95%E8%84%9A%E6%8F%90%E4%BE%9B%205v%20%E7%94%B5%E5%8E%8B%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3E%E4%B8%80%E6%97%A6%E7%94%B5%E8%B7%AF%E6%9D%BF%E9%80%9A%E7%94%B5%EF%BC%8C%E4%BB%A5%E4%B8%8B%20LED%20%E5%B0%B1%E4%BC%9A%E4%BA%AE%E8%B5%B7%EF%BC%9A%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3E%E5%8A%9B%E9%87%8F%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3E100%E5%85%86%E8%B5%AB%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3E%E5%8D%97%E5%8A%A0%E5%B7%9E%E5%A4%A7%E5%AD%A6%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%20color%3A%20%23646464%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%20font-size%3A%2012px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3E%20%3C%2FSPAN%3E%26nbsp%3B%3C%2FP%3E%3CH2%20style%3D%22font-family%3A%20Lato%2C%20sans-serif%3B%20color%3A%20%23e66e08%3B%20font-size%3A%2018px%3B%20text-decoration%3A%20underline%3B%20background%3A%200%2050%25%20%23ffffff%3B%22%20id%3D%22toc-hId-1305768026%22%20id%3D%22toc-hId--2068475585%22%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3ELPC17xx_LPCXpressoRevB%EF%BC%88LPCXpresso%20Rev%20B%20%E5%9F%BA%E6%9D%BF%E4%B8%8A%E7%9A%84%20LPCXpresso%20LPC17xx%EF%BC%89%3C%2FSPAN%3E%3C%2FH2%3E%3CP%20style%3D%22color%3A%20%23646464%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%20font-size%3A%2012px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3E%3CSPAN%20style%3D%22font-weight%3A%20bold%3B%22%3E%E5%8E%9F%E7%90%86%E5%9B%BE%EF%BC%9A%3C%2FSPAN%3E%20.%2FBSP%2Fschematics%2FLPCXpressoLPC1769revB.pdf%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3E%E5%B0%86%20LPCXpresso%20LPC1769%20%E6%9D%BF%E6%8F%92%E5%85%A5%E6%A0%87%E6%9C%89%20J4%20%E7%9A%84%E8%BF%9E%E6%8E%A5%E5%99%A8%E4%B8%8A%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3ELPCXpresso%E5%9F%BA%E6%9D%BF%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3E%E5%B0%86%20JTAG%20%E8%BF%9E%E6%8E%A5%E5%88%B0%20LPCXpresso%20LPC1769%20%E4%B8%8A%E6%A0%87%E6%9C%89%20J3%20%E7%9A%84%20mini%20USB%20%E6%8F%92%E5%BA%A7%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3E%E6%9C%A8%E6%9D%BF%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3E%E6%A0%B9%E6%8D%AE%20Embedded%20Artists%20%E7%9A%84%E7%94%A8%E6%88%B7%E6%8C%87%E5%8D%97%E9%85%8D%E7%BD%AE%E5%9F%BA%E6%9D%BF%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3E%E5%9C%A8%E5%BA%95%E6%9D%BF%E4%B8%8A%E6%A0%87%E6%9C%89%20J61%20%E7%9A%84%E8%B7%B3%E7%BA%BF%E5%9D%97%E4%B8%8A%E5%AE%89%E8%A3%85%E8%B7%B3%E7%BA%BF%201-2%E3%80%813-4%E3%80%815-6%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3E%E5%B0%86%20USB%20%E9%97%AA%E5%AD%98%E9%A9%B1%E5%8A%A8%E5%99%A8%E6%8F%92%E5%85%A5%E5%BA%95%E6%9D%BF%E4%B8%8A%E6%A0%87%E6%9C%89%20J60%20%E7%9A%84%20A%20%E5%9E%8B%E6%8F%92%E5%BA%A7%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3E%E5%B0%86%20USB%20%E7%94%B5%E7%BC%86%E7%9A%84%E8%BF%B7%E4%BD%A0%20B%20%E5%9E%8B%E7%AB%AF%E8%BF%9E%E6%8E%A5%E5%88%B0%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3E%E5%B0%86%E6%A0%87%E6%9C%89%20X3%20%E7%9A%84%E5%9F%BA%E6%9D%BF%E5%92%8C%20A%20%E5%9E%8B%E7%AB%AF%E8%BF%9E%E6%8E%A5%E5%88%B0%20PC%20%E4%B8%8A%E7%9A%84%20USB%20%E6%8F%92%E5%BA%A7%E3%80%82%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3E%E4%B8%80%E6%97%A6%20USB%20%E7%94%B5%E7%BC%86%E8%BF%9E%E6%8E%A5%E5%88%B0%E5%BC%80%E5%8F%91%E6%9D%BF%EF%BC%8C%E4%BB%A5%E4%B8%8B%20LED%20%E5%BA%94%E8%AF%A5%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3E%E4%BA%AE%E8%B5%B7%EF%BC%9A%3C%2FSPAN%3E%3CBR%20%2F%3E%20%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3ELED25%EF%BC%88%E7%94%B5%E6%BA%90%E6%80%BB%E7%BA%BF%EF%BC%89%3C%2FSPAN%3E%3CBR%20%2F%3E%20%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3ELED26%EF%BC%883.3V%20%E5%AF%BC%E8%BD%A8%EF%BC%89%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%20color%3A%20%23646464%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%20font-size%3A%2012px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3E%20%3C%2FSPAN%3E%26nbsp%3B%3C%2FP%3E%3CH1%20style%3D%22font-size%3A%2026px%3B%20font-weight%3A%20400%3B%20color%3A%20%23333333%3B%20font-family%3A%20Lato%2C%20sans-serif%3B%22%20id%3D%22toc-hId-1295264922%22%20id%3D%22toc-hId--2078978689%22%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3E%3CSTRONG%3E%3CBIG%3EPC%E9%85%8D%E7%BD%AE%3C%2FBIG%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FH1%3E%3CP%20style%3D%22color%3A%20%23646464%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%20font-size%3A%2012px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3E%E4%BD%BF%E7%94%A8%E8%BF%90%E8%A1%8C%20Windows%20XP%E3%80%81Vista%20%E6%88%96%207%20%E7%9A%84%20PC%20%E6%98%BE%E7%A4%BA%E5%8F%AF%E4%BD%BF%E7%94%A8%20Teraterm%20%E6%88%96%20Hyperterm%20%E7%AD%89%E7%BB%88%E7%AB%AF%E4%BB%BF%E7%9C%9F%E7%A8%8B%E5%BA%8F%E6%9F%A5%E7%9C%8B%E7%9A%84%E8%BF%90%E8%A1%8C%E6%97%B6%E8%AF%8A%E6%96%AD%E3%80%82%E8%BF%99%E4%BA%9B%E7%A8%8B%E5%BA%8F%E4%B8%AD%E7%9A%84%E6%B3%A2%E7%89%B9%E7%8E%87%E5%BA%94%E8%AE%BE%E7%BD%AE%E4%B8%BA%209600%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%20color%3A%20%23646464%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%20font-size%3A%2012px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3E%20%3C%2FSPAN%3E%26nbsp%3B%3C%2FP%3E%3CH1%20style%3D%22font-size%3A%2026px%3B%20font-weight%3A%20400%3B%20color%3A%20%23333333%3B%20font-family%3A%20Lato%2C%20sans-serif%3B%22%20id%3D%22toc-hId--764453880%22%20id%3D%22toc-hId-156269805%22%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3E%3CBIG%3E%3CSTRONG%3E%E6%9E%84%E5%BB%BA%E5%B9%B6%E8%B0%83%E8%AF%95%E7%A4%BA%E4%BE%8B%3C%2FSTRONG%3E%3C%2FBIG%3E%3C%2FSPAN%3E%3C%2FH1%3E%3CH2%20style%3D%22font-family%3A%20Lato%2C%20sans-serif%3B%20color%3A%20%23e66e08%3B%20font-size%3A%2018px%3B%20background%3A%200%2050%25%20%23ffffff%3B%22%20id%3D%22toc-hId-1852141672%22%20id%3D%22toc-hId--1522101939%22%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%20font-family%3A%20helvetica%3B%22%3ELPCXpresso%20IDE%3C%2FSPAN%3E%3C%2FH2%3E%3CP%20style%3D%22color%3A%20%23646464%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%20font-size%3A%2012px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3E%E5%9C%A8%20IDE%20%E7%9A%84%E9%A1%B9%E7%9B%AE%E8%B5%84%E6%BA%90%E7%AE%A1%E7%90%86%E5%99%A8%E7%AA%97%E5%8F%A3%E4%B8%AD%EF%BC%8C%E5%8F%B3%E9%94%AE%E5%8D%95%E5%87%BB%20Example_MassStorageHost%20%E9%A1%B9%E7%9B%AE%E5%B9%B6%E9%80%89%E6%8B%A9%20Debug%20As-%26gt%3BC%2FC%2B%2B%20MCU%20Application%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3E%E5%9C%A8%20IDE%20%E4%B8%BB%E7%AA%97%E5%8F%A3%E4%B8%AD%E5%8D%95%E5%87%BB%20Run-%26gt%3BResume%20%E5%BC%80%E5%A7%8B%E8%BF%90%E8%A1%8C%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%20color%3A%20%23646464%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%20font-size%3A%2012px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3E%20%3C%2FSPAN%3E%26nbsp%3B%3C%2FP%3E%3CH2%20style%3D%22font-family%3A%20Lato%2C%20sans-serif%3B%20color%3A%20%23e66e08%3B%20font-size%3A%2018px%3B%20background%3A%200%2050%25%20%23ffffff%3B%22%20id%3D%22toc-hId-44687209%22%20id%3D%22toc-hId-965410894%22%3E%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%20font-family%3A%20helvetica%3B%22%3EKeil%20uVision%204%20IDE%3C%2FSPAN%3E%3C%2FH2%3E%3CP%20style%3D%22color%3A%20%23646464%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%20font-size%3A%2012px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3E%E5%9C%A8%E6%89%B9%E9%87%8F%E6%9E%84%E5%BB%BA%E7%AA%97%E5%8F%A3%E4%B8%AD%EF%BC%8C%E6%8C%89%E7%85%A7%E7%BC%96%E8%AF%91%E5%99%A8%E6%9E%84%E5%BB%BA%E9%85%8D%E7%BD%AE%E4%B8%AD%E7%9A%84%E8%AF%B4%E6%98%8E%E9%80%89%E6%8B%A9%E9%A1%B9%E7%9B%AE%E7%9B%AE%E6%A0%87%EF%BC%8C%E7%84%B6%E5%90%8E%E5%8D%95%E5%87%BB%E6%9E%84%E5%BB%BA%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3E%E5%9C%A8%20IDE%20%E4%B8%BB%E7%AA%97%E5%8F%A3%E4%B8%AD%E5%8D%95%E5%87%BB%E2%80%9C%E8%B0%83%E8%AF%95%E2%80%9D-%26gt%3B%E2%80%9C%E5%90%AF%E5%8A%A8%2F%E5%81%9C%E6%AD%A2%E8%B0%83%E8%AF%95%E4%BC%9A%E8%AF%9D%E2%80%9D%EF%BC%8C%E5%8D%95%E5%87%BB%E2%80%9C%E8%B0%83%E8%AF%95%E2%80%9D-%26gt%3B%E2%80%9C%E8%BF%90%E8%A1%8C%E2%80%9D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%20color%3A%20%23646464%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%20font-size%3A%2012px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3E%20%3C%2FSPAN%3E%26nbsp%3B%3C%2FP%3E%3CH1%20style%3D%22font-size%3A%2026px%3B%20font-weight%3A%20400%3B%20color%3A%20%23333333%3B%20font-family%3A%20Lato%2C%20sans-serif%3B%22%20id%3D%22toc-hId--1891849973%22%20id%3D%22toc-hId--971126288%22%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3E%3CBIG%3E%3CSTRONG%3E%E6%AD%A4%E7%A4%BA%E4%BE%8B%E5%A6%82%E4%BD%95%E8%BF%90%E8%A1%8C%E4%BB%A5%E5%8F%8A%E8%A6%81%E6%9F%A5%E6%89%BE%E7%9A%84%E5%86%85%E5%AE%B9%3C%2FSTRONG%3E%3C%2FBIG%3E%3C%2FSPAN%3E%3C%2FH1%3E%3CP%20style%3D%22color%3A%20%23646464%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%20font-size%3A%2012px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3E%E9%A6%96%E6%AC%A1%E8%BF%90%E8%A1%8C%E7%A4%BA%E4%BE%8B%E6%97%B6%EF%BC%8C%E7%BB%88%E7%AB%AF%E7%AA%97%E5%8F%A3%E5%B0%86%E6%98%BE%E7%A4%BA%EF%BC%9A%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3E%E5%A4%A7%E5%AE%B9%E9%87%8F%E5%AD%98%E5%82%A8%E4%B8%BB%E6%9C%BA%E6%BC%94%E7%A4%BA%E6%AD%A3%E5%9C%A8%E8%BF%90%E8%A1%8C%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3E%E5%BD%93%E9%97%AA%E5%AD%98%E9%A9%B1%E5%8A%A8%E5%99%A8%E6%8F%92%E5%85%A5%E7%BB%88%E7%AB%AF%E7%AA%97%E5%8F%A3%E6%97%B6%E5%B0%86%E6%98%BE%E7%A4%BA%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3E%E7%B1%BB%E4%BC%BC%E8%BF%99%E6%A0%B7%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3E%E8%AE%BE%E5%A4%87%E5%B7%B2%E8%BF%9E%E6%8E%A5%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3ELUN%20%E6%80%BB%E6%95%B0%EF%BC%9A1%20-%20%E4%BD%BF%E7%94%A8%E8%AE%BE%E5%A4%87%E4%B8%AD%E7%9A%84%E7%AC%AC%E4%B8%80%E4%B8%AA%20LUN%E3%80%82%3C%2FSPAN%3E%3CBR%20style%3D%22font-family%3A%20monospace%3B%22%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3E%E4%BE%9B%E5%BA%94%E5%95%86%E2%80%9CUSB%E2%80%9D%EF%BC%8C%E4%BA%A7%E5%93%81%E2%80%9C%E9%97%AA%E5%AD%98%E7%9B%98%E2%80%9D%3C%2FSPAN%3E%3CBR%20style%3D%22font-family%3A%20monospace%3B%22%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3E%E5%B7%B2%E6%9E%9A%E4%B8%BE%E5%A4%A7%E5%AE%B9%E9%87%8F%E5%AD%98%E5%82%A8%E8%AE%BE%E5%A4%87%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3E%E7%AD%89%E5%BE%85%E5%87%86%E5%A4%87%E5%A5%BD...%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3E%E6%AD%A3%E5%9C%A8%E6%A3%80%E7%B4%A2%E5%AE%B9%E9%87%8F...%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3E1957887%20%E4%B8%AA%20512%20%E5%AD%97%E8%8A%82%E7%9A%84%E5%9D%97%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3E%E7%AC%AC%E4%B8%80%E4%B8%AA%E5%8C%BA%E5%9D%97%E7%9A%84%E5%86%85%E5%AE%B9%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3E33%20C0%208E%20D0%20BC%2000%207C%20FB%2050%2007%2050%201F%20FC%20BE%201B%207C%203.....%7C.PP...%7C%3C%2FSPAN%3E%3CBR%20style%3D%22font-family%3A%20monospace%3B%22%20%2F%3E%20%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3EBF%201B%2006%2050%2057%20B9%20E5%2001%20F3%20A4%20CB%20BD%20BE%2007%20B1%2004%20...PW...........%3C%2FSPAN%3E%3CBR%20style%3D%22font-family%3A%20monospace%3B%22%20%2F%3E%20%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3E38%206E%2000%207C%2009%2075%2013%2083%20C5%2010%20E2%20F4%20CD%2018%208B%20F5%208n.%7C.u..........%3C%2FSPAN%3E%3CBR%20style%3D%22font-family%3A%20monospace%3B%22%20%2F%3E%20%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3E83%20C6%2010%2049%2074%2019%2038%202C%2074%20F6%20A0%20B5%2007%20B4%2007%208B%20...It.8%2Ct.......%3C%2FSPAN%3E%3CBR%20style%3D%22font-family%3A%20monospace%3B%22%20%2F%3E%20%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3EF0%20AC%203C%2000%2074%20FC%20BB%2007%2000%20B4%200E%20CD%2010%20EB%20F2%2088%20..%26lt%3B.t...........%3C%2FSPAN%3E%3CBR%20style%3D%22font-family%3A%20monospace%3B%22%20%2F%3E%20%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3E4E%2010%20E8%2046%2000%2073%202A%20FE%2046%2010%2080%207E%2004%200B%2074%200B%20N..Fs*.F..~..t%3C%2FSPAN%3E%3CBR%20style%3D%22font-family%3A%20monospace%3B%22%20%2F%3E%20%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3E80%207E%2004%200C%2074%2005%20A0%20B6%2007%2075%20D2%2080%2046%2002%2006%2083%20.~..t....u..F...%3C%2FSPAN%3E%3CBR%20style%3D%22font-family%3A%20monospace%3B%22%20%2F%3E%20%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3E46%2008%2006%2083%2056%200A%2000%20E8%2021%2000%2073%2005%20A0%20B6%2007%20EB%20F...V...!.s.....%3C%2FSPAN%3E%3CBR%20style%3D%22font-family%3A%20monospace%3B%22%20%2F%3E%20%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3EBC%2081%203E%20FE%207D%2055%20AA%2074%200B%2080%207E%2010%2000%2074%20C8%20A0%20..%26gt%3B.%7DUt.~..t..%3C%2FSPAN%3E%3CBR%20style%3D%22font-family%3A%20monospace%3B%22%20%2F%3E%20%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3EB7%2007%20EB%20A9%208B%20FC%201E%2057%208B%20F5%20CB%20BF%2005%2000%208A%2056%20.......W.......V%3C%2FSPAN%3E%3CBR%20style%3D%22font-family%3A%20monospace%3B%22%20%2F%3E%20%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3E00%20B4%2008%20CD%2013%2072%2023%208A%20C1%2024%203F%2098%208A%20DE%208A%20FC%20.....r%23..%24%3F.....%3C%2FSPAN%3E%3CBR%20style%3D%22font-family%3A%20monospace%3B%22%20%2F%3E%20%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3E43%20F7%20E3%208B%20D1%2086%20D6%20B1%2006%20D2%20EE%2042%20F7%20E2%2039%2056%20C.........B..9V%3C%2FSPAN%3E%3CBR%20style%3D%22font-family%3A%20monospace%3B%22%20%2F%3E%20%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3E0A%2077%2023%2072%2005%2039%2046%2008%2073%201C%20B8%2001%2002%20BB%2000%207C%20.w%23r.9F.s......%7C%3C%2FSPAN%3E%3CBR%20style%3D%22font-family%3A%20monospace%3B%22%20%2F%3E%20%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3E8B%204E%2002%208B%2056%2000%20CD%2013%2073%2051%204F%2074%204E%2032%20E4%208A%20.N..V...sQOtN2..%3C%2FSPAN%3E%3CBR%20style%3D%22font-family%3A%20monospace%3B%22%20%2F%3E%20%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3E56%2000%20CD%2013%20EB%20E4%208A%2056%2000%2060%20BB%20AA%2055%20B4%2041%20CD%20V......V.%60..UA%3C%2FSPAN%3E%3CBR%20style%3D%22font-family%3A%20monospace%3B%22%20%2F%3E%20%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3E13%2072%2036%2081%20FB%2055%20AA%2075%2030%20F6%20C1%2001%2074%202B%2061%2060%20.r6..U.u0...t%2Ba%60%3C%2FSPAN%3E%3CBR%20style%3D%22font-family%3A%20monospace%3B%22%20%2F%3E%20%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3E6A%2000%206A%2000%20FF%2076%200A%20FF%2076%2008%206A%2000%2068%2000%207C%206A%20jj.v..vjh%7Cj%3C%2FSPAN%3E%3CBR%20style%3D%22font-family%3A%20monospace%3B%22%20%2F%3E%20%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3E01%206A%2010%20B4%2042%208B%20F4%20CD%2013%2061%2061%2073%200E%204F%2074%200B%20.j..B....aas.Ot%E3%80%82%3C%2FSPAN%3E%3CBR%20style%3D%22font-family%3A%20monospace%3B%22%20%2F%3E%20%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3E32%20E4%208A%2056%2000%20CD%2013%20EB%20D6%2061%20F9%20C3%2049%206E%2076%2061%202..V.....a..Inva%3C%2FSPAN%3E%3CBR%20style%3D%22font-family%3A%20monospace%3B%22%20%2F%3E%20%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3E6C%2069%2064%2020%2070%2061%2072%2074%2069%2074%2069%206F%206E%2020%2074%2061%20%E7%9B%96%E9%9A%94%E6%9D%BF%3C%2FSPAN%3E%3CBR%20style%3D%22font-family%3A%20monospace%3B%22%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3E62%206C%2065%2000%2045%2072%2072%206F%2072%2020%206C%206F%2061%2064%2069%206E%20ble.%20%E5%8A%A0%E8%BD%BD%E9%94%99%E8%AF%AF%3C%2FSPAN%3E%3CBR%20style%3D%22font-family%3A%20monospace%3B%22%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3E67%2020%206F%2070%2065%2072%2061%2074%2069%206E%2067%2020%2073%2079%2073%2074%20g%20%E6%93%8D%E4%BD%9C%E7%B3%BB%E7%BB%9F%3C%2FSPAN%3E%3CBR%20style%3D%22font-family%3A%20monospace%3B%22%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3E65%206D%2000%204D%2069%2073%2073%2069%206E%2067%2020%206F%2070%2065%2072%2061%20em.%E7%BC%BA%E5%B0%91%E6%AD%8C%E5%89%A7%3C%2FSPAN%3E%3CBR%20style%3D%22font-family%3A%20monospace%3B%22%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3E74%2069%206E%2067%2020%2073%2079%2073%2074%2065%206D%2000%2000%2000%2000%2000%20%E7%B3%BB%E7%BB%9F.....%3C%2FSPAN%3E%3CBR%20style%3D%22font-family%3A%20monospace%3B%22%20%2F%3E%20%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3E00%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%20................%3C%2FSPAN%3E%3CBR%20style%3D%22font-family%3A%20monospace%3B%22%20%2F%3E%20%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3E00%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%20................%3C%2FSPAN%3E%3CBR%20style%3D%22font-family%3A%20monospace%3B%22%20%2F%3E%20%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3E00%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%20................%3C%2FSPAN%3E%3CBR%20style%3D%22font-family%3A%20monospace%3B%22%20%2F%3E%20%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3E00%2000%2000%2000%2000%202C%2044%2063%2018%202E%2007%20C3%2000%2000%2080%2001%20.....%2CDc........%3C%2FSPAN%3E%3CBR%20style%3D%22font-family%3A%20monospace%3B%22%20%2F%3E%20%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3E01%2000%2006%2020%2000%2077%2000%2002%2000%2000%2000%20DE%201D%2000%2000%2000%20...%20.w%20..............%3C%2FSPAN%3E%3CBR%20style%3D%22font-family%3A%20monospace%3B%22%20%2F%3E%20%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3E00%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%20................%3C%2FSPAN%3E%3CBR%20style%3D%22font-family%3A%20monospace%3B%22%20%2F%3E%20%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3E00%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%20................%3C%2FSPAN%3E%3CBR%20style%3D%22font-family%3A%20monospace%3B%22%20%2F%3E%20%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3E00%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2055%20AA%20........................U%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3E%E5%BD%93%E9%97%AA%E5%AD%98%E9%A9%B1%E5%8A%A8%E5%99%A8%E6%8B%94%E5%87%BA%E6%97%B6%EF%BC%8C%E7%BB%88%E7%AB%AF%E7%AA%97%E5%8F%A3%E5%B0%86%E6%98%BE%E7%A4%BA%EF%BC%9A%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%22%3E%E8%AE%BE%E5%A4%87%E6%9C%AA%E8%BF%9E%E6%8E%A5%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
无评分
版本历史
最后更新:
‎04-25-2016 02:22 PM
更新人:
